keithbk Posted October 16, 2019 Share Posted October 16, 2019 (edited) Back in 2011, Nukey had worked up an idea I had for a possible future Adventure-style game that included the concept of an "overhead" game map. In this version, just south of the gold castle, was a teleport that would take you to a map that would transport you to other areas. Conceptually, I was playing around at developing a multi-region environment (a complete game world), but I never completed my work on the project and the project languished in developmental oblivion. So, here's the code for you to play with. You can test this code online at 8bitworkshop: https://8bitworkshop.com/v3.4.2/?file=examples%2Fhello.a&platform=vcs This is pretty much Nukey's code, and he may have published it elsewhere, but in the off chance he did not, someone should have the benefit of learning from it: ;ADVENTURE: 8K/16K/32K multicolor sprite & playfield hack by Kurt (Nukey Shay) Howe, 3/09/2011 ;Test options... TEST_MAP = 1 IGNORE_WALLS = 0 ;1 = player can move any direction through walls IGNORE_DOT = 0 ;1 = allow passage through right panels without dot or objects IGNORE_LEFT_PANELS = 0 ;1 = allow passage through left panels TEST_SEED = 0 ;1 = check the random generator...uses next constant as seed value SEED = $0F ;value $0F should produce a game that only has bat & magnet present ;Size of binary to produce... BANKS = 0 ;0 = 8K (F8), 1 = 16K (F6), 2 = 32K (F4) ;Region options... PAL = 0 ; 0 = Use NTSC color palette, 1 = Use PAL color palette PAL50 = 0 ; 0 = Display 262 scanlines @60hz, 1 = Display 312 scanlines 50hz ;Randomization options... FIX_RANDOM = 0 ;1 = regroup castle interiors to end of list RANDOM_XY = 1 ;1 = alter starting X/Y of game objects in random game selection(s) ;Gameplay options... ANIMATE_DRAGON = 0 ;1 = use 2 frames for roaming dragon FLIP_DRAGONS = 1 ;1 = have dragons face the player when chasing ROTATING_SWORD = 1 ;1 = move sword around player as it's carried BAT_REVIVES_DRAGONS = 0 ;1 = dead dragon will be alive again if bat picks it up EDGE_PANELS = 1 ;1 = place panels closer to the screen border BW_PAUSE = 1 ;1 = allow B&W switch to pause gameplay indefinately NO_TRAP = 0 ;1 = impossible to intentionally lock keys in their own castles MERGE_STICKS = 1 ;0 = left stick only, 1 = use either stick ;Game kernel options... COLOR_DELIMITER = 0 ;constant, signifies end of bitmap...must be zero USE_TITLE_DISPLAY = 1 ;1 = use a special screen for game selection TITLE_BANK = 0 ;Bank number if the above is used (just put Titlescreen anywhere) MAP_BANK = 0 ;Bank number if the above is used (just put Titlescreen anywhere) MONOCOLOR = 1 ;set to 1 if any bank uses the monocolor playfield kernel MULTICOLOR = 0 ;set to 1 if any bank uses the multicolor playfield kernel USE_UNIQUE_BACKGROUND_COLORS = 0 ;1 = use seperate colors for each screen's background (floor) FLASH_WALLS = 1 ;set to 1 if winning flashes the playfield FLASH_GROUND = 0 ;set to 1 if winning flashes the background SIMULATE_CHALISE_FLASH = 1 ;1 = use multiple states for the chalise UNROLL_SUBS = 1 ;set to 1 to avoid collision subroutines (costs romspace in last bank) UNROLL_POSITIONING = 1 ;set to 1 to avoid sprite repositioning as a subroutine (costs rom) IF PAL50 TIME1 = $3F TIME2 = $4F ONE_PIXEL = $01 TWO_PIXELS = $03 THREE_PIXELS = $04 ELSE TIME1 = $20 TIME2 = $32 ONE_PIXEL = $01 TWO_PIXELS = $02 THREE_PIXELS = $03 ENDIF processor 6502 ;2600's hardware equates... VSYNC = $00 VBLANK = $01 WSYNC = $02 NUSIZ0 = $04 NUSIZ1 = $05 COLUP0 = $06 COLUP1 = $07 COLUPF = $08 COLUBK = $09 CTRLPF = $0A REFP0 = $0B REFP1 = $0C PF0 = $0D PF1 = $0E PF2 = $0F RESP0 = $10 RESP1 = $11 RESBL = $14 AUDC0 = $15 AUDC1 = $16 AUDF0 = $17 AUDF1 = $18 AUDV0 = $19 AUDV1 = $1A GRP0 = $1B GRP1 = $1C ENAM0 = $1D ENAM1 = $1E ENABL = $1F HMP0 = $20 HMP1 = $21 HMBL = $24 VDELBL = $27 HMOVE = $2A HMCLR = $2B CXCLR = $2C Waste2 = $2E ; invalid ram location used to waste cycles CXP0FB = $32 ; Player0 - Ball collisions CXP1FB = $33 ; Player1 - Ball collisions CXM0FB = $34 ; Missile0 - Ball collisions CXM1FB = $35 ; Missile1 - Ball collisions CXBLPF = $36 ; Ball - Playfield collisions CXPPMM = $37 ; Player0 - Player1 collisions INPT4 = $3C ; Left joystick trigger INPT5 = $3D ; Right joystick trigger SWCHA = $0280 ; Joystick direction SWCHB = $0282 ; Console switches INTIM = $0284 TIM64T = $0296 SEG.U variables ORG $80 ;game engine variables... Obj1Lo DS 2 ; Indirect pointer of object 1...must remain unchanged between frames Obj1Hi = Obj1Lo+1 Obj2Lo DS 2 ; Indirect pointer of object 2...must remain unchanged between frames Obj2Hi = Obj2Lo+1 Obj1Y DS 1 ; Vertical position of object 1 (must remain unchanged for 3 frames) Obj2Y DS 1 ; Vertical position of object 2 (must remain unchanged for 3 frames) NoteCnt DS 7 ; Game Reset restores these 7 bytes in a loop. PlayerRoom = NoteCnt+1 ; Current display variables PlayerX = NoteCnt+2 PlayerY = NoteCnt+3 PrevRoom = NoteCnt+4 ; Previous display variables (needed for post-collision corrections) PrevX = NoteCnt+5 PrevY = NoteCnt+6 CurrentObject DS 4 ; This must be 4 consecutive bytes CurrentStick DS 1 ; Upper nybble = stick, bit2 = B&W toggle, bit 0/1,3 = console switch LastObj DS 1 ; Pointer to the list of printable objects (unsharable) ObjDir DS 1 ; Current direction of player/AI object being dealt with ObjAddress DS 1 ; Current object's dynamic data pointer...also used as portcullis number ObjLst DS 2 ; Used as an indirect pointer Delta2 DS 2 ; Delta2 & 1 also used as the indirect ball sprite pointer Delta1 = Delta2+1 ObjCr DS 1 ; Sharable...used to match current object Level DS 1 ; Bit0 = console type, bit3-1 = game selection, upper nybble = game sound Control DS 1 ; Bit7=inactive game, bits6-0 = room # backup (for printing) Index1 DS 1 ; Object # of "liked" object (sharable?) LoCnt DS 1 ; Bumped once after 3 display frames (rollover @ 768/60 = 12.8 seconds) HiCnt DS 1 ; Bumped upon LoCnt rollover. When high bit set, "attract mode" is enabled ; Bit0 of HiCnt = flag to display game select screen ObjectNumber DS 1 ; Current object # of sprite being dealt with Temp DS 1 ; General purpose ram CarriedObj DS 3 ; All 3 must be consecutive CarriedX = CarriedObj+1 CarriedY = CarriedObj+2 ;Object variables... SurroundR DS 3 ;(3 bytes) MapPortR DS 3 ;(3 bytes) DotR DS 3 ;(3 bytes) NOTE: should be the first movable object in RAM ;NOTE: all dragons must be consecutive RDragonR DS 5 ;(5 bytes) YDragonR DS 5 ;(5 bytes) GDragonR DS 5 ;(5 bytes) MagnetR DS 3 ;(3 bytes) SwordR DS 3 ;(3 bytes) ChalliseR DS 3 ;(3 bytes) BridgeR DS 3 ;(3 bytes) ;NOTE: all keys must be consecutive YKeyR DS 3 ;(3 bytes) WKeyR DS 3 ;(3 bytes) BKeyR DS 3 ;(3 bytes) ;NOTE: all gates must be consecutive YGateR DS 1 WGateR DS 1 BGateR DS 1 BatR DS 6 ;(6 bytes) IF ROTATING_SWORD SwordState DS 1 ;sword rotation ENDIF ;------------------------------------------------------------------------------- ;Ram locations D8-FB free (FC/FF used by the stack...subroutines nested 2 levels) ;------------------------------------------------------------------------------- ;Shared variables used in the kernel (sharing temp ram used by the main program) RoomDefIndex = ObjCr RoomLo = ObjLst ; RoomLo/Hi pushed to the stack prior to kernel execution, & pulled RoomHi = ObjLst+1 ; Back when returning (leaves a 2-byte margin for nesting subs) PixelCount = CurrentObject+1 NextPF0 = ObjAddress NextPF1 = Temp NextPF2 = CurrentObject NextCount = ObjDir NextCOLUPF = ObjectNumber Ball = Delta2 ;Shared variables used by the main program: NullR = BridgeR Sound = Level ;Upper nybble of the Level variable ObjX = Delta2 ;Used only during object setup MagSave = Delta1 ;Used for saving/restoring magnet Y position in it's subroutine BatStateBackup = Obj2Hi ;Constants... ;Object numbers...these are used to calculate the offsets of the object table ;"Passthru" objects... NullNumber = NullData - Object_Data_LSB ;($00) SurroundNumber = SurroundData - Object_Data_LSB ;($12) LastPassNumber = SurroundNumber ;(last object that allows you to walk into w/no collision!) MapPortNumber = MapPortData - Object_Data_LSB ; ;"Solid" objects... YGateNumber = YGateData - Object_Data_LSB ;($01) WGateNumber = WGateData - Object_Data_LSB ;($02) BGateNumber = BGateData - Object_Data_LSB ;($03) AuthorNumber = AuthorData - Object_Data_LSB ;($04) IF USE_TITLE_DISPLAY = 0 ;seperate level-select screen doesn't use the number tokens NumberNumber = NumberData - Object_Data_LSB ;($05) ENDIF RDragonNumber = RDragonData - Object_Data_LSB ;($06) YDragonNumber = YDragonData - Object_Data_LSB ;($07) GDragonNumber = GDragonData - Object_Data_LSB ;($08) SwordNumber = SwordData - Object_Data_LSB ;($09) BridgeNumber = BridgeData - Object_Data_LSB ;($0A) YKeyNumber = YKeyData - Object_Data_LSB ;($0B) WKeyNumber = WKeyData - Object_Data_LSB ;($0C) BKeyNumber = BKeyData - Object_Data_LSB ;($0D) BatNumber = BatData - Object_Data_LSB ;($0E) DotNumber = DotData - Object_Data_LSB ;($0F) ChalliseNumber = ChalliseData - Object_Data_LSB ;($10) MagnetNumber = MagnetData - Object_Data_LSB ;($11) LastObjectNumber = MagnetNumber ;RD0 used to calculate map direction value when including differences RD0 = Level1Diffs - $80 ;the number of castle gates... Gates = $02 ;# of castle gates - 1 ;Winning game screen (where to bring the challise) WinRoom = <(Rm12-Rm00) ;(Yellow Castle's room number) ;Game setup... ByteNum = Game2Objects - (Game1Objects+1) ;number of bytes in each "fill" table RndNum = Object_Map_Tbl-(Room_Bounds_Tbl+3) ; offset value for the room bounds table RndMax = $1F ;Mask for the upper bounds of the random seed ;NOTE: to allow objects to be placed in more than 32 rooms, alter this to be $3F for a maximum ; of 64 rooms, or $7F for a maximum of 128 rooms. Using $FF for 256 rooms is possible ; only if the RoomDiffs method is altered or removed. ;height of magnet object (used to adjust attracted object) MAGNET_HEIGHT = (GfxMagnetEnd - GfxMagnet)/2 ;alternate use of room GFX pointer MSB's upper 3 bits... BANK0 = %00000000 ; room gfx exists in first bank (irrelevant for 8K) BANK1 = %00100000 ; room gfx exists in second bank (irrelevant for 8K) BANK2 = %01000000 ; room gfx exists in third bank (irrelevant for 8K) IF BANKS = 2 BANK3 = %01100000 ; room gfx exists in fourth bank (irrelevant for 8K/16K) BANK4 = %10000000 ; room gfx exists in fifth bank (irrelevant for 8K/16K) BANK5 = %10100000 ; room gfx exists in sixth bank (irrelevant for 8K/16K) BANK6 = %11000000 ; room gfx exists in seventh bank (irrelevant for 8K/16K) ELSE BANK3 = %00000000 ; force invalid banks to be first bank BANK4 = %00000000 ; . BANK5 = %00000000 ; . BANK6 = %00000000 ; . ENDIF SURROUND = %00010000 ; display the "surround" sprite. Playfield priority is suggested ;Used to merge sprite size with MSB table... SIZE0 = %00000000 ;1x width SIZE1 = %00100000 ;Two copies-close SIZE2 = %01000000 ;Two copies-medium SIZE3 = %01100000 ;Three copies-close SIZE4 = %10000000 ;Two copies-wide SIZE5 = %10100000 ;2x width SIZE6 = %11000000 ;Three copies-medium SIZE7 = %11100000 ;4x width ;set value to use in bankswitch AND# instruction IF BANKS BANK_SELECT = (BANKS * 2)-1 ;16K = 3, 32K = 7 ELSE BANK_SELECT = 0 ;8K = 0 ENDIF ;low nybble of PF0 data... REV = %0001 ; bit position to (R)everse playfield LP = %0010 ; bit position to activate left-hand panels (missile0) HIDE = %0100 ; bit position to give playfield priority (i.e. hide sprite objects) RP = %1000 ; bit position to activate right-hand panels (missile1) ;This section defines the display kernel and object bitmaps that remain the same in all three ;display banks. If you want an object to differ in appearance depending on which bank you are ;in, it would be necessary to remove it from the macro and have the bitmap present in any bank ;that it is allowed to appear in AT THE SAME ADDRESS in each bank. ; If you have no clue about what this means, just add your object bitmaps *in* the ; Object_Bitmaps macro (i.e. above the ENDM line), and keep your room GFX *out of* the macro. ; ;Using multicolor sprite objects: ; Sprite definitions must begin with a zero value (to handle cases where the object is not ; at the top of the screen). The color value immediately following this zero value does ; not matter...as long as it's not zero (if color = zero, end of bitmap reached). If the ; black color is needed anywhere in the sprite, just use value $01. Also, because the loop ; always draws sprite info no matter what, the bitmap value immediately preceding the zero ; color must be zero as well (to erase the sprite when the drawing has finished). ; Because the sprite definition MUST begin with zero, and MUST end with zero, you could ; run one bitmap directly into another using a single zero value both as the end of the ; first bitmap, and the beginning gfx of the next. See the dot bitmap below for an example ; of running sprites together to save 1 byte for each case. ; The "Null" object needs no bitmap values...and can be located at any double-zero data. ; Sprite objects are allowed to extend right to the end of a page (i.e. Delimiter placed ; at $xxFF)...but any single sprite definition must not cross any page boundries. ; ;ROOM GRAPHICS DATA DESCRIPTION - ; Monocolor_Display_Kernel2 uses this data layout for each band of playfield graphics: ; .byte PF0|CTRL,PF1,PF2,LINES ;4 bytes per band ; Multicolor_Display_Kernel2 uses this data layout for each band of playfield graphics: ; .byte COLOR,PF0|CTRL,PF1,PF2,LINES,{2nd color, 3rd color, etc} ;5+ bytes per band ; The intro color value must be an even value (bit0 = off), but any additional color ; values for that band of gfx must be an odd value (bit0 = on). ; ; Caching / Page crossing of PF data: ; Before display, room data is cached in temp memory (this does not rob from available ; user ram), so that it is accessed much quicker when actually needed. ; ; Monocolor_Display_Kernel2 will automatically adjust room pointers to next page should ; the caching routine notice that less than 4 bytes currently exist before an upcoming ; page break...and will skip 3, 2, or 1 bytes accordingly ; ; Multicolor_Display_Kernel2 will also adjust pointers for page breaks...but ONLY when ; the routine is updating the current band's color (so you should align data so that page ; breaks only happen between full definition lines...and set bit0 in remaining bytes). ; Take note that the rest of the caching routine is SKIPPED when a band's color is being ; adjusted, so the number of times you can REcolor a band is limited to LINES-2 (the ; initial color being set by the first byte, and a 1-scanline margin to allow caching of ; the next band. ; ; Playfield control: ; The high nybble of the first byte in each band is the bitpattern used for PF0 gfx ; Lower nybble description: ; "REV" Bit0 (+$01) true if (R)eversed playfield ; "LP" Bit1 (+$02) true if left panel wanted ; "HIDE" Bit2 (+$04) true if playfield has priority over sprites (dark rooms, hide sprites) ; "RP" Bit3 (+$08) true if right panel wanted ; ; NOTE: ; In 16/32k build, you can use differing kernels depending on how you want the gfx displayed ; for room definitions present in that bank - cycle timing is identical leading into and out ; of either kernel back to the main program. Any sprite definitions confined to those rooms ; must at least be present in the bank where the room graphics exists (i.e. free-roaming or ; carriable sprites should probably be present in all banks...but the number tokens and the ; author signature sprites need only be present in banks that include the game-select and ; signature rooms...respectively). Similarly, the "surround" sprite must be present in any ; bank that features "dark" rooms...but not needed in any bank that has no dark rooms. This ; strategy saves space in any bank that does not call for such objects to be present. To do ; this with any sprite object, just remove it from the Object_Bitmaps macro and paste it ; directly into one of the banks/pages below. ; ; Ball enable: ; To save time, the ball is updated by using the current scanline count as an indirect ; pointer to a large, 201-byte display table. This table's values are currently only using ; bit1...and can be shared with other data that does not need that bit. The table can be ; relocated if desired...although as with any other sprite data, it must not cross a page ; boundry. To relocate, just remove the Ball_Enable_Table macro call from the end of bank ; data (and move the tag BallGFX wherever you want). In this way, you can save 201 bytes in ; each bank if you have at least that number of consecutive bytes with bit1 unused in movable ; object sprite data. Keep in mind that a 4-byte stretch must have bit1 enabled at 93 bytes ; into the table, with all the rest turned off. SEG Macros MAC CHECKPAGE IF >. != >{1} ECHO "" ECHO "ERROR: different pages! (", {1}, ",", ., ")" ECHO "" ERR ENDIF ENDM MAC Monocolor_Display_Kernel2 IF BANKS = 2 lda $FFFB ;4 jmp StartGame ;3 Go to cold start routine in last bank IF USE_TITLE_DISPLAY TitleDone: ;65 lda $FFFB ;4 69 Select last bank jmp TitleKernel ;3 MapDone: ;65 lda $FFFB ;4 69 Select last bank jmp MapKernel ;3 ENDIF KernelDone: ;55 lda $FFFB ;4 59 Select last bank ELSE lda $FFF9 ;4 jmp StartGame ;3 Go to cold start routine in last bank IF USE_TITLE_DISPLAY TitleDone: ;65 lda $FFF9 ;4 69 Select last bank jmp TitleKernel ;3 MapDone: ;65 lda $FFF9 ;4 69 Select last bank jmp MapKernel ;3 ENDIF KernelDone: ;55 lda $FFF9 ;4 59 Select last bank ENDIF ;47 from other bank... ldy #$00 ;2 48 Set initial room definition index lda (RoomLo),y ;5 53 Get PF0 and control bits for this row sta ENAM0 ;3 56 Enable left hand wall(if wanted-missle00) iny ;2 58 sta PF0 ;3 61 ...And display PF0 and #$0D ;2 63 Keep only low nybble of PF0 ora #$20 ;2 65 Merge in the ball size sta CTRLPF ;3 68 Store to playfield control lsr ;2 70 Roll right panel enable lsr ;2 72 Roll right panel enable sta ENAM1 ;3 76 Carry clear-Enable right hand wall(if wanted-missle01) ;----------------------------------- sty VBLANK ;3 03 Clear any Vertical Blank lda (RoomLo),y ;5 08 Get PF1 definition byte sta PF1 ;3 11 ...And display iny ;2 13 Bump index lda (RoomLo),y ;5 18 Get PF2 definition byte sta PF2 ;3 21 ...And display iny ;2 23 Bump index lda (RoomLo),y ;5 28 Get # of scanlines for this band sta.w PixelCount ;4 32 Store to line counter lda #$04 ;2 34 bne Print_Top_Line ;3 37 Always branch DrawNextPlayfield: ;67 ldy NextPF1 ;3 70 Grab new band data from cache lda NextPF0 ;3 73 . sta ENAM0 ;3 76 Enable left hand wall(if wanted) ;----------------------------------- sta PF0 ;3 03 Transfer cache to playfield registers sty PF1 ;3 06 . and #$0D ;2 08 . ora #$20 ;2 10 . sta CTRLPF ;3 13 . ldy NextPF2 ;3 16 . sty PF2 ;3 19 . lsr ;2 21 . lsr ;2 23 . sta ENAM1 ;3 26 Enable right hand wall(if wanted)...carry is clear now lda NextCount ;3 29 . sta PixelCount ;3 32 Store to line counter lda RoomDefIndex ;3 35 Load room gfx pointer adc #$04 ;2 37 Bump the LSB by 4 bytes Print_Top_Line: ;37 - Carry clear sta RoomDefIndex ;3 40 Update .byte $2C ;4 44 Skip next 2 bytes (BIT.w) SkipPlayfieldUpdate: ;41 - Carry clear sta NextCount ;3 41 Update cache SkipPlayfieldUpdate2: ;44 - Carry clear dex ;2 46 Decrease double-scanline counter txs ;2 48 Save the current scanline counter temporarily txa ;2 50 Flip to A as well to check the ball tay ;2 52 beq KernelDone ;2 54 Branch if display finished lda (Ball),y ;5 59 ldy #$00 ;2 61 sta ENABL ;3 64 Display Ball (If Wanted) lax (Obj1Lo),y ;5 69 Get the next Object1 bitmap value (pass to X) lda (Obj2Lo),y ;5 74 Get the next Object2 bitmap value iny ;2 76 Bump index to load color data ;----------------------------------- stx GRP0 ;3 03 Display both sprite bitmaps sta GRP1 ;3 06 . lda (Obj2Lo),y ;5 11 Get the color info for Object2 sta COLUP1 ;3 14 Recolor Object2 lda (Obj1Lo),y ;5 19 Get the color info for Object1 sta COLUP0 ;3 22 Recolor Object1 beq Waste11 ;2 24 Branch if color = 0 (delimiter) tsx ;2 26 Restore saved scanline counter cpx Obj1Y ;3 29 Have we reached Object1's Y Co-ordinate? bpl Waste4 ;2 31 If not, continue to use first bitmap value (0) lda Obj1Lo ;3 34 (Carry clear) Otherwise, load the LSB adc #$02 ;2 36 ...And bump by 2 for next time sta Obj1Lo ;3 39 Update Object1skipped: ;39 lda (Obj2Lo),y ;5 44 Get the Next Player00 definition byte (give to X) beq Waste11_2 ;2 46 Branch if color = 0 (delimiter) cpx Obj2Y ;3 49 Have we reached Object2's Y Co-ordinate? bpl Waste4_2 ;2 51 If not, continue to use first bitmap value (0) lda Obj2Lo ;3 54 (Carry clear) Otherwise, load the LSB adc #$02 ;2 56 ...And bump by 2 for next time sta Obj2Lo ;3 59 Update Object2skipped: ;59 dec PixelCount ;5 64 Decrement the line counter beq DrawNextPlayfield ;2 66 If more lines remain, branch ldy.w RoomDefIndex ;4 70 Update cache...load current index tya ;2 72 Flip current index to A adc RoomLo ;3 75 ...And add the LSB ;----------------------------------- cmp #$FD ;2 01 Check if less than 4 bytes remain in current page bcs PageUpdate ;2 03 Branch if so (and adjust pointers to next page) lda (RoomLo),y ;5 08 Get PF0 value for next band (if any) sta NextPF0 ;3 11 Update cache iny ;2 13 Bump index lda (RoomLo),y ;5 18 Get PF1 value for next band (if any) sta NextPF1 ;3 21 Update cache iny ;2 23 Bump index lda (RoomLo),y ;5 28 Get PF2 value for next band (if any) sta NextPF2 ;3 31 Update cache iny ;2 33 Bump index lda (RoomLo),y ;5 38 Get # of scanlines for next band (if any) jmp SkipPlayfieldUpdate ;3 41 ...And jump back into the kernel PageUpdate: ;04 ldy #$05 ;2 06 Set to waste 24 cycles inc RoomHi ;5 11 Move pointer to next page WasteLoop: dey ;2 13/18/23/28/33 bne WasteLoop ;2 16/21/27/31/35 sty RoomDefIndex ;3 38 Set both pointers to zero sty RoomLo ;3 41 . beq SkipPlayfieldUpdate2;3 44 Always branch Waste11: ;25 tsx ;2 27 Restore saved scanline counter dec Waste2 ;5 32 Object1 not reached yet...kill time Waste4: ;32 clc ;2 34 Object1 done...kill time clc ;2 36 bcc Object1skipped ;3 39 Always branch Waste11_2: ;47 dec Waste2 ;5 52 Object2 not reached yet...kill time Waste4_2: ;52 clc ;2 54 Object2 done...kill time clc ;2 56 bcc Object2skipped ;3 59 Always branch IF MULTICOLOR ;21-byte difference needed to align following data should both kernels be used .byte "Nukey Shay-03/09/2011" ENDIF ENDM MAC Multicolor_Display_Kernel2 IF BANKS = 2 lda $FFFB ;4 jmp StartGame ;3 Go to cold start routine in last bank IF USE_TITLE_DISPLAY TitleDone: ;65 lda $FFFB ;4 69 Select last bank jmp TitleKernel ;3 MapDone: ;65 lda $FFFB ;4 69 Select last bank jmp MapKernel ;3 ENDIF MKernelDone: ;55 lda $FFFB ;4 59 Select last bank ELSE lda $FFF9 ;4 jmp StartGame ;3 Go to cold start routine in last bank IF USE_TITLE_DISPLAY TitleDone: ;65 lda $FFF9 ;4 69 Select last bank jmp TitleKernel ;3 MapDone: ;65 lda $FFF9 ;4 69 Select last bank jmp MapKernel ;3 ENDIF MKernelDone: ;55 lda $FFF9 ;4 59 Select last bank ENDIF ;47 from other bank... ldy #$05 ;2 50 Set room gfx pointer to 5 bytes in sty RoomDefIndex ;3 53 ...And save for next time ldy #$00 ;2 55 Set initial room definition index lda (RoomLo),y ;5 60 Get color for top band sta COLUPF ;3 63 Display iny ;2 65 Bump index lda (RoomLo),y ;5 70 Get PF0 and control bits for top row sta ENAM0 ;3 73 Enable left hand wall(if wanted-missle00) sta.w PF0 ;4 76 ...And display PF0 ;----------------------------------- sty VBLANK ;3 03 Clear any Vertical Blank iny ;2 05 Bump index and #$0D ;2 07 Keep only low nybble of PF0 ora #$20 ;2 09 Merge in the ball size sta CTRLPF ;3 12 Store to playfield control lsr ;2 14 Roll right panel enable lsr ;2 16 Roll right panel enable sta ENAM1 ;3 19 Enable right hand wall(if wanted-missle01) lda (RoomLo),y ;5 24 Get PF1 of top row sta PF1 ;3 27 ...And display iny ;2 29 Bump index lda (RoomLo),y ;5 34 Get PF2 of top row sta PF2 ;3 37 ...And display iny ;2 39 Bump index lda (RoomLo),y ;5 44 Get # of scanlines for top row jmp MPrint_Top_Line ;3 47 Jump mid-kernel to store MDrawNextPlayfield: ;69 ldy NextPF1 ;3 72 Otherwise, update playfield using cached values lda NextCOLUPF ;3 75 ;----------------------------------- asl ;2 01 . (value was LSR'ed to check for color change) sty PF1 ;3 04 . (carry clear from above) sta COLUPF ;3 07 . lda NextPF0 ;3 10 . sta ENAM0 ;3 13 . Enable left hand wall(if wanted) sta PF0 ;3 16 . and #$0D ;2 18 . ora #$20 ;2 20 . sta CTRLPF ;3 23 . ldy NextPF2 ;3 26 . sty PF2 ;3 29 . lsr ;2 31 . lsr ;2 33 . sta ENAM1 ;3 36 . Enable right hand wall(if wanted)...carry clear now lda RoomDefIndex ;3 39 Get current pointer to room graphics adc #$05 ;2 41 Bump index by 5 bytes for next time sta RoomDefIndex ;3 44 Update lda NextCount ;3 47 Load new line counter from cache MPrint_Top_Line: ;47 sta PixelCount ;3 50 Update line counter MSkipPlayfieldUpdate: ;50 dex ;2 52 Decrease double-scanline counter beq MKernelDone ;2 54 Branch if display finished txa ;2 56 Flip to A as well to set ball display tay ;2 58 lda (Ball),y ;5 63 sta ENABL ;3 66 Display Ball (If Wanted) ldy #$00 ;2 68 Clear Y index lda (Obj1Lo),y ;5 73 Get the next Object1 bitmap value sta GRP0 ;3 76 ...And display ;----------------------------------- lda (Obj2Lo),y ;5 05 Get the next Object2 bitmap value sta GRP1 ;3 08 ...And display iny ;2 10 Bump index lda (Obj2Lo),y ;5 15 Get the color value for Object2 sta COLUP1 ;3 18 Update lda (Obj1Lo),y ;5 23 Get the color value for Object1 sta COLUP0 ;3 26 Update beq MWaste11 ;2 28 Branch if color = 0 (delimiter) cpx Obj1Y ;3 31 Have we reached Object1's Y Co-ordinate? bpl MWaste4 ;2 33 If not, continue to use first bitmap value (0) lda Obj1Lo ;3 36 (Carry clear) Otherwise, load the LSB adc #$02 ;2 38 ...And bump by 2 for next time sta Obj1Lo ;3 41 MObject1skipped: ;41 lda (Obj2Lo),y ;5 46 Get the Next Player00 definition byte (give to X) beq MWaste11_2 ;2 48 Branch if color = 0 (delimiter) cpx Obj2Y ;3 51 Have we reached Object2's Y co-ordinate? bpl MWaste4_2 ;2 53 If not, continue to use first bitmap value (0) lda Obj2Lo ;3 56 (Carry clear) Otherwise, load the LSB adc #$02 ;2 58 ...And bump by 2 for next time sta Obj2Lo ;3 61 MObject2skipped: ;61 dec PixelCount ;5 66 Decrement the line counter beq MDrawNextPlayfield ;2 68 If more lines remain, branch and cache next line ldy RoomDefIndex ;3 71 Get current room definition index lda (RoomLo),y ;5 76 Get color data for next band (if any) ;----------------------------------- iny ;2 02 Bump index lsr ;2 04 Move bit0 to carry to check for a color change bcs MUpdateColorOnly ;2 06 Branch if set (and load next color only) sta NextCOLUPF ;3 09 Otherwise, store (value will be ASL'ed later) lda (RoomLo),y ;5 14 Get PF0 data for next band (if any) sta NextPF0 ;3 17 iny ;2 19 Bump index lda (RoomLo),y ;5 24 Get PF1 data for next band (if any) sta NextPF1 ;3 27 iny ;2 29 Bump index lda (RoomLo),y ;5 34 Get PF2 data for next band (if any) sta NextPF2 ;3 37 iny ;2 39 Bump index lda (RoomLo),y ;5 44 Get # of scanlines for next band (if any) sta NextCount ;3 47 MSkipJmp: jmp MSkipPlayfieldUpdate;3 50 Jump back into the kernel MWaste11: ;29 dec Waste2 ;5 34 Object1 not reached yet...kill time MWaste4: ;34 clc ;2 36 Object1 done...kill time clc ;2 38 bcc MObject1skipped ;3 41 Always branch MWaste11_2: ;49 dec Waste2 ;5 54 Object2 not reached yet...kill time MWaste4_2: ;54 clc ;2 56 Object2 done...kill time clc ;2 58 bcc MObject2skipped ;3 61 Always branch MUpdateColorOnly: ;07 rol ;2 09 sta COLUPF ;3 12 Carry clear, update displayed color tya ;2 14 Check for page break by moving index to A adc RoomLo ;3 17 ...And adding LSB of room pointer bcc MSkipPageUpdate ;2 19 Branch if page not crossed sta RoomDefIndex ;3 22 Otherwise, update the pointers sta RoomLo ;3 25 inc RoomHi ;5 30 ...And bump to next page ldy #$02 ;2 32 Set to waste 9 additional cycles bne MWasteLoop ;3 35 Always branch MSkipPageUpdate: ;20 sty RoomDefIndex ;3 23 If page wasn't crossed, adjust current pointer +1 byte ldy #$04 ;2 25 Set to waste 19 additional cycles MWasteLoop: ;35 dey ;2 27/32/37/42 Kill off remaining cycles bne MWasteLoop ;2 30/35/40/44 beq MSkipJmp ;3 47 Always branch ENDM ;basic level-select screen... MAC Titlescreen ; ALIGN 256,0 TitleKernel: inc LoCnt ;5 Bump low counter to help with random selection later lda Level ;3 Get current level and #$0E ;2 Trim off sound effect and console type bits tay ;2 Pass to Y lda GameNumGFX,y ;4 Get address LSB of GFX to use for this level sta Ball ;3 Pass to ram for later (indirect),y access lda GameNumGFX+1,y ;4 Do the same for it's MSB sta Ball+1 ;3 . ;NOTE: a LOT of time exists before this loop...so you can design any title you want! ; I just used a very basic kernel by setting an indirect address above for the ; level number, and drew block letters using standard PF tables ahead. Title_Wait: ldx INTIM ;4 Wait for end of the current frame bne Title_Wait ;2 . sta WSYNC ;3 Wait for horizontal Blank sta WSYNC ;3 Wait for horizontal Blank ;----------------------------------- stx VBLANK ;3 Clear any Vertical Blank stx COLUBK ;3 Clear background color stx CTRLPF ;3 Set display mode to Mirrored (PF0 PF1 PF2 PF0 PF1 PF2) IF PAL lda #$2A ;2 Gold ELSE lda #$1A ;2 Yellow ENDIF sta COLUPF ;3 Set color of upper text ldy #$04 ;2 Set number of pixels (data bytes) for this block of text DrawTopInit: ;57 ldx #$0F ;2 Set number of scanlines to use for each data line DrawTopLoop: ;53 sta WSYNC ;3 Wait for horizontal Blank lda Top_PF1,y ;4 04 Update PF registers for left half sta PF1 ;3 07 . lda Top_PF2,y ;4 11 . sta PF2 ;3 14 . lda Top_PF0,y ;4 18 . sta PF0 ;3 21 . asl ;2 23 Lower nybble of data contains right side asl ;2 25 . asl ;2 27 . asl ;2 29 . nop ;2 31 Waste 2 more cycles between halves sta PF0 ;3 34 Update PF registers for right half lda Top_PF4,y ;4 38 . sta PF1 ;3 41 . lda Top_PF5,y ;4 45 . sta PF2 ;3 48 . dex ;2 50 Reduce scanline counter bne DrawTopLoop ;2 52 Loop to continue current data if non-zero dey ;2 54 Reduce pixel counter bpl DrawTopInit ;2 56 Loop to read next data if no rollover sta WSYNC ;3 Wait for horizontal Blank IF PAL lda #$4A ;2 Light orange ELSE lda #$3A ;2 Light orange ENDIF sta COLUPF ;3 Set color of lower text stx PF0 ;3 Clear pixel data between text lines stx PF1 ;3 . stx PF2 ;3 . ldx #$07 ;2 Set number of additional scanlines to waste between text DrawGapLoop: sta WSYNC ;3 Wait for horizontal Blank dex ;2 Bump scanline counter bne DrawGapLoop ;2 Loop to waste scanlines ldy #$04 ;2 Set number of pixels (data bytes) for this block of text DrawBottomInit: ;58 ldx #$0F ;2 Set number of scanlines to use for each data line DrawBottomLoop: ;54 sta WSYNC ;3 Wait for horizontal Blank lda Bottom_PF1,y ;4 04 Update PF registers for left half sta PF1 ;3 07 . lda Bottom_PF2,y ;4 11 . sta PF2 ;3 14 . lda Bottom_PF0,y ;4 18 . sta PF0 ;3 21 . asl ;2 23 Lower nybble of data contains right side asl ;2 25 . asl ;2 27 . asl ;2 29 . dex ;2 31 Reduce scanline counter sta PF0 ;3 34 Update PF registers for right half lda Bottom_PF4,y ;4 38 . sta PF1 ;3 41 . lda (Ball),y ;5 46 . sta PF2 ;3 49 . txa ;2 51 Check scanline counter bne DrawBottomLoop ;2 53 Loop to continue current data if non-zero dey ;2 55 Reduce pixel counter bpl DrawBottomInit ;2 57 Loop to read next data if no rollover ldx #$0B ;2 59 Waste 54 add'l cycles before returning to last bank ldy #$20 ;2 61 Set number of scanlines to waste at the bottom WasteLines: sta PF0 ;3 64 Clear PF registers sta PF1 ;3 67 . sta WSYNC ;3 Wait for horizontal Blank sta.w PF2 ;4 04 . dey ;2 06 Bump scanline counter bne WasteLines ;2 08 Loop to waste lines Kill54cycles: dex ;2 10/15/20/25/30/35/40/45/50/55/60 bne Kill54cycles ;2 13/18/23/28/33/38/43/48/53/58/62 jmp TitleDone ;3 Needs to hit @ cycle 65 with X = 0 (the only requirements) ;"ADVENTURE" text Top_PF0: .byte #%10000010 ; Block pixels 5 .byte #%10000010 ; Block pixels 4 .byte #%10000010 ; Block pixels 3 .byte #%10000010 ; Block pixels 2 .byte #%00001001 ; Block pixels 1 Top_PF1: .byte #%01011001 ; Block pixels 5 .byte #%11010101 ; Block pixels 4 .byte #%01010101 ; Block pixels 3 .byte #%01010101 ; Block pixels 2 .byte #%10011001 ; Block pixels 1 Top_PF2: .byte #%10111000 ; Block pixels 5 .byte #%10001001 ; Block pixels 4 .byte #%10011010 ; Block pixels 3 .byte #%10001010 ; Block pixels 2 .byte #%10111010 ; Block pixels 1 Top_PF4: .byte #%10001101 ; Block pixels 5 .byte #%10010101 ; Block pixels 4 .byte #%10010101 ; Block pixels 3 .byte #%10010101 ; Block pixels 2 .byte #%11010101 ; Block pixels 1 Top_PF5: .byte #%00111010 ; Block pixels 5 .byte #%00001001 ; Block pixels 4 .byte #%00011010 ; Block pixels 3 .byte #%00001010 ; Block pixels 2 .byte #%00111001 ; Block pixels 1 ;"GAME#" text Bottom_PF0: .byte #%00001110 ; Block pixels 10 .byte #%10000010 ; Block pixels 9 .byte #%10001110 ; Block pixels 8 .byte #%10000010 ; Block pixels 7 .byte #%00001110 ; Block pixels 6 Bottom_PF1: .byte #%11110100 ; Block pixels 10 .byte #%00010111 ; Block pixels 9 .byte #%01110100 ; Block pixels 8 .byte #%00000010 ; Block pixels 7 .byte #%11110001 ; Block pixels 6 Bottom_PF2: .byte #%10001010 ; Block pixels 10 .byte #%10001011 ; Block pixels 9 .byte #%10101010 ; Block pixels 8 .byte #%11011001 ; Block pixels 7 .byte #%10001000 ; Block pixels 6 Bottom_PF4: .byte #%11001010 ; Block pixels 10 .byte #%00011111 ; Block pixels 9 .byte #%00001010 ; Block pixels 8 .byte #%00011111 ; Block pixels 7 .byte #%11001010 ; Block pixels 6 Bottom_PF5_1: ;"1" text .byte #%00011100 ; Block pixels 10 .byte #%00001000 ; Block pixels 9 .byte #%00001000 ; Block pixels 8 .byte #%00001100 ; Block pixels 7 .byte #%00001000 ; Block pixels 6 Bottom_PF5_2: ;"2" text .byte #%00111110 ; Block pixels 10 .byte #%00000010 ; Block pixels 9 .byte #%00011100 ; Block pixels 8 .byte #%00100000 ; Block pixels 7 .byte #%00011100 ; Block pixels 6 Bottom_PF5_3: ;"3" text .byte #%00011100 ; Block pixels 10 .byte #%00100010 ; Block pixels 9 .byte #%00011000 ; Block pixels 8 .byte #%00100000 ; Block pixels 7 .byte #%00011100 ; Block pixels 6 GameNumGFX: ;add more bitmaps if you increase the number of game variations .word Bottom_PF5_1 ;GFX for level 1 .word Bottom_PF5_2 ; "" level 2 .word Bottom_PF5_3 ; "" level 3 ENDM MAC MapScreen ;NOTE: a LOT of time exists before the INTIM loop...so you can design any map you want! MapKernel: sta WSYNC ;3 Wait for horizontal Blank sta HMOVE ;3 Update dot's position lda #$00 ;2 sta VDELBL ;3 Disable ball delay ldx PlayerX ;3 Deal with moving the small pixel...load current X ldy PlayerY ;3 ...And Y lda SWCHA ;4 Then grab the stick's direction IF MERGE_STICKS asl ;2 Push the right stick high... asl ;2 . asl ;2 . asl ;2 . and SWCHA ;4 ...And mix with the left stick ENDIF asl ;2 Push "right" into carry bcs Not_Mapping_Right ;2 Branch if not moving that direction inx ;2 Otherwise, bump X co-ordinate up by 1 pixel Not_Mapping_Right: asl ;2 Push "left" into carry bcs Not_Mapping_Left ;2 Branch if not moving that direction dex ;2 Otherwise, bump X co-ordinate down by 1 pixel Not_Mapping_Left: asl ;2 Push "down" into carry bcs Not_Mapping_Down ;2 Branch if not moving that direction dey ;2 Otherwise, bump Y co-ordinate down by 1 pixel bne Not_Mapping_Down ;2 Branch if no wraparound ldy #$BD ;2 Or reset Y co-ordinate to top border Not_Mapping_Down: asl ;2 Push "up" into carry bcs Not_Mapping_Up ;2 Branch if not moving that direction iny ;2 Otherwise, bump Y co-ordinate up by 1 pixel cpy #$BE ;2 Check for wraparound bcc Not_Mapping_Up ;2 Branch if none ldy #$01 ;2 Or reset Y co-ordinate to bottom border Not_Mapping_Up: txa ;2 Move horizontal to A and #$7F ;2 Trim upper bit (if present) to handle wraparound Map_Wait: ldx INTIM ;4 Wait for end of the current frame bne Map_Wait ;2 . sta WSYNC ;3 Wait for horizontal Blank ;----------------------------------- stx VBLANK ;3 Clear any Vertical Blank sta PlayerX ;3 Update dot's co-ordinates sty PlayerY ;3 . stx PF0 ;3 Clear any PF graphics stx PF1 ;3 . stx PF2 ;3 . stx COLUBK ;3 Black background stx REFP0 ;3 Clear any sprite reflect stx REFP1 ;3 . stx CTRLPF ;3 Set ball = small stx Temp ;3 Set temporary collisions to none ($00) dex ;2 stx COLUPF ;3 Give a color to the ball lda #$04 ;2 Set sprite positions to 2 wide copies sta NUSIZ0 ;3 Update sprite control sta NUSIZ1 ;3 . sta CXCLR ;3 Clear previous collisions sta HMCLR ;3 ...And horizontal motion sta HMP0 ;3 Update new positions for the icons lda #$10 ;2 . sta HMP1 ;3 . sta RESP0 ;3 Update sprite horizontal locations sta RESP1 ;3 . ldx #$BD ;2 Set total number of scanlines to draw Above_Map_Screen: sta WSYNC ;3 Wait for horizontal Blank ;----------------------------------- sta HMOVE ;3 03 Move icons to their proper spots cpx PlayerY ;3 06 Check player's vertical location php ;3 09 . pla ;4 13 . sta ENABL ;3 16 ...By using carry status dex ;2 18 Bump scanline count dec Waste2 ;5 23 (Waste a little time for upcoming HMCLR) cpx #$A0 ;2 25 Is the upper blank area finished? sta HMCLR ;3 28 bcs Above_Map_Screen ;2 30 Branch if not ldy #$0F ;2 32 Set the top area icon height Map_Screen_Top: ;58 cpx PlayerY ;3 61 Check player's vertical location php ;3 64 . pla ;4 68 . sta WSYNC ;3 Wait for horizontal Blank ;----------------------------------- sta ENABL ;3 03 ...By using carry status lda AreaT1gfx,y ;4 07 Update the gfx for the left icon sta GRP0 ;3 10 . lda AreaT2gfx,y ;4 14 . sta GRP1 ;3 17 . lda AreaT1color,y ;4 21 . sta COLUP0 ;3 24 . sta COLUP1 ;3 27 . dex ;2 29 Bump scanline count lda AreaT3gfx,y ;4 33 Then update the gfx for the right icon sta GRP0 ;3 36 . lda AreaT4gfx,y ;4 40 . sta GRP1 ;3 43 . lda AreaT2color,y ;4 47 . sta COLUP0 ;3 50 . sta COLUP1 ;3 53 . dey ;2 55 Finished drawing upper icons? bpl Map_Screen_Top ;2 57 Branch if not ldy #$30 ;2 59 Gap between top and middle areas Map_Screen_Top_Gap: sta WSYNC ;3 Wait for horizontal Blank ;----------------------------------- cpx PlayerY ;3 03 Check player's vertical location php ;3 06 . pla ;4 10 . sta ENABL ;3 13 ...By using carry status lda #$00 ;2 15 Clear top icon gfx sta GRP0 ;3 18 . sta GRP1 ;3 21 . dex ;2 23 Bump scanline count dey ;2 25 Done drawing this gap? bpl Map_Screen_Top_Gap ;2 27 Branch if not ldy #$02 ;2 29 Pointer for top area lda CXP0FB ;3 32 Mix both collision registers ora CXP1FB ;3 35 . and #$40 ;2 37 Check for ball collisions beq Top_Not_Hit ;2 39 Branch if none in this section sty