ivop Posted October 19, 2022 Share Posted October 19, 2022 (edited) On 10/17/2022 at 9:47 PM, ivop said: atari800 -nopatch -nopatchall -ntsc -xl -xlxe_rom sixteenkay.rom -xl-rev custom -cart basicrevc.bin -cart-type 1 blank.atr Screenshots: Edit: and PAL works, too: In theory, this should work on real hardware. Edited October 19, 2022 by ivop Quote Link to comment Share on other sites More sharing options...
ivop Posted October 19, 2022 Share Posted October 19, 2022 (edited) Double Post DELETED. Meh. Posting on page advancements sucks... Edited October 19, 2022 by ivop Quote Link to comment Share on other sites More sharing options...
+Larry Posted October 19, 2022 Share Posted October 19, 2022 OK, some testing completed. Your "Blank" version works best -- on real hardware. I don't have an original disk. I have the Rdos that was posted some years ago. It is the same as your 0.1 version atr. When I boot your Blank, it does the boot sectors and immediately goes to READY. If I don't have a Basic cart inserted, it loads DUPR. In light testing, everything works correctly using Blank. I copied files, formatted ATR's, locked and unlocked files, loaded files. I think this is a keeper! Here is the OSS version. Takes a little longer to load, since it has to actually load the DOS.SYS code. But gives you a few more bytes of ram. I have no idea what the 1-sector Autorun.sys file does. Perhaps you can determine its purpose. I have added the same ATR minus the AUTORUN.SYS, since I believe that it has nothing to do with the dos files. Romdos for Suprcarts.atr RomdosforSuprcarts minus AUTORUN.SYS.atr 2 Quote Link to comment Share on other sites More sharing options...
ivop Posted October 19, 2022 Share Posted October 19, 2022 14 minutes ago, Larry said: If I don't have a Basic cart inserted, it loads DUPR. Yes, this was expected as it doesn't recognize internal BASIC. 15 minutes ago, Larry said: In light testing, everything works correctly using Blank. I copied files, formatted ATR's, locked and unlocked files, loaded files. Good to hear! Have you tried writing DOS files to a newly formatted ATR and then boot it again? And to be sure, were you able to boot romdos.atr in the end, or only the blank.atr image? Thanks for the supercarts.atr. I'll look into it later. Quote Link to comment Share on other sites More sharing options...
luckybuck Posted October 20, 2022 Share Posted October 20, 2022 Thank you all so much, especially Larry for the Supercart version. Just a short question, does someone has the Omnimon! rom with help, the very 1st version? Omnimon!, by CDY Consulting (David Young), 1982 - Resident machine language monitor - Direct successor to Supermon! by David Young - Installs into the 4KiB byte block of memory at $C000. - Standard Version (4KiB): Has a HELP command (not present in other versions) - Shipped with piggyback board by The Peripheral Connection (Bill Williams) - Shipped with Newell Industries Ramrod personality board (800) 1 Quote Link to comment Share on other sites More sharing options...
+Larry Posted October 20, 2022 Share Posted October 20, 2022 Will get back to testing those other things this afternoon -- errands to run this AM. Quote Link to comment Share on other sites More sharing options...
+Larry Posted October 20, 2022 Share Posted October 20, 2022 OK, back to testing... RDos (0.1) needs only one file on the disk/ATR: DUPR.SYS. It evidently depends on all of DOS.SYS being in the the rom. As far as I can tell, it does everything correctly, including writing the one file when using the H command. And the resulting disk is bootable just as the original. It provides an FRE(0) of 35106. RDos for OSS (0.0) works fine also, but it has the two normally expected files -- DOS.SYS and DUP.SYS. There is one new wrinkle -- the original ATR that I was using has a couple of BBS files on it and an AUTORUN.SYS file of one sector. When I delete those files, then FRE(0) = 37532 instead of 36373. So presumably, that AUTORUN altered available memory, probably raising MEMLO. Some slightly bad news, the RDos for OSS cannot be used with regular Atari Basic. Not much of an issue, but it must be used with a Supercartridge. 1 Quote Link to comment Share on other sites More sharing options...
