Any compressor between rle and lz4 ?
Hi!
Well I got curious, so I took my 9 deinterleaved raw SAPR channels and compressed them with LZSS v0.01. and the total was about 4KB vs 2KB for LZ4 best setting.
Doh! ... I've only-just realized that rensoup is actually talking about *music* compression, silly me!
Well, I tested the LZSS compressor with *very* small windows (8 bits for offset+length), for my test sample the best combination was 5 bytes for the match offset and 3 bytes for the length, but this makes the buffer too big (9*32 = 288, > 256).
So, I settled for match offsets and lengths of 4 bits.
Attached is the code and two samples: one song extracted from the RMT distribution: "4Tk35 by Caruso" (compressed to 30% of original), and the Archon loading screen (compressed to 12% of original).
The attached "lzss.c" reads a TYPE-R SAP file on standard input and writes a compressed binary to standard output, the ASM file includes this to assemble a working player.
Overall, the compression is just not great, as the small window size can't capture the repetitions through the song, and there is much waste - for example, channel 9 is POKEY register AUDCTL, this does not varies in the songs I tried, and channels 1,3,5 and 7 are AUDC*, the values hold there are limited.
playlzs.asm
sap-lzss.zip
playlzs1.xex
playlzs2.xex
Hi!
Ok. Noob question.
For the 65816 SNES rom depack what would you recommend?
I think that depends on the data size, available RAM and speed needed. But, just try LZ4 and see if your data is already compressible enough to make it worth.
Hi!
Yeah lz4 is my standard depacker for all my demos but I thought there is already an 65816 version. Ok. Can run it in emu mode (SEP #$30 ;))
Having said which ... if you only need to decompress 9-bytes of data per frame to feed the POKEY registers, then decompression speed really isn't your problem IMHO. You're going to be more concerned with managing ring-buffers.
Yes, I wasn't very clear on that, speed isn't essential in this case (it is for decrunching sprites). I managed to get my RLE stuff working and the code is horrible... way too much setup code. dmsc' solution is much cleaner.
Did you implement optimal parsing? (or at least, lazy parsing with at least checking 4 bytes in advance)
Most papers say that you can get a lot of extra compression ration with that (and it is what LZ4HC compressor does).
Nope, not in my SWD encoding.
I used the official LZ4 compressor for testing ... I have no idea if that has lazy encoding.
Lazy encoding does sound like a good idea for *any* of the LZ-style compressors, and I've been meaning to try it out.
All right ... now I've got to "thank" you for destroying my productivity in the last few days and sending me back down the rabbit-hole of compression strategies! :mad: ;)
When it comes to the fascinating subject of the bragging-rights of the best optimal coding, it seems from articles like this ...
http://cbloomrants.blogspot.com/2012/09/09-04-12-lz4-optimal-parse.html
... that we're only talking about a less than a 0.5% improvment in the compression compared to the much simpler lazy encoding's 1.0% advantage over greedy encoding.
Anyway, I guess that I'll be going back and adding at-least lazy encoding to my compression testbed, just so that I can have another go at trying to beat aPlib.
So, this is equivalent to the data:
XX YY ZZ MM NN QQ RR SS TT XX YY ZZ MM NN QQ RR SS TT XX YY ZZ MM NN QQ RR SS TT XX YY ZZ MM UU QQ RR SS TT XX ....Hope above example makes it clearer.
Yes, very clear now, I thought you meant standard RLE.
GREAT! :thumbsup: :thumbsup: :thumbsup:
Well... almost.
I've tried it on a bunch of SAPs and they all fail to decrunch/play at some point... not sure if I've done anything wrong ? I've attached an example that failed. (I did "lzss <shadows.sap >test.lzs")
So I got my modified RLE to work and for a 35KB raw, RLE would get it down to 12.5KB, my modified RLE did 9KB, your LZS did 8.5KB. But your LZS did better on other files.
The decode time on the 6502 was similar, about 10 scanlines.
There are others things that I could do that might improve the compression quite a bit but I'm ok with what I got now. And if your LZS works I'll probably use that instead!
