tjlazer Posted September 6, 2019 Share Posted September 6, 2019 Been having some issues lately with my set up. Tried creating a new ROM and burning to a new 29F040 B chip and I’m getting intermittent issues with corrupt graphics on games and crashing. At first I thought it was my new ROM and maybe the ROM code, but it’s happening with the original EEPROM too. Tried programming the new code to my old chip and it’s still doing the same thing now. Tried making sure that everything is sealed correctly and also replace the RAM chips which didn’t help. (has Rambo 256k upgrade). Anything else I can try? Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted September 6, 2019 Share Posted September 6, 2019 Is the system stable if you replace the original OS ROM chip? How about if you program 1 OS (maybe a Stock Atari OS) to a 27128 EPROM and try that by itself? It is interesting that you say the original 29F040B is causing you grief now. Can you tell me what the speed ratings of both chips are? ie: 29F040B-150, 120, 70 (nanoseconds). My original chip was 120ns, and I'm currenting using a chip rated at 150ns. 70ns "may" be too fast. Lastly, can you confirm the "Chip ID" bytes for each of your chips, as reported by your programmer software. If you're using a MiniPro TL866, it shows here after a read or clicking the "ID" button: Counterfeit chips may add confusion, as the indicators on the chip may not match what the chip identifies itself as internally... Quote Link to comment Share on other sites More sharing options...
BillC Posted September 6, 2019 Share Posted September 6, 2019 Have you checked the power supply? The voltage could be marginally high/low, or perhaps has some AC ripple, which is making the system unstable. Quote Link to comment Share on other sites More sharing options...
tjlazer Posted September 7, 2019 Author Share Posted September 7, 2019 Here’s what it can look like. When I change ROMs it can go away, but then returns later or the next day. Haven’t tried the power supply, I can try another one. Quote Link to comment Share on other sites More sharing options...
tjlazer Posted September 7, 2019 Author Share Posted September 7, 2019 I then changed the ROM to the stock rev C and it’s fine now... but it will return later or on a cold boot. Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted September 7, 2019 Share Posted September 7, 2019 39 minutes ago, tjlazer said: I then changed the ROM to the stock rev C and it’s fine now... but it will return later or on a cold boot. Can you clarify if "stock rev C" is via an actual original Atari OS ROM chip, or are you just changing the OS selection in your 32-in-1? Quote Link to comment Share on other sites More sharing options...
Rybags Posted September 7, 2019 Share Posted September 7, 2019 Maybe a bad flash chip? When mine was installed I experienced the Phi2 problem which caused graphical glitches but when they occur it's usually fairly consistent around the text screen and wasn't causing crashes. Or maybe not mounted quite right in the OS socket, and heat expansion causing the problem to occur some time after startup. Quote Link to comment Share on other sites More sharing options...
tjlazer Posted September 8, 2019 Author Share Posted September 8, 2019 Can you clarify if "stock rev C" is via an actual original Atari OS ROM chip, or are you just changing the OS selection in your 32-in-1?On the 32-in-1. I don’t have the original ROM on this one, I can try to install the rev 10 from my other machine if it’ll fit without uninstalling the 32-in-1. Can I just remove this from the socket and put the old Ron’s in? Aren’t they 2 chips? Quote Link to comment Share on other sites More sharing options...
Rybags Posted September 8, 2019 Share Posted September 8, 2019 Only 400, 800 and 1200XL have the OS on multiple chips - 2 for the 1200XL and 3 for the original 8-bits. The second smaller IC near the OS on XL/XE is the Basic Rom. XEGS has a single 32K which contains the OS as well as Basic + Missile Command. 1 Quote Link to comment Share on other sites More sharing options...
tjlazer Posted September 8, 2019 Author Share Posted September 8, 2019 Tried it this morning and corrupt graphics again. So frustrating. I’ll try to put in stock 1200XL ROMs and see if that persists Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted September 8, 2019 Share Posted September 8, 2019 If you're using a 32-in-1 in a 1200XL your machine would have had the modifications done to allow use of a single 16KB 28-pin OS ROM in 1 socket, instead of 2 8KB OS ROM's as would be the case for a stock machine. Test with an OS ROM chip from any other model XL or XE, or program a stock XL/XE OS to a 27c128 EPROM, which is a drop-in replacement. Edit: or do you mean you already have a stock 1200XL OS on an EPROM? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 8, 2019 Share Posted September 8, 2019 concerning, make one wonder if the 1200XL modification was done with the extra bits that come with it when selecting the 32 in 1... time for pictures maybe? Quote Link to comment Share on other sites More sharing options...