ivop Posted October 20, 2022 Share Posted October 20, 2022 22 minutes ago, Larry said: OK, back to testing... RDos (0.1) needs only one file on the disk/ATR: DUPR.SYS. It evidently depends on all of DOS.SYS being in the the rom. As far as I can tell, it does everything correctly, including writing the one file when using the H command. And the resulting disk is bootable just as the original. It provides an FRE(0) of 35106. That's good to hear! But you mean 36106, right? Did you do this all starting with the 'blank.atr' image, or can you now also boot romdos.atr and create a blank disk and initialize it with the H command? (which should give you blank.atr without HELLO.BAS ) 22 minutes ago, Larry said: RDos for OSS (0.0) works fine also, but it has the two normally expected files -- DOS.SYS and DUP.SYS. There is one new wrinkle -- the original ATR that I was using has a couple of BBS files on it and an AUTORUN.SYS file of one sector. When I delete those files, then FRE(0) = 37532 instead of 36373. So presumably, that AUTORUN altered available memory, probably raising MEMLO. Interesting. You're probably right that the AUTORUN.SYS has nothing to do with the RDOS capability and does something for the BBS stuff. 22 minutes ago, Larry said: Some slightly bad news, the RDos for OSS cannot be used with regular Atari Basic. Not much of an issue, but it must be used with a Supercartridge. That was to be expected I guess. Enabling and disabling the ROM to reach the RAM underneath is different. Thanks for running your tests! Quote Link to comment Share on other sites More sharing options...
+Larry Posted October 20, 2022 Share Posted October 20, 2022 Yes, 36106. Quote Link to comment Share on other sites More sharing options...
ivop Posted October 21, 2022 Share Posted October 21, 2022 Third time I ask this question Can you now also boot romdos.atr on real hardware, or only the blank.atr and the generated new disks with that? Quote Link to comment Share on other sites More sharing options...
ivop Posted October 21, 2022 Share Posted October 21, 2022 (edited) And a other question about this 4kB slot on RAMROD cards. Does it always need a boot disk? I assume if you put an OmniView 4kB ROM in there, it would need a boot disk to register the handler to the OS, right? On the same subject, is that OmniView 4kB ROM available anywhere? I can only find ROM images that are prepended to OSB which then itself is patched. Edited October 21, 2022 by ivop Quote Link to comment Share on other sites More sharing options...
+Larry Posted October 21, 2022 Share Posted October 21, 2022 1 hour ago, ivop said: Third time I ask this question Can you now also boot romdos.atr on real hardware, or only the blank.atr and the generated new disks with that? Yes, you can boot it with your "Ramrod XLOS" and the atr boots normally. If you write the dos files, it just writes the DUPR.SYS file. So presumably it checks to see if the dos code is in rom. But that atr does not work correctly with an XLOS. It boots, but when you go to to the DUP menu, it puts some garbage on the screen and that garbage increases. Or, if you let the autorun.sys file load, the dup menu does not appear. Since I don't have an original disk I can't be sure what is really supposed to be on that disk. For instance, I don't know what the 15 sector Autorun.sys file does. But using your Ramrod XLOS, and DUPR.SYS, everything appears to work normally. 1 Quote Link to comment Share on other sites More sharing options...
tep392 Posted October 21, 2022 Share Posted October 21, 2022 2 hours ago, ivop said: And a other question about this 4kB slot on RAMROD cards. Does it always need a boot disk? I assume if you put an OmniView 4kB ROM in there, it would need a boot disk to register the handler to the OS, right? On the same subject, is that OmniView 4kB ROM available anywhere? I can only find ROM images that are prepended to OSB which then itself is patched. Omniview is switched between 40/80 modes with certain keystroke combinations. No boot disk required. It's best to read the Omniview manual for details because hit has other features besides 80 columns. https://archive.org/details/Atari_OMNIVIEW_manual/mode/2up Quote Link to comment Share on other sites More sharing options...
ivop Posted October 21, 2022 Share Posted October 21, 2022 3 hours ago, tep392 said: Omniview is switched between 40/80 modes with certain keystroke combinations. No boot disk required. It's best to read the Omniview manual for details because hit has other features besides 80 columns. https://archive.org/details/Atari_OMNIVIEW_manual/mode/2up That's OmniView XL/XE with a patched OS ROM. I was asking about the 4kB OmniView ROM that could be plugged into the personality board and appear at $C000, not related to the OS at all, similar to how ROMDOS/RDOS works. If the OS is not patched, special key combinations will not work. Quote Link to comment Share on other sites More sharing options...