Your method is much cleaner, my setup code is a lot more messy and I have to expand the files to make them multiples of 9 when packing.
Sure a better compression ratio would be great but as it is, it makes it possible using some of those costly RMTs into actual productions.
PS:People have suggested delta encoding, I gave it a quick shot but ended up with results slightly worse.
shadows.zip
Edited by rensoup
I made one more small mod to my LZSS code earlier, to make the nibble-unpacking faster by 14-cycles-per-byte, mostly just so that it's a bit of practical LZSS code that people can look at, rather than it being something that'll help you in your (already solved) problem.
Having something that works is always the most-import goal ... congratulations!!! :-D
Hi!
Well... almost.
Well, the posted code does not detect the end of the compressed stream, so it keeps playing random notes after the end of the song.
Also, if you are using Windows, I discovered that the C program does not work, because the redirections are in "text mode", as opposed to "binary mode". I only tried on windows, this is why I did not see the problem,
Attached is a new program with the changes:
- On Windows, the lzss.c sets binary mode on files.
- The playlzs.asm detects the end of the stream and properly terminates.
- Added a lot more statistics to the lzss program, now shows empty and fixed channels that should be left out of the player.
Delta encoding is good when you do Huffman or other type of entropy coding, as it reduces the set of values, but will not give you too much with the kind of data in SAP.
sap-lzss.v2.zip
playlzs.asm
  • Like 4
Hi!
Great articles, after seeing this http://cbloomrants.blogspot.com/2008/10/10-10-08-7_10.htmlI think will also implement optimal parsing to the LZSS coder ;)
  • Like 5
Yes I'm under Windows, so your fix worked perfectly. The files are a bit bigger now but still slightly smaller than my RLE.
Thanks again! I'm still baffled that nobody has done this before :roll:
Guess I won't use my RLE :-D. Your code is much smaller, speed is the same, files can be a little smaller or quite a bit smaller, and there aren't any silly restrictions (I have to ORG the compressed data, and have to set manually the song duration in the code for looping. )
I'm just gonna go ahead and post it anyway so you can have a laugh :twisted:
If you look at some of the compressed channels files, the compression is outrageously bad. I could probably implement RLE on duplicate sequences and save a good amount of space but compared to your solution, it wouldn't be very elegant code.
sapRLE.zip
actually, I'm still having an issue further in the song, it's still before the loop point I believe. Maybe another redirection issue ?
I'm attaching the obj and the converted file
lzsfail.zip
Hi!
An idea: would it help to deinterleave the sap-r data and compress them indiviually with lzss? Your window will reach 9 times further back in the song and might capture more repetitions.
This is exactly what the code does, in fact the compressor shows the compressed size for each of the 9 streams:
 ./lzss < test1.sap > test1.lzs
WARNING: stream #8 is empty, should not be included in output!
Ratio: 37619 / 126792 = 29.67%
 Stream #0: 24939 bits,	22.13%,	 8.29% of output
 Stream #1: 29502 bits,	26.18%,	 9.80% of output
 Stream #2: 46260 bits,	41.05%,	15.37% of output
 Stream #3: 53586 bits,	47.55%,	17.81% of output
 Stream #4: 13140 bits,	11.66%,	 4.37% of output
 Stream #5: 68274 bits,	60.58%,	22.69% of output
 Stream #6: 36621 bits,	32.49%,	12.17% of output
 Stream #7: 21159 bits,	18.77%,	 7.03% of output
 Stream #8: 7470 bits,	 6.63%,	 2.48% of output
As you see, pokey register 8 (AUDCTL) does not change, so it compresses the most, followed by register 4 (AUDF3), probably does not changes a lot.
The small window size (16 bytes for each stream) is to limit the buffer needed at decompression time, as you don't want to keep the samples in memory.
Hi!