Temp ;3 42 Save top area collisions Top_Not_Hit: ;40 sta CXCLR ;3 45 Clear collisions for next area ldy #$0F ;2 47 Middle area icon height Map_Screen_Middle: ;58 cpx PlayerY ;3 61 Check player's vertical location php ;3 64 . pla ;4 68 . sta WSYNC ;3 Wait for horizontal Blank ;----------------------------------- sta ENABL ;3 03 ...By using carry status lda AreaM1gfx,y ;4 07 Update the gfx for the left icon sta GRP0 ;3 10 . lda AreaM2gfx,y ;4 14 . sta GRP1 ;3 17 . lda AreaM1color,y ;4 21 . sta COLUP0 ;3 24 . sta COLUP1 ;3 27 . dex ;2 29 Bump scanline count lda AreaM3gfx,y ;4 33 Then update the gfx for the right icon sta GRP0 ;3 36 . lda AreaM4gfx,y ;4 40 . sta GRP1 ;3 43 . lda AreaM2color,y ;4 47 . sta COLUP0 ;3 50 . sta COLUP1 ;3 53 . dey ;2 55 Finished drawing middle icons? bpl Map_Screen_Middle ;2 57 Branch if not ldy #$30 ;2 59 Gap between middle and bottom areas Map_Screen_Mid_Gap: sta WSYNC ;3 Wait for horizontal Blank ;----------------------------------- cpx PlayerY ;3 03 Check player's vertical location php ;3 06 . pla ;4 10 . sta ENABL ;3 13 ...By using carry status lda #$00 ;2 15 Clear middle icon gfx sta GRP0 ;3 18 . sta GRP1 ;3 21 . dex ;2 23 Bump scanline count dey ;2 25 Done drawing this gap? bpl Map_Screen_Mid_Gap ;2 27 Branch if not ldy #$08 ;2 29 Pointer for middle area lda CXP0FB ;3 32 Mix both collision registers ora CXP1FB ;3 35 . and #$40 ;2 37 Check for ball collisions beq Middle_Not_Hit ;2 39 Branch if none in this section sty Temp ;3 42 Save middle area collisions Middle_Not_Hit: ;40 sta CXCLR ;3 45 Clear collisions for next area ldy #$0F ;2 47 Bottom area icon height Map_Screen_Bottom: ;58 cpx PlayerY ;3 61 Check player's vertical location php ;3 64 . pla ;4 68 . sta WSYNC ;3 Wait for horizontal Blank ;----------------------------------- sta ENABL ;3 03 ...By using carry status lda AreaB1gfx,y ;4 07 Update the gfx for the left icon sta GRP0 ;3 10 . lda AreaB2gfx,y ;4 14 . sta GRP1 ;3 17 . lda AreaB1color,y ;4 21 . sta COLUP0 ;3 24 . sta COLUP1 ;3 27 . dex ;2 29 Bump scanline count lda AreaB3gfx,y ;4 33 Then update the gfx for the right icon sta GRP0 ;3 36 . lda AreaB4gfx,y ;4 40 . sta GRP1 ;3 43 . lda AreaB2color,y ;4 47 . sta COLUP0 ;3 50 . sta COLUP1 ;3 53 . dey ;2 55 Finished drawing bottom icons? bpl Map_Screen_Bottom ;2 57 Branch if not Map_Screen_Bot_Gap: ;23 cpx PlayerY ;3 60 Check player's vertical location sta WSYNC ;3 Wait for horizontal Blank ;----------------------------------- php ;3 03 . pla ;4 07 . sta ENABL ;3 10 ...By using carry status lda #$00 ;2 12 Clear bottom icon gfx sta GRP0 ;3 15 . sta GRP1 ;3 18 . dex ;2 20 Bump scanline count bpl Map_Screen_Bot_Gap ;2 22 Branch if any still remain ldy #$0E ;2 24 Pointer for bottom area lda CXP0FB ;3 27 Mix both collision registers ora CXP1FB ;3 30 . and #$40 ;2 32 Check for ball collisions beq Bottom_Not_Hit ;2 34 Branch if none in this section .byte $2C ;4 38 Skip next 2 bytes Bottom_Not_Hit: ;35 ldy Temp ;3 38 Load previous collisions tya ;2 40 Flip to A instead of using CPY (saves a byte) beq No_Icons_Hit ;2 42 Branch if no icons collided with bit.w PlayerX ;4 46 Check horizontal position bvc Left_Side ;2 48 Branch if on the left iny ;2 50 Otherwise, increase pointer by 3 iny ;2 52 . iny ;2 54 . Left_Side2: ;54 sty Temp ;3 57 Save pointer for later sta CXCLR ;3 60 Clear collisions lda HiCnt ;3 63 and #$FD ;2 65 Remove "map display" bit sta HiCnt ;3 68 ldx #$03 ;2 70 Set to transfer 3 bytes to player Entry_Transfer_Loop: lda New_Room_Entered,y ;4 74/21/44 Get first room # for this area sta PlayerRoom-1,x ;4 02/25/48 Update player info sta PrevRoom-1,x ;4 06/29/52 ...And previous info sta MapPortR-1,x ;4 10/33/56 ...And new portal location dey ;2 12/35/58 dex ;2 14/37/60 bne Entry_Transfer_Loop ;2 17/40/62 jmp MapDone ;3 Needs to hit @ cycle 65 with X = 0 (the only requirements) No_Icons_Hit: ;43 ldx #$0C ;2 Waste 59 add'l cycles before returning to last bank sta WSYNC ;3 Wait for horizontal Blank ;----------------------------------- sta CXCLR ;3 03 Kill59cycles: dex ;2 05/10/15/20/25/30/35/40/45/50/55/60 bne Kill59cycles ;2 08/13/18/23/28/33/38/43/48/53/58/62 jmp MapDone ;3 Needs to hit @ cycle 65 with X = 0 (the only requirements) Left_Side: ;49 clc ;2 51 bcc Left_Side2 ;3 54 Always branch New_Room_Entered: ;This table must not cross a page break...it's very time-critical! .byte <(Rm12-Rm00),$4D,$30 ;Entry point for first icon (inside the yellow castle!) .byte <(Rm02-Rm00),$4D,$30 ;...Second (below yellow castle) .byte <(Rm1D-Rm00),$4D,$30 ;...Third (lower dungeon room) .byte <(Rm06-Rm00),$4D,$30 ;...Fourth (large open area in the hedge maze) .byte <(Rm1C-Rm00),$4D,$30 ;...Fifth (upper dungeon room - in black castle for game 1) .byte <(Rm0E-Rm00),$4D,$30 ;...Sixth (dungeon below white castle - try it in game 1!) ;NOTE: page-crossing is pretty much OK for these tables AreaT1gfx: ;top left icon data .byte %11111111 .byte %10000000 .byte %10000000 .byte %10000111 .byte %10000001 .byte %10000001 .byte %10000001 .byte %10000001 .byte %10000001 .byte %10000001 .byte %10000001 .byte %10000011 .byte %10000001 .byte %10000000 .byte %10000000 .byte %11111111 AreaT2gfx: .byte %11111111 .byte %00000001 .byte %00000001 .byte %11100001 .byte %10000001 .byte %10000001 .byte %10000001 .byte %10000001 .byte %10000001 .byte %10000001 .byte %10000001 .byte %10000001 .byte %10000001 .byte %00000001 .byte %00000001 .byte %11111111 AreaT1color: .byte $1A .byte $1A .byte $1A .byte $1A .byte $1A .byte $1A .byte $1A .byte $1A .byte $1A .byte $1A .byte $1A .byte $1A .byte $1A .byte $1A .byte $1A .byte $1A AreaT3gfx: ;top right icon data .byte %11111111 .byte %10000000 .byte %10000000 .byte %10001111 .byte %10000100 .byte %10000010 .byte %10000001 .byte %10000000 .byte %10000000 .byte %10000000 .byte %10000000 .byte %10001000 .byte %10000111 .byte %10000000 .byte %10000000 .byte %11111111 AreaT4gfx: .byte %11111111 .byte %00000001 .byte %00000001 .byte %11110001 .byte %00000001 .byte %00000001 .byte %00000001 .byte %10000001 .byte %01000001 .byte %00100001 .byte %00010001 .byte %00010001 .byte %11100001 .byte %00000001 .byte %00000001 .byte %11111111 AreaT2color: .byte $3A .byte $3A .byte $3A .byte $3A .byte $3A .byte $3A .byte $3A .byte $3A .byte $3A .byte $3A .byte $3A .byte $3A .byte $3A .byte $3A .byte $3A .byte $3A AreaM1gfx: ;middle left icon data .byte %11111111 .byte %10000000 .byte %10000000 .byte %10000111 .byte %10001000 .byte %10000000 .byte %10000000 .byte %10000000 .byte %10000001 .byte %10000000 .byte %10000000 .byte %10001000 .byte %10000111 .byte %10000000 .byte %10000000 .byte %11111111 AreaM2gfx: .byte %11111111 .byte %00000001 .byte %00000001 .byte %11100001 .byte %00010001 .byte %00010001 .byte %00010001 .byte %00010001 .byte %11100001 .byte %10000001 .byte %01000001 .byte %00100001 .byte %11110001 .byte %00000001 .byte %00000001 .byte %11111111 AreaM1color: .byte $5A .byte $5A .byte $5A .byte $5A .byte $5A .byte $5A .byte $5A .byte $5A .byte $5A .byte $5A .byte $5A .byte $5A .byte $5A .byte $5A .byte $5A .byte $5A AreaM3gfx: ;middle right icon data .byte %11111111 .byte %10000000 .byte %10000000 .byte %10000000 .byte %10000000 .byte %10000000 .byte %10001111 .byte %10000100 .byte %10000010 .byte %10000001 .byte %10000000 .byte %10000000 .byte %10000000 .byte %10000000 .byte %10000000 .byte %11111111 AreaM4gfx: .byte %11111111 .byte %00000001 .byte %00000001 .byte %00100001 .byte %00100001 .byte %00100001 .byte %11110001 .byte %00100001 .byte %00100001 .byte %00100001 .byte %10100001 .byte %00100001 .byte %00100001 .byte %00000001 .byte %00000001 .byte %11111111 AreaM2color: .byte $7A .byte $7A .byte $7A .byte $7A .byte $7A .byte $7A .byte $7A .byte $7A .byte $7A .byte $7A .byte $7A .byte $7A .byte $7A .byte $7A .byte $7A .byte $7A AreaB1gfx: ;bottom left icon data .byte %11111111 .byte %10000000 .byte %10000000 .byte %10000111 .byte %10001000 .byte %10000000 .byte %10000000 .byte %10000000 .byte %10000000 .byte %10001111 .byte %10001000 .byte %10001000 .byte %10001111 .byte %10000000 .byte %10000000 .byte %11111111 AreaB2gfx: .byte %11111111 .byte %00000001 .byte %00000001 .byte %11100001 .byte %00010001 .byte %00010001 .byte %00010001 .byte %00010001 .byte %00010001 .byte %11100001 .byte %00000001 .byte %00000001 .byte %11110001 .byte %00000001 .byte %00000001 .byte %11111111 AreaB1color: .byte $9A .byte $9A .byte $9A .byte $9A .byte $9A .byte $9A .byte $9A .byte $9A .byte $9A .byte $9A .byte $9A .byte $9A .byte $9A .byte $9A .byte $9A .byte $9A AreaB3gfx: ;bottom right icon data .byte %11111111 .byte %10000000 .byte %10000000 .byte %10000111 .byte %10001000 .byte %10001000 .byte %10001000 .byte %10001000 .byte %10001000 .byte %10000111 .byte %10000010 .byte %10000001 .byte %10000000 .byte %10000000 .byte %10000000 .byte %11111111 AreaB4gfx: .byte %11111111 .byte %00000001 .byte %00000001 .byte %11100001 .byte %00010001 .byte %00010001 .byte %00010001 .byte %00010001 .byte %00010001 .byte %11100001 .byte %00000001 .byte %00000001 .byte %10000001 .byte %00000001 .byte %00000001 .byte %11111111 AreaB2color: .byte $BA .byte $BA .byte $BA .byte $BA .byte $BA .byte $BA .byte $BA .byte $BA .byte $BA .byte $BA .byte $BA .byte $BA .byte $BA .byte $BA .byte $BA .byte $BA ENDM MAC Object_Bitmaps GfxBat1: ;18 bytes, bat's 1st bitmap (states $00-$03) .byte %00000000 ; First bitmap value (must be zero) .byte $01 ; First color value (anything *but* zero) .byte %10000001 ;X X ; Sprite actually begins here...bitmap first... .byte $01 ; ...Then color for that line .byte %10000001 ;X X ; Continue 2-byte pattern for the rest... .byte $01 .byte %11000011 ;XX XX .byte $01 .byte %11000011 ;XX XX .byte $01 .byte %11111111 ;XXXXXXXX .byte $01 .byte %01011010 ; X XX X .byte $02 .byte %01100110 ; XX XX .byte $01 .byte %00000000 ; Last bitmap value must be zero .byte COLOR_DELIMITER ;end ; ...And last color must be zero GfxWKey: ;10 bytes, key bitmap .byte %00000000 ; It's possible to share a delimiter above for this value... .byte $0E .byte %00000111 ; XXX .byte $0E .byte %11111101 ;XXXXXX X .byte $0A .byte %10100111 ;X X XXX .byte $0E .byte %00000000 GfxDot: ;6 bytes, dot bitmap .byte COLOR_DELIMITER ;end ; ...As demonstrated here .byte $08 .byte %10000000 ;X .byte $08 GfxNull: ; Null sprite requires no graphics...just any double-zero. .byte %00000000 .byte COLOR_DELIMITER ;end ;0 bytes free ALIGN 256,0 GfxGDrag1: ;48 bytes, biting dragon bitmap (states $03-$FF) .byte %00000000 .byte $C8 .byte %10000000 ;X .byte $C8 .byte %01000000 ; X .byte $C8 .byte %00100110 ; X XX .byte $C8 .byte %00011111 ; XXXXX .byte $C8 .byte %00001011 ; X XX .byte $C8 .byte %00001110 ; XXX .byte $C8 .byte %00011110 ; XXXX .byte $C8 .byte %00100100 ; X X .byte $C8 .byte %01000100 ; X X .byte $C8 .byte %10001110 ;X XXX .byte $C8 .byte %00011110 ; XXXX .byte $C8 .byte %00111111 ; XXXXXX .byte $C8 .byte %01111111 ; XXXXXXX .byte $C8 .byte %01111111 ; XXXXXXX .byte $C8 .byte %01111111 ; XXXXXXX .byte $C8 .byte %01111111 ; XXXXXXX .byte $C8 .byte %00111110 ; XXXXX .byte $C8 .byte %00011100 ; XXX .byte $C8 .byte %00001000 ; X .byte $C4 .byte %11111000 ;XXXXX .byte $C4 .byte %10000000 ;X .byte $C4 .byte %11100000 ;XXX .byte $C4 .byte %00000000 .byte COLOR_DELIMITER ;end GfxYDrag1: ;48 bytes, biting dragon bitmap (states $03-$FF) .byte %00000000 .byte $1A .byte %10000000 ;X .byte $1A .byte %01000000 ; X .byte $1A .byte %00100110 ; X XX .byte $1A .byte %00011111 ; XXXXX .byte $1A .byte %00001011 ; X XX .byte $1A .byte %00001110 ; XXX .byte $1A .byte %00011110 ; XXXX .byte $1A .byte %00100100 ; X X .byte $1A .byte %01000100 ; X X .byte $1A .byte %10001110 ;X XXX .byte $1A .byte %00011110 ; XXXX .byte $1A .byte %00111111 ; XXXXXX .byte $1A .byte %01111111 ; XXXXXXX .byte $1A .byte %01111111 ; XXXXXXX .byte $1A .byte %01111111 ; XXXXXXX .byte $1A .byte %01111111 ; XXXXXXX .byte $1A .byte %00111110 ; XXXXX .byte $1A .byte %00011100 ; XXX .byte $1A .byte %00001000 ; X .byte $16 .byte %11111000 ;XXXXX .byte $16 .byte %10000000 ;X .byte $16 .byte %11100000 ;XXX .byte $16 .byte %00000000 .byte COLOR_DELIMITER ;end GfxRDrag1: ;48 bytes, biting dragon bitmap (states $03-$FF) .byte %00000000 .byte $38 .byte %10000000 ;X .byte $38 .byte %01000000 ; X .byte $38 .byte %00100110 ; X XX .byte $38 .byte %00011111 ; XXXXX .byte $38 .byte %00001011 ; X XX .byte $38 .byte %00001110 ; XXX .byte $38 .byte %00011110 ; XXXX .byte $38 .byte %00100100 ; X X .byte $38 .byte %01000100 ; X X .byte $38 .byte %10001110 ;X XXX .byte $38 .byte %00011110 ; XXXX .byte $38 .byte %00111111 ; XXXXXX .byte $38 .byte %01111111 ; XXXXXXX .byte $38 .byte %01111111 ; XXXXXXX .byte $38 .byte %01111111 ; XXXXXXX .byte $38 .byte %01111111 ; XXXXXXX .byte $38 .byte %00111110 ; XXXXX .byte $38 .byte %00011100 ; XXX .byte $38 .byte %00001000 ; X .byte $34 .byte %11111000 ;XXXXX .byte $34 .byte %10000000 ;X .byte $34 .byte %11100000 ;XXX .byte $34 .byte %00000000 .byte COLOR_DELIMITER ;end GfxGDrag2: ;38 bytes, dead dragon bitmap (state $01) .byte %00000000 .byte $C8 .byte %00001100 ; XX .byte $C8 .byte %00001100 ; XX .byte $C8 .byte %00001100 ; XX .byte $C8 .byte %00001110 ; XXX .byte $C8 .byte %00011011 ; XX XX .byte $C8 .byte %01111111 ; XXXXXXX .byte $C8 .byte %11001110 ;XX XXX .byte $C8 .byte %10000000 ;X .byte $46 .byte %11111100 ;XXXXXX .byte $46 .byte %11111110 ;XXXXXXX .byte $C8 .byte %11111110 ;XXXXXXX .byte $C8 .byte %01111110 ; XXXXXX .byte $C8 .byte %01111000 ; XXXX .byte $C8 .byte %00100000 ; X .byte $C4 .byte %01101110 ; XX XXX .byte $C4 .byte %01000010 ; X X .byte $C4 .byte %01111110 ; XXXXXX .byte $C4 .byte %00000000 .byte COLOR_DELIMITER ;end GfxYDrag2: ;38 bytes, dead dragon bitmap (state $01) .byte %00000000 .byte $1A .byte %00001100 ; XX .byte $1A .byte %00001100 ; XX .byte $1A .byte %00001100 ; XX .byte $1A .byte %00001110 ; XXX .byte $1A .byte %00011011 ; XX XX .byte $1A .byte %01111111 ; XXXXXXX .byte $1A .byte %11001110 ;XX XXX .byte $1A .byte %10000000 ;X .byte $46 .byte %11111100 ;XXXXXX .byte $46 .byte %11111110 ;XXXXXXX .byte $1A .byte %11111110 ;XXXXXXX .byte $1A .byte %01111110 ; XXXXXX .byte $1A .byte %01111000 ; XXXX .byte $1A .byte %00100000 ; X .byte $16 .byte %01101110 ; XX XXX .byte $16 .byte %01000010 ; X X .byte $16 .byte %01111110 ; XXXXXX .byte $16 .byte %00000000 .byte COLOR_DELIMITER ;end IF USE_TITLE_DISPLAY = 0 GfxNum1: ;18 bytes, game selection #1 bitmap (states $00-$01) .byte %00000000 .byte $C8 .byte %00100000 ; X .byte $38 .byte %01100000 ; XX .byte $3A .byte %00100000 ; X .byte $38 .byte %00100000 ; X .byte $0E .byte %00100000 ; X .byte $88 .byte %00100000 ; X .byte $8A .byte %01110000 ; XXX .byte $88 .byte %00000000 .byte COLOR_DELIMITER ;end GfxNum2: ;18 bytes, game selection #2 bitmap (states $02-$03) .byte %00000000 .byte $C8 .byte %01110000 ; XXX .byte $CE .byte %10001000 ;X X .byte $CC .byte %00001000 ; X .byte $CA .byte %00010000 ; X .byte $C8 .byte %00100000 ; X .byte $C6 .byte %01000000 ; X .byte $C4 .byte %11111000 ;XXXXX .byte $C2 .byte %00000000 .byte COLOR_DELIMITER ;end ELSE GfxMapPort: ;map portal bitmap .byte %00000000 .byte $01 .byte %01111110 .byte $01 .byte %00000001 .byte $01 .byte %00111001 .byte $01 .byte %01000101 .byte $01 .byte %01010101 .byte $01 .byte %01011001 .byte $01 .byte %01000001 .byte $01 .byte %00111110 .byte $01 .byte %00000000 .byte COLOR_DELIMITER ;end ENDIF ;0 bytes free ALIGN 256,0 GfxBKey: ;10 bytes, key bitmap .byte %00000000 .byte $01 .byte %00000111 ; XXX .byte $01 .byte %11111101 ;XXXXXX X .byte $04 .byte %10100111 ;X X XXX .byte $01 .byte %00000000 .byte COLOR_DELIMITER ;end GfxSwordL: ;14 bytes, sword left bitmap .byte %00000000 .byte $1A .byte %00100000 ; X .byte $1A .byte %01000000 ; X .byte $1A .byte %11111111 ;XXXXXXXX .byte $1A .byte %01000000 ; X .byte $1A .byte %00100000 ; X .byte $1A .byte %00000000 .byte COLOR_DELIMITER ;end GfxRDrag2: ;38 bytes, dead dragon bitmap (state $01) .byte %00000000 .byte $38 .byte %00001100 ; XX .byte $38 .byte %00001100 ; XX .byte $38 .byte %00001100 ; XX .byte $38 .byte %00001110 ; XXX .byte $38 .byte %00011011 ; XX XX .byte $38 .byte %01111111 ; XXXXXXX .byte $38 .byte %11001110 ;XX XXX .byte $38 .byte %10000000 ;X .byte $46 .byte %11111100 ;XXXXXX .byte $46 .byte %11111110 ;XXXXXXX .byte $38 .byte %11111110 ;XXXXXXX .byte $38 .byte %01111110 ; XXXXXX .byte $38 .byte %01111000 ; XXXX .byte $38 .byte %00100000 ; X .byte $34 .byte %01101110 ; XX XXX .byte $34 .byte %01000010 ; X X .byte $34 .byte %01111110 ; XXXXXX .byte $34 .byte %00000000 .byte COLOR_DELIMITER ;end GfxAuthor: ;194 bytes, Signature bitmap .byte %00000000 .byte $36 .byte %11110000 ;XXXX .byte $36 .byte %10000000 ;X .byte $36 .byte %10000000 ;X .byte $36 .byte %10000000 ;X .byte $36 .byte %11110000 ;XXXX .byte $36 .byte %00000100 ; X .byte $0E .byte %10000100 ;X X .byte $0E .byte %11100111 ;XXX XXX .byte $0E .byte %10000101 ;X X X .byte $0E .byte %10000111 ;X XXX .byte $0E .byte %00000000 ; .byte $0E .byte %11100101 ;XXX X X .byte $82 .byte %10100101 ;X X X X .byte $82 .byte %11100111 ;XXX XXX .byte $82 .byte %10000001 ;X X .byte $82 .byte %11100111 ;XXX XXX .byte $82 .byte %00000000 ; .byte $82 .byte %11100000 ;XXX .byte $36 .byte %10100000 ;X X .byte $36 .byte %11110000 ;XXXX .byte $36 .byte %00000000 ; .byte $36 .byte %01000000 ; X .byte $0E .byte %11100000 ;XXX .byte $0E .byte %01000000 ; X .byte $0E .byte %01000000 ; X .byte $0E .byte %01000000 ; X .byte $0E .byte %00000000 ; .byte $0E .byte %11100000 ;XXX .byte $82 .byte %10100000 ;X X .byte $82 .byte %11100000 ;XXX .byte $82 .byte %10000000 ;X .byte $82 .byte %11100000 ;XXX .byte $82 .byte %00000000 ; .byte $82 .byte %00100000 ; X .byte $36 .byte %00100000 ; X .byte $36 .byte %11100000 ;XXX .byte $36 .byte %10100000 ;X X .byte $36 .byte %11100000 ;XXX .byte $36 .byte %00000000 ; .byte $36 .byte %00000000 ; .byte $36 .byte %00000000 ; .byte $36 .byte %00000000 ; .byte $36 .byte %10101000 ;X X X .byte $36 .byte %10101000 ;X X X .byte $36 .byte %10101000 ;X X X .byte $36 .byte %11111000 ;XXXXX .byte $36 .byte %00000000 ; .byte $36 .byte %11100000 ;XXX .byte $0E .byte %10100000 ;X X .byte $0E .byte %11110000 ;XXXX .byte $0E .byte %00000000 ; .byte $0E .byte %10001111 ;X XXXX .byte $82 .byte %11101001 ;XXX X X .byte $82 .byte %10001111 ;X XXXX .byte $82 .byte %10001010 ;X X X .byte $82 .byte %00001001 ; X X .byte $82 .byte %10000000 ;X .byte $36 .byte %11101110 ;XXX XXX .byte $36 .byte %10001010 ;X X X .byte $36 .byte %10001010 ;X X X .byte $36 .byte %00001110 ; XXX .byte $36 .byte %11100000 ;XXX .byte $0E .byte %10101000 ;X X X .byte $0E .byte %11101000 ;XXX X .byte $0E .byte %10001110 ;X XXX .byte $0E .byte %11101010 ;XXX X X .byte $0E .byte %00001110 ; XXX .byte $0E .byte %10000000 ;X .byte $82 .byte %11100100 ;XXX X .byte $82 .byte %10100100 ;X X X .byte $82 .byte %10100100 ;X X X .byte $82 .byte %00000100 ; X .byte $82 .byte %00000000 ; .byte $82 .byte %00001000 ; X .byte $36 .byte %00001110 ; XXX .byte $36 .byte %00001010 ; X X .byte $36 .byte %00001010 ; X X .byte $36 .byte %00000000 ; .byte $36 .byte %00001110 ; XXX .byte $0E .byte %00001010 ; X X .byte $0E .byte %00001110 ; XXX .byte $0E .byte %00001000 ; X .byte $0E .byte %00001110 ; XXX .byte $0E .byte %00000000 ; .byte $0E .byte %00000100 ; X .byte $82 .byte %00001110 ; XXX .byte $82 .byte %00000100 ; X .byte $82 .byte %00000100 ; X .byte $82 .byte %00000100 ; X .byte $82 .byte %00000000 ; .byte $82 .byte %00000100 ; X .byte $36 .byte %00001110 ; XXX .byte $36 .byte %00000100 ; X .byte $36 .byte %00000100 ; X .byte $36 .byte %00000100 ; X .byte $36 .byte %00000000 .byte COLOR_DELIMITER ;end ;0 bytes free ALIGN 256,0 GfxGDrag0: ;44 bytes, roaming/swallowed dragon bitmap (States $00 and $02) .byte %00000000 .byte $C8 .byte %00000110 ; XX .byte $C8 .byte %00001111 ; XXXX .byte $C8 .byte %11110011 ;XXXX XX .byte $C8 .byte %11111110 ;XXXXXXX .byte $C8 .byte %00001110 ; XXX .byte $C8 .byte %00000100 ; X .byte $C8 .byte %00000100 ; X .byte $C8 .byte %00011110 ; XXXX .byte $C8 .byte %00111111 ; XXXXXX .byte $C8 .byte %01111111 ; XXXXXXX .byte $C8 .byte %11100011 ;XXX XX .byte $C8 .byte %11000011 ;XX XX .byte $C8 .byte %11000011 ;XX XX .byte $C8 .byte %11000111 ;XX XXX .byte $C8 .byte %11111111 ;XXXXXXXX .byte $C8 .byte %00111100 ; XXXX .byte $C8 .byte %00001000 ; X .byte $C4 .byte %10001111 ;X XXXX .byte $C4 .byte %11100001 ;XXX X .byte $C4 .byte %00111111 ; XXXXXX .byte $C4 .byte %00000000 .byte COLOR_DELIMITER ;end GfxYDrag0: ;44 bytes, roaming/swallowed dragon bitmap (States $00 and $02) .byte %00000000 .byte $1A .byte %00000110 ; XX .byte $1A .byte %00001111 ; XXXX .byte $1A .byte %11110011 ;XXXX XX .byte $1A .byte %11111110 ;XXXXXXX .byte $1A .byte %00001110 ; XXX .byte $1A .byte %00000100 ; X .byte $1A .byte %00000100 ; X .byte $1A .byte %00011110 ; XXXX .byte $1A .byte %00111111 ; XXXXXX .byte $1A .byte %01111111 ; XXXXXXX .byte $1A .byte %11100011 ;XXX XX .byte $1A .byte %11000011 ;XX XX .byte $1A .byte %11000011 ;XX XX .byte $1A .byte %11000111 ;XX XXX .byte $1A .byte %11111111 ;XXXXXXXX .byte $1A .byte %00111100 ; XXXX .byte $1A .byte %00001000 ; X .byte $16 .byte %10001111 ;X XXXX .byte $16 .byte %11100001 ;XXX X .byte $16 .byte %00111111 ; XXXXXX .byte $16 .byte %00000000 .byte COLOR_DELIMITER ;end GfxRDrag0: ;44 bytes, roaming/swallowed dragon bitmap (States $00 and $02) .byte %00000000 .byte $38 .byte %00000110 ; XX .byte $38 .byte %00001111 ; XXXX .byte $38 .byte %11110011 ;XXXX XX .byte $38 .byte %11111110 ;XXXXXXX .byte $38 .byte %00001110 ; XXX .byte $38 .byte %00000100 ; X .byte $38 .byte %00000100 ; X .byte $38 .byte %00011110 ; XXXX .byte $38 .byte %00111111 ; XXXXXX .byte $38 .byte %01111111 ; XXXXXXX .byte $38 .byte %11100011 ;XXX XX .byte $38 .byte %11000011 ;XX XX .byte $38 .byte %11000011 ;XX XX .byte $38 .byte %11000111 ;XX XXX .byte $38 .byte %11111111 ;XXXXXXXX .byte $38 .byte %00111100 ; XXXX .byte $38 .byte %00001000 ; X .byte $34 .byte %10001111 ;X XXXX .byte $34 .byte %11100001 ;XXX X .byte $34 .byte %00111111 ; XXXXXX .byte $34 .byte %00000000 .byte COLOR_DELIMITER ;end IF ANIMATE_DRAGON GfxGDrag0a: ;42 bytes, roaming/swallowed dragon bitmap (States $00 and $02) .byte %00000000 ; .byte $C8 .byte %00000110 ; XX .byte $C8 .byte %00001111 ; XXXX .byte $C8 .byte %11110011 ;XXXX XX .byte $C8 .byte %11111110 ;XXXXXXX .byte $C8 .byte %00001110 ; XXX .byte $C8 .byte %00000100 ; X .byte $C8 .byte %00011110 ; XXXX .byte $C8 .byte %00111111 ; XXXXXX .byte $C8 .byte %01111111 ; XXXXXXX .byte $C8 .byte %11100011 ;XXX XX .byte $C8 .byte %11000011 ;XX XX .byte $C8 .byte %11000011 ;XX XX .byte $C8 .byte %11000111 ;XX XXX .byte $C8 .byte %11111111 ;XXXXXXXX .byte $C8 .byte %00111100 ; XXXX .byte $C8 .byte %00001000 ; X .byte $C4 .byte %10001111 ;X XXXX .byte $C4 .byte %11100001 ;XXX X .byte $C4 .byte %00111111 ; XXXXXX .byte $C4 .byte %00000000 GfxYDrag0a: ;42 bytes, roaming/swallowed dragon bitmap (States $00 and $02) .byte COLOR_DELIMITER ;end .byte $1A .byte %00000110 ; XX .byte $1A .byte %00001111 ; XXXX .byte $1A .byte %11110011 ;XXXX XX .byte $1A .byte %11111110 ;XXXXXXX .byte $1A .byte %00001110 ; XXX .byte $1A .byte %00000100 ; X .byte $1A .byte %00011110 ; XXXX .byte $1A .byte %00111111 ; XXXXXX .byte $1A .byte %01111111 ; XXXXXXX .byte $1A .byte %11100011 ;XXX XX .byte $1A .byte %11000011 ;XX XX .byte $1A .byte %11000011 ;XX XX .byte $1A .byte %11000111 ;XX XXX .byte $1A .byte %11111111 ;XXXXXXXX .byte $1A .byte %00111100 ; XXXX .byte $1A .byte %00001000 ; X .byte $16 .byte %10001111 ;X XXXX .byte $16 .byte %11100001 ;XXX X .byte $16 .byte %00111111 ; XXXXXX .byte $16 .byte %00000000 GfxRDrag0a: ;42 bytes, roaming/swallowed dragon bitmap (States $00 and $02) .byte COLOR_DELIMITER ;end .byte $38 .byte %00000110 ; XX .byte $38 .byte %00001111 ; XXXX .byte $38 .byte %11110011 ;XXXX XX .byte $38 .byte %11111110 ;XXXXXXX .byte $38 .byte %00001110 ; XXX .byte $38 .byte %00000100 ; X .byte $38 .byte %00011110 ; XXXX .byte $38 .byte %00111111 ; XXXXXX .byte $38 .byte %01111111 ; XXXXXXX .byte $38 .byte %11100011 ;XXX XX .byte $38 .byte %11000011 ;XX XX .byte $38 .byte %11000011 ;XX XX .byte $38 .byte %11000111 ;XX XXX .byte $38 .byte %11111111 ;XXXXXXXX .byte $38 .byte %00111100 ; XXXX .byte $38 .byte %00001000 ; X .byte $34 .byte %10001111 ;X XXXX .byte $34 .byte %11100001 ;XXX X .byte $34 .byte %00111111 ; XXXXXX .byte $34 .byte %00000000 .byte COLOR_DELIMITER ;end ENDIF ;0 bytes free ALIGN 256,0 IF ROTATING_SWORD GfxSwordUL: ;16 bytes, sword up + left bitmap .byte %00000000 .byte $1A .byte %01111100 ; XXXXX .byte $1A .byte %01100000 ; XX .byte $1A .byte %01010000 ; X X .byte $1A .byte %01001000 ; X X .byte $1A .byte %00000100 ; X .byte $1A .byte %00000010 ; X .byte $1A .byte %00000000 .byte COLOR_DELIMITER ;end GfxSwordU: ;18 bytes, sword up bitmap .byte %00000000 .byte $1A .byte %00010000 ; X .byte $1A .byte %00111000 ; XXX .byte $1A .byte %01010100 ; X X X .byte $1A .byte %00010000 ; X .byte $1A .byte %00010000 ; X .byte $1A .byte %00010000 ; X .byte $1A .byte %00010000 ; X .byte $1A .byte %00000000 .byte COLOR_DELIMITER ;end GfxSwordUR: ;16 bytes, sword up + right bitmap .byte %00000000 .byte $1A .byte %01111100 ; XXXXX .byte $1A .byte %00001100 ; XX .byte $1A .byte %00010100 ; X X .byte $1A .byte %00100100 ; X X .byte $1A .byte %01000000 ; X .byte $1A .byte %10000000 ;X .byte $1A .byte %00000000 .byte COLOR_DELIMITER ;end GfxSwordR: ;14 bytes, sword right bitmap .byte %00000000 .byte $1A .byte %00000100 ; X .byte $1A .byte %00000010 ; X .byte $1A .byte %11111111 ;XXXXXXXX .byte $1A .byte %00000010 ; X .byte $1A .byte %00000100 ; X .byte $1A .byte %00000000 .byte COLOR_DELIMITER ;end GfxSwordDR: ;16 bytes, sword down + right bitmap .byte %00000000 .byte $1A .byte %10000000 ;X .byte $1A .byte %01000000 ; X .byte $1A .byte %00100100 ; X X .byte $1A .byte %00010100 ; X X .byte $1A .byte %00001100 ; XX .byte $1A .byte %01111100 ; XXXXX .byte $1A .byte %00000000 .byte COLOR_DELIMITER ;end GfxSwordD: ;18 bytes, sword down bitmap .byte %00000000 .byte $1A .byte %00010000 ; X .byte $1A .byte %00010000 ; X .byte $1A .byte %00010000 ; X .byte $1A .byte %00010000 ; X .byte $1A .byte %01010100 ; X X X .byte $1A .byte %00111000 ; XXX .byte $1A .byte %00010000 ; X .byte $1A .byte %00000000 .byte COLOR_DELIMITER ;end GfxSwordDL: ;16 bytes, sword down + left bitmap .byte %00000000 .byte $1A .byte %00000010 ; X .byte $1A .byte %00000100 ; X .byte $1A .byte %01001000 ; X X .byte $1A .byte %01010000 ; X X .byte $1A .byte %01100000 ; XX .byte $1A .byte %01111100 ; XXXXX .byte $1A .byte %00000000 .byte COLOR_DELIMITER ;end ENDIF GfxBat2: ;26 bytes, bat's 2nd bitmap (states $04-$FF) .byte %00000000 .byte $01 .byte %00000000 ; .byte $01 .byte %00000000 ; .byte $01 .byte %00000000 ; .byte $01 .byte %00000000 ; .byte $01 .byte %00111100 ; XXXX .byte $01 .byte %01011010 ; X XX X .byte $02 .byte %01100110 ; XX XX .byte $01 .byte %11000011 ;XX XX .byte $01 .byte %10000001 ;X X .byte $01 .byte %10000001 ;X X .byte $01 .byte %10000001 ;X X .byte $01 .byte %00000000 .byte COLOR_DELIMITER ;end GfxChallise: ;22 bytes, Challise bitmap .byte %00000000 .byte $1C .byte %10000001 ;X X .byte $1C .byte %10000001 ;X X .byte $1C .byte %11000011 ;XX XX .byte $1C .byte %01111110 ; XXXXXX .byte $1A .byte %01111110 ; XXXXXX .byte $18 .byte %00111100 ; XXXX .byte $16 .byte %00011000 ; XX .byte $0E .byte %00011000 ; XX .byte $0E .byte %01111110 ; XXXXXX .byte $1A .byte %00000000 .byte COLOR_DELIMITER ;end IF USE_TITLE_DISPLAY = 0 GfxNum3: ;18 bytes, game selection #3 bitmap (states $04-$FF) .byte %00000000 .byte $C8 .byte %01110000 ; XXX .byte $C8 .byte %10001000 ;X X .byte $C4 .byte %00001000 ; X .byte $C8 .byte %00110000 ; XX .byte $C4 .byte %00001000 ; X .byte $C8 .byte %10001000 ;X X .byte $C4 .byte %01110000 ; XXX .byte $C8 .byte %00000000 .byte COLOR_DELIMITER ;end ENDIF GfxSurround: ;66 bytes, Surround bitmap .byte %00000000 .byte $20 .byte %00011000 ; XX .byte $20 .byte %00111100 ; XXXX .byte $22 .byte %00111100 ; XXXX .byte $24 .byte %01111110 ; XXXXXX .byte $26 .byte %01111110 ; XXXXXX .byte $28 .byte %01111110 ; XXXXXX .byte $2A .byte %11111111 ;XXXXXXXX .byte $2C .byte %11111111 ;XXXXXXXX .byte $2E .byte %11111111 ;XXXXXXXX .byte $2C .byte %11111111 ;XXXXXXXX .byte $2A .byte %11111111 ;XXXXXXXX .byte $28 .byte %11111111 ;XXXXXXXX .byte $2A .byte %11111111 ;XXXXXXXX .byte $2C .byte %11111111 ;XXXXXXXX .byte $2E .byte %11111111 ;XXXXXXXX .byte $2C .byte %11111111 ;XXXXXXXX .byte $2A .byte %11111111 ;XXXXXXXX .byte $2C .byte %11111111 ;XXXXXXXX .byte $2E .byte %11111111 ;XXXXXXXX .byte $2C .byte %11111111 ;XXXXXXXX .byte $2A .byte %11111111 ;XXXXXXXX .byte $28 .byte %11111111 ;XXXXXXXX .byte $2A .byte %11111111 ;XXXXXXXX .byte $2C .byte %11111111 ;XXXXXXXX .byte $2E .byte %11111111 ;XXXXXXXX .byte $2C .byte %01111110 ; XXXXXX .byte $2A .byte %01111110 ; XXXXXX .byte $28 .byte %01111110 ; XXXXXX .byte $26 .byte %00111100 ; XXXX .byte $24 .byte %00111100 ; XXXX .byte $22 .byte %00011000 ; XX .byte $20 .byte %00000000 ; End of bitmap values...this value should be zero... .byte COLOR_DELIMITER ;end ; ...and followed by zero to tell the kernel it's done. GfxYKey: ;10 bytes, key bitmap .byte %00000000 .byte $1A .byte %00000111 ; XXX .byte $1A .byte %11111101 ;XXXXXX X .byte $1C .byte %10100111 ;X X XXX .byte $1A .byte %00000000 .byte COLOR_DELIMITER ;end ;0 bytes free ALIGN 256,0 GfxMagnet: ;20 bytes, Magnet bitmap .byte %00000000 .byte $34 .byte %00111100 ; XXXX .byte $34 .byte %01111110 ; XXXXXX .byte $36 .byte %11100111 ;XXX XXX .byte $38 .byte %11000011 ;XX XX .byte $3A .byte %11000011 ;XX XX .byte $38 .byte %11000011 ;XX XX .byte $36 .byte %11000011 ;XX XX .byte $01 GfxMagnetEnd: .byte %11000011 ;XX XX .byte $0E .byte %00000000 .byte COLOR_DELIMITER ;end GfxPort01: ;36 bytes, Portcullis bitmap (state $1C...closed) .byte %00000000 .byte $01 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %00000000 .byte COLOR_DELIMITER ;end GfxPort02: ;32 bytes, (state $18 and $20) .byte %00000000 .byte $01 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %00000000 .byte COLOR_DELIMITER ;end GfxPort03: ;28 bytes, (state $14 and $24) .byte %00000000 .byte $01 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %00000000 .byte COLOR_DELIMITER ;end GfxPort04: ;24 bytes, (state $10 and $28) .byte %00000000 .byte $01 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %00000000 .byte COLOR_DELIMITER ;end GfxPort05: ;20 bytes, (state $0C and $2C) .byte %00000000 .byte $01 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %00000000 .byte COLOR_DELIMITER ;end GfxPort06: ;16 bytes, (state $08 and $30) .byte %00000000 .byte $01 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %00000000 .byte COLOR_DELIMITER ;end GfxPort07: ;12 bytes, (state $04 and $FF...open) .byte %00000000 .byte $01 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %11111110 ;XXXXXXX .byte $01 .byte %10101010 ;X X X X .byte $06 .byte %00000000 .byte COLOR_DELIMITER ;end GfxBridge: ;52 bytes, bridge bitmap .byte %00000000 .byte $20 .byte %11000011 ;XX XX .byte $26 .byte %11000011 ;XX XX .byte $24 .byte %11000011 ;XX XX .byte $22 .byte %11000011 ;XX XX .byte $20 .byte %01000010 ; X X .byte $08 .byte %01000010 ; X X .byte $01 .byte %01000010 ; X X .byte $08 .byte %01000010 ; X X .byte $01 .byte %01000010 ; X X .byte $08 .byte %01000010 ; X X .byte $01 .byte %01000010 ; X X .byte $08 .byte %01000010 ; X X .byte $01 .byte %01000010 ; X X .byte $08 .byte %01000010 ; X X .byte $01 .byte %01000010 ; X X .byte $08 .byte %01000010 ; X X .byte $01 .byte %01000010 ; X X .byte $08 .byte %01000010 ; X X .byte $01 .byte %01000010 ; X X .byte $08 .byte %01000010 ; X X .byte $01 .byte %11000011 ;XX XX .byte $20 .byte %11000011 ;XX XX .byte $22 .byte %11000011 ;XX XX .byte $24 .byte %11000011 ;XX XX .byte $26 .byte %00000000 .byte COLOR_DELIMITER ;end ;16 bytes free IF SIMULATE_CHALISE_FLASH ALIGN 256,0 GfxChallise2: ;22 bytes, Challise bitmap .byte %00000000 .byte $3C .byte %10000001 ;X X .byte $3C .byte %10000001 ;X X .byte $3C .byte %11000011 ;XX XX .byte $3C .byte %01111110 ; XXXXXX .byte $3A .byte %01111110 ; XXXXXX .byte $38 .byte %00111100 ; XXXX .byte $36 .byte %00011000 ; XX .byte $2E .byte %00011000 ; XX .byte $2E .byte %01111110 ; XXXXXX .byte $3A .byte %00000000 .byte COLOR_DELIMITER ;end GfxChallise3: ;22 bytes, Challise bitmap .byte %00000000 .byte $5C .byte %10000001 ;X X .byte $5C .byte %10000001 ;X X .byte $5C .byte %11000011 ;XX XX .byte $5C .byte %01111110 ; XXXXXX .byte $5A .byte %01111110 ; XXXXXX .byte $58 .byte %00111100 ; XXXX .byte $56 .byte %00011000 ; XX .byte $4E .byte %00011000 ; XX .byte $4E .byte %01111110 ; XXXXXX .byte $5A .byte %00000000 .byte COLOR_DELIMITER ;end GfxChallise4: ;22 bytes, Challise bitmap .byte %00000000 .byte $7C .byte %10000001 ;X X .byte $7C .byte %10000001 ;X X .byte $7C .byte %11000011 ;XX XX .byte $7C .byte %01111110 ; XXXXXX .byte $7A .byte %01111110 ; XXXXXX .byte $78 .byte %00111100 ; XXXX .byte $76 .byte %00011000 ; XX .byte $6E .byte %00011000 ; XX .byte $6E .byte %01111110 ; XXXXXX .byte $7A .byte %00000000 .byte COLOR_DELIMITER ;end GfxChallise5: ;22 bytes, Challise bitmap .byte %00000000 .byte $9C .byte %10000001 ;X X .byte $9C .byte %10000001 ;X X .byte $9C .byte %11000011 ;XX XX .byte $9C .byte %01111110 ; XXXXXX .byte $9A .byte %01111110 ; XXXXXX .byte $98 .byte %00111100 ; XXXX .byte $96 .byte %00011000 ; XX .byte $8E .byte %00011000 ; XX .byte $8E .byte %01111110 ; XXXXXX .byte $9A .byte %00000000 .byte COLOR_DELIMITER ;end GfxChallise6: ;22 bytes, Challise bitmap .byte %00000000 .byte $BC .byte %10000001 ;X X .byte $BC .byte %10000001 ;X X .byte $BC .byte %11000011 ;XX XX .byte $BC .byte %01111110 ; XXXXXX .byte $BA .byte %01111110 ; XXXXXX .byte $B8 .byte %00111100 ; XXXX .byte $B6 .byte %00011000 ; XX .byte $AE .byte %00011000 ; XX .byte $AE .byte %01111110 ; XXXXXX .byte $BA .byte %00000000 .byte COLOR_DELIMITER ;end GfxChallise7: ;22 bytes, Challise bitmap .byte %00000000 .byte $DC .byte %10000001 ;X X .byte $DC .byte %10000001 ;X X .byte $DC .byte %11000011 ;XX XX .byte $DC .byte %01111110 ; XXXXXX .byte $DA .byte %01111110 ; XXXXXX .byte $D8 .byte %00111100 ; XXXX .byte $D6 .byte %00011000 ; XX .byte $CE .byte %00011000 ; XX .byte $CE .byte %01111110 ; XXXXXX .byte $DA .byte %00000000 .byte COLOR_DELIMITER ;end GfxChallise8: ;22 bytes, Challise bitmap .byte %00000000 .byte $FC .byte %10000001 ;X X .byte $FC .byte %10000001 ;X X .byte $FC .byte %11000011 ;XX XX .byte $FC .byte %01111110 ; XXXXXX .byte $FA .byte %01111110 ; XXXXXX .byte $F8 .byte %00111100 ; XXXX .byte $F6 .byte %00011000 ; XX .byte $EE .byte %00011000 ; XX .byte $EE .byte %01111110 ; XXXXXX .byte $FA .byte %00000000 .byte COLOR_DELIMITER ;end ENDIF ENDM MAC Ball_Enable_Table ;possible to reuse these bytes...so long as bit1 is not needed (ENABL) BallGFX: .byte 0 ;0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;10 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;20 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;30 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;40 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;50 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;60 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;70 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;80 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;90 .byte 0 .byte 2 ;display .byte 2 ;display .byte 2 ;display .byte 2 ;display .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;100 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;110 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;120 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;130 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;140 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;150 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;160 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;170 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;180 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;hiding game select (y=0)... .byte 0 .byte 0 .byte 0 ;190 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 .byte 0 ;200 ENDM ;end of macro definitions SEG rom code ;============================================================================== ; START OF FIRST BANK ;============================================================================== ORG $1000 ;fill lower part of bank with kernel and game objects ; Multicolor_Display_Kernel2 Monocolor_Display_Kernel2 Object_Bitmaps ;then fill the rest of bank with room GFX (and sprite GFX) specific to that bank's definitions ALIGN 256,0 ;NOTE: I left enough space in each page to add color info to each of the (existing) room ; definitions...if you want to try out the multicolor kernel. Be wary of page boundries, ; if you expand the definitions to use less scanlines per band. Full data lines must not ; cross page boundries! Use color change data to cross boundries in Multicolor kernel, ; or fill remaining 1-3 bytes between data lines if using Monocolor kernel. IF USE_TITLE_DISPLAY = 0 Room00: ;Number Room Definition .byte $F0|REV ,$FF,$FF,$08 ;XXXXXXXXXXXXXXXXXXXXRRRRRRRRRRRRRRRRRRRR - 8 .byte $30|REV ,$00,$00,$50 ;XX RR - 80 .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 ENDIF Room01: ;Below blue maze .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 .byte $00|REV|LP ,$00,$00,$50 ; | - 80 .byte $F0|REV ,$FF,$FF,$08 ;XXXXXXXXXXXXXXXXXXXXRRRRRRRRRRRRRRRRRRRR - 8 Room02: ;Below Yellow Castle .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 .byte $00|REV ,$00,$00,$50 ; - 80 .byte $F0|REV ,$FF,$FF,$08 ;XXXXXXXXXXXXXXXXXXXXRRRRRRRRRRRRRRRRRRRR - 8 Room03: ;Above the catacombs .byte $F0|REV ,$FF,$FF,$08 ;XXXXXXXXXXXXXXXXXXXXRRRRRRRRRRRRRRRRRRRR - 8 .byte $00|REV|RP ,$00,$00,$50 ; | - 80 .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 Room04: ;Blue Maze, below black castle .