tep392 Posted October 21, 2022 Share Posted October 21, 2022 6 minutes ago, ivop said: That's OmniView XL/XE with a patched OS ROM. I was asking about the 4kB OmniView ROM that could be plugged into the personality board and appear at $C000, not related to the OS at all, similar to how ROMDOS/RDOS works. If the OS is not patched, special key combinations will not work. RTM Quote Link to comment Share on other sites More sharing options...
ivop Posted October 21, 2022 Share Posted October 21, 2022 (edited) 1 hour ago, tep392 said: RTM I was specifically asking about the oldest 4kB OmniView that was mentioned in the FAQ. To rephrase my question, are such 4kB ROMs known to exist and are any dumps available? That's a 4kB ROM that should work alongside a NON-PATCHED OS A or B. Like the 4kB ROMDOS ROM we are using in this thread. A boot disk should not really be available if you run OmniView aware applications. They can init themselves. RTM. Turning on 80 columns by software. So basically this only works if you run OmniView aware software? And where do I find OmniWriter and such? Edited October 21, 2022 by ivop Quote Link to comment Share on other sites More sharing options...
tep392 Posted October 21, 2022 Share Posted October 21, 2022 Edit: From the manual Turning on 80 columns: if you are not using one of the programs that activates 60 columns automatically, you can do so from the keyboard by holding down the START and SELECT switches and then very briefly pressing the OPTION switch. Then press the BREAK key to clear out the line buffer, it is important that you hold down the OPTION switch as briefly as possible (more of a tap actually). This is because these three switches are monitored during the vertical blank Interrupt (VBI). If the VBI detects the closure of all three switchs, it doe^ a JSR $C001 to initialize OtINlVIEW. Holding the switches down longer than one VBI causes the VBI to be reentered, pushing more stuff on the stack and eventually causing the stack to overflow. A great way to lock up your computer! Other ways to turn on 80 columns are •X=USR(49152)' from BASIC or 'JSR $C00r from assembly language. Quote Link to comment Share on other sites More sharing options...
ivop Posted October 21, 2022 Share Posted October 21, 2022 (edited) 15 minutes ago, tep392 said: I don't know how the 4k ROM's work with out an OS patch, but they do. Omnimon 4k doesn't require a patched OS. I only know SuperMon and OmniMon as 16kB ROMS, which were patched OS.B ROMS with 4kB of code prepended and a gap of zeroes and then plugged into an XL. Or 64kB EPROMs with 4 OSes and a switch. So they were also 4kB ROMs that worked alongside a non-patched 400/800 OS on this personality board? I can hardly believe it. How can it intercept cold start SELECT to go to the monitor if there's no such thing in the OS code and the code in $C000-$CFFFF has never been run yet? Edited October 21, 2022 by ivop Quote Link to comment Share on other sites More sharing options...
tep392 Posted October 22, 2022 Share Posted October 22, 2022 49 minutes ago, ivop said: I only know SuperMon and OmniMon as 16kB ROMS, which were patched OS.B ROMS with 4kB of code prepended and a gap of zeroes and then plugged into an XL. Or 64kB EPROMs with 4 OSes and a switch. So they were also 4kB ROMs that worked alongside a non-patched 400/800 OS on this personality board? I can hardly believe it. How can it intercept cold start SELECT to go to the monitor if there's no such thing in the OS code and the code in $C000-$CFFFF has never been run yet? I haven't looked into why it works, but somehow the Newell daughter card is able to intercept the interrupt when select/reset or option/reset is pressed. The daughter card plugs into the C014599B OS socket and re-uses the Atari ROM. There is no other ROM except the 4k Omnimon or Omniview chip. Edit: The only thing I can think is that the board intercepts the interrupt by switching in the Omnimon/view rom when the interrupt vector is read. Edit2: I just popped into omnimon from the Memopad and checked the vectors at 200-217. The VBREAK vector at 206,207 is $C0C4. It had to be set by some address decoding trickery during the OS boot process. 1 Quote Link to comment Share on other sites More sharing options...