See:
$ ataricom music.obx
ataricom 0.30-150320
(c) 2008-2014 Matthias Reichl <hias@horus.com>
block    1: 0582-0d4e (bytes:  1997, offset:      6)
block    2: 3ffa-4f61 (bytes:  3944, offset:   2007)
block    3: 1000-1052 (bytes:    83, offset:   5955)
block    4: 02e0-02e1 (bytes:     2, offset:   6042)
       RUN: 1000
block    5: 1053-2a4b (bytes:  6649, offset:   6048)
block    6: 0094-009e (bytes:    11, offset:  12701)
block    7: 2100-2160 (bytes:    97, offset:  12716)
block    8: 02e0-02e1 (bytes:     2, offset:  12817)
       RUN: 1000
Your XEX has many segments, and segment 7 ($2100 to $2160) is overwriting segment 5 (the compressed musing, at $1053 to $2A4B).
Sorry, I wasn't aware of that.
Could you post this test1.sap? I would like to have a look at it and perhaps have a go at it myself.
Regards,
Ivo
OOoops Sorry, I'd ORGd the tune at $1000 and forgot that your player is ORGd at $2000, so the player ended up playing itself!
Verified to work again, added looping, looping perfectly!
Regards,
Ivo
For ./lzss < test1.sap > test1.lzs, it's shadows.zip which I posted above.
my sapRLE: +-8KB
dmsc: 6.6KB
Are we going to end up with 3 solutions :) ?
my sapRLE: +-8KB
dmsc: 6.6KB
Now let shadows.zip be the one file I didn't download :)
I have called this day "a day" already, but I'll have a look at it tomorrow.
Edit: ok, couldn't resist. Looks like shadows.sap is not test1.sap
$ src2/lzss < shadows.sap > shadows.lzs
WARNING: stream #6 is empty, should not be included in output!
WARNING: stream #7 is empty, should not be included in output!
WARNING: stream #8 contains only $40, should not be included in output!
Ratio: 6623 / 42759 = 15.49%
 Stream #0: 8208 bits,	21.60%,	15.49% of output
 Stream #1: 13005 bits,	34.22%,	24.55% of output
 Stream #2: 4734 bits,	12.46%,	 8.93% of output
 Stream #3: 8388 bits,	22.07%,	15.83% of output
 Stream #4: 5481 bits,	14.42%,	10.34% of output
 Stream #5: 5580 bits,	14.68%,	10.53% of output
 Stream #6: 2529 bits,	 6.65%,	 4.77% of output
 Stream #7: 2529 bits,	 6.65%,	 4.77% of output
 Stream #8: 2529 bits,	 6.65%,	 4.77% of output
value	  POS	  LEN
 0	    0	 2197
 1	 2572	    0
 2	    0	  778
 3	    8	   62
 4	    6	  348
 5	    0	   61
 6	  374	  106
 7	    0	   78
 8	    2	   23
 9	   18	   13
10	    3	  224
11	    1	   39
12	  115	   37
13	    0	    9
14	   17	   19
15	   17	   18
16	  557	    1
17	    0	 1874
Edited by ivop
Here's coding the delta's before lzss, but only on the distortion+volume streams:
./main < ../shadows.sap > foo
Ratio: 6538 / 42759 = 15.29%
 Stream #0: 8208 bits,	21.60%,	15.69% of output
 Stream #1: 11502 bits,	30.26%,	21.99% of output
 Stream #2: 4734 bits,	12.46%,	 9.05% of output
 Stream #3: 9792 bits,	25.76%,	18.72% of output
 Stream #4: 5481 bits,	14.42%,	10.48% of output
 Stream #5: 4995 bits,	13.14%,	 9.55% of output
 Stream #6: 2529 bits,	 6.65%,	 4.84% of output
 Stream #7: 2529 bits,	 6.65%,	 4.84% of output
 Stream #8: 2529 bits,	 6.65%,	 4.84% of output
Interesting that stream #3 actually increases in size (probably the drum channel), but stream #1 and #5 decrease in size, with an overall saving of an extra 85 bytes. But it would need an extra operation during decompression.
Edited by ivop
Hi!
Perhaps you could simply flag which streams are delta-encoded, with one byte you could cover the eight main streams.