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 .byte $00|REV ,$0C,$0C,$10 ; XX XX RR RR - 16 .byte $F0|REV ,$0C,$3C,$10 ;XXXX XX XXXX RRRR RR RRRR - 16 .byte $F0|REV ,$0C,$00,$10 ;XXXX XX RR RRRR - 16 .byte $F0|REV ,$FF,$3F,$10 ;XXXXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRRRR - 16 .byte $00|REV ,$30,$30,$10 ; XX XX RR RR - 16 .byte $F0|REV ,$33,$3F,$08 ;XXXX XX XXXXXXXX RRRRRRRR RR RRRR - 8 Room05: ;Blue Maze, above entry .byte $F0|REV ,$FF,$FF,$08 ;XXXXXXXXXXXXXXXXXXXXRRRRRRRRRRRRRRRRRRRR - 8 .byte $00|REV ,$00,$00,$10 ; - 16 .byte $F0|REV ,$FC,$FF,$10 ;XXXXXXXXXX XXXXXXXXRRRRRRRR RRRRRRRRRR - 16 .byte $F0|REV ,$00,$C0,$10 ;XXXX XXRR RRRR - 16 .byte $F0|REV ,$3F,$CF,$10 ;XXXX XXXXXXXXXX XXRR RRRRRRRRRR RRRR - 16 .byte $00|REV ,$30,$CC,$10 ; XX XX XXRR RR RR - 16 .byte $F0|REV ,$F3,$CC,$08 ;XXXXXXXX XX XX XXRR RR RR RRRRRRRR - 8 Room06: ;Bottom of Blue Maze .byte $F0|REV ,$F3,$0C,$08 ;XXXXXXXX XX XX RR RR RRRRRRRR - 8 .byte $00|REV ,$30,$0C,$10 ; XX XX RR RR - 16 .byte $F0|REV ,$3F,$0F,$10 ;XXXX XXXXXXXXXX RRRRRRRRRR RRRR - 16 .byte $F0|REV ,$00,$00,$10 ;XXXX RRRR - 16 .byte $F0|REV ,$F0,$00,$10 ;XXXXXXXX RRRRRRRR - 16 .byte $00|REV ,$30,$00,$10 ; XX RR - 16 .byte $F0|REV ,$FF,$FF,$08 ;XXXXXXXXXXXXXXXXXXXXRRRRRRRRRRRRRRRRRRRR - 8 Room07: ;Center of Blue Maze .byte $F0|REV ,$33,$3F,$08 ;XXXX XX XXXXXXXX RRRRRRRR RR RRRR - 8 .byte $00|REV ,$30,$3C,$10 ; XX XXXX RRRR RR - 16 .byte $F0|REV ,$FF,$3C,$10 ;XXXXXXXXXXXX XXXX RRRR RRRRRRRRRRRR - 16 .byte $00|REV ,$03,$3C,$10 ; XX XXXX RRRR RR - 16 .byte $F0|REV ,$33,$3C,$10 ;XXXX XX XX XXXX RRRR RR RR RRRR - 16 .byte $00|REV ,$33,$0C,$10 ; XX XX XX RR RR RR - 16 .byte $F0|REV ,$F3,$0C,$08 ;XXXXXXXX XX XX RR RR RRRRRRRR - 8 Room08: ;Blue Maze Entry .byte $F0|REV ,$F3,$CC,$08 ;XXXXXXXX XX XX XXRR RR RR RRRRRRRR - 8 .byte $00|REV ,$33,$0C,$10 ; XX XX XX RR RR RR - 16 .byte $F0|REV ,$33,$FC,$10 ;XXXX XX XX XXXXXXRRRRRR RR RR RRRR - 16 .byte $00|REV ,$33,$00,$10 ; XX XX RR RR - 16 .byte $F0|REV ,$F3,$FF,$10 ;XXXXXXXX XXXXXXXXXXRRRRRRRRRR RRRRRRRR - 16 .byte $00|REV ,$00,$00,$10 ; - 16 .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 Room0C: ;Right corridor, right of catacombs .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 .byte $00|REV|RP ,$00,$00,$50 ; | - 80 .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 ;56 bytes free ALIGN 256,0 Room09: ;Catacombs Middle .byte $F0|REV|HIDE ,$FF,$CC,$08 ;XXXXXXXXXXXX XX XXRR RR RRRRRRRRRRRR - 8 .byte $00|REV|HIDE ,$00,$CC,$10 ; XX XXRR RR - 16 .byte $F0|REV|HIDE ,$03,$CF,$10 ;XXXX XXXXXX XXRR RRRRRR RRRR - 16 .byte $00|REV|HIDE ,$03,$00,$10 ; XX RR - 16 .byte $F0|REV|HIDE ,$F3,$FC,$10 ;XXXXXXXX XX XXXXXXRRRRRR RR RRRRRRRR - 16 .byte $00|REV|HIDE ,$33,$0C,$10 ; XX XX XX RR RR RR - 16 .byte $F0|REV|HIDE ,$33,$CC,$08 ;XXXX XX XX XX XXRR RR RR RR RRRR - 8 Room0A: ;Catacombs Entry .byte $F0|REV|HIDE ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 .byte $00|REV|HIDE ,$30,$00,$10 ; XX RR - 16 .byte $F0|REV|HIDE ,$30,$FF,$10 ;XXXX XX XXXXXXXXRRRRRRRRR RR RRRR - 16 .byte $00|REV|HIDE ,$30,$C0,$10 ; XX XXRR RR - 16 .byte $F0|REV|HIDE ,$F3,$C0,$10 ;XXXXXXXX XX XXRR RR RRRRRRRR - 16 .byte $00|REV|HIDE ,$03,$C0,$10 ; XX XXRR RR - 16 .byte $F0|REV|HIDE ,$FF,$CC,$08 ;XXXXXXXXXXXX XX XXRR RR RRRRRRRRRRRR - 8 Room0B: ;Catacombs Side .byte $F0|REV|HIDE ,$33,$CC,$08 ;XXXX XX XX XX XXRR RR RR RR RRRR - 8 .byte $00|REV|HIDE ,$30,$CC,$10 ; XX XX XXRR RR RR - 16 .byte $00|REV|HIDE ,$3F,$CF,$10 ; XXXXXX XX XXRR RR RRRRRR - 16 .byte $00|REV|HIDE ,$00,$C0,$10 ; XXRR - 16 .byte $00|REV|HIDE ,$3F,$C3,$10 ; XXXXXXXX XXRR RRRRRRRR - 16 .byte $00|REV|HIDE ,$30,$C0,$10 ; XX XXRR RR - 16 .byte $F0|REV|HIDE ,$FF,$FF,$08 ;XXXXXXXXXXXXXXXXXXXXRRRRRRRRRRRRRRRRRRRR - 8 Room0D: ;Left corridor, below white castle .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 .byte $00|REV|LP ,$00,$00,$50 ; | - 80 .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 Room0E: ;Below left corridor (2 screens below white castle) .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 .byte $30|REV ,$00,$00,$50 ;XX RR - 80 .byte $F0|REV ,$FF,$FF,$08 ;XXXXXXXXXXXXXXXXXXXXRRRRRRRRRRRRRRRRRRRR - 8 Room0F: ;White Castle (outside) .byte $F0|REV ,$FE,$15,$08 ;XXXXXXXXXXX X X X R R R RRRRRRRRRRR - 8 .byte $30|REV ,$03,$1F,$10 ;XX XXXXXXX RRRRRRR RR - 16 .byte $30|REV ,$03,$FF,$10 ;XX XXXXXXXXXXRRRRRRRRRR RR - 16 .byte $30|REV ,$00,$FF,$10 ;XX XXXXXXXXRRRRRRRR RR - 16 .byte $30|REV ,$00,$3F,$10 ;XX XXXXXX RRRRRR RR - 16 .byte $30|REV ,$00,$00,$10 ;XX RR - 16 .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 Room10: ;Black Castle (outside) .byte $F0|REV ,$FE,$15,$08 ;XXXXXXXXXXX X X X R R R RRRRRRRRRRR - 8 .byte $30|REV ,$03,$1F,$10 ;XX XXXXXXX RRRRRRR RR - 16 .byte $30|REV ,$03,$FF,$10 ;XX XXXXXXXXXXRRRRRRRRRR RR - 16 .byte $30|REV ,$00,$FF,$10 ;XX XXXXXXXXRRRRRRRR RR - 16 .byte $30|REV ,$00,$3F,$10 ;XX XXXXXX RRRRRR RR - 16 .byte $30|REV ,$00,$00,$10 ;XX RR - 16 .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 Room12: ;Inside Yellow castle .byte $F0|REV ,$FF,$FF,$08 ;XXXXXXXXXXXXXXXXXXXXRRRRRRRRRRRRRRRRRRRR - 8 .byte $30|REV ,$00,$00,$50 ;XX RR - 80 .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 Room1B: ;Just inside the black castle .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 .byte $30|REV ,$00,$00,$50 ;XX RR - 80 .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 Room1C: ;Above right corridor (#1 - 2nd room in black castle, #2/#3 - right of catacombs) .byte $F0|REV ,$FF,$FF,$08 ;XXXXXXXXXXXXXXXXXXXXRRRRRRRRRRRRRRRRRRRR - 8 .byte $30|REV ,$00,$00,$50 ;XX RR - 80 .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 ;56 bytes free ALIGN 256,0 Room11: ;Yellow Castle (outside) .byte $F0|REV ,$FE,$15,$08 ;XXXXXXXXXXX X X X R R R RRRRRRRRRRR - 8 .byte $30|REV ,$03,$1F,$10 ;XX XXXXXXX RRRRRRR RR - 16 .byte $30|REV ,$03,$FF,$10 ;XX XXXXXXXXXXRRRRRRRRRR RR - 16 .byte $30|REV ,$00,$FF,$10 ;XX XXXXXXXXRRRRRRRR RR - 16 .byte $30|REV ,$00,$3F,$10 ;XX XXXXXX RRRRRR RR - 16 .byte $30|REV ,$00,$00,$10 ;XX RR - 16 .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 Room13: ;Black Maze, right from entry .byte $F0|REV|HIDE ,$F0,$FF,$08 ;XXXXXXXX XXXXXXXXRRRRRRRR RRRRRRRR - 8 .byte $00|REV|HIDE ,$00,$03,$10 ; XX RR - 16 .byte $F0|REV|HIDE ,$FF,$03,$10 ;XXXXXXXXXXXXXX RRRRRRRRRRRRRR - 16 .byte $00|REV|HIDE ,$00,$00,$10 ; - 16 .byte $30|REV|HIDE ,$3F,$FF,$10 ;XX XXXXXXXXXXXXXXRRRRRRRRRRRRRR RR - 16 .byte $00|REV|HIDE ,$30,$00,$10 ; XX RR - 16 .byte $F0|REV|HIDE ,$F0,$FF,$08 ;XXXXXXXX XXXXXXXXRRRRRRRR RRRRRRRR - 8 Room14: ;Black Maze, Challise room .byte $F0|HIDE ,$FF,$FF,$08 ;XXXXXXXXXXXXXXXXXXXXMMMMMMMMMMMMMMMMMMMM - 8 .byte $00|HIDE ,$00,$C0,$10 ; XX MM - 16 .byte $F0|HIDE ,$FF,$CF,$10 ;XXXXXXXXXXXXXXXX XXMMMMMMMMMMMMMMMM MM - 16 .byte $00|HIDE ,$00,$0C,$10 ; XX MM - 16 .byte $F0|HIDE ,$0F,$FF,$10 ;XXXX XXXXXXXXXXXXMMMM MMMMMMMMMMMM - 16 .byte $00|HIDE ,$0F,$C0,$10 ; XXXX XX MMMM MM - 16 .byte $30|HIDE ,$CF,$CC,$08 ;XX XX XXXX XX XXMM MM MMMM MM MM - 8 Room15: ;Black Maze, Dot's room .byte $F0|HIDE ,$F0,$FF,$08 ;XXXXXXXX XXXXXXXXMMMMMMMM MMMMMMMM - 8 .byte $30|HIDE ,$00,$00,$10 ;XX MM - 16 .byte $30|HIDE ,$3F,$FF,$10 ;XX XXXXXXXXXXXXXXMM MMMMMMMMMMMMMM - 16 .byte $00|HIDE ,$30,$00,$10 ; XX MM - 16 .byte $F0|HIDE ,$F0,$FF,$10 ;XXXXXXXX XXXXXXXXMMMMMMMM MMMMMMMM - 16 .byte $30|HIDE ,$00,$03,$10 ;XX XX .MM MM - 16 .byte $F0|HIDE ,$F0,$FF,$08 ;XXXXXXXX XXXXXXXXMMMMMMMM MMMMMMMM - 8 Room16: ;Black Maze Entry .byte $30|REV|HIDE ,$CF,$CC,$08 ;XX XX XXXX XX XXRR RR RRRR RR RR - 8 .byte $00|REV|HIDE ,$C0,$CC,$10 ; XX XX XXRR RR RR - 16 .byte $F0|REV|HIDE ,$FF,$0F,$10 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 16 .byte $00|REV|HIDE ,$00,$00,$10 ; - 16 .byte $F0|REV|HIDE ,$FF,$0F,$10 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 16 .byte $00|REV|HIDE ,$00,$00,$10 ; - 16 .byte $F0|REV|HIDE ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 Room17: ;Red Maze, above black key's room .byte $F0|REV ,$FF,$FF,$08 ;XXXXXXXXXXXXXXXXXXXXRRRRRRRRRRRRRRRRRRRR - 8 .byte $00|REV ,$00,$00,$10 ; - 16 .byte $F0|REV ,$FF,$0F,$10 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 16 .byte $00|REV ,$00,$0C,$10 ; XX RR - 16 .byte $F0|REV ,$FF,$0C,$10 ;XXXXXXXXXXXX XX RR RRRRRRRRRRRR - 16 .byte $F0|REV ,$03,$CC,$10 ;XXXX XX XX XXRR RR RR RRRR - 16 .byte $F0|REV ,$33,$CF,$08 ;XXXX XX XXXXXX XXRR RRRRRR RR RRRR - 8 Room18: ;Red Maze, above entry .byte $F0|REV ,$FF,$FF,$08 ;XXXXXXXXXXXXXXXXXXXXRRRRRRRRRRRRRRRRRRRR - 8 .byte $00|REV ,$00,$C0,$10 ; XXRR - 16 .byte $F0|REV ,$FF,$CF,$10 ;XXXXXXXXXXXXXXXX XXRR RRRRRRRRRRRRRRRR - 16 .byte $00|REV ,$00,$CC,$10 ; XX XXRR RR - 16 .byte $F0|REV ,$33,$FF,$10 ;XXXX XX XXXXXXXXXXRRRRRRRRRR RR RRRR - 16 .byte $F0|REV ,$33,$00,$10 ;XXXX XX XX RR RR RRRR - 16 .byte $F0|REV ,$3F,$0C,$08 ;XXXX XXXXXX XX RR RRRRRR RRRR - 8 ;60 bytes free ALIGN 256,0 Room19: ;Red Maze, black key's room .byte $F0|REV ,$33,$CF,$08 ;XXXX XX XXXXXX XXRR RRRRRR RR RRRR - 8 .byte $F0|REV ,$30,$00,$10 ;XXXX XX RR RRRR - 16 .byte $F0|REV ,$33,$FF,$10 ;XXXX XX XXXXXXXXXXRRRRRRRRRR RR RRRR - 16 .byte $00|REV ,$33,$00,$10 ; XX XX RR RR RRRR - 16 .byte $F0|REV ,$FF,$00,$10 ;XXXXXXXXXXXX RRRRRRRRRRRR - 16 .byte $00|REV ,$00,$00,$10 ; - 16 .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 Room1A: ;Red Maze Entry .byte $F0|REV ,$3F,$0C,$08 ;XXXX XXXXXX XX RR RRRRRR RRRR - 8 .byte $F0|REV ,$00,$0C,$10 ;XXXX XX RR RRRR - 16 .byte $F0|REV ,$FF,$0F,$10 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 16 .byte $00|REV ,$30,$00,$10 ; XX RR - 16 .byte $F0|REV ,$30,$00,$10 ;XXXX XX RR RRRR - 16 .byte $00|REV ,$30,$00,$10 ; XX RR - 16 .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 Room1D: ;Below right corridor (below right panel room - #1, right of catacombs - #2/#3) .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 .byte $30|REV ,$00,$00,$50 ;XX RR - 80 .byte $F0|REV ,$FF,$FF,$08 ;XXXXXXXXXXXXXXXXXXXXRRRRRRRRRRRRRRRRRRRR - 8 Room1E: ;Warren Robinett's room .byte $F0|REV ,$FF,$0F,$08 ;XXXXXXXXXXXXXXXX RRRRRRRRRRRRRRRR - 8 .byte $00|REV ,$00,$00,$50 ; - 80 .byte $F0|REV ,$FF,$FF,$08 ;XXXXXXXXXXXXXXXXXXXXRRRRRRRRRRRRRRRRRRRR - 8 ;Set these wherever you want! IF USE_TITLE_DISPLAY Titlescreen MapScreen ENDIF IF BANKS = 0 ORG $1F2F,0 RORG $1F2F Ball_Enable_Table ORG $1FF8,0 RORG $1FF8 .byte "3911" ENDIF IF BANKS = 1 ORG $1F2D,0 RORG $1F2D Ball_Enable_Table ORG $1FF6,0 RORG $1FF6 .byte "3/9/11" ENDIF IF BANKS = 2 ORG $1F2B,0 RORG $1F2B Ball_Enable_Table ORG $1FF4,0 RORG $1FF4 .byte "3/9/2011" ENDIF .word START ;cold start vector .word START ;interrupt vector ;============================================================================== ; END OF FIRST BANK ;============================================================================== ;Second & Third for 16K or 32K IF BANKS ;============================================================================== ; START OF SECOND BANK ;============================================================================== ORG $2000 RORG $1000 ;fill lower part of bank with kernel and game objects ; Multicolor_Display_Kernel2 Monocolor_Display_Kernel2 Object_Bitmaps ;then fill the rest of bank with room GFX (and sprite GFX) specific to that bank's definitions IF BANKS = 1 ORG $2F2D,0 RORG $1F2D Ball_Enable_Table ORG $2FF6,0 RORG $1FF6 .byte "3/9/11" ELSE ORG $2F2B,0 RORG $1F2B Ball_Enable_Table ORG $2FF4,0 RORG $1FF4 .byte "3/9/2011" ENDIF .word START ;cold start vector .word START ;interrupt vector ;============================================================================== ; END OF SECOND BANK ;============================================================================== ;============================================================================== ; START OF THIRD BANK ;============================================================================== ORG $3000 RORG $1000 ;fill lower part of bank with kernel and game objects ; Multicolor_Display_Kernel2 Monocolor_Display_Kernel2 Object_Bitmaps ;then fill the rest of bank with room GFX (and sprite GFX) specific to that bank's definitions IF BANKS = 1 ORG $3F2D,0 RORG $1F2D Ball_Enable_Table ORG $3FF6,0 RORG $1FF6 .byte "3/9/11" ELSE ORG $3F2B,0 RORG $1F2B Ball_Enable_Table ORG $3FF4,0 RORG $1FF4 .byte "3/9/2011" ENDIF .word START ;cold start vector .word START ;interrupt vector ;============================================================================== ; END OF THIRD BANK ;============================================================================== ENDIF ;Fourth thru Seventh for 32K only IF BANKS = 2 ;============================================================================== ; START OF FOURTH BANK ;============================================================================== ORG $4000 RORG $1000 ;fill lower part of bank with kernel and game objects ; Multicolor_Display_Kernel2 Monocolor_Display_Kernel2 Object_Bitmaps ;then fill the rest of bank with room GFX (and sprite GFX) specific to that bank's definitions ORG $4F2B,0 RORG $1F2B Ball_Enable_Table ORG $4FF4,0 RORG $1FF4 .byte "3/9/2011" .word START ;cold start vector .word START ;interrupt vector ;============================================================================== ; END OF FOURTH BANK ;============================================================================== ;============================================================================== ; START OF FIFTH BANK ;============================================================================== ORG $5000 RORG $1000 ;fill lower part of bank with kernel and game objects ; Multicolor_Display_Kernel2 Monocolor_Display_Kernel2 Object_Bitmaps ;then fill the rest of bank with room GFX (and sprite GFX) specific to that bank's definitions ORG $5F2B,0 RORG $1F2B Ball_Enable_Table ORG $5FF4,0 RORG $1FF4 .byte "3/9/2011" .word START ;cold start vector .word START ;interrupt vector ;============================================================================== ; END OF FIFTH BANK ;============================================================================== ;============================================================================== ; START OF SIXTH BANK ;============================================================================== ORG $6000 RORG $1000 ;fill lower part of bank with kernel and game objects ; Multicolor_Display_Kernel2 Monocolor_Display_Kernel2 Object_Bitmaps ;then fill the rest of bank with room GFX (and sprite GFX) specific to that bank's definitions ORG $6F2B,0 RORG $1F2B Ball_Enable_Table ORG $6FF4,0 RORG $1FF4 .byte "3/9/2011" .word START ;cold start vector .word START ;interrupt vector ;============================================================================== ; END OF SIXTH BANK ;============================================================================== ;============================================================================== ; START OF SEVENTH BANK ;============================================================================== ORG $7000 RORG $1000 ;fill lower part of bank with kernel and game objects ; Multicolor_Display_Kernel2 Monocolor_Display_Kernel2 Object_Bitmaps ;then fill the rest of bank with room GFX (and sprite GFX) specific to that bank's definitions ORG $7F2B,0 RORG $1F2B Ball_Enable_Table ORG $7FF4,0 RORG $1FF4 .byte "3/9/2011" .word START ;cold start vector .word START ;interrupt vector ;============================================================================== ; END OF SEVENTH BANK ;============================================================================== ENDIF ;============================================================================== ; START OF LAST BANK ;============================================================================== IF BANKS = 0 ORG $2000 RORG $F000 START: lda $FFF9 ;4 jmp StartGame ;3 Go to cold start routine in last bank IF USE_TITLE_DISPLAY TitleBankswitch: lda $FFF8 ;4 Select first bank jmp TitleReturn ;3 72 MapBankswitch: lda $FFF8 ;4 Select first bank jmp MapReturn ;3 72 ENDIF Kernel: ;43 lda $FFF8 ;4 47 ENDIF IF BANKS = 1 ORG $4000 RORG $F000 START: lda $FFF9 ;4 jmp StartGame ;3 Go to cold start routine in last bank IF USE_TITLE_DISPLAY TitleBankswitch: lda $FFF6,y ;4 Select bank number (Y) jmp TitleReturn ;3 72 MapBankswitch: lda $FFF6,y ;4 Select bank number (Y) jmp MapReturn ;3 72 ENDIF Kernel: ;43 lda $FFF6,y ;4 47 Select bank number (Y) ENDIF IF BANKS = 2 ORG $8000 RORG $F000 START: lda $FFFB ;4 jmp StartGame ;3 Go to cold start routine in last bank IF USE_TITLE_DISPLAY TitleBankswitch: lda $FFF4,y ;4 Select bank number (Y) jmp TitleReturn ;3 72 MapBankswitch: lda $FFF4,y ;4 Select bank number (Y) jmp MapReturn ;3 72 ENDIF Kernel: ;43 lda $FFF4,y ;4 47 Select bank number (Y) ENDIF ;59 from first bank, X=0 ldy $FC ;3 62 sty Obj2Lo ;3 65 ldy $FD ;3 68 sty.w Obj1Lo ;4 72 TitleReturn: ;72 MapReturn: ;72 txa ;2 74 ldx #$02 ;2 76 ;----------------------------------- stx VBLANK ;3 03 Turn on VBLANK ldx #$FD ;2 txs ;2 sta ENABL ;3 Clear all sprites sta GRP0 ;3 . sta GRP1 ;3 . lda #TIME1 ;2 Set overscan time bne Store_Timer ;2 Always branch (save timer and return) DoVSYNC: ;Perform VSYNC DoVSYNC_2: ldx INTIM ;4 Get Timer Output bne DoVSYNC_2 ;2 Wait for Time-Out lda #$02 ;2 (enable) sta WSYNC ;3 Wait for horizontal Blank sta VSYNC ;3 Start vertical sync sta WSYNC ;3 Wait for horizontal Blank stx VSYNC ;3 End vertical sync lda #TIME2 ;2 Set clock interval to countdown next frame Store_Timer: sta TIM64T ;4 rts ;6 PrintDisplay: ;draw a frame... IF UNROLL_POSITIONING ;Position ball horizontally. lda PlayerX ;3 Position Ball Strite to the X Coordinate (all frames) ldx #$00 ;2 sec ;2 PosBall_1: inx ;2 Divide the Coordinate wanted by fifteen sbc #$0F ;2 Get Course Horizontal Value...In Multiples of 5 Clock bcs PosBall_1 ;2 Cycles...