ivop Posted October 22, 2022 Share Posted October 22, 2022 48 minutes ago, tep392 said: Edit: From the manual Turning on 80 columns: if you are not using one of the programs that activates 60 columns automatically, you can do so from the keyboard by holding down the START and SELECT switches and then very briefly pressing the OPTION switch. Then press the BREAK key to clear out the line buffer, it is important that you hold down the OPTION switch as briefly as possible (more of a tap actually). This is because these three switches are monitored during the vertical blank Interrupt (VBI). If the VBI detects the closure of all three switchs, it doe^ a JSR $C001 to initialize OtINlVIEW. Holding the switches down longer than one VBI causes the VBI to be reentered, pushing more stuff on the stack and eventually causing the stack to overflow. A great way to lock up your computer! Other ways to turn on 80 columns are •X=USR(49152)' from BASIC or 'JSR $C00r from assembly language. Yes, that's the software way I mentioned to enable OmniView what I R'd in TM. That's what OmniView aware applications call OmniView is pretty clear now I guess, but SuperMon and OmniMon as a single 4kB alongside an unpatched ROM is not The 400/800 generates an NMI (unlike the XL/XE) when you press RESET, but somehow the Newell card has to present different ROM code for the NMI handler than the OS provides. Interesting stuff. Never owned an 800 as they were rare over here. Quote Link to comment Share on other sites More sharing options...
tep392 Posted October 22, 2022 Share Posted October 22, 2022 1 minute ago, ivop said: Yes, that's the software way I mentioned to enable OmniView what I R'd in TM. That's what OmniView aware applications call OmniView is pretty clear now I guess, but SuperMon and OmniMon as a single 4kB alongside an unpatched ROM is not The 400/800 generates an NMI (unlike the XL/XE) when you press RESET, but somehow the Newell card has to present different ROM code for the NMI handler than the OS provides. Interesting stuff. Never owned an 800 as they were rare over here. I've confirmed that it alters the VBREAK vector. This is why BRK instructions will jump into omnimon. I'm pretty sure the board has to be enabling the 4K rom when the OS is copying the vectors from ROM to $0200. I should be able to verify by comparing the vector table in the OS ROM to the Omnimon ROM. Quote Link to comment Share on other sites More sharing options...
tep392 Posted October 22, 2022 Share Posted October 22, 2022 I figured it out. If I use Omnimon to read $FFFA, I get CE CF F5 CF F3 E6. So the daughter card is using address decoding to intercept the 6502 boot vectors, giving the Omnimon control when the machine is powered up or reset. 2 Quote Link to comment Share on other sites More sharing options...
ivop Posted October 22, 2022 Share Posted October 22, 2022 (edited) I see. So that's different compared to the ROMDOS ROM which is completely separate and needs a boot disk. Well, version 0.1 at least Thanks for testing! Back on topic: I have an 80% complete annotated disassembly of the boot code (384 bytes), but my arms and shoulders are tired, so I guess that has to wait until tomorrow. Interesting stuff in there though. Supercart stuff even! Hadn't expected that on the romdos.atr/blank.atr. Teaser for tomorrow! Edited October 22, 2022 by ivop Quote Link to comment Share on other sites More sharing options...
tep392 Posted October 22, 2022 Share Posted October 22, 2022 3 minutes ago, ivop said: I see. So that's different compared to the ROMDOS ROM which is completely separate. Well, version 0.1 was Thanks for testing! Back on topic: I have an 80% complete annotated disassembly of the boot code (384 bytes), but my arms and shoulders are tired, so I guess that has to wait until tomorrow. Interesting stuff in there though. Supercart stuff even! Hadn't expected that on the romdos.atr/blank.atr. Teaser for tomorrow! They could have made ROMDOS auto initiate at startup, so they must have made the conscious decision not to. As a user, I would rather have the option of what DOS I boot up with, so I think that makes sense. Quote Link to comment Share on other sites More sharing options...
