JohnBlbec Posted May 30, 2023 Share Posted May 30, 2023 On 5/17/2020 at 1:18 AM, tajvdz said: Yes this looks good! what I have so far is the enclosed file but it doesn't have the gaps filled. The file I have has the stylus holder on the other side, but I think this is much better. The lead hole on that side yes but not at the bottom but a bit higher. What is missing in my stl file are holes for the 2 leds and the switch. I think the only place to put them is on the front. Leds left of the Atari logo and switch right of the Atari logo. So I think if you continue with your file is to add the text on top and the logo on the front and move the hole for the lead a bit higher and center it between the 2 connections. And at last to add a hole for the switch with the letters S and E and 2 small holes for the leds. I do have an example of the switch. It was done on another case. SDRive Max Case Tweaks-3.stl 354.77 kB · 65 downloads hi. do you have that case also for arduino board with micro usb? i can't find it. thanks. Quote Link to comment Share on other sites More sharing options...
tajvdz Posted August 11 Share Posted August 11 I finally finished my Sdrive-Max case. I think it turned out very well. Are people interested in the STL file and a short manual on how to add the leds? 4 Quote Link to comment Share on other sites More sharing options...
Jfcatari Posted August 12 Share Posted August 12 7 hours ago, tajvdz said: I finally finished my Sdrive-Max case. I think it turned out very well. Are people interested in the STL file and a short manual on how to add the leds? I would be interested in it. Quote Link to comment Share on other sites More sharing options...
tajvdz Posted August 12 Share Posted August 12 Ok. I didn't print it myself but I can get the modified stl. Will the 2 colors cause problems because not everyone is able to do that? Quote Link to comment Share on other sites More sharing options...
