Esci Posted August 1, 2019 Share Posted August 1, 2019 Ive been working on a game for afew days and wanted to know what you guys thought about it so far you play as a goblin with a stick who has to hunt slimes currently each of the 6 areas has 8 slimes that you have to hunt you use joystick 1 to move and the button to swing the stick the stick must be on the slime in order to kill it and gain points if you go into the blank areas on the sides of the screen it will put you in the next area so you can hunt more slimes a pfscore bar will tell you how many slimes are left in the current area and when it hits 0 the slimes will stop spawning after killed Goblin6.bin sometimes when you go into a corner you will get stuck in the walls since im bad at collision stuff so it will reset your position and give you 1000 points when that happens there is also no win screen or title screen yet since im still working on the world 4 Quote Link to comment Share on other sites More sharing options...
easmith Posted August 9, 2019 Share Posted August 9, 2019 I encourage you to keep working on this ! You could use sprites for player and enemy , and missile for sword. You could have multiple enemies on screen ( might require flicker but that's ok ) . You could have enemies fire missiles. In order to have 2 players and two missiles on screen would require 2 line kernel but folks would help with that . Currently contacting enemies does not hurt player. Also, game needs an objective ( such as kill all enemies and win ) . 1 Quote Link to comment Share on other sites More sharing options...
Esci Posted August 12, 2019 Author Share Posted August 12, 2019 (edited) After fixing most of the bugs ive been able to find ive almost run out of room for a 4kb rom (383 byte left) so if i want to add multiple enemies and have them able to attack ill probably have to figure out bank switching I think im able to get enemies to be able to attack and damage the player with the space i have left but i might not be able to without getting bankswitching to work In the current version you win by killing all 8 in each area, i got almost all collision issues fixed so the playfield doesnt flash colours when in the last 2 areas and so they player cant get stuck in the walls on corners, and i also made it so when you move to a different area the slime will be put in a random position on the screen instead of staying where it was before Goblin11.bin Edited August 12, 2019 by Esci in 1 Quote Link to comment Share on other sites More sharing options...
Esci Posted August 14, 2019 Author Share Posted August 14, 2019 I got missiles working and i tried getting multiple enemies on screen I didnt like how multiple enemies was working so i decided not to use it Also redid all of the code to free up some extra space so some stuff may be alittle broken Goblin13 is with 2 enemies flikering and Goblin15 is with missiles If the left slime didnt break i wouldve kept the multiple enemies In 15 if you die it will reboot to the title screen, there is no way to restore health currently but you can change left difficulty to make the missile do more or less damage to you Goblin13.bin Goblin15.bin 2 Quote Link to comment Share on other sites More sharing options...
CrazyChris Posted August 25, 2019 Share Posted August 25, 2019 batari Basic? Quote Link to comment Share on other sites More sharing options...
Esci Posted August 28, 2019 Author Share Posted August 28, 2019 Yeah, im not very good with assembly so i used bB Quote Link to comment Share on other sites More sharing options...
Esci Posted October 23, 2019 Author Share Posted October 23, 2019 I had some issues with my laptop so i wasn't able to work on this much But now i have those issues fixed and i can work on this again I got bankswitching to work so now storage is nolonger an issue, and several bugs have been fixxed I will add some more stuff and fix some other things tomorrow but for now I put the first version of the game in, if you go all the way to the left and hold up until you go out to the right you can see how bad the first version was :) It's now possible to heal aswell Goblin22.zip Quote Link to comment Share on other sites More sharing options...
Esci Posted October 24, 2019 Author Share Posted October 24, 2019 I added a southwest area and southeast area neither are complete yet The southeast is a bigger snow area and the southwest is a maze if you want to access the entire maze you have to change ram_EF to 01 I will put something in to unlock that area soon I will put more slimes in the snow area so you can get a higher score since im not going to put any in the maze area (yet) collision has also been changed to use way less space but its not fully working yet so you can use it to clip through walls Goblin23.zip 1 Quote Link to comment Share on other sites More sharing options...
