Mathy Posted October 23, 2023 Share Posted October 23, 2023 Hello MrFish But it might also send out an email to an address that is no longer used by Bernard. No sure if his relatives get to see those. I personally wouldn't like it if a deceased relative still receives mails. And if the mail address is cancelled, Albert might get a notice saying so. Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
+MrFish Posted October 23, 2023 Share Posted October 23, 2023 11 minutes ago, Mathy said: No sure if his relatives get to see those. I personally wouldn't like it if a deceased relative still receives mails. I think you're being a little too sensitive. I have no reason to do it often; an email or two once every 10 years shouldn't cause any distress. Like I said, my primary reason for tagging him isn't the notification function; that just happens to be a side effect in this case. I used it for the reasons stated above; and this is something I commonly do for users here. So, it has purposes beyond notifications, and I like to utilize those. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted October 23, 2023 Share Posted October 23, 2023 dec'd should have mail off after a period of time like on most other forums. I see both points but these things should be non issues if the forum here handled it like most others, everything would still be there, the mail would stop after a period of time and a stamp letting you know they passed on would be on the account still able to be tagged and referred to. Quote Link to comment Share on other sites More sharing options...
rdefabri Posted November 8, 2023 Share Posted November 8, 2023 I am working on an RMT project that attempts to create a distortion guitar sound. I say "attempts" because I'm not particularly good at editing instruments in RMT, and the results are mixed. I will post the project when done, it was a significant effort as I transcribed nearly every instrument as close to the original song as I could. That being said, I've hit kind of a block. The song has a guitar solo that would include bending strings. I'm using a guitar sound that uses channels 1+3, which affects the output considerably, at least in RMT 1.34. When I try to use the note tables, it sounds all corrupted, not so great. I'm looking for something like what @VinsCool got in Flourishing Falls. Although that's more of a "flute" type sound, it's about what I need. Any help is appreciated! Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 8 Author Share Posted March 8 On 11/8/2023 at 4:06 PM, rdefabri said: I am working on an RMT project that attempts to create a distortion guitar sound. I say "attempts" because I'm not particularly good at editing instruments in RMT, and the results are mixed. I will post the project when done, it was a significant effort as I transcribed nearly every instrument as close to the original song as I could. That being said, I've hit kind of a block. The song has a guitar solo that would include bending strings. I'm using a guitar sound that uses channels 1+3, which affects the output considerably, at least in RMT 1.34. When I try to use the note tables, it sounds all corrupted, not so great. I'm looking for something like what @VinsCool got in Flourishing Falls. Although that's more of a "flute" type sound, it's about what I need. Any help is appreciated! A couple of caveats here: The RMT emulation in sa_pokey.dll is dodgy and not to be trusted. I think @VinsCool was working on a project to enable these custom modes into RMT. Also, the distorted guitar sounds I used in odyssey do not lend themselves naturally to pitch bending, because the modulation frequency on each note is not exactly linear. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 13 Author Share Posted March 13 (edited) Back at it again ... found a new setting that was documented by the late @analmux: AUDCTL=$60 (1.79 on 1 and 3) Play $AF on first and third channel The idea is, by setting maximum volume ($AF) on first and third channels, the clipping makes a resonant frequency of a NES type triangle wave. The note table used is identical to the "croissant" wave AUDCTL=$64 setting and the same caution applies: Lower frequencies (beginning at $40) will introduce a high pitched whine as the source frequencies come down into the audible range. I will try a test tune. Edited March 13 by Synthpopalooza 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 13 Author Share Posted March 13 Here's a test. AUDCTL=$60 00 and 02: $AF (1.79 mhz) 01 and 03: $A3 (standard square wave) The ultrasonic frequencies at max volume make the triangle wave. There are several problems with this technique: The resultant triangle wave is quiet, so the volume of other tracks must be lowered. Frequencies below $40 introduce a high pitched artifact Frequencies above c6 are out of tune, meaning you have a 1 1/2 octave range that can be effectively used. Binaries attached plus a note table. The note table varies the two frequencies in 0 and 2 off by one step. The table used for the "croissant" wave (AUDCTL=$64) is better in tune but not an option here as it dips into frequencies below $40 to make the notes in tune, and introduces the high pitched whine. dk-title.asm dk-title.s dk-title.xex AUDCTL=$64 AUDC1=$AX AUDC3=$00 optimal.txt 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 14 Author Share Posted March 14 Other possibilities in this setting: Using double POKEY, setting up a 1.79 mhz channel on the first channel each POKEY, then having the third channel each POKEY add a harmonic, or turn on the filter for each channel. It would require downmixing to mono from stereo but might produce interesting results Quote Link to comment Share on other sites More sharing options...
+Stephen Posted March 14 Share Posted March 14 20 hours ago, Synthpopalooza said: Here's a test. Interesting sounds, but the high pitch noise and clicking/popping pretty much make it unusable. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 14 Author Share Posted March 14 Also, the restrictive octave range as well. Quote Link to comment Share on other sites More sharing options...
+MrFish Posted March 14 Share Posted March 14 All the quick sound effects seem to work fine though. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 16 Author Share Posted March 16 I may try another tune with it ... and also some double POKEY stuff to see what else may be possible. The Ms Pac Man opening may suit. 1 Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted March 16 Share Posted March 16 On 3/14/2024 at 12:43 AM, Synthpopalooza said: The ultrasonic frequencies at max volume make the triangle wave. Actually it's sine: 1 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted March 27 Author Share Posted March 27 So, in addition to my game projects, I am taking little bites out of documenting the SKCTL=$8B AUDCTL=$41 Distortion $4x settings at 15 khz. The major table is of course the ones where AUDF1 is not a mod 5 or 15. This has enough guitar sounds to where dozens of timbres (and note tables) are possible, and the octave range for such will reach into the 5th octave without tuning errors. Once I have this table, I'll write a utility in TurboBASIC that will let you build your own note tables from the listed frequencies. This should be fun. Once built, thanks to @VinsCool, they can be hacked into RMT, hopefully. Other tables are: AUDF1 is mod 5. This is the "Fuzzy C" setting, where C distortion frequencies are played in channel 2, and the mod 15 frequency in 1 introduces a fuzzbox AUDF2 is mod 5. Distorted guitars which will hit intermittently depending on polycounters AUDF1 is mod 15. Alien crunch sound fx After that, the same must be done to the equivalent setting in AUDCTL=$40 (i.e. standard 64khz clock). I think once I have both these in the bag, I will write out an extensive doc which documents the various tables in these settings and how to use them. 1 Quote Link to comment Share on other sites More sharing options...