ivop Posted October 22, 2022 Share Posted October 22, 2022 (edited) Okay, here it is. Reverse engineered annotated source code of the RDOS V0.1 boot code. Spoiler ; ---------------------------------------------------------------------------- ; Dissassembly of RDOS/ROMDOS boot code (first three sectors) ; October 2022 by Ivo van Poorten ; Tools used: atari800, frida, dis6502, vim and mads ; ---------------------------------------------------------------------------- opt h- ; no XEX header org $0700 ; ---------------------------------------------------------------------------- DIRSECTOR = $0169 ; 361 ; ---------------------------------------------------------------------------- ; OS Equates DOSINI = $0C ICAX5Z = $2E FMZSPG = $43 ZBUFP = FMZSPG ZDRVA = FMZSPG + 2 DDEVIC = $0300 DCOMND = $0302 DSTATS = $0303 DBUFLO = $0304 DBUFHI = $0305 DTIMLO = $0306 DBYTLO = $0308 DBYTHI = $0309 DAUX1 = $030A DAUX2 = $030B SIOV = $E459 ; ---------------------------------------------------------------------------- ; Other Equates CARTLEFT = $A000 ROMDOSROM = $C000 CARTIO = $D500 ; ---------------------------------------------------------------------------- ; BOOT SECTOR starts here BFLAG boot_flag dta $00 ; unused BRCNT boot_record_count dta $03 ; 3 boot sectors BLDADR boot_loader_address dta a($0700) ; where the bootcode is loaded BIWTARR boot_initialization_address dta a(ROMDOSROM + $0CB0) ; somewhere in ROM :) XBCONT boot_jmp_boot_continuation_vector jmp boot_continuation ; variables for RDOS/MyDOS dta $03,$DF,$01,$04,$0B density dta $01 ; $01 = SD, $02 = DD buffer_index dta $FD ; $fd for DD disks, $7d for SD disks ; drives info dta $01,$01,$00,$00,$00,$00,$00,$00 dta $52,$52,$D2,$D2,$D2,$D2,$D2,$D2 ; dta $4C,$06,$08 jmp do_sio_without_setting_daux ; coincidence? dta $00,$00,$00,$00 command_mirror dta 'W' ; write filename dta 'DOS SYS' ; ---------------------------------------------------------------------------- boot_continuation ldx #$21 compare_ram_to_part_of_rom lda ROMDOSROM+$10,X cmp advance_zbufp_and_dbuf-1,X bne ram_is_not_equal dex bne compare_ram_to_part_of_rom ; ROMDOS ROM is present lda #$B0 ldy #$CC jmp store_dosini_and_return ; -------------------------------- ; No ROMDOS present ram_is_not_equal jsr some_supercart_stuff ; check if supercart banking works cpy #$08 bcs going_to_skip_modify tya jsr some_supercart_stuff cpy #$08 beq modify_code ; only if Y is 8, whatever that means ;) going_to_skip_modify lda #>BUFFER ; (a,y) = $0874 low mem buffer ldy #<BUFFER ldx #' ' ; normal DOS.SYS bne skip_modify ; branch always modify_code sta store_a_to_cartio+1 ; LSB of store to CARTIO + what is stored here lda #>(CARTLEFT + $0400) ; (a,y) = $a400 buffer under supercart ldy #<(CARTLEFT + $0400) ldx #'C' ; load DOSC.SYS version to be hidden underneath the cart skip_modify stx filename+3 jsr set_zbufp_and_dbuf ; set both pointers ldy #<DIRSECTOR bne load_sector ; branch always ; -------------------------------- next_dir_entry tya sbc #$10 ; subtract one directory line (16 bytes) ora #$0f ; always start comparing from the end of the dirline tay bpl continue_comparing ; not went "under zero" so continue ldy ZDRVA ; remembered LSB of sector iny ; next one cpy #<DIRSECTOR+8 bcs error_out ; stop at 369, 368 was last directory sector ; -------------------------------- load_sector sty ZDRVA ; remember LSB of sector clc ldx density lda #>DIRSECTOR jsr do_sio_with_daux_ay bmi error_out ; -------------------------------- ; start comparing from last entry backwards through the directory ldy #$7f ; end of buffer continue_comparing ldx #$0b ; 11 bytes (compare is done with bne keep_comparing) ; compare filename keep_comparing lda (ZBUFP),Y cmp filename-1,X bne next_dir_entry dey dex bne