Gibstov Posted April 11, 2019 Share Posted April 11, 2019 (edited) Here is an idea, if I can explain it in a way that makes sense. You could throw RAM at the problem. Basically you have two sets of the background character set that you toggle between every VBI. This could give you more colors, but the plan is in one character set you outline all your floors in a chosen color, and none of the other background graphics use this color. And in the other character set, it doesn't matter you can use it as you want. So then you could use the Jumpman method with the extra sprite, but only check for the ground collision on the VBI that has the floor color. Edited April 11, 2019 by Gibstov Quote Link to comment Share on other sites More sharing options...
emkay Posted April 12, 2019 Share Posted April 12, 2019 In a game like Limbo, where only 2 colors were used, it shouldn't be that hard to check, if the byte that is the 1st byte(s) in the direction of movement, where the sprites moves, is empty or not. If empty is a row of eight 1-s or eight 0-s, or 10101010 is depending on the use of the graphics. To prevent the graphics from some irregular visuals(when walking ascending or descending) , the moving "sprite" should move one dot below the "ground". Particular in Limbo, the background should be done in a parallax scrolling using PMg . Quote Link to comment Share on other sites More sharing options...
Yaron Nir Posted April 13, 2019 Author Share Posted April 13, 2019 Here is an idea, if I can explain it in a way that makes sense. You could throw RAM at the problem. Basically you have two sets of the background character set that you toggle between every VBI. This could give you more colors, but the plan is in one character set you outline all your floors in a chosen color, and none of the other background graphics use this color. And in the other character set, it doesn't matter you can use it as you want. So then you could use the Jumpman method with the extra sprite, but only check for the ground collision on the VBI that has the floor color. this could work, but would complicated things. i am searching for a much staight forward easy method. thanks anyways Quote Link to comment Share on other sites More sharing options...
emkay Posted April 13, 2019 Share Posted April 13, 2019 this could work, but would complicated things. It would result in flickering graphics. Depending on the Atari's CPU speed, using character mode or graphics mode is essential. Limbo could easily be done in Antic F. Using character modes, will result in some faster and more colorful graphics, but the character boundaries. have to be used , to have a benefit in the speed. It's obvious. If you want to do a character mode based software sprites that moves as smooth as in a graphics mode, you may find yourself in a very small graphical box. 32 Bytes wide 100 lines high. Quote Link to comment Share on other sites More sharing options...
+therealbountybob Posted April 13, 2019 Share Posted April 13, 2019 Jumpman uses a single PMG for the main character and uses collision detection to walk over arbitrary slopes. The method used requires sacrificing a 2nd PMG as a one pixel high "shadow" below the Jumpman character that tracks what the character is walking on. If the shadow doesn't have a collision with the floor color, it increments the Y position of the character, which could mean the character is falling or just going down a slope... won't know till the next frame when it does the check again. If the shadow has a collision with the floor color and the player also has a collision with the floor, the Y position is decremented because the character's foot is touching the floor and must be going uphill. It's a cool technique, but the cost is an additional PMG (or, I suppose you could do it with one player with a complicated variable-positioned DLI to reset the collision register for the scan line below the player's feet). Nice thread :thumbsup: As my latest game looks like it is turning into a platformer, whether I like it or not, I was also thinking about exactly this (above). In "Gwobby Strikes Back!" (turbo basic) I did the raises through one two playfields and stops on another, this would walk up a big slope etc but does bounce him around a bit. I liked Miner 2049'ers' walking up the slopes on level 1 and wondered how in that and in BBSB (which has the two playfields creating 3d effect) how he sticks to the plaforms so well? Quote Link to comment Share on other sites More sharing options...
Yaron Nir Posted April 13, 2019 Author Share Posted April 13, 2019 Gwobby Strikes Back i've looked at that game. the walking and sticking to the platform is not accurate as in limbo or jumpman game. the jumpman technicque is indeed super fast , but, unfortunately, my beatemup game already uses entire 4 players and 4 missiles ..... Quote Link to comment Share on other sites More sharing options...
