MegaManFan Posted April 2, 2019 Share Posted April 2, 2019 It seems to fit and it seems to run but I've been warned it could fry the system for being incorrect voltage. True/false? If true where could I source a good power supply for a Super Famicom without spending an arm and a leg? (And don't say Genesis 1 power supply because those are hard to come by and I need the only one I have for my model 1 Sega Genesis.) Quote Link to comment Share on other sites More sharing options...
Shawn Posted April 2, 2019 Share Posted April 2, 2019 False. You are just fine using a US power supply on the Japanese System. Worst thing that could happen is you pop the fuse or voltage regulator but even that is very, very unlikely. Thought you where saying the SNES power supply not an NES one. NES one is not a good option. Quote Link to comment Share on other sites More sharing options...
DragonGrafx-16 Posted April 3, 2019 Share Posted April 3, 2019 Why bother with a Super Famicom when you can just bust the tabs in the NA SNES cartridge port? There is no difference in the internals. All Super Famicom games run in a NA SNES. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted April 3, 2019 Share Posted April 3, 2019 Or no need to remove the tabs. Just use a game genie. 1 Quote Link to comment Share on other sites More sharing options...
Tanooki Posted April 3, 2019 Share Posted April 3, 2019 I did the tab removal on my original 1991 model in the mid 90s nice and smooth with an automatic nail file, worked great for some years but it's like without the tabs and having the door wider than the game the pins got sloppy in time. I eventually had to wedge something in there or a fart in the wind would cause the game to wiggle and lose the connection locking up the game. Ever since then, I've picked up adapters. Quote Link to comment Share on other sites More sharing options...
DragonGrafx-16 Posted April 3, 2019 Share Posted April 3, 2019 (edited) I did the tab removal on my original 1991 model in the mid 90s nice and smooth with an automatic nail file, worked great for some years but it's like without the tabs and having the door wider than the game the pins got sloppy in time. I eventually had to wedge something in there or a fart in the wind would cause the game to wiggle and lose the connection locking up the game. Ever since then, I've picked up adapters. I've had mine busted out for a decade with no issues... eh mine just has a really tight cartridge port I guess... Or maybe it's because I did not completely bust the tabs out just enough so that Super Famicom games can fit.. Edited April 3, 2019 by DragonGrafx-16 Quote Link to comment Share on other sites More sharing options...
empsolo Posted April 3, 2019 Share Posted April 3, 2019 False. You are just fine using a US power supply on the Japanese System. Worst thing that could happen is you pop the fuse or voltage regulator but even that is very, very unlikely.WTF are you talking about? An NES power supply carries straight AC power through it’s brick into an NES. AN NES power supply does not have the transformer to turn the AC into DC. This is because the NES’s AC adapter is in the NES itself. You will fry your system if you use an NES power supply. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
empsolo Posted April 3, 2019 Share Posted April 3, 2019 It seems to fit and it seems to run but I've been warned it could fry the system for being incorrect voltage. True/false? If true where could I source a good power supply for a Super Famicom without spending an arm and a leg? (And don't say Genesis 1 power supply because those are hard to come by and I need the only one I have for my model 1 Sega Genesis.)It will fry the system. An NES power brick carries straight AC into the system. This is because the NES has the Adapter in the system instead of the power brick for some reason. You want something like a Genesis model 1 or master system PSU to power your Super Famicom. Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
MegaManFan Posted April 3, 2019 Author Share Posted April 3, 2019 It will fry the system. An NES power brick carries straight AC into the system. This is because the NES has the Adapter in the system instead of the power brick for some reason. You want something like a Genesis model 1 or master system PSU to power your Super Famicom. Sent from my iPhone using Tapatalk Okay, this checks out with what I was told was well, which is why I quickly unplugged the NES power brick. I'm on the hunt for a Genesis or Master System power supply but if push comes to shove I'll buy a Gen 1 replacement PS from Retrobit. Quote Link to comment Share on other sites More sharing options...
Shawn Posted April 3, 2019 Share Posted April 3, 2019 WTF are you talking about? An NES power supply carries straight AC power through it’s brick into an NES. AN NES power supply does not have the transformer to turn the AC into DC. This is because the NES’s AC adapter is in the NES itself. You will fry your system if you use an NES power supply. Sent from my iPhone using Tapatalk My bad, I thought he said SNES not NES. I was refering to the 100v and 115v difference between the US and JPN standards. Anyhow, here is a 3rd party PS for $6 shipped that will work like a champ. https://www.ebay.com/itm/NEW-AC-Adapter-Power-Supply-for-Nintendo-NES-Super-SNES-Sega-Genesis-1-3-in-1/113360827272?hash=item1a64d4f388:g:4FQAAOSwAE9b5eFc 1 Quote Link to comment Share on other sites More sharing options...
MegaManFan Posted April 5, 2019 Author Share Posted April 5, 2019 My bad, I thought he said SNES not NES. I was refering to the 100v and 115v difference between the US and JPN standards. Anyhow, here is a 3rd party PS for $6 shipped that will work like a champ. https://www.ebay.com/itm/NEW-AC-Adapter-Power-Supply-for-Nintendo-NES-Super-SNES-Sega-Genesis-1-3-in-1/113360827272?hash=item1a64d4f388:g:4FQAAOSwAE9b5eFc That's probably the same one I just bought. There were two on eBay. One was $6.11 shipped, the other was $4.99 but almost $2 shipping. I bought the $6.11 one. Quote Link to comment Share on other sites More sharing options...
MegaManFan Posted April 9, 2019 Author Share Posted April 9, 2019 In case anybody was wondering I got the RetroBit replacement power supply listed above. It was a bit concerning when I took it out of the box because it was so lightweight compared to the real power supplies that go with these things, but it worked perfectly. I suppose they're just lighter because the technology has gotten smaller and cheaper to manufacture for power supplies over the decades but still... I swear it feels like it's 90% air. Works though!! Quote Link to comment Share on other sites More sharing options...
