G7400 video problem
Macross_VF1
So I have an issue with my Philips Videopac G7400. It outputs a piss poor RF signal, no matter how much I try to tune the TV. When I started digging around the net I saw that it was easy to convert to RGB, just a matter of installing a number of components.
https://www.the-nextlevel.com/odyssey2/articles/g7400guide/rgbmod.php
Unfortunately, nothing improved. As can be seen in the attached image (the image was taken while using RGB), the signal is still distorted and it does not matter if it is RF, composite or RGB. Anyone have any idea what the problem might be? I have tested the internal AC adapter and it outputs pretty much the correct voltage, 4.95V on one line and 11.43V (should be 5 and 12V respectively) on another.