(Therefore giving 15 Color Cycles) eor #$FF ;2 Flip remainder to positive value (inverted) sbc #$06 ;2 Convert to left or right of current position sta WSYNC ;3 Wait for horizontal Blank asl ;2 Move to high nybble for TIA horizontal motion... asl ;2 . asl ;2 . asl ;2 . PosBall_2: dex ;2 Count down the color cycles... bpl PosBall_2 ;2 These are 5 machine/15 color cycles sta HMBL ;3 Set horizontal (fine) motion of sprite sta RESBL ;3 Reset the sprite, thus positioning it coursely inx ;2 X=0 ELSE lda PlayerX ;3 Position Ball Strite to the X Coordinate (all frames) ldx #$04 ;2 Select sprite #5 (ball) jsr PosSpriteX ;6 Execute repositioning subroutine ENDIF lda Control ;3 Get 3-frame room number and #$7F ;2 Strip inactive game bit tay ;2 ...and pass to Y for an index lda Obj1Lo ;3 Transfer low sprite0 pointer to stack pha ;3 lda Obj2Lo ;3 Transfer low sprite1 pointer to stack pha ;3 lda #>BallGFX ;2 sta Ball+1 ;3 lda RoomGFX_LSB_Tbl,y ;4 Get the room gfx LSB pointer sta RoomLo ;3 ...And store lda PlayerY ;3 Get the Y Coordinate of the ball cmp #$68 ;2 Check if on top 2 scanlines bcc Ball_Lower_Than_Top ;2 Branch if not ldx #$02 ;2 Otherwise...enable the ball immediately Ball_Lower_Than_Top: stx ENABL ;3 lda #<BallGFX+105 ;2 PrintDisplay_1: ldx INTIM ;4 Wait for end of the current frame bne PrintDisplay_1 ;2 sta WSYNC ;3 Wait for horizontal Blank ;----------------------------------- sta HMOVE ;3 03 Apply Horizontal Motion sec ;2 05 sbc PlayerY ;3 08 Get the Y Coordinate of the ball sta Ball ;3 11 lda RoomGFX_MSB_Tbl,y ;4 15 Get the room gfx MSB pointer ora #SURROUND ;2 17 Ignore "SURROUND" flag, set to MSB to ROM instead sta RoomHi ;3 20 ...And store rol ;2 22 rol ;2 24 rol ;2 26 rol ;2 28 and #BANK_SELECT ;2 30 tay ;2 32 ...And give to Y for bank # where room GFX exists ldx #$60 ;2 34 Set to start displaying playfield sta CXCLR ;3 37 Clear Collision Latches sta HMCLR ;3 40 Clear horizontal motion jmp Kernel ;3 43 CacheObjects: ;Fill cache with two objects in this room. ldx LastObj ;3 Get Last Object ldy #NullNumber ;2 Set cache to no objects (zero) / also use as (Ind),y ptr sty CurrentObject+2 ;3 . sty CurrentObject+3 ;3 . MoveNextObject: dex ;2 Goto the next object bne GetObjectsInfo ;2 Branch if all objects not checked ldx #LastObjectNumber ;2 Otherwise, reset to the last sprite object GetObjectsInfo: lda Object_Data_LSB,x ;4 Get low byte of object info sta CurrentObject ;3 ...And store lda Object_Data_MSB,x ;4 Get high byte of object info sta CurrentObject+1 ;3 ...And store lda (CurrentObject),y ;5 Get object's current room cmp PlayerRoom ;3 Is it in this room? bne CheckForMoreObjects ;2 If not, try next object lda CurrentObject+2 ;3 Check first slot bne StoreObjectToPrint ;2 If not free then branch stx CurrentObject+2 ;3 Store this object's number to print CheckForMoreObjects: cpx LastObj ;3 Have we done all the objects? bne MoveNextObject ;2 If not, continue beq StoreCount ;2 Always branch StoreObjectToPrint: stx CurrentObject+3 ;3 Store this object's number to print StoreCount: stx LastObj ;3 If so, store current count for next time SetupRoomPrint: ;Setup a room for print lda Control ;3 and #$80 ;2 ora PlayerRoom ;3 Create a backup of the room number for 3 frames sta Control ;3 ...So that it does not need setting up each time ldy PlayerRoom ;3 Get current room number lda Wall_Color_Tbl,y ;4 Get the room's foreground color jsr ChangeColor ;6 Change if necessary sta COLUPF ;3 Put it in the foreground color register IF USE_UNIQUE_BACKGROUND_COLORS lda Ground_Color_Tbl,y ;4 Get the room's background color jsr ChangeColor ;6 Change if necessary ELSE lda #$04 ;2 Get light grey background (all rooms) jsr ChangeColor_2 ;6 Change if necessary (ASL at end moves it to color $08) ENDIF sta COLUBK ;3 Put it in the Background color register ;Sort out their order...do 1st sprite... lda CurrentObject+2 ;3 Check first object cmp #SurroundNumber ;2 If the first object is the surround... beq SwapPrintObjects ;2 Then branch to swap (we want it as player01) cmp #BridgeNumber ;2 If the first object is the bridge... bne SetupObjectPrint ;2 Then swap the objects (we want it as player01) lda CurrentObject+3 ;3 Check object2 cmp #SurroundNumber ;2 If object2 is the surround... beq SetupObjectPrint ;2 branch (we want it as player01) SwapPrintObjects: lda CurrentObject+2 ;3 Swap the objects to print ldx CurrentObject+3 ;3 . sta CurrentObject+3 ;3 . stx CurrentObject+2 ;3 . SetupObjectPrint: ldx CurrentObject+2 ;3 Setup Object1 to print...get Object 1 lda BatR+4 ;3 sta BatStateBackup ;3 Save as backup and #$07 ;2 Ignore bits 7-3 sta BatR+4 ;3 lda Object_Data_LSB,x ;4 Get low pointer to it's dynamic information sta CurrentObject ;3 ...Store lda Object_Data_MSB,x ;4 Get high pointer to it's dynamic informtion sta CurrentObject+1 ;3 ...Store rol ;2 Move upper 3 bits to low position for sprite width rol ;2 . rol ;2 . rol ;2 . and #$07 ;2 Trim to only those 3 bits ora #$10 ;2 Value to include width of corresponding missile sprite sta NUSIZ0 ;3 Update ldy #$01 ;2 Set initial Y index lda (CurrentObject),y ;5 Get Object1's horizontal co-ordinate IF UNROLL_POSITIONING sta Temp ;3 ...And store for printing ENDIF sta ObjX ;3 (Also save as current) iny ;2 Bump index lda (CurrentObject),y ;5 Get Object1's vertical co-ordinate sec ;2 sbc #$08 ;2 Adjust by 8 pixels for display sta Obj1Y ;3 ...And store for printing ldy Object_State_LSB,x ;4 Get low pointer to state value lda Object_State_MSB,x ;4 Get high pointer to state value beq Animated_Object_1 ;2 If animated object then skip ahead sty Obj1Lo ;3 Otherwise, store for print... bne Static_Object_1 ;2 ...And skip ahead to store the MSB (always branch) Animated_Object_1: jsr GetObjectState ;6 Find current state in the state information iny ;2 Index to the state's corresponding graphic pointer lda (CurrentObject),y ;5 Get Object1's low graphic address sta Obj1Lo ;3 ...And store for printing iny ;2 Bump index lda (CurrentObject),y ;5 Get Object1's high graphic address Static_Object_1: sta Obj1Hi ;3 ...And store for printing IF FLIP_DRAGONS jsr CheckFlip ;6 sty REFP0 ;3 ...And store reflect ENDIF IF UNROLL_POSITIONING = 0 ldx #$00 ;2 Reposition Object1...select sprite 1 (player0) lda ObjX ;3 ...And get current X co-ordinate jsr PosSpriteX ;6 Execute subroutine ENDIF ;do 2nd sprite... ldx CurrentObject+3 ;3 Setup Object 2 to Print...get Object 2 lda Object_Data_LSB,x ;4 Get low pointer to it's dynamic information sta CurrentObject ;3 ...And store lda Object_Data_MSB,x ;4 Get high pointer to it's dynamic information sta CurrentObject+1 ;3 ...And store rol ;2 Move upper 3 bits to low position for sprite width rol ;2 . rol ;2 . rol ;2 . and #$07 ;2 Trim to only those 3 bits ora #$10 ;2 Value to include width of corresponding missile sprite sta NUSIZ1 ;3 Update ldy #$01 ;2 Set initial Y index lda (CurrentObject),y ;5 Get Object2's horizontal co-ordinate sta ObjX ;3 ...And store for printing iny ;2 Bump index lda (CurrentObject),y ;5 Get Object2's vertical co-ordinate sec ;2 sbc #$08 ;2 Adjust by 8 pixels for display sta Obj2Y ;3 ...And store for printing ldy Object_State_LSB,x ;4 Get low pointer to state value lda Object_State_MSB,x ;4 Get high pointer to state value beq Animated_Object_2 ;2 If animated object then skip ahead sty Obj2Lo ;3 Otherwise, store for printing... bne Static_Object_2 ;2 ...And skip ahead to store the MSB (always branch) Animated_Object_2: jsr GetObjectState ;6 Find the current state in the state information iny ;2 Index to state's corresponding graphic pointer lda (CurrentObject),y ;5 Get Object2's low graphic address sta Obj2Lo ;3 ...And store iny ;2 Bump index lda (CurrentObject),y ;5 Get Object2's high graphic address Static_Object_2: ldy BatStateBackup ;3 Restore bat's original state sty BatR+4 ;3 sta Obj2Hi ;3 ...And store IF FLIP_DRAGONS jsr CheckFlip ;6 sty REFP1 ;3 ...And store reflect ENDIF IF UNROLL_POSITIONING lda ObjX ;3 Get current X co-ordinate ldy #$00 ;2 Start with 10 clock cycles (to avoid HBLANK) sec ;2 PosObject2: iny ;2 Divide the Coordinate wanted by fifteen sbc #$0F ;2 Get Course Horizontal Value...In Multiples of 5 Clock bcs PosObject2 ;2 Cycles...(Therefore giving 15 Color Cycles) eor #$FF ;2 Flip remainder to positive value (inverted) sbc #$06 ;2 Convert to left or right of current position asl ;2 Move to high nybble for TIA horizontal motion... asl ;2 . pha ;3 ldx #$00 ;2 Start with 10 clock cycles (to avoid HBLANK) lda Temp ;3 Get current horizontal co-ordinate of object1 sec ;2 PosObject1: inx ;2 Divide the Coordinate wanted by fifteen sbc #$0F ;2 Get Course Horizontal Value...In Multiples of 5 Clock bcs PosObject1 ;2 Cycles...(Therefore giving 15 Color Cycles) eor #$FF ;2 Flip remainder to positive value (inverted) sbc #$06 ;2 Convert to left or right of current position sta WSYNC ;3 Wait for horizontal Blank asl ;2 Move to high nybble for TIA horizontal motion... asl ;2 . asl ;2 . asl ;2 . PosCourse1: dex ;2 Count down the color cycles... bpl PosCourse1 ;2 These are 5 machine/15 color cycles sta HMP0 ;3 Set horizontal (fine) motion of sprite sta RESP0 ;4 Reset the sprite, thus positioning it coursely sta WSYNC ;3 Wait for horizontal Blank pla ;4 asl ;2 . asl ;2 . PosCourse2: dey ;2 Count down the color cycles... bpl PosCourse2 ;2 These are 5 machine/15 color cycles sta HMP1 ;3 Set horizontal (fine) motion of sprite sta RESP1 ;3 Reset the sprite, thus positioning it coursely rts ;6 ELSE ldx #$01 ;2 Reposition Object2...select sprite 2 (player1) lda ObjX ;3 ...And get current horizontal co-ordinate ;Fall into positioning subroutine (use it's RTS to return to main loop) ENDIF PosSpriteX: ;Position Sprite X horizontally. ldy #$02 ;2 Start with 10 clock cycles (to avoid HBLANK) sec ;2 PosSpriteX_1: iny ;2 Divide the Coordinate wanted by fifteen sbc #$0F ;2 Get Course Horizontal Value...In Multiples of 5 Clock bcs PosSpriteX_1 ;2 Cycles...(Therefore giving 15 Color Cycles) eor #$FF ;2 Flip remainder to positive value (inverted) sbc #$06 ;2 Convert to left or right of current position asl ;2 Move to high nybble for TIA horizontal motion... asl ;2 . asl ;2 . asl ;2 . sta HMP0,x ;4 Set horizontal (fine) motion of sprite sta WSYNC ;3 Wait for horizontal Blank PosSpriteX_2: dey ;2 Count down the color cycles... bpl PosSpriteX_2 ;2 These are 5 machine/15 color cycles sta RESP0,x ;4 Reset the sprite, thus positioning it coursely rts ;6 GetObjectState: ;Get pointer to current state lda State_List_LSB,x ;4 Get low pointer to state information sta CurrentObject ;3 ...And store lda State_List_MSB,x ;4 Get high pointer to state information sta CurrentObject+1 ;3 ...And store lda.wy $00,y ;4 Get current state value ldy #$FD ;2 Reset state table offset (INY's ahead bump this to zero) GetObjectState_1: iny ;2 Goto next state in list of states (bump index by 3 bytes) iny ;2 . iny ;2 . cmp (CurrentObject),y ;5 Have we found it in the list of states? bcc GetObjectState_2 ;2 If near, then state found (exit subroutine) bne GetObjectState_1 ;2 Branch if state not found yet GetObjectState_2: rts ;6 CheckInput: ;Check for input inc LoCnt ;5 Increment low count (3x frames) bne GetJoystick ;2 Branch if no rollover (12.8 seconds) lda HiCnt ;3 Increment hight count if needed clc ;2 adc #$04 ;2 Skip past low 2 bits bcc No_HiCnt_Rollover ;2 ora #$80 ;2 Keep high bit set on rollover No_HiCnt_Rollover: sta HiCnt ;3 Update GetJoystick: lda SWCHA ;4 Get joystick values cmp #$FF ;2 Check for any movement from either stick bne GetJoystick_2 ;2 Branch if movement lda SWCHB ;4 Get the console switches and #$03 ;2 Mask for the reset/select switches cmp #$03 ;2 Have either of them been used? beq GetJoystick_3 ;2 If not, branch GetJoystick_2: lda HiCnt ;3 and #$03 ;2 Preserve low bits sta HiCnt ;3 Clear any attract mode GetJoystick_3: rts ;6 CheckFlip: IF FLIP_DRAGONS ldy #$00 ;2 Set default reflect cmp #>GfxGDrag0 ;2 Check for chasing/biting dragons bne Dont_Flip_Sprite ;2 ...And skip ahead if not IF BW_PAUSE = 0 lda CurrentStick ;3 Check CurrentStick... and #$04 ;2 For BW switch status beq Dont_Flip_Sprite ;2 Skip flip if the BW switch is toggled ENDIF lda PlayerX ;3 Check against player's location sec ;2 sbc ObjX ;3 bmi Dont_Flip_Sprite ;2 If chasing from the right, don't bother ldy #$08 ;2 Set reflect Dont_Flip_Sprite: ENDIF rts ;6 ChangeColor: ;Change color of objects/screens... lsr ;2 Roll bit 0 to carry bcc ChangeColor_2 ;2 If no carry, use original color value lda LoCnt ;3 Otherwise...use frame counter for color ChangeColor_2: bit HiCnt ;3 Check for attract mode bpl ChangeColor_3 ;2 Branch if clear eor HiCnt ;2 Otherwise, flip bits of attract with the original color and #$FB ;2 ...And strip bit 2 ChangeColor_3: asl ;2 Roll bits to their original position rts ;6 StartGame: ;Cold Start sei ;2 Set initial interrupt status cld ;2 Clear any powerup decimal mode ldy #$00 ;2 Set Console = 2600 initially tya ;2 Pass zero value to A for ram clear loop ahead ldx $D0 ;3 Console type checking...look at a couple of ram locations cpx #$2C ;2 This value will be in a 7800 bne SaveConsole ;2 Branch if not ldx $D1 ;3 First test passed...check another to be sure cpx #$A9 ;2 This value will be in a 7800 bne SaveConsole ;2 Branch if not iny ;2 Both tests pass...set Console = 7800 (Y=1) SaveConsole: tax ;2 Clear X for ram clear loop ResetAll: sta $00,x ;4 Save zeros to all ram txs ;2 ...And push stack status until it rolls inx ;2 bne ResetAll ;2 Loop until done sty Level ;3 Save console type to low bit of the Level variable tya ;2 Move that bit a couple of spots upward asl ;2 . asl ;2 . sta CurrentStick ;3 ...And save to current "flip" status lda #<(Rm14-Rm00) ;2 Load a "dark" room number sta SurroundR ;3 ...And save it to the surround's room IF EDGE_PANELS lda #$06 ;2 Position missiles. Near left boundry... ldx #$02 ;2 Set index to point at missile0 jsr PosSpriteX ;6 ...And position it lda #$9D ;2 Near right boundry... ELSE lda #$0D ;2 Position missiles. Near left boundry... ldx #$02 ;2 Set index to point at missile0 jsr PosSpriteX ;6 ...And position it lda #$96 ;2 Near right boundry... ENDIF inx ;2 Bump index to point at missile1 stx LastObj ;3 Bugfix...set last object to anything low stx VDELBL ;3 Set vertical delay of ball jsr PosSpriteX ;6 ...And position it sta WSYNC ;3 Wait for horizontal blank sta HMOVE ;3 Apply horizonal position bmi SetupRoomObjects ;2 Always branch- setup objects' initial rooms and positions CheckGameStart: ;moved to main game loop to avoid triple-nesting lax SWCHB ;4 Get the console switches eor #$FF ;2 Flip (as reset active low) and CurrentStick ;3 Compare with what was before lsr ;2 And check only the reset switch bcc CheckReset ;2 If no reset then branch txa ;2 lsr ;2 Check if switch still held bcs KeepInactive ;2 Branch if so lda ChalliseR ;3 Get the room the Challise is in cmp #WinRoom ;2 Is it in the yellow castle? beq SetupRoomObjects ;2 Branch if game already won (and set up a new game) lda Control ;3 Set the game to active and #$7F ;2 Signal that the game has started sta Control ;3 KeepInactive: lda Control ;3 Has the Game Started? bmi SetupRoomObjects_1 ;2 If not then branch IF USE_TITLE_DISPLAY = 0 jsr DoVSYNC ;6 Wait for VSYNC ENDIF ldx #$07 ;2 Init_Loop: lda Game_Start_Tbl-1,x ;4 Reset the sound and player's room/X/Y to yellow castle sta NoteCnt-1,x ;4 . dex ;2 bne Init_Loop ;2 Loop for all 7 bytes stx RDragonR+4 ;3 Set the red dragon's state to OK stx YDragonR+4 ;3 Set the yellow dragon's state to OK stx GDragonR+4 ;3 Set the green dragon's state to OK sta HiCnt ;3 Set level select & map to be OFF IF RANDOM_XY jmp SignalGameStart ;3 ELSE beq SignalGameStart ;2 Always branch ENDIF StoreSwitchesJmp: jmp StoreSwitches ;3 CheckReset: lsr ;2 And check only the select switch bcc StoreSwitchesJmp ;2 Branch if select not being used lda HiCnt ;3 Check if level select shown (bit0) lsr ;2 bcc SetupRoomObjects ;2 Branch if not (game in progress) lda Level ;3 Get current game level and #$0F ;2 Strip off any sound clc ;2 adc #$02 ;2 Increment the level number (by two) cmp #$06 ;2 Have we reached the maximum? bcc ResetSetup ;2 Branch if not and #$01 ;2 Otherwise, set back to zero ResetSetup: sta Level ;3 Store the new level number SetupRoomObjects: asl Control ;6 Set the game to inactive sec ;2 ror Control ;6 ...By moving set carry flag into high bit SetupRoomObjects_1: IF USE_TITLE_DISPLAY = 0 ldy #$00 ;2 Set the current room sty PlayerRoom ;3 ...To be the "Number" room sty PrevRoom ;3 And the previous room sty PlayerY ;3 And the current and previous vertical co-ordinate sty PrevY ;3 ...So the ball can't be seen iny ;2 Y = 1 ELSE ldy #$01 ;2 Set level select to be ON/map OFF ENDIF sty HiCnt ;3 Update lda Level ;3 Get the level number and #$0F ;2 Strip off any sound sta Level ;3 and #$0E ;2 ...And the remaining bit before giving to the index tay ;2 lda Object_Map_Tbl,y ;4 Get the low pointer to object locations sta CurrentObject ;3 ...And store lda Object_Map_Tbl+1,y ;4 Get the high pointer to object locations sta CurrentObject+1 ;3 ...And store IF USE_TITLE_DISPLAY = 0 jsr DoVSYNC ;6 Wait for VSYNC ENDIF ldy #ByteNum ;2 Copy all the objects dynamic information SetupRoomObjects_2: lda (CurrentObject),y ;5 (The rooms and positions) into sta.wy MapPortR,y ;4 ...The working area dey ;2 bpl SetupRoomObjects_2 ;2 Loop for all lda Level ;3 Get the level number and #$0F ;2 Strip off any sound cmp #$04 ;2 Branch if level one bcc SignalGameStart ;2 Or two (Where all objects are in defined areas) ldy #RndNum ;2 Otherwise, randomize game objects... IF TEST_SEED lda #SEED ;2 Check against known setup pattern sta LoCnt ;3 ENDIF IF RANDOM_XY lda LoCnt ;3 lsr ;2 sta Delta1 ;3 Set initial "random" vertical location ENDIF RandomizeLevel3_2: lda LoCnt ;3 Get the low input counter as seed lsr ;2 IF RANDOM_XY sta Temp ;3 Use bits 6-0 to set a random horizontal location ENDIF lsr ;2 lsr ;2 Generate a psudo-random room number lsr ;2 lsr ;2 sec ;2 adc LoCnt ;3 Store the low input counter sta LoCnt ;3 and #RndMax ;2 Trim so represents a room value cmp Room_Bounds_Tbl+1,y ;4 If it is less than the lower bound for the object... bcc RandomizeLevel3_2 ;2 ...Then get another cmp Room_Bounds_Tbl+2,y ;4 If it equals or is less than the higher bound... beq RandomizeLevel3_3 ;2 For the object... bcs RandomizeLevel3_2 ;2 Then continue (branch if higher) RandomizeLevel3_3: ldx Room_Bounds_Tbl,y ;4 Get the dynamic data index for this object sta $00,x ;4 Store the new room value IF RANDOM_XY eor LoCnt ;3 Set initial "random" vertical location lsr ;2 eor Delta1 ;3 lsr ;2 adc #$18 ;2 sta $02,x ;4 Store the new vertical location lda Temp ;3 Use bits 6-0 to set a random horizontal location sta $01,x ;4 Store the new horizontal location ENDIF dey ;2 Goto the next object dey ;2 . dey ;2 . bpl RandomizeLevel3_2 ;2 Loop until all done SignalGameStart: IF USE_TITLE_DISPLAY = 0 jsr PrintDisplay ;6 Display rooms and objects ENDIF SignalGameStart_2: lda #NullNumber ;2 Set no object carried (zero) sta CarriedObj ;3 StoreSwitches: lda SWCHB ;4 Load current switches and #$0B ;2 Keep B&W, Select, & Reset tax ;4 Load current switches eor CurrentStick ;3 Compare against last and #$08 ;2 Keep only B&W beq No_Toggle ;2 Branch if no change lda Level ;3 lsr ;2 Check for console type bcc A2600 ;2 Branch if 2600 txa ;2 Console is 7800...get switches and #$08 ;2 Keep only B&W bne No_Toggle ;2 Skip return position A2600: lda CurrentStick ;3 eor #$04 ;2 Flip status .byte $2C ;4 Skip 2 bytes No_Toggle: lda CurrentStick ;3 and #$F4 ;2 stx CurrentStick ;3 ora CurrentStick ;3 sta CurrentStick ;3 MainGameLoop: jsr MakeSound ;6 Make noise if necessary IF USE_TITLE_DISPLAY lda HiCnt ;3 Check if level select shown (bit0) lsr ;2 bcc MainGameLoop_1 ;2 Branch if level display/win screen is not shown jsr DoVSYNC ;6 Wait for VSYNC ldy #TITLE_BANK ;2 jsr TitleBankswitch ;3 jmp CheckGameStart ;3 Check for Game Start MainGameLoop_1: lsr ;2 bcc No_Map_Display ;2 Branch if player is not on map screen jsr DoVSYNC ;6 Wait for VSYNC lda PlayerX ;3 Position Ball Strite to the X Coordinate (all frames) clc ;2 adc #$12 ;2 Give a bit more of a margin for the small dot ldx #$04 ;2 Select sprite #5 (ball) jsr PosSpriteX ;6 Execute repositioning subroutine ldy #MAP_BANK ;2 jsr MapBankswitch ;3 sta CXCLR ;3 lda Temp ;3 Check if the map has been exited beq NotReturningFromMap ;2 Branch if not lda MapPortR+2 ;3 Load portal's Y co-ordinate sec ;2 sbc #$10 ;2 ...And adjust by a bit (so player doesn't hit it already) sta MapPortR+2 ;3 Update ;do more map stuff here (such as scrambling enemy locations, etc) NotReturningFromMap: jmp CheckGameStart ;3 Check for Game Start No_Map_Display: ENDIF jsr CheckInput ;6 Check for controller input IF BW_PAUSE lda CurrentStick ;3 and #$04 ;2 Check B&W switch beq NonActiveLoop ;2 Branch if clear (pause) ENDIF lda Control ;3 Is the game active? bmi NonActiveLoop ;2 If not, Branch lda ChalliseR ;3 Get the room the chalise is in cmp #WinRoom ;2 Is it in