+therealbountybob Posted April 13, 2019 Share Posted April 13, 2019 i've looked at that game. the walking and sticking to the platform is not accurate as in limbo or jumpman game. the jumpman technicque is indeed super fast , but, unfortunately, my beatemup game already uses entire 4 players and 4 missiles ..... yes it was just an example - I had uneven (and animated) pieces of the "raise" playfield in the floors but with a straighter/continuous line of the playfields maybe it would be fairly good Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted April 13, 2019 Share Posted April 13, 2019 Is there a common practice for this? I know how to convert the PMG unit into char unit and compare, but I want to get the effect of the sticky ground thing. Someone could analyze "Spelunker" as this title does exactly what you want.... Quote Link to comment Share on other sites More sharing options...
emkay Posted April 14, 2019 Share Posted April 14, 2019 Someone could analyze "Spelunker" as this title does exactly what you want.... No. It doesn't. The protagonist ist build on a Player, and the Playfield color "brown" is the collision register to react on, when "down" movement is checked. Didn't he mention there is no Player or Missile left? Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 14, 2019 Share Posted April 14, 2019 I forgot all about Spelunker, much better example than Pharoah's Curse. Very easy to test and hey presto! Disable all collision detections and the character still hugs the ground, elevators etc as expected. The animated intro disk version has encryption, not sure about the other, so it might be easiest analysed while running. Quote Link to comment Share on other sites More sharing options...
emkay Posted April 14, 2019 Share Posted April 14, 2019 I forgot all about Spelunker, much better example than Pharoah's Curse. Very easy to test and hey presto! Disable all collision detections and the character still hugs the ground, elevators etc as expected. The animated intro disk version has encryption, not sure about the other, so it might be easiest analysed while running. What makes me wondering is there is a special Missile detection which Altirra doesn't disable. Quote Link to comment Share on other sites More sharing options...
ggn Posted April 14, 2019 Share Posted April 14, 2019 What makes me wondering is there is a special Missile detection which Altirra doesn't disable. And Atari800Win PLus 4 Quote Link to comment Share on other sites More sharing options...
emkay Posted April 14, 2019 Share Posted April 14, 2019 I was always impressed in the accuracy of the movement. It allowed a much better detail in controls and what happens on the screen. OK. Prove me wrong... In normal circumstances, the game reads the register, checking the content, and while a VBI happening, the game is acting on the result of the read, and then writing to the register for a reset. What, if the game is doing the following, to assure the properly movement of the "sprite" ? Starting an interrupt , writing the register to reset, check the bottom, read the register content and write the result into Memory then end the interrupt. As you might recognize, the protagonist is doing a "down" correction, one pixel, if the "toes" stand in the air. Is the emulation interfering the chip writes or just erasing the readable content? Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 15, 2019 Share Posted April 15, 2019 If Spelunker used collision detection then your man would be bouncing all the time due to position corrections after he lands from a jump. That obviously isn't happening. There are times when he seems to overlap terrain pixels but my guess there is that it's when they're in the adjacent character cell and not considered for the positioning calculation. 2 Quote Link to comment Share on other sites More sharing options...
dmsc Posted April 15, 2019 Share Posted April 15, 2019 It i easy to simply check in the charset if the pixel just bellow your P/M is used or not, check this simple FastBasic program: ' P/M walking test program graphics 0 ' Setups graphics mode pmgraphics 2 ' And P/M mode P0Mem = pmadr(0) ' Get player 0 address oldPos = P0Mem ' and into "old position" mset P0Mem, 128, 0 ' Clears P/M 0 Memory setcolor -4, 1, 15 ' P/M data DATA PMdata() byte = $38,$44,$54,$44,$38 data AndTab() byte = 192, 48, 12, 3 ' Initial Conditions pos.2,14 ? "| \ ___ |" ? "| ------\_____/M-----M" ? "|" ? "M_____________________M" do xPos = 96 : yPos = 40 : blocked = 0 repeat ' Draw at current pos exec MovePm ' Generate new position j = stick(0) oldX = xPos xPos = xPos + (NOT (j & ) - (NOT (j & 4)) ' Check slope exec CheckBack if blocked yPos = yPos - 1 exec CheckBack if blocked yPos = yPos - 1 exec CheckBack yPos = yPos + 1 if blocked xPos = oldX yPos = yPos + 1 endif else yPos = yPos + 1 endif else yPos = yPos + 1 endif until Key() poke 764, 255 loop graphics 0 END proc MovePm y = P0Mem + yPos pause 0 pmhpos 0, xPos ' Set new horizontal position mset oldPos, 5, 0 ' Clear old sprite oldPos = P0Mem + yPos move adr(PMdata), oldPos, 5 ' Draw at new vertical pos. endproc proc CheckBack xc = xPos - 45 yc = yPos - 11 xm = AndTab(xc & 3) ym = (yc & 3) * 2 + $E000 xc = xc / 4 yc = yc / 4 pos = dpeek(88) + yc * 40 + xc char = peek(pos) ' Char under sprite ym = ym + 8 * char p = peek(ym) ! peek(ym+1) blocked = p & xm endproc pmwalk.bas pmwalk.xex 5 Quote Link to comment Share on other sites More sharing options...
emkay Posted April 15, 2019 Share Posted April 15, 2019 ... Looks good. Next step is to do that with with several objects, software sprites, scrolling... still curious, even if Spelunker might use something similar. Quote Link to comment Share on other sites More sharing options...