keep_comparing ; found! lda (ZBUFP),Y tax ; save MSB of first sector dey lda (ZBUFP),Y sta FMZSPG+5 ; save LSB of first sector dey dey dey lda (ZBUFP),Y ; flags and #$81 ; DELETED | CREATED_BY_DOS2 bne next_dir_entry ; if one of them is true txa ; MSB of first sector in A ldy FMZSPG+5 ; LSB of first sector in Y read_next_sector clc ldx density beq error_out jsr do_sio_with_daux_ay bmi error_out ; process sector link for next sector or end ldy buffer_index lda (ZBUFP),Y and #$03 ; upper two bits of next sector pha ; save MSB iny ora (ZBUFP),Y ; logical OR with lower eight bits beq we_are_done ; if all zero, we are done lda (ZBUFP),Y ; otherwise, load lower eigth bits pha ; save LSB jsr advance_zbufp_and_dbuf ; where we load stuff pla ; restore LSB in Y tay pla ; restore MSB in A bcc read_next_sector error_out sec rts ; ----------- we_are_done pla ; one stray byte on the stack lda #<($17B0) ; DOSINI in DOS.SYS loaded from disk ldy #>($17B0) ; ldx ZBUFP bpl store_dosini_and_return lda #<($B440) ; DOSINI under supercart ldy #>($B440) store_dosini_and_return sta DOSINI ; store 'em! sty DOSINI+1 clc rts ; ---------------------------------------------------------------------------- nop nop ; ---------------------------------------------------------------------------- ; This is the code that is checked against the ROM to see if it is present. .proc advance_zbufp_and_dbuf clc lda ZBUFP adc buffer_index tay ; calculate new Y lda ZBUFP+1 adc #0 ; and new A .endp ; fall through!! ; ------------------------------------ .proc set_zbufp_and_dbuf ; set by Y and A sty ZBUFP sta ZBUFP+1 sty DBUFLO sta DBUFHI rts .endp ; ------------------------------------ .proc do_sio_with_daux_ay sta DAUX2 ; MSB sty DAUX1 ; LSB .endp .proc do_sio_without_setting_daux ldy #10 ; retry circa 10 seconds lda #'R' ; Read bcc do_not_load_mirror lda command_mirror ; Default to Write do_not_load_mirror sta DCOMND sty DTIMLO ; ----- ; determine amount of bytes that will be transfered? lda #$80 clc dex beq store_DBYT ; single density ldx DAUX2 bne _double_density ldx DAUX1 cpx #$04 bcc store_DBYT ; first three sectors are 128 bytes _double_density asl store_DBYT sta DBYTLO ; clever trick to get either $0080 or $0100 rol ; SD carry is clear, DD carry is set sta DBYTHI ; ----- ldy #$31 ; Disk drive D1: $30+num sty DDEVIC ldy #$03 ; Number of retries sty FMZSPG+5 ; Temporary variable retry ldx #$40 ; DSTATS for read and format lda DCOMND cmp #'R' ; Read beq stats_and_call_sio cmp #'!' ; Format! beq stats_and_call_sio ldx #$80 ; DSTATS for the rest stats_and_call_sio stx DSTATS jsr SIOV ; Call SIO bpl sio_done ; Succes dec FMZSPG+5 ; The temp retry variable bne retry sio_done ldx ICAX5Z lda DSTATS rts .endp ; ---------------------------------------------------------------------------- .proc some_supercart_stuff ldy CARTLEFT+$0fff inc CARTLEFT+$0fff cpy CARTLEFT+$0fff beq L0869 sty CARTLEFT+$0fff ldy #$08 L0869 sty CARTIO+8 sty store_a_to_cartio+1 ; Note: self modifying code here! rts .endp ; ---------------------------------------------------------------------------- .proc store_a_to_cartio sta CARTIO ; modified by SMC rts .endp ; ---------------------------------------------------------------------------- BUFFER dta $00,$00,$00,$00 dta $00,$00,$00,$00 dta $00,$00,$00,$00 Edit: BTW you can assemble this with mads and the binary output is identical. $ !mads mads -o:bootcode.out bootcode.s && diff -s bootcode.dat bootcode.out Writing object file... 430 lines of source assembled in 3 pass 384 bytes written to the object file Files bootcode.dat and bootcode.out are identical bootcode.s Edited October 22, 2022 by ivop added bootcode.s for download 1 2 Quote Link to comment Share on other sites More sharing options...
