+therealbountybob Posted August 11, 2019 Share Posted August 11, 2019 My abbuc entry "Block on Legs: First Steps" has a serious bug that I've now figured out how to fix (literally woke up in the night and figured it) but it's unlikely they will allow an updated version - -luckily it should be a case of replacing two JSR statements with NOPs so I need a disk/file patch that I can send out for people to run. Ideally repace a series of specific bytes on specific sectors. Perhaps some code that I can add the bytes to and assemble myself? Thanks Jason Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 11, 2019 Share Posted August 11, 2019 I don't think Windows, even PowerShell, has an easy built in way of doing such patches. Essentially what you want is to verify data to ensure you're patching the right thing then perform the actual patch. Likely something such as Perl could handle it but it's not a built in product. Can't you just send out a new version given that the typical ATR zips down to under 50K? Quote Link to comment Share on other sites More sharing options...
E474 Posted August 11, 2019 Share Posted August 11, 2019 (edited) Hi, It sounds like you need to write data directly to specific sectors on disk using the 8-bit SIO routines in the OS. I use this code: WRITE_SD_BUFFER_TO_SECTOR LDA #<SECTOR_BUFFER STA DBUFLO LDA #>SECTOR_BUFFER STA DBUFHI LDA #$80 STA DBYTLO LDA #0 STA DBYTHI LDA SECTOR_NUMBER STA DAUX1 LDA SECTOR_NUMBER+1 STA DAUX2 LDA #'P ; would like to update this to write with verify STA DCOMND LDA #$80 STA DSTATS LDA #$31 STA DDEVIC LDA DESTINATION_DRIVE_NUMBER ; Supplied by user STA DUNIT LDA #20 ; NOT SURE STA DTIMLO JSR SIOV RTS ; BMI ERROR You just need to define/include the standard SIO DCB equates, and define the other variables (SECTOR_NUM, SECTOR_BUFFER, etc. according to your needs). Your assembler probably has these defined already, or they are somewhere out there on the net, or you can just get them from "Mapping the Atari", etc. I don't know how the contest disk/images are being distributed, but you might want to try reading the sector that you want to patch, checking the data is what you expect, update the values in memory, then write it back. If you need a READ_SECTOR subroutine, just adjust the one above to use $40 for DSTATS and #'R for DCOMND (If I recall correctly). I think DUNIT is a binary value, e.g. $01 for drive #1, not ATASCII "1", or maybe the other way round! I think the rules don't allow distributing a new version after the deadline, but by the same token, I think if you want to write a utility to patch a program, there's nothing forbidding you from doing so. Hope this helps! P.S. You can also use this code if you want to write the patch utility in Basic: Edited August 11, 2019 by E474 3 Quote Link to comment Share on other sites More sharing options...
dmsc Posted August 11, 2019 Share Posted August 11, 2019 Hi! I think that the easiest will be distributing a BASIC program, like this (untested): 10 GR.0 : ? : ? "TheRealBountyBob Game FIXER" : ? 20 ? "Please, insert original game disk in drive 1" : GOSUB 300 30 TRAP 150: OPEN #2,4,0,"D:MYGAME.COM" : OPEN #3,8,0,"D:NEWGAME.COM" 40 TRAP 80 : READ SKIP, LEN 50 FOR I=1 TO SKIP: GET #2,A: PUT #3,A: NEXT I 60 FOR I=1 TO LEN: GET #2,A: READ A :PUT #3,A : NEXT I 70 GOTO 40 80 TRAP 100 : REM COPY REST OF BYTES 90 GET #2, A: PUT #3, A: GOTO 90 100 CLOSE #2 : CLOSE #3 : ? "Ok, new file created!" : GOSUB 300 110 GR.0 : END 150 ? "ERROR, CAN'T OPEN FILES": ? "VERIFY CORRECT DISK" : ?"AND REMOVE WRITE PROTECCTION" 160 GOSUB 300 : G. 110 300 ? "Press a key" 310 OPEN #1,4,0,"K:" : GET #1, K : CLOSE #1 320 RETURN 390 REM PATCH DATA: # BYTES TO SKIP, # TO REPLACE, VALUES TO REPLACE 400 DATA 1000, 3, 240, 240, 240 410 DATA 200, 3, 32, 123, 45 The last DATA sections are the number of bytes to read from the original and write to the copy unmodified, then the number of bytes to modify, then the values, and then repeats again. So, if you want to replace bytes 150, 151 and 301 with 10, 11 and 12, the DATA should be "149, 2, 10, 11, 149, 12". Have Fun! 4 Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted August 11, 2019 Share Posted August 11, 2019 5 hours ago, Rybags said: Can't you just send out a new version given that the typical ATR zips down to under 50K? He can and he did - but the deadline for the Abbuc Software Contest is already over (31st July 2019) and thus updates are no longer allowed... and the disk images (including the "buggy-version") have already been made available for download. 1 Quote Link to comment Share on other sites More sharing options...
+therealbountybob Posted August 15, 2019 Author Share Posted August 15, 2019 Thanks guys, I'll take a look at both the assembler and the BASIC code posted. Quote Link to comment Share on other sites More sharing options...