Meanwhile, I did a few modifications to the code:
- Implemented optimal parsing. This does not help with compression as the LZSS with only one byte is so simple that greedy parsing gives the same compression.
- Change the coding of matches to make decoding smaller (and faster).
- Adds a flag to skip streams that don't vary - only for streams 1 to 8, stream 0 is always coded. If no stream is skipped, the compressed file is one byte longer, but the ASM player is 13 bytes bigger.
Attached are the sources, player and Linux + Windows binaries:
Skipping channel #8, set with $40.
Skipping channel #7, set with $00.
Skipping channel #6, set with $00.
Ratio: 5675 / 42759 = 13.27%
 Stream #0: 8208 bits,	21.60%,	18.08% of output
 Stream #1: 13005 bits,	34.22%,	28.65% of output
 Stream #2: 4734 bits,	12.46%,	10.43% of output
 Stream #3: 8388 bits,	22.07%,	18.48% of output
 Stream #4: 5481 bits,	14.42%,	12.07% of output
 Stream #5: 5580 bits,	14.68%,	12.29% of output
Have Fun!
lzss-sap-20190524.zip
  • Like 4
Gave it a shot... the player is quite a bit faster indeed. Litterally 4-5 times faster than the original RMT sometimes!
Only issue is that I can't seem to get it to loop 100% right with the new version... not excluding that I've done something wrong of course...
zip contains just obxs for all versions for a quick perf compare.
shadowsobx.zip
Hi!
The problem is that now the payer has an initialization phase that reads from the song bytes, to select which streams are available and initialize the POKEY register with proper values.
So, on the second run, don't re-init the streams, as this info does not change during the song, but set the song_ptr to the position after the initialization bytes. So, one posible code is:
  jsr initPlayer
  sty saved_y
start_song:
  lda get_byte+1
  pha
  lda get_byte+2
  pha
play_song:
  ldy saved_y
  jsr advancePlayer
  sty saved_y
  ; ... do other things here ...
  ; Wait for new frame
  lda 20
delay
  cmp 20
  beq delay
  ; Compare with end and loop
  lda get_byte + 2
  cmp #>song_end
  bne play_song
  lda get_byte + 1
  cmp #<song_end
  bne play_song
  ; Now, reset the song pointer to loop the song
  pla
  sta get_byte+2
  pla
  sta get_byte+1
  jmp start_song
Now, the code for "initPlayer" is from current "start" in the ASM up to just before "sap_loop", and "advancePlayer" is from "sap_loop" up to just before "delay".
I have a question: is there a program to convert a standard SAP to a type-R SAP?
Have Fun!
About looping, I did -some- of those things you mentioned, I'll give it another try. Thanks!
I've been wondering about SAP->SAPR myself... Only found ASAP so far:
http://asap.sourceforge.net/
There's a command line tool included which I haven't tried yet. On Win, there's a player called WASAP included in the package. If you load a song and go to info, you can save a XEX and SAPR it from Altirra.
Best I found was to get an RMT and assemble it, then SAPR it in Altirra and KIL on song loop to get a perfect loop :roll:
Edited by rensoup
I tried on a 8KB RLE compressed song and all channels but one got bigger. The one that got smaller shrunk by 500 bytes! But I couldn't be bothered.
Again I'm thinking I'd get better results by modifying the RLE format but I'd be trying to catch up with dmsc so not much point.
Perhaps larger buffer sizes in dmsc's lzss would yield good gains too? It's pretty usable for any tune under 2 minutes right now.
Just curious about your Sid player, are you feeding pokey at a higher frequency than 50hz ? (I'm guessing the sprites shapes in your player reflect that)
Edited by rensoup
Seeing you mention sprite shapes, I guess you mean AtariSid. That one bangs three Pokey registers at 15kHz :)
Sid2gumby on the other hand updates Pokey at 50Hz, but uses large tables to convert from sid frequencies to pokey values. Those could be replaced with some math routines, but that would be slower than a table lookup.
Edited by ivop