Sugarland Posted September 9, 2019 Share Posted September 9, 2019 My guesses would be power supply over/under voltage, GTIA, timing chip (74F08N) if it's locking up, CPU, Antic. Quote Link to comment Share on other sites More sharing options...
tjlazer Posted September 9, 2019 Author Share Posted September 9, 2019 Ok some more troubleshooting to see if there is a pattern. There seems to be. On a cold boot I get really bad corrupt graphics on Temple of Apshai Trilogy. On a reboot, less corrupt graphics, then on the 3rd reboot it’s fine! Seems to do this every time. Weird. What I was doing before was changing Roms (in the 32-in-1 menu), or changing flash chips. And it would then work. So it seems the system needs to warm up to work correctly. Quote Link to comment Share on other sites More sharing options...
tjlazer Posted September 9, 2019 Author Share Posted September 9, 2019 If you're using a 32-in-1 in a 1200XL your machine would have had the modifications done to allow use of a single 16KB 28-pin OS ROM in 1 socket, instead of 2 8KB OS ROM's as would be the case for a stock machine. Test with an OS ROM chip from any other model XL or XE, or program a stock XL/XE OS to a 27c128 EPROM, which is a drop-in replacement. Edit: or do you mean you already have a stock 1200XL OS on an EPROM?Ok that’s good news as I can program a 27c128 or 256. And yes I also have the old 2 chip Rev 10 1200XL OS from upgrading my other 1200XL to rev 11. Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted September 9, 2019 Share Posted September 9, 2019 1 minute ago, tjlazer said: Ok that’s good news as I can program a 27c128 or 256. And yes I also have the old 2 chip Rev 10 1200XL OS from upgrading my other 1200XL to rev 11. If you program a 256, repeat/append the same 16KB twice (for 32KB programmed) 1 Quote Link to comment Share on other sites More sharing options...
tjlazer Posted September 9, 2019 Author Share Posted September 9, 2019 If you program a 256, repeat/append the same 16KB twice (for 32KB programmed)I’ll burn that new patched XE OS onto a chip and test it. Might also burn one and put it into my 130XE. Does that also take a 27c128? Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted September 9, 2019 Share Posted September 9, 2019 1 minute ago, tjlazer said: I’ll burn that new patched XE OS onto a chip and test it. Might also burn one and put it into my 130XE. Does that also take a 27c128? Yep. 27c128 will work in any stock XL or XE except 1200XL. Quote Link to comment Share on other sites More sharing options...
scotty Posted September 11, 2019 Share Posted September 11, 2019 Where is the 'hidden' configurator to make your own image on AtariMax? I can not find it anywhere. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted September 11, 2019 Share Posted September 11, 2019 http://www.atarimax.com/warpos/configurator/ Needs a User and Password..Just Ask Steve 1 Quote Link to comment Share on other sites More sharing options...
scotty Posted September 11, 2019 Share Posted September 11, 2019 Will he give me one without buying the 32-in-1 first? Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted September 11, 2019 Share Posted September 11, 2019 Pass, a small amount of white lie maybe needed 1 Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted September 21, 2019 Share Posted September 21, 2019 @tjlazer did you ever get a chance to see the chip ID of your existing 29F040B's as they are reported from your programmer? Quote Link to comment Share on other sites More sharing options...
tjlazer Posted September 21, 2019 Author Share Posted September 21, 2019 (edited) 6 minutes ago, Nezgar said: @tjlazer did you ever get a chance to see the chip ID of your existing 29F040B's as they are reported from your programmer? Yeah here it is. I found two non B variants on eBay and ordered them! I'll let you know if I have any luck with them. Edited September 21, 2019 by tjlazer Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted September 21, 2019 Share Posted September 21, 2019 3 hours ago, tjlazer said: Yeah here it is. I found two non B variants on eBay and ordered them! I'll let you know if I have any luck with them. Alright, "01A4" matches an AMD Am29F040-90JC & AMD Am29F040B-150JC I have - both identify with the same ID and work fine in the 32-in-1. So, if yours is a fake, its not blatant at least... One AMD AM29F040B-120JC I bought from eBay/China identified itself with Chip ID "20E3" - with some searching I found was really an ST M29W040B, which was rated for 3.3V, not 5.0V! So the top labelling would have been re-printed... yeesh Quote Link to comment Share on other sites More sharing options...
