2019 Harmony Games -Final Round:Mappy (Best Homebrew Game)
Its, time to announce the Final Game in the 2019 Homebrew Tournament.
Which is Mappy that won for Best Homebrew Game
(as well as Programing,Technical Achievement ,Music and sound and Graphics).
This round officially starts on June 11th at Noon Central and ends on July 13th at 6pm
You can download the game here and instructions here
Rules play on standard with both difficultly switches et on "A"
Scoring goes for as forward: top 10: 10 (for first) to 2(for tenth) 1 for everybody after 10
Good Luck!!
Just played a few rounds, great game! :)
But we should play with the left difficulty switch set to B. If you set it to A you become invincible.
oh didn't know that according to instructions
LEFT DIFFICULTY: A - Loot will be located in random positions at the start of each level. B - Loot is located in the same position on each level.
doesn't mention about invincibility will check it out. (only month left to play)
Ok this wasn't my fault but we changing the difficulty setting for left to B (the instructions thats was in arenafoots onedrive made no mention of this as mentioned before)still a month left.
will make changes in the other sites(AVC Online ,VGS and avc onlineforum)
thanks for heads up implaler
  • 2 weeks later...
MAPPY new attempt  34,910
Timeline in the video above:
00:05 - Difficulty switches (Left B and Right A)
00:10 - Controller used (Keyboard as Joystick)
00:12 - Color format (NTSC) and Phosphor enabled
00:19 - Opening of Mappy - Skill adjusted to Standard (Factory Default)
00:27 - Run to verify the correct position of Left Difficulty (NO invincibility at the contact with cats on the platform)
00:38 - First run starts
06:11 - End of first run with the score of 26,690 points
06:29 - Second run starts
13:35 - End of second run with the score of 34,910 points
Edited by oyamafamily
Text correction/revision in this post
good score will update scoreboard on the website(AVC Online) as well on AVC online forum.
Only few weeks left
I'm going prob play as well before VGS
Edited by Dan Iacovelli
Scores as of 6/29/2019
Nathan Strum---------- 91,730
root42------------------72,180
oyamafamily------------34,910
roadrunner------------- 32,400
Dan I---------------------6,190
its coming close to end of this seasons harmony games just about 2 weeks to go
Mappy, new attempt  53,560
(I decided to provide here more 2 gameplay videos!)
Take 1:
00:06 - Difficulty Switches (Left B / Right A)
00:14 - Mappy opening (skill Standard)
00:20 to 05:34 - 30,880-point run
05:40 - Double-Check - Difficulty Switches (Left B / Right A)
05:49 - New Mappy opening (skill Standard)
05:55 to 07:06 - Unsuccessful runs
07:06 to 16:00 - 41,700-point run
Take 2:
00:04 - Difficulty Switches (Left B / Right A)
00:12 - Mappy opening (skill Standard)
00:16 to 05:51 - 34,520-point run
05:52 to 14:57 - 53,560-point run
