joelgraff Posted May 20, 2019 Share Posted May 20, 2019 I'm working on restoring an old 410 cassette player. It's in great shape and I've successfully replaced the belts. But, when I had it apart, I also noticed the rubber rollers that drive the forward / reverse operations have flat spots on them - especially the forward roller. So I need to source replacement rollers - then figure out how to replace them. I've been googling and really haven't found anything, apart from sources for cassette pinch rollers. Is there anything that addresses this? Quote Link to comment Share on other sites More sharing options...
SoundGammon Posted May 20, 2019 Share Posted May 20, 2019 When I use to work on VCRs with bad tires, I would go to a hardware store and get small "O" rings and that worked well! Just take it with you to size it up! Quote Link to comment Share on other sites More sharing options...
eizner23 Posted May 20, 2019 Share Posted May 20, 2019 (edited) I think this guy can help you, ship him the old roller and he will put new rubber on it http://www.terrysrubberrollers.com/ this site has a large selection of new idlers and tires https://webspareparts.com/collections/belts-pinch-rollers-idler-tires?page=1 I have the some problem with my 410 someday Ill get the roller replaced. Edited May 20, 2019 by eizner23 1 Quote Link to comment Share on other sites More sharing options...
joelgraff Posted May 20, 2019 Author Share Posted May 20, 2019 I discoverd the rollers are fairly easily removed... so I'll hit the hardware store first, but that one website looks useful too, thanks! Quote Link to comment Share on other sites More sharing options...
joelgraff Posted May 23, 2019 Author Share Posted May 23, 2019 So I've been investigating my options. Really, just to make this run, I could swap rollers (one is much better than the other) or try the O-Ring solution. But I think I'll try making my own first. Ordered some rubber solid core rope / cordage from McMaster-Carr. We shall see. Quote Link to comment Share on other sites More sharing options...
Geister Posted July 13, 2019 Share Posted July 13, 2019 I'm wondering if you have a follow up. I just bought a 410 that needs belts for sure. Now I'm concerned I'll be following that up with pinch rollers. Quote Link to comment Share on other sites More sharing options...
adam1977 Posted July 13, 2019 Share Posted July 13, 2019 I wonder if WJOE Radio could help with pinch rollers for our tape decks? I've used them in the past for belts for my vintage Pioneer Hi-Fi http://www.wjoe.com/vintageandantiques.htm Quote Link to comment Share on other sites More sharing options...
Geister Posted July 14, 2019 Share Posted July 14, 2019 I replaced the three easy belts. The main belt was hard as rock and stuck to the pulley. I cleaned everything with 90% isopropyl and cotton swaps. Of course rewind is not working at all, but fast forward works great. I then hooked it up to my 130xe and tried to load a Pooyan tape. Things did not go well. The take up reel seemed to be moving jerky and eventually stopped turning. when I stopped it, the tape had started to suck into the unit. I had to rewind it by hand. I don't think it was the pinch roller. I had cleaned that up and it looked great. Maybe I need to try some rubber conditioner on the wheel. Any idea what I should look at? Quote Link to comment Share on other sites More sharing options...
adam1977 Posted July 14, 2019 Share Posted July 14, 2019 Don't use any chemicals like alcohol on the rubber parts: Quote Many people ask me what to clean their pinch rollers with. I wish I had a good super secret formula I used and could tell you about, but I don't. I see daily and hear what chemicals do to rubber, and it isn't good. Sooner or later the rubber will be ruined. Some types of rubber dry out, crack, and get hard, while others get soft and gooey. My advise and its only my opinion, and I know this doesn't clean as good as some high octaine chemicals, but I suggest just plain old dish soap and water, then rinse good. Sorry thats about it. As far as rubber conditioner, on my car I use Aerospace 303, with some components I soak them in 303 and they come up like new 1 Quote Link to comment Share on other sites More sharing options...
drpeter Posted July 14, 2019 Share Posted July 14, 2019 For what it's worth, the Atari maintenance manuals suggest using (carbon) tetrachloride cleaning fluid for the pinch roller and isopropyl alcohol for the heads. 1 Quote Link to comment Share on other sites More sharing options...
adam1977 Posted July 14, 2019 Share Posted July 14, 2019 For metal parts, isopropyl is fine, but for rubber it's definitely not Quote Link to comment Share on other sites More sharing options...
stushug Posted October 19, 2022 Share Posted October 19, 2022 For rubber parts such as roller tires, I have used CaiKleen RBR rubber cleaner and have had great results on many cassette decks. There are others, but I've only used Caig's product. Quote Link to comment Share on other sites More sharing options...