Yaron Nir Posted April 15, 2019 Author Share Posted April 15, 2019 dmsc, thnx please expalin the following calc in your above code: proc CheckBack xc = xPos - 45 yc = yPos - 11 xm = AndTab(xc & 3) ym = (yc & 3) * 2 + $E000 xc = xc / 4 yc = yc / 4 pos = dpeek(88) + yc * 40 + xc char = peek(pos) ' Char under sprite ym = ym + 8 * char p = peek(ym) ! peek(ym+1) blocked = p & xm endproc Quote Link to comment Share on other sites More sharing options...
dmsc Posted April 15, 2019 Share Posted April 15, 2019 Hi!, dmsc, thnx please expalin the following calc in your above code: proc CheckBack xc = xPos - 45 ' gets X and Y position of the pixel in playfield for the yc = yPos - 11 ' corresponding pixel in the P/M, adjust with the correct shape! xm = AndTab(xc & 3) ' gets the position inside the character mode for the pixel ym = (yc & 3) * 2 + $E000 ' for Y, we also add the chbase value xc = xc / 4 ' gets the character, assuming 4x4 pixels (P/M have half resolution) yc = yc / 4 pos = dpeek(88) + yc * 40 + xc ' and the address of the character in screen memory char = peek(pos) ' read the character at the address ym = ym + 8 * char ' gets address of memory for the character data p = peek(ym) ! peek(ym+1) ' read the byte and beloow blocked = p & xm ' and use the mask to get the pixels endproc 1 Quote Link to comment Share on other sites More sharing options...
Yaron Nir Posted April 15, 2019 Author Share Posted April 15, 2019 dmsc tnx! clearly i need more info, so let me break the questions down: xc = xPos - 45 ' gets X and Y position of the pixel in playfield for the yc = yPos - 11 ' corresponding pixel in the P/M, adjust with the correct shape! Why minus 45 and minus 11? this is graphics 0 correct? so it is 24 lines of 40 chars right? so i am not sure what is this calculation xm = AndTab(xc & 3) ' gets the position inside the character mode for the pixel ym = (yc & 3) * 2 + $E000 ' for Y, we also add the chbase value this i don't undestand at all. if you can explain exactly what is done here it would be helpful xc = xc / 4 ' gets the character, assuming 4x4 pixels (P/M have half resolution) yc = yc / 4 pos = dpeek(88) + yc * 40 + xc ' and the address of the character in screen memory char = peek(pos) ' read the character at the address this i perfectly understand ym = ym + 8 * char ' gets address of memory for the character data p = peek(ym) ! peek(ym+1) ' read the byte and beloow blocked = p & xm ' and use the mask to get the pixels this i don't get at all Quote Link to comment Share on other sites More sharing options...
R0ger Posted April 15, 2019 Share Posted April 15, 2019 The first part with xc and yc just adjust the coordinates. PMG has 48 invisible pixels on the left, and 16 on top (both depends on dlist and screen width). So if you want to convert PMG coordinates to playfield coordinates you have to adjust for that. I usually just use good old trial and error method for correct amount As for the rest, it seems you are confused by & sign. That's for bitwise AND. It's used for getting bits of a number .. X and 3 for example extract bottom two bits, as 3 is 00000011. Here it is used for modulo. XC & 3 is the same as XC mod 4. Note this only applies for numbers 2^x (2,4,8,16,32 etc). I'm not sure what AndTab does either. 1 Quote Link to comment Share on other sites More sharing options...
dmsc Posted April 16, 2019 Share Posted April 16, 2019 Hi! The first part with xc and yc just adjust the coordinates. PMG has 48 invisible pixels on the left, and 16 on top (both depends on dlist and screen width). So if you want to convert PMG coordinates to playfield coordinates you have to adjust for that. I usually just use good old trial and error method for correct amount As for the rest, it seems you are confused by & sign. That's for bitwise AND. It's used for getting bits of a number .. X and 3 for example extract bottom two bits, as 3 is 00000011. Here it is used for modulo. XC & 3 is the same as XC mod 4. Note this only applies for numbers 2^x (2,4,8,16,32 etc). I'm not sure what AndTab does either. The table is basically a mask with 3*4^(3-i), the bits you need to check for a give pixel: 11000000, 00110000, 00001100 and 00000011. Regards, 1 Quote Link to comment Share on other sites More sharing options...
Yaron Nir Posted April 16, 2019 Author Share Posted April 16, 2019 I am pretty familiar with bitwise AND. I just wast sure where did the fixed numbers came from but after the explanation it makes some sense. The demo seems to be working pretty well. Quote Link to comment Share on other sites More sharing options...
