PacManPlus Posted April 30, 2019 Share Posted April 30, 2019 (edited) Ok, as promised, here is the pic of the entire board. I took the video mod out of the socket as to get more of the board showing up. Hope this helps. It figures that I have a version of a board that nobody has worked with before. :-/ EDIT: My apologies, I didn't mean to derail the thread. If we should split this into another thread, please by all means, do it, or just let me know and I'll start another one. Edited April 30, 2019 by PacManPlus Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted April 30, 2019 Share Posted April 30, 2019 Stupid AV mod, but no multi-BIOS? 2 Quote Link to comment Share on other sites More sharing options...
Jinks Posted April 30, 2019 Share Posted April 30, 2019 Is this the show ur innards thread or what? 1 Quote Link to comment Share on other sites More sharing options...
+Mitch Posted April 30, 2019 Share Posted April 30, 2019 That looks vaguely familiar. I may have one of those boards, still need to take apart some 7800s to check. Mitch 1 Quote Link to comment Share on other sites More sharing options...
PacManPlus Posted April 30, 2019 Share Posted April 30, 2019 Stupid AV mod, but no multi-BIOS? If I knew how to do that, I would have... I'd like to make a version of the BIOS that starts up, say Meteor Shower instead of Asteroids when no cart is inserted. I suspect that whatever game I would use, I will need about 4K free for the actual BIOS? Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted May 2, 2019 Share Posted May 2, 2019 Stupid AV mod, but no multi-BIOS? And what I suspect is a blue LED power indicator as well hehe. Because we were all putting in blue LEDs in the early 2000s !!! 1 Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted April 7, 2020 Share Posted April 7, 2020 On 4/29/2019 at 9:51 PM, PacManPlus said: Ok, as promised, here is the pic of the entire board. I took the video mod out of the socket as to get more of the board showing up. Hope this helps. It figures that I have a version of a board that nobody has worked with before. ? EDIT: My apologies, I didn't mean to derail the thread. If we should split this into another thread, please by all means, do it, or just let me know and I'll start another one. Do you have a pic of the solder side of the board? I'm curious what revision it claims it is and who manufactured it. Quote Link to comment Share on other sites More sharing options...
davyK Posted April 13, 2020 Share Posted April 13, 2020 Does NTSC Asteroids play faster than the PAL version or is it speed adjusted? Quote Link to comment Share on other sites More sharing options...
gambler172 Posted September 27, 2020 Share Posted September 27, 2020 On 4/29/2019 at 1:57 AM, Trebor said: Sorry, I didn't mean to imply the "bulk" BIOS archive for the A7800 emulator is all-inclusive. I believe the folder capture below covers the additional BIOS files you mentioned and some others. I think it has all the HSC ROM files also, or there might be a third one not in the folder. A couple of other files may be 'scattered' elsewhere too. I might have to snoop around in my folders and files. *Edit: Looking over that list, I spelled Asteroids incorrectly, or was that intentional. *Edit2: Nope...just a typo on my part. Hi Trebor could you send me this bios es...so that i could burn them on an eprom??? Quote Link to comment Share on other sites More sharing options...
Trebor Posted September 28, 2020 Share Posted September 28, 2020 6 hours ago, gambler172 said: Hi Trebor could you send me this bios es...so that i could burn them on an eprom??? Check your PMs. Quote Link to comment Share on other sites More sharing options...
gambler172 Posted November 24, 2020 Share Posted November 24, 2020 Hi Guys i have a burner and some empty chips.... I never used it. how can i burn a 7800 OS? Quote Link to comment Share on other sites More sharing options...
mimo Posted November 26, 2020 Share Posted November 26, 2020 On 11/24/2020 at 4:10 PM, gambler172 said: Hi Guys i have a burner and some empty chips.... I never used it. how can i burn a 7800 OS? plug in eprom burner open software for your burner insert correct size eprom the right way round check it's really empty select rom file click the go button wait for program to finish test 2 Quote Link to comment Share on other sites More sharing options...
gambler172 Posted January 3, 2021 Share Posted January 3, 2021 Hi Guys in a Dev os mod description,i read.....remove W6 and install it at W5.....silly question..what is W 5 and W 6 ? Quote Link to comment Share on other sites More sharing options...
mimo Posted January 3, 2021 Share Posted January 3, 2021 (edited) 1 hour ago, gambler172 said: Hi Guys in a Dev os mod description,i read.....remove W6 and install it at W5.....silly question..what is W 5 and W 6 ? Iirc it's just a piece of wire or maybe a resistor . It's a jumper setting Looking at pacmanplus' image above it looks to be directly above the 2 colour trim pots right by the cart port Edited January 3, 2021 by mimo Quote Link to comment Share on other sites More sharing options...