the yellow castle? bne MainGameLoop_2 ;2 If not, branch lda Control ;3 ora #$80 ;2 sta Control ;3 Set the game to inactive lda #$FF ;2 sta NoteCnt ;3 Set the note count to maximum lda Sound ;3 and #$0F ;2 Set the noise type to end-noise sta Sound ;3 ...And store MainGameLoop_2: ldy #$00 ;2 Allow joystick read - all movement jsr BallMovement ;6 Check ball collisions and move ball jsr MoveCarriedObject ;6 Move any carried object jsr DoVSYNC ;6 Wait for VSYNC jsr CacheObjects ;6 Get next two objects to display jsr PrintDisplay ;6 Display the room and objects jsr PickupPutdown ;6 Deal with object pickup and putdown ldy #$01 ;2 Disallow joystick read - move vertically only jsr BallMovement ;6 Check ball collisions and move ball jsr Surround ;6 Deal with surround moving jsr DoVSYNC ;6 Wait for VSYNC jsr MoveBat ;6 Move and deal with bat ldy #Gates ;2 For each portcullis jsr Portals_2 ;6 Move and deal with portcullises jsr PrintDisplay ;6 Display the room and objects jsr MoveGreenDragon ;6 Move and deal with the green dragon jsr MoveYellowDragon ;6 Move and deal with the yellow dragon jsr DoVSYNC ;6 Wait for VSYNC ldy #$02 ;2 Disallow stick read/bridge check - move horizontally only jsr BallMovement ;6 Check ball collisions and move ball jsr MoveRedDragon ;6 Move and deal with red dragon jsr Magnet_Routine ;6 Deal with the magnet jsr PrintDisplay ;6 Display the room and objects jmp CheckGameStart ;3 Check for Game Start NonActiveLoop: ;Non-Active Game Loop jsr DoVSYNC ;6 Wait for VSYNC IF USE_TITLE_DISPLAY = 0 lda PlayerRoom ;3 bne Dont_Slow_Display ;2 Branch if level display is not shown jsr PrintDisplay ;6 Do another frame to slow down jsr DoVSYNC ;6 Dont_Slow_Display: ENDIF jsr PrintDisplay ;6 Display the room and objects IF SIMULATE_CHALISE_FLASH inc BatR+4 ;5 Bump the bat state ENDIF jsr CacheObjects ;6 Get next two objects to display jmp CheckGameStart ;3 Check for Game Start IF UNROLL_SUBS = 0 FindObjHit: ;Find which object has hit object wanted bit CXPPMM ;3 Get Player00-Player01 bpl FindObjHit_2 ;2 If nothing, Branch cpx CurrentObject+2 ;3 Is object 1 the one being hit? beq FindObjHit_3 ;2 If so, Branch cpx CurrentObject+3 ;3 Is object 2 the one being hit? beq FindObjHit_4 ;2 If so, Branch FindObjHit_2: lda #NullNumber ;2 Neither, select the null object (zero) rts ;6 FindObjHit_3: lda CurrentObject+3 ;3 Yes, select the other rts ;6 FindObjHit_4: lda CurrentObject+2 ;3 Yes, select the other rts ;6 ENDIF PickupPutdown: ;Deal with object pickup and putdown lda INPT4 ;3 Get left joystick trigger IF MERGE_STICKS and INPT5 ;3 Mix with right joystick trigger ENDIF bmi PickupPutdown_2 ;2 Branch if no change lda CarriedObj ;3 Check carried object (if any) beq PickupPutdown_2 ;2 Branch if nothing is being carried lda #NullNumber ;2 Set to nothing (zero) sta CarriedObj ;3 ...And drop object lda Sound ;2 Do the dropping noise: and #$0F ;2 Strip any current sound ora #$50 ;2 Set noise type to five (drop object) sta Sound ;3 lda #$04 ;2 sta NoteCnt ;3 Set noise count to four notes PickupPutdown_2: ;Check for collision bit CXP0FB ;3 Get Ball-Player00 collision bvc PickupPutdown_3 ;2 If nothing occured then branch ldx CurrentObject+2 ;3 With Player00...get type of Player00 jmp CollisionDetected ;3 Deal with collision PickupPutdown_4: IF USE_TITLE_DISPLAY cpx #MapPortNumber ;2 Is the map portal hit? bne PickupPutdown_5 ;2 Branch if not lda HiCnt ;3 Set the "map active" bit ora #$02 ;2 . sta HiCnt ;3 . lda #$40 ;2 Put player in the middle of the map sta PlayerX ;3 . ENDIF PickupPutdown_5: rts ;6 PickupPutdown_3: bit CXP1FB ;3 Get Ball-Player01 collision bvc PickupPutdown_5 ;2 If nothing has happened, branch ldx CurrentObject+3 ;3 Get type of Player01... CollisionDetected: ;Collision occurred (with something)... cpx #SwordNumber ;2 Is it carriable? bcc PickupPutdown_4 ;2 If not, branch cpx CarriedObj ;3 Is it the object being carried? beq PickupObject ;2 If so, branch (and skip pickup sound) lda Sound ;3 Otherwise, set the object pickup noise and #$0F ;2 Strip any current sound ora #$40 ;2 Set noise type to four (pickup object) sta Sound ;3 lda #$04 ;2 Set noise type to four notes sta NoteCnt ;3 PickupObject: stx CarriedObj ;3 Set the object as being carried lda Object_Data_LSB,x ;4 Get and store the low address tax ;2 lda CurrentStick ;3 Direction moved into the object... lsr ;2 lsr ;2 lsr ;2 lsr ;2 tay ;2 lda $01,x ;4 Get the object's X co-ordinate sec ;2 sbc PlayerX ;3 Subtract the ball's X co-ordinate clc ;2 adc X6pixels,y ;4 sta CarriedX ;3 ...And store the difference for the carried object lda $02,x ;4 Get the object's Y coordinate sec ;2 sbc PlayerY ;3 Subtract the Ball's Y coordinate clc ;2 adc Y6pixels,y ;4 sta CarriedY ;3 ...And store the difference for the carried object MoveCarriedObject_2: rts ;6 MoveCarriedObject: ;Move the carried object ldy CarriedObj ;3 Get the object being carried beq MoveCarriedObject_2 ;2 If nothing carried, return lda Object_Data_LSB,y ;4 Get and store the low address tax ;2 Transfer to the X register lda PlayerRoom ;3 Get the current room sta $00,x ;4 ...And store the object's current room IF ROTATING_SWORD cpy #SwordNumber ;2 Check if carried object is the sword bne KeepOldCarryY ;2 If not, skip this lda CurrentStick ;3 Get current direction moving lsr ;2 Move to low nybble... lsr ;2 . lsr ;2 . lsr ;2 . tay ;2 ...And give to an index register lda CarryXtbl,y ;4 Using a table, load the new position bmi KeepOldCarryX ;2 If invalid, don't update asl ;2 sta CarriedX ;2 ...Or store as current KeepOldCarryX: lda CarryYtbl,y ;4 Do the same for vertical bmi KeepOldCarryY ;2 If invalid, don't update asl ;2 sta CarriedY ;3 ...Or store as current KeepOldCarryY: ENDIF lda PlayerX ;3 Get the ball's horizontal co-ordinate clc ;2 adc CarriedX ;3 Add the horizontal difference sta $01,x ;4 ...And store as the object's horizontal co-ordinate lda PlayerY ;3 Get the ball's vertical co-ordinate clc ;2 adc CarriedY ;3 Add the vertical difference jmp MoveObjectDelta ;3 ...And jump to store BallMovement: ;Check ball collisions and move ball using bit to check the two upper bits lda CXBLPF ;3 Get ball-playfield collision IF IGNORE_WALLS = 0 bmi PlayerCollision ;2 Branch if collision (Player-Wall) ENDIF bit CXM0FB ;3 Get ball-missile00 collision IF IGNORE_LEFT_PANELS = 0 bvs PlayerCollision ;2 Branch if collision. (Player-Left Thin) ENDIF bit CXM1FB ;3 Get ball-missile01 collision bvc BallMovement_2 ;2 Branch if no collision lda CurrentObject+3 ;3 If object2 (to print) is... cmp #DotNumber ;2 ...Not the black dot IF IGNORE_DOT = 0 bne PlayerCollision ;2 ...Then collide with the panel ENDIF BallMovement_2: ;using bit to check the flags instead of and... bit CXP0FB ;3 Get sprite0-ball collision bvc BallMovement_3 ;2 If no collision then branch lda CurrentObject+2 ;3 If object1 (to print) is "solid"... cmp #LastPassNumber ;2 bcs PlayerCollision ;2 ...Then branch (collision) BallMovement_3: bit CXP1FB ;3 Get sprite1-ball collision bvc NoCollision ;2 If no collision then branch lda CurrentObject+3 ;3 If player01 to print is "passthru"... cmp #LastPassNumber+1 ;2 bcc NoCollision ;2 ...Then branch (no collision) PlayerCollision: ;Player collided (with something) cpy #$02 ;2 Are we checking for the bridge? bne ReadStick ;2 If not, branch lda CarriedObj ;3 Get the object being carried cmp #BridgeNumber ;2 Branch if it is the bridge beq ReadStick ;2 lda PlayerRoom ;3 Get the current room cmp BridgeR ;3 Is the bridge in this room? bne ReadStick ;2 If not, branch lda PlayerX ;3 Check going thru bridge...get the ball's X coordinate sec ;2 sbc BridgeR+1 ;3 Subtract the bridge's X coordinate cmp #$0A ;2 If less than 10 pixels then forget it bcc ReadStick ;2 cmp #$17 ;2 If more than 23 pixels then forget it bcs ReadStick ;2 lda BridgeR+2 ;3 Get the bridge's Y coordinate sec ;2 sbc PlayerY ;3 Subtract the ball's Y coordinate cmp #$FC ;2 bcs NoCollision ;2 If more than $FC then going through bridge cmp #$19 ;2 If more than $19 then forget it bcs ReadStick ;2 NoCollision: ;No collision (and going through bridge) lda CurrentStick ;3 ora #$F0 ;2 Reset the joystick input sta CurrentStick ;3 lda PlayerRoom ;3 Get the current room... sta PrevRoom ;3 ...And store temporarily lda PlayerX ;3 Get the ball's X coordinate... sta PrevX ;3 ...And store temporarily lda PlayerY ;3 Get the ball's Y coordinate... sta PrevY ;3 ...And Store Temporarily ReadStick: ;Read Sticks tya ;2 Check for zero (all movement) bne ReadStick_2 ;2 If not, don't bother with joystick read lda CurrentStick ;3 and #$0F ;2 sta CurrentStick ;3 lda SWCHA ;4 Read joysticks IF MERGE_STICKS asl ;2 Move right stick to upper nybble asl ;2 . asl ;2 . asl ;2 . and SWCHA ;4 ...And mix with left stick ELSE and #$F0 ;2 Trim to read left stick only ENDIF IF ROTATING_SWORD cmp #$F0 ;2 beq Not_the_sword ;2 Not moving...skip update ldx CarriedObj ;3 Check object being carried cpx #SwordNumber ;2 Is it the sword? bne Not_the_sword ;2 If not, branch sta SwordState ;3 ...or update the sword's rotation based on movement Not_the_sword: ENDIF ora CurrentStick ;3 sta CurrentStick ;3 ReadStick_2: lda PrevRoom ;3 Get Temporary room... sta PlayerRoom ;3 ...And make it the current room lda PrevX ;3 Get temporary X coordinate... sta PlayerX ;3 ...And make it the ball's X coordinate lda PrevY ;3 Get temporary Y coordinate... sta PlayerY ;3 ...And make it the ball's Y coordinate lda CurrentStick ;3 Get the Joystick position ora ReadStick_3,y ;4 Merge out movement not allowed in this phase sta ObjDir ;3 ...And store cooked movement ldx #PlayerRoom ;2 Point to ball's co-ordinates ldy #THREE_PIXELS ;2 Set the delta for the ball (3 pixels) bne MoveGroundObject ;2 Branch to move the ball IF UNROLL_SUBS = 0 PBCollision: ;Get player-ball collision cmp CurrentObject+2 ;3 Is it the first object? beq PBCollision_2 ;2 YES - Then Branch cmp CurrentObject+3 ;3 Is it the second object? beq PBCollision_3 ;2 YES - Then Branch lda #$00 ;2 Otherwise, nothing rts ;6 PBCollision_2: lda CXP0FB ;3 Get player00-ball collision .byte $2C ;4 Skip next 2 bytes (BIT.w) PBCollision_3: lda CXP1FB ;3 Get player01-ball collision asl ;2 Move bit6 to bit7's spot rts ;6 ENDIF MoveGameObject: ldx Delta1 ;3 Get dynamic data address lda ObjDir ;3 Get Movement bne MoveGameObject_2 ;2 If movement then branch lda $03,x ;4 Use old movement MoveGameObject_2: sta $03,x ;4 Store the new movement ldy Delta2 ;3 Get the object's Delta MoveGroundObject: ;Move the object and #$F0 ;2 Check for motion beq MoveObjectNoDelta ;2 Skip if no movement cmp #$F0 ;2 beq MoveObjectNoDelta ;2 Skip if no movement sty ObjAddress ;3 Store delta cpy #$00 ;2 beq MoveObjectNoDelta ;2 Skip if no movement lsr ;2 lsr ;2 lsr ;2 lsr ;2 tay ;2 lda Xeor,y ;4 Flip direction if applicable cmp #$80 ;2 beq SkipXadjustment ;2 eor ObjAddress ;3 Load the delta clc ;2 bpl NotLeft ;2 adc #$01 ;2 NotLeft: adc $01,x ;4 Add the horizontal coordinate sta $01,x ;4 Store the horizontal coordinate SkipXadjustment: lda Yeor,y ;4 Flip direction if applicable cmp #$80 ;2 beq MoveObjectNoDelta ;2 eor ObjAddress ;3 Load the delta clc ;2 bpl NotDown ;2 adc #$01 ;2 NotDown: adc $02,x ;4 Add the vertical co-ordinate MoveObjectDelta: sta $02,x ;4 Store the vertical co-ordinate MoveObjectNoDelta: ldy #Gates ;2 Set to do the three portcullises MoveGroundObject_2: sty ObjAddress ;3 lda.wy YGateR,y ;4 Get the portal state cmp #$1C ;2 Is it in a closed state? beq GetPortal ;2 If not, next portal ldy ObjAddress ;3 Deal with object moving out of a castle...get port number lda $00,x ;4 Get object's room number cmp EntryRoomOffsets,y ;4 Is it in a castle entry room bne GetPortal ;2 If not, next portal lda $02,x ;4 Get the object's Y coordinate cmp #$0D ;2 Is it above $0D i.e at the bottom? bpl GetPortal ;2 If so then branch lda CastleRoomOffsets,y ;4 Get the castle room sta $00,x ;4 And put the object in the castle room lda #$50 ;2 sta $01,x ;4 Set the object's new X coordinate lda #$2C ;2 sta $02,x ;4 Set the new object's Y coordinate lda #$00 ;2 sta.wy YGateR,y ;4 Set the portcullis state to Open rts ;6 GetPortal: ldy ObjAddress ;3 Get the portcullis number dey ;2 ...Goto next portcullis bpl MoveGroundObject_2 ;2 ...And loop until done ldy $00,x ;4 Check and Deal with Up...get the object's room lda $02,x ;4 Get the object's vertical co-ordinate cmp #$6A ;2 Has it reached above the top bmi DealWithLeft ;2 If not, branch lda #$0D ;2 Set new vertical co-ordinate to bottom sta $02,x ;4 lda North_Map_Tbl,y ;4 Get the room number to the North jmp GetNewRoom ;3 DealWithLeft: ;Check and Deal with Left lda $01,x ;4 Get the object's horizontal co-ordinate cmp #$02 ;2 Is it Two or less? bcc DealWithLeft_2 ;2 If so, branch (off to left) cmp #$F0 ;2 Is it's $F0 or more bcc DealWithDown ;2 If not, branch (off to left) DealWithLeft_2: cpx #PlayerRoom ;2 Are we dealing with the ball? beq DealWithLeft_3 ;2 If so then branch lda #$9A ;2 Set new horizontal co-ordinate for the others bne DealWithLeft_4 ;2 Always branch DealWithLeft_3: lda #$9E ;2 Set new horizontal co-ordinate for the ball DealWithLeft_4: sta $01,x ;4 Store the next horizontal co-ordinate lda West_Map_Tbl,y ;4 Get the room number to the Left jmp GetNewRoom ;3 DealWithDown: ;Check and Deal with Down lda $02,x ;4 Get object's Y coordinate cmp #$0D ;2 If it's greater than $0D bcs DealWithRight ;2 ...Then branch lda #$69 ;2 Set new vertical co-ordinate sta $02,x ;4 lda South_Map_Tbl,y ;4 Get the room number to the South jmp GetNewRoom ;3 DealWithRight: ;Check and Deal with Right lda $01,x ;4 Get the object's horizontal co-ordinate cpx #PlayerRoom ;2 Are we dealing with the ball? bne DealWithRight_2 ;2 Branch if not cmp #$9F ;2 Has the object reached the right? bcc MovementReturn ;2 Branch if not lda $00,x ;4 Get the Ball's Room cmp #<(Rm03-Rm00) ;2 Is it room #3 (Right to secret room) bne DealWithRight_3 ;2 Branch if not IF IGNORE_DOT = 0 lda DotR ;3 Check the room of the black dot cmp #<(Rm15-Rm00) ;2 Is it in the hidden room area? beq DealWithRight_3 ;2 If so, Branch ENDIF lda #$02 ;2 Set the horizontal co-ordinate sta $01,x ;4 lda #<(Rm1E-Rm00) ;2 Manually change to secret room bne AdjustRoomLevel_2 ;2 Always branch (store room # as current and exit) DealWithRight_2: cmp #$9B ;2 Has the object reached the right of screen? bcc MovementReturn ;2 Branch if not (no room change) DealWithRight_3: lda #$02 ;2 Set the next horizontal co-ordinate sta $01,x ;4 lda East_Map_Tbl,y ;4 Get the room number to the Right GetNewRoom: ;Adjust room for different levels bpl AdjustRoomLevel_2 ;2 Branch if high bit not set and #$7F ;2 Remove the high bit... tay ;2 Set pointer lda Level ;3 Get the level number and #$0E ;2 Strip off any sound cmp #$02 ;2 Level 2? beq FindLevel2Room ;2 Branch if second game cmp #$04 ;2 Level 3? beq FindLevel3Room ;2 Branch if second game lda Level1Diffs,y ;4 Use as an offset to get the next room AdjustRoomLevel_2: sta $00,x ;4 ...And store as new object's room MovementReturn: rts ;6 FindLevel2Room: lda Level2Diffs,y ;4 Use as an offset to get the next room sta $00,x ;4 ...And store as new object's room rts ;6 FindLevel3Room: lda Level3Diffs,y ;4 Use as an offset to get the next room sta $00,x ;4 ...And store as new object's room rts ;6 GetLikedObject: ;Find liked object and get movement ldy #$FF ;2 Set index to zero GetLikedObject_2: iny ;2 sty Index1 ;3 Set the index number lda (ObjLst),y ;5 Get first object beq GetLikedObject_3 ;2 Check for table end right away sta Temp ;3 tax ;2 lda $00,x ;4 Get object1's room sta ObjDir ;3 Temp (xroom) iny ;2 lda (ObjLst),y ;5 Get second object tax ;2 lda $00,x ;4 Compare with object2's room cmp ObjDir ;3 Temp (xroom) bne GetLikedObject_2 ;2 If not the same room then branch cpx ObjCr ;3 Have we matched the second object beq GetLikedObject_2 ;2 ...For difficulty? (if so, carry on) lda Temp ;3 Temp (x) cmp ObjCr ;3 Have we matched the first object? beq GetLikedObject_2 ;2 Branch if so (56 cycles each pass) GetLikedObject_4: ;Work out object's movement ldy Temp ;3 Temp (x) lda #$FF ;2 Set object movement to none sta ObjDir ;3 lda $00,x ;4 Get object2's room cmp.wy $00,y ;4 Compare it with object's room bne GetLikedObject_8 ;2 If not the same, forget it lda $01,x ;4 Get Object2's horizontal co-ordinate cmp.wy $01,y ;4 Get Object1's horizontal co-ordinate bcc GetLikedObject_5 ;2 If Object2 to left of Object1 then branch beq GetLikedObject_6 ;2 If Object2 = Object1 then branch lda #$7F ;2 Signal a move right bne GetLikedObject_5b ;2 Always branch GetLikedObject_5: lda #$BF ;2 Signal a move left GetLikedObject_5b: cpy #MagnetR ;2 Bugfix... bne GetLikedObject_5c ;2 eor #$C0 ;2 GetLikedObject_5c: sta ObjDir ;3 GetLikedObject_6: lda $02,x ;4 Get Object2's vertical co-ordinate cmp.wy $02,y ;4 Compare with Get Object1's vertical co-ordinate bcc GetLikedObject_7 ;2 If Object2 is below Object1 then branch beq GetLikedObject_8 ;2 If Object2 is equal to Object1's position then branch lda #$EF ;2 Signal a move up bne GetLikedObject_9 ;2 Always branch GetLikedObject_8: lda ObjDir ;3 Get the move rts ;6 GetLikedObject_7: lda #$DF ;2 Signal a move down GetLikedObject_9: and ObjDir ;3 Get object movement cpy #MagnetR ;2 Bugfix... bne GetLikedObject_3 ;2 ldy MagSave ;3 Bugfix...check backup cpy #<MAGNET_HEIGHT ;2 ...For lowest valid position bcc GetLikedObject_3 ;2 Branch if clear (and continue current course) eor #$30 ;2 ...Otherwise, reverse direction GetLikedObject_3: ;tag moved down here sta ObjDir ;3 rts ;6 MoveRedDragon: ;Move the Red Dragon lda #<RedDragMatrix ;2 Select red dragon's "liked" matrix address LSB ldy #THREE_PIXELS ;2 Use fast speed for the red dragon (delta) ldx #RDragonNumber ;2 ...And point at the first byte of ram for the dragon bne MoveDragon ;2 Always branch MoveYellowDragon: ;Move the Yellow Dragon lda #<YelDragMatrix ;2 Select yellow dragon's "liked" matrix address LSB ldx #YDragonNumber ;2 ...And point at the first byte of ram for the dragon bne DragonSlowSpeed ;2 Always branch MoveGreenDragon: ;Move the Green Dragon lda #<GreenDragonMatrix ;2 Select green dragon's "liked" matrix address LSB ldx #GDragonNumber ;2 ...And point at the first byte of ram for the dragon DragonSlowSpeed: ldy #TWO_PIXELS ;2 Slow speed (delta) ;existing lines... MoveDragon: sta ObjLst ;3 Set low address of object store sty Delta2 ;3 Set the dragon's delta lda #>RedDragMatrix ;2 NOTE: all dragon matrixes must be on the same page! sta ObjLst+1 ;3 Set high address of object store stx ObjectNumber ;3 Save Object were dealing with lda Object_Data_LSB,x ;4 Get the Object's dynamic data tax ;2 lda $04,x ;4 Get the Object's state IF ANIMATE_DRAGON lsr ;2 Ignore any animation frame ENDIF beq MoveDragon_1 ;2 Branch if roaming MoveDragon_6: ;these values still work...since the state was LSR'ed before going here cmp #$01 ;2 Is it in state 02 (dead)? beq MoveDragon_9 ;2 Branch if so (return) cmp #$02 ;2 Is it in state 04 (ball already swallowed)? bne MoveDragon_7 ;2 Branch if not lda $01,x ;4 Get the dragon's horizontal co-ordinate clc ;2 Normal dragon state 2 (eaten ball) adc #$03 ;2 Adjust to it's belly location sta PlayerX ;3 ...And store as the ball's horizontal co-ordinate sta PrevX ;3 ...And ball's previous horizontal co-ordinate lda $02,x ;4 Get the Dragon's vertical co-ordinate sec ;2 sbc #$0B ;2 Adjust to it's belly location sta PlayerY ;3 ...And store as the ball's vertical co-ordinate sta PrevY ;3 ...And ball's previous vertical co-ordinate ldy $00,x ;4 Get the dragon's current room sty PlayerRoom ;3 Store as the ball's current room sty PrevRoom ;3 ...And previous room rts ;6 MoveDragon_7: ;Dragon Roaring IF ANIMATE_DRAGON lda $04,x ;4 Get the Object's state ENDIF tay ;2 Transfer state to Y iny ;2 Bump state sty $04,x ;4 Save it's state cpy #$FC ;2 Is it near the end? bcc MoveDragon_9 ;2 If not, branch lda ObjectNumber ;3 Get the dragon's number IF UNROLL_SUBS ;Get player-ball collision cmp CurrentObject+2 ;3 Is it the first object? beq DragCollision_2 ;2 YES - Then Branch cmp CurrentObject+3 ;3 Is it the second object? bne MoveDragon_9 ;2 NO - Then Branch lda CXP1FB ;3 Get player01-ball collision .byte $2C ;4 Skip next 2 bytes (BIT.w) DragCollision_2: lda CXP0FB ;3 Get player00-ball collision asl ;2 Move bit6 to bit7's spot ELSE jsr PBCollision ;6 Get the player-ball collision ENDIF bpl MoveDragon_9 ;2 If not, branch IF ANIMATE_DRAGON lda #$04 ;2 Set the state to state 04 : eaten ELSE lda #$02 ;2 Set the state to state 02 : eaten ENDIF sta $04,x ;4 lda Sound ;3 and #$0F ;2 Strip any current sound ora #$20 ;2 Set noise two (roar) sta Sound ;3 lda #$10 ;2 Set the count of noise to 17 frames sta NoteCnt ;3 lda #$9B ;2 Get the maximum horizontal co-ordinate cmp $01,x ;4 Compare with the dragon's horizontal co-ordinate beq MoveDragon_8 ;2 bcs MoveDragon_8 ;2 sta $01,x ;4 If too large then use it MoveDragon_8: lda #$0F ;2 Set minimum vertical co-ordinate cmp $02,x ;4 Compare with the dragon's vertical co-ordinate bcc MoveDragon_9 ;2 sta $02,x ;4 If too small, set as dragon's vertical co-ordinate MoveDragon_9: rts ;6 MoveDragon_1: IF ANIMATE_DRAGON sta $04,x ;5 Save w/bit0 missing lda BatR+4 ;3 Get bat's animation lsr ;2 Use only 1 bit...roll bit2 down to carry lsr ;2 . lsr ;2 . rol $04,x ;6 ...And merge carry into dragon's state as bit0 lda #$00 ;2 Reload zero value needed ahead ENDIF bit SWCHB ;4 Dragon normal (State 1)...read console switches bmi MoveDragon_2 ;2 If expert, branch (don't ignore sword) lda #SwordR ;2 Set easy - ignore sword MoveDragon_2: sta ObjCr ;3 Store difficulty stx Delta1 ;3 Store dynamic data address jsr GetLikedObject ;6 Get liked object and movement jsr MoveGameObject ;6 lda ObjectNumber ;3 Get Object# IF UNROLL_SUBS ;Get player-ball collision cmp CurrentObject+2 ;3 Is it the first object? beq DragCollision_3 ;2 YES - Then Branch cmp CurrentObject+3 ;3 Is it the second object? bne MoveDragon_4 ;2 NO - Then Branch lda CXP1FB ;3 Get player01-ball collision .byte $2C ;4 Skip next 2 bytes (BIT.w) DragCollision_3: lda CXP0FB ;3 Get player00-ball collision asl ;2 Move bit6 to bit7's spot ELSE jsr PBCollision ;6 Get the player-ball collision ENDIF bpl MoveDragon_4 ;2 If none then branch lda Level ;3 Get level number and #$0E ;2 Strip off any sound tay ;2 Create lookup bit SWCHB ;4 Get console switches bvc MoveDragon_3 ;2 If P0="B" then branch iny ;2 Bump lookup MoveDragon_3: lda DragonDiff,y ;4 Get new state sta $04,x ;4 Store as dragon's state (open mouthed) lda PrevX ;3 Get temp ball horizontal co-ordinate sta $01,x ;4 ...And store as dragon's lda PrevY ;3 Get temp ball vertical co-ordinate sta $02,x ;4 ...And store as dragon's lda #$10 ;2 sta NoteCnt ;3 Set noise count to 17 frames ora Sound ;3 and #$1F ;2 Strip any current sound and mix w/bit4 set sta Sound ;3 Set noise type to 01 (roar) MoveDragon_4: stx ObjAddress ;3 Store object's dynamic data address ldx ObjectNumber ;3 Get the object number IF UNROLL_SUBS FindDragHit: ;Find which object has hit object wanted bit CXPPMM ;3 Get Player00-Player01 bpl FindDragHit_2 ;2 If nothing, Branch lda CurrentObject+3 ;3 Select object2 cpx CurrentObject+2 ;3 Is object1 the one being hit? beq FindDragHit_4 ;2 If so, Branch cpx CurrentObject+3 ;3 Is object2 the one being hit? beq FindDragHit_3 ;2 If so, Branch FindDragHit_2: lda #NullNumber ;2 Neither, select the null object (zero) beq FindDragHit_4 ;2 Always branch FindDragHit_3: lda CurrentObject+2 ;3 If object2 hit, select object1 FindDragHit_4: ELSE jsr FindObjHit ;6 See if another object has hit the dragon ENDIF ldx ObjAddress ;3 Get the object's address cmp #SwordNumber ;2 Has the sword hit the dragon? bne MoveDragon_5 ;2 If not, branch IF ANIMATE_DRAGON lda #$02 ;2 Set the state to 02 (dead) ELSE lda #$01 ;2 Set the state to 01 (dead) ENDIF sta $04,x ;4 lda Sound ;3 and #$0F ;2 Strip any current sound ora #$30 ;2 Set sound three (dying dragon) sta Sound ;3 ...And store lda #$10 ;2 Set a noise count of 17 frames sta NoteCnt ;3 ...And store MoveDragon_5: rts ;6 MoveBat: ;Move and deal with the bat ldx #BatR ;2 Set the bat's dynamic data address ldy #THREE_PIXELS ;2 Set the bat's delta (3 pixels) inc BatR+4 ;5 Bump the bat state lda BatR+4 ;3 Get the bat state cmp #$10 ;2 In the "fed-up" range? beq MoveBat_2 ;2 Bat is STILL fed-up...correct the state bcc MoveBat_3 ;2 If bat is fed-up then branch lda BatR+3 ;3 Get the bat's movement jsr MoveGroundObject ;6 Move the bat jmp MoveBat_4 ;3 Jump to update the bat's carried object (if any) MoveBat_2: ;Bat Fed-Up, correct the state lda #$00 ;2 Bump state back to zero sta BatR+4 ;3 MoveBat_3: ;Bat Fed-Up stx Delta1 ;3 Store the bat's dynamic data address sty Delta2 ;3 Store the bat's delta (3 pixels) lda #<BatMatrix ;2 Set the low address of object store sta ObjLst ;3 lda #>BatMatrix ;2 Set the high address of object store sta ObjLst+1 ;3 lda BatR+5 ;3 Get object being carried by bat... sta ObjCr ;3 ...And copy jsr GetLikedObject ;6 Get liked object and movement jsr MoveGameObject ;6 Move the bat ldy Index1 ;3 Get "object liked" index lda (ObjLst),y ;5 Look up the object in the bat's table of "liked" objects beq MoveBat_4 ;2 If nothing found then forget it iny ;2 lax (ObjLst),y ;5 Get the object wanted lda $01,x ;4 Get the object's horizontal co-ordinate sec ;2 ;See if the bat can pick up object sbc BatR+1 ;3 Find the difference with the bat's horizontal co-ordinate clc ;2 adc #$04 ;2 Adjust so the bat is in middle of the object and #$F8 ;2 Is the bat within seven pixels either direction? bne MoveBat_4 ;2 If not, no pickup possible lda $02,x ;4 Get the object's vertical co-ordinate sec ;2 sbc BatR+2 ;3 Find the difference with the bat's vertical co-ordinate clc ;2 adc #$04 ;2 Adjust and #$F8 ;2 Is the bat within seven pixels either direction? bne MoveBat_4 ;2 If not, no pickup possible stx BatR+5 ;3 Both passed...store the object as being carried IF BAT_REVIVES_DRAGONS cpx #GDragonR+1 ;2 Compare to whatever the last dragon is bcs MoveOn ;2 Branch if object is not a dragon sta $04,x ;4 Otherwise, use known A value to revive applicable dragon MoveOn: ENDIF lda BatR+4 ;3 ora #$10 ;2 Reset the bat's "fed-up" time sta BatR+4 ;3 MoveBat_4: ;Move object being carried by bat ldx BatR+5 ;3 Get object being carried by bat beq MoveBat_5 ;2 Branch if none lda BatR ;3 Get the bat's room sta $00,x ;4 Store this as the carried object's room lda BatR+1 ;3 Get the bat's horizontal co-ordinate clc ;2 adc #$08 ;2 Adjust to the right by 8 pixels sta $01,x ;4 Make it the object's horizontal co-ordinate lda BatR+2 ;3 Get the bat's vertical co-ordinate sta $02,x ;4 Store it as the object's vertical co-ordinate lda BatR+5 ;3 Get the object being carried by the bat ldy CarriedObj ;3 Get the object being carried by the ball eor Object_Data_LSB,y ;4 Are the the same? bne MoveBat_5 ;2 If not, branch sta CarriedObj ;3 Otherwise, store null object to player (bat wins) MoveBat_5: rts ;6 Portals_2: ;Deal with Portcullis and Collisions ldx PortOffsets,y ;4 Get the portcullises offset number IF UNROLL_SUBS FindGateHit: ;Find which object has hit object wanted bit CXPPMM ;3 Get Player00-Player01 bpl FindGateHit_2 ;2 If nothing, Branch lda CurrentObject+3 ;3 Select object2 cpx CurrentObject+2 ;3 Is object1 the one being hit? beq FindGateHit_4 ;2 If so, Branch cpx CurrentObject+3 ;3 Is object2 the one being hit? beq FindGateHit_3 ;2 If so, Branch FindGateHit_2: lda #NullNumber ;2 Neither, select the null object (zero) beq FindGateHit_4 ;2 Always branch FindGateHit_3: lda CurrentObject+2 ;3 If object2 hit, select object1 FindGateHit_4: ELSE jsr FindObjHit ;6 See if an object collided with it ENDIF sta Temp ;3 ...Store that object ldx YGateR,y ;4 cmp KeyOffsets,y ;4 Is it the associated key? IF NO_TRAP beq Portals_7a ;2 If so, then branch ELSE bne Portals_3 ;2 If not, then branch inx ;2 Otherwise, change the portcullis state to open or close ENDIF Portals_3: cpx #$1C ;2 Is it closed? beq Portals_8 ;2 If so, then branch (altered) lda PortOffsets,y ;4 Get the portcullis number IF UNROLL_SUBS ;Get player-ball collision cmp CurrentObject+2 ;3 Is it the first object? beq GateCollision_2 ;2 YES - Then Branch cmp CurrentObject+3 ;3 Is it the second object? bne Portals_4 ;2 NO - Then Branch lda CXP1FB ;3 Get player01-ball collision .byte $2C ;4 Skip next 2 bytes (BIT.w) GateCollision_2: lda CXP0FB ;3 Get player00-ball collision GateCollision_3: asl ;2 Move bit6 to bit7's spot ELSE jsr PBCollision ;6 Get the player-ball collision ENDIF bpl Portals_4 ;2 If none, then branch lda #$00 ;2 Set the portcullis to open state sta ObjAddress ;3 Store port's state temporarily (altered) ldx #PlayerRoom ;2 Set to the castle bne Portals_6 ;2 Always branch (put the ball in the castle) (altered) Portals_4: stx ObjAddress ;3 Store port's state temporarily (altered) ldx Temp ;3 Get object cpx #LastPassNumber ;2 Is it a passthru object? bcc Portals_7 ;2 If so, branch lda Object_Data_LSB,x ;4 Get the object's ram address tax ;2 Transfer the object's ram address to X Portals_6: lda EntryRoomOffsets,y ;4 Look up the castle entry room for this portal sta $00,x ;4 Make it the object's room lda #$10 ;2 Give the object a new vertical co-ordinate sta $02,x ;4 Portals_7: ldx ObjAddress ;3 Retrieve port's state (altered) beq Portals_8 ;2 If open, then branch (altered) Portals_7a: inx ;2 cpx #$38 ;2 Has it reached the maximum state? bne Portals_8 ;2 If not, branch ldx #$00 ;2 Set to open state Portals_8: stx YGateR,y ;4 dey ;2 Goto the next portcullis bpl Portals_2 ;2 Loop until done rts ;6 Magnet_Routine: ;Deal with magnet lda MagnetR+2 ;3 Get Magnet's vertical co-ordinate sta MagSave ;3 Make a backup for when exiting this routine sec ;2 sbc #<MAGNET_HEIGHT ;2 Adjust to it's "poles" during it sta MagnetR+2 ;3 lda #$00 ;2 Ignore difficulty sta ObjCr ;3 lda #<MagnetMatrix ;2 Set low address of object store sta ObjLst ;3 lda #>MagnetMatrix ;2 Set high address of object store sta ObjLst+1 ;3 jsr GetLikedObject ;6 Get "liked object" and set movement lda ObjDir ;3 Get movement beq Mag_2 ;2 If none, then forget It ldy #ONE_PIXEL ;2 Set delta to 1 pixel (very slow movement) jsr MoveGroundObject ;6 Move the "liked" object until it's equal to magnet's poles Mag_2: lda MagSave ;3 Restore magnet's actual position sta MagnetR+2 ;3 rts ;6 Surround: ;Deal with surround movement ldy PlayerRoom ;3 Get the current room lda RoomGFX_MSB_Tbl,y ;4 Get the room's CTRL and #SURROUND ;2 Is it "dark"? beq Surround_4 ;2 If not, branch sty SurroundR ;3 Store room as the surround's room lda PlayerX ;3 Get the ball's horizontal co-ordinate sec ;2 sbc #$10 ;2 Adjust surround sprite to 16 pixels left bpl Surround_3 ;2 (00 to 7F OK) cmp #$F0 ;2 Is it close to the right edge? bcc Surround_2 ;2 Branch if not lda #$01 ;2 Flick surround to the left bne Surround_3 ;2 Always branch Surround_2: lda #$7F ;2 If higher than $7F, keep boundry on the right Surround_3: sta SurroundR+1 ;3 ...And store as surround's horizontal co-ordinate lda PlayerY ;3 Get the ball's vertical co-ordinate clc ;2 adc #$0E ;2 Adjust surround sprite to 14 pixels up sta SurroundR+2 ;3 ...And store as surround's vertical co-ordinate Surround_4: rts ;6 MakeSound: ;Make a noise lda Sound ;3 Get the noise type in upper nybble lsr ;2 Move down to lower nybble... lsr ;2 . lsr ;2 . lsr ;2 . tax ;2 ...And pass to X for index ldy NoteCnt ;3 Check current note count beq NoiseSaveVolume ;2 Branch if no noise to be made MakeSound_2: dey ;2 sty NoteCnt ;3 Goto the next note tya ;2 ldy #$00 ;2 dex ;2 Game over noise? bmi NoiseGameOver ;2 Branch if so dex ;2 Roar noise? bmi NoiseRoar ;2 Branch if so dex ;2 Eaten player noise? bmi EatenNoise ;2 Branch if so dex ;2 Dying dragon noise? bmi DragDieNoise ;2 Branch if so dex ;2 Picking up object noise? bmi NoiseGetObject ;2 Branch if so dex ;2 Dropping object noise? bpl NoiseSaveVolume ;2 Branch if not ;Sounds...Set A (Frequency), Y (Volume), and X (distortion)...& branch to NoiseSave ;Noise 5 : Dropping Object eor #$03 ;2 Reverse it as pitch goes up NoiseGetObject: ;Noise 4 : Picking up an Object ldy #$05 ;2 bne NoiseSaveX ;2 Always branch NoiseGameOver: ;Noise 0 : winning game IF FLASH_WALLS sta COLUPF ;3 Color flash playfield ENDIF IF FLASH_GROUND sta COLUBK ;3 Color flash background ENDIF tax ;2 Audio-Control 0 lsr ;2 tay ;2 Audio-Volume 0 lsr ;2 lsr ;2 bpl NoiseSave ;2 Always branch NoiseRoar: ;Noise 1 : Roar tay ;2 Put the note count in the volume lsr ;2 ldx #$03 ;2 If it was even... bcs SetVolume ;2 ...Then branch ldx #$08 ;2 Get a different audio distortion value SetVolume: tya ;2 Set the volume clc ;2 adc #$70 ;2 Set the frequency NoiseFrequency: lsr ;2 Divide by four lsr ;2 . bpl NoiseSave ;2 Always branch DragDieNoise: ;Noise 3 : Dying Dragon tay ;2 Put the note count in the volume eor #$1F ;2 ldx #$04 ;2 Set the audio distortion bne NoiseSave ;2 Always branch EatenNoise: ;Noise 2 : Man Eaten lsr ;2 Divide note count by 2 adc #$08 ;2 tay ;2 lda NoteCnt ;3 eor #$0F ;2 NoiseSaveX: ldx #$06 ;2 NoiseSave: sta AUDF0 ;3 Store in frequency for channel 0 stx AUDC0 ;3 Set a noise on channel 0 NoiseSaveVolume: sty AUDV0 ;3 Set volume on channel 0 rts ;6 IF SIMULATE_CHALISE_FLASH ChaliseState: .byte $00 ;State 0 .word GfxChallise .byte $01 ;State 1 .word GfxChallise2 .byte $02 ;State 2 .word GfxChallise3 .byte $03 ;State 3 .word GfxChallise4 .byte $04 ;State 4 .word GfxChallise5 .byte $05 ;State 5 .word GfxChallise6 .byte $06 ;State 6 .word GfxChallise7 .byte $FF ;State FF .word GfxChallise8 ENDIF IF ROTATING_SWORD CarryXtbl: ;# of pixels to carry sword away from ball horizontally .byte $FF ;invalid .byte $FF ;invalid .byte $FF ;invalid .byte $FF ;invalid .byte $FF ;invalid .byte $02 ;right+down .byte $02 ;right+up .byte $02 ;right .byte $FF ;invalid .byte $7B ;left+down .byte $7B ;left+up .byte $7B ;left .byte $FF ;invalid .byte $7F ;down .byte $7F ;up CarryYtbl: ;# of pixels to carry sword away from ball vertically .byte $FF ;not moving (shared) .byte $FF ;invalid .byte $FF ;invalid .byte $FF ;invalid .byte $FF ;invalid .byte $7D ;right+down .byte $03 ;right+up .byte $00 ;right .byte $FF ;invalid .byte $7D ;left+down .byte $03 ;left+up .byte $00 ;left .byte $FF ;invalid .byte $7D ;down .byte $04 ;up .byte $FF ;not moving SwordStates: ;24 bytes, sword's list of states .byte %01010000 ;State down + right .word GfxSwordDR .byte %01100000 ;State up + right .word GfxSwordUR .byte %01110000 ;State right .word GfxSwordR .byte %10010000 ;State down + left .word GfxSwordDL .byte %10100000 ;State up + left .word GfxSwordUL .byte %10110000 ;State left .word GfxSwordL .byte %11010000 ;State down .word GfxSwordD .byte %11100000 ;State up .word GfxSwordU ENDIF ALIGN 256,0 Y6pixels: ;used to select intial object vertical pickup offset .byte $00 .byte $FA ;-6 .byte $06 .byte $00 .byte $00 .byte $FA ;-6 .byte $06 .byte $00 .byte $00 .byte $FA ;-6 .byte $06 .byte $00 .byte $00 .byte $FA ;-6 .byte $06 X6pixels: ;used to select intial object horizontal pickup offset .byte $00 ;shared .byte $00 .byte $00 .byte $00 .byte $06 .byte $06 .byte $06 .byte $06 .byte $FA ;-6 .byte $FA ;-6 .byte $FA ;-6 .byte $FA ;-6 .byte $00 .byte $00 .byte $00 .byte $00 MagnetMatrix: ;13 bytes, Magnet's "liked object" matrix .byte MagnetR,YKeyR ;Yellow Key, Magnet .byte MagnetR,WKeyR ;White Key, Magnet .byte MagnetR,BKeyR ;Black Key, Magnet .byte MagnetR,SwordR ;Sword, Magnet .byte MagnetR,BridgeR ;Bridge, Magnet .byte MagnetR,ChalliseR ;Challise, Magnet ReadStick_3: ;Joystick Merge Values .byte $00 ;no change (zero value shared by above table) .byte $C0 ;no horizontal .byte $30 ;no vertical AuthorInfo: ;3 bytes, Author's signature data .byte <(Rm1E-Rm00),$50,$69 ;Room 1E, (50, 69) BatMatrix: ;21 bytes, Bat's "liked object" matrix .byte BatR,ChalliseR ;Bat,Challise .byte BatR,SwordR ;Bat,Sword .byte BatR,BridgeR ;Bat,Bridge .byte BatR,YKeyR ;Bat,yellow Key .byte BatR,WKeyR ;Bat,White Key .byte BatR,BKeyR ;Bat,Black Key .byte BatR,RDragonR ;Bat,Red Dragon .byte BatR,YDragonR ;Bat,yellow Dragon .byte BatR,GDragonR ;Bat,Green Dragon .byte BatR,MagnetR ;Bat,Magnet Game_Start_Tbl: ;7 bytes - initial start values for the ball and note counter .byte $00 ;NoteCnt (shared) .byte <(Rm11-Rm00) ;PlayerRoom .byte $50 ;PlayerX .byte $20 ;PlayerY .byte <(Rm11-Rm00) ;PrevRoom .byte $50 ;PrevX .byte $20 ;PrevY BatStates: ;6 bytes, Bat's animation list .byte $03 ;State contains values 0 to 7, this byte is used for first 4 frames .word GfxBat1 .byte $FF ;...this byte is thus used for the next 4 frames .word GfxBat2 DragonDiff: ;Dragon difficulty .byte $D0,$E8 ;Level 1 : Am, Pro .byte $F0,$F6 ;Level 2 : Am, Pro .byte $F0,$F6 ;Level 3 : Am, Pro CastleRoomOffsets: ;Castle Rooms (Yellow, White, Black)...the screen # of the castle itself .byte <(Rm11-Rm00),<(Rm0F-Rm00),<(Rm10-Rm00) KeyOffsets: ;Keys #1, #2, #3 (Yellow, White, Black) .byte YKeyNumber,WKeyNumber,BKeyNumber PortOffsets: ;Portcullis #1, #2, #3 .byte YGateNumber,WGateNumber,BGateNumber PortInfo1: ;Yellow castle's portcullis .byte <(Rm11-Rm00),$4D,$31 ;Room number, X, Y PortInfo2: ;White castle's portcullis .byte <(Rm0F-Rm00),$4D,$31 ;Room number, X, Y PortInfo3: ;Black castle's portcullis .byte <(Rm10-Rm00),$4D,$31 ;Room number, X, Y PortStates: ;39 bytes, Portcullis animation list .byte $04 ;State 04 -Open .word GfxPort07 .byte $08 ;State 08 .word GfxPort06 .byte $0C ;State 0C .word GfxPort05 .byte $10 ;State 10 .word GfxPort04 .byte $14 ;State 14 .word GfxPort03 .byte $18 ;State 18 .word GfxPort02 .byte $1C ;State 1C -Closed .word GfxPort01 .byte $20 ;State 20 .word GfxPort02 .byte $24 ;State 24 .word GfxPort03 .byte $28 ;State 28 .word GfxPort04 .byte $2C ;State 2C .word GfxPort05 .byte $30 ;State 30 .word GfxPort06 .byte $FF ;State FF -Open .word GfxPort07 IF USE_TITLE_DISPLAY = 0 NumberStates: ;9 bytes, game select number token states .byte $01 ;State 1 .word GfxNum1 .byte $03 ;State 2 .word GfxNum2 .byte $FF ;State 3 .word GfxNum3 ENDIF ;NOTE: Game1Objects and Game2Objects must hold the same number of bytes ;currently 102 bytes total for both tables Game1Objects: ;Object locations (room and co-ordinate) for game 1 .byte <(Rm02-Rm00),$4D,$20 ;Map portal (room,X,Y) .byte <(Rm15-Rm00),$51,$12 ;Black dot (Room,X,Y) .byte <(Rm0E-Rm00),$50,$20,$00,$00 ;Red Dragon (Room,X,Y,Movement,State) .byte <(Rm01-Rm00),$50,$20,$00,$00 ;Yellow Dragon (Room,X,Y,Movement,State) .byte <(Rm1D-Rm00),$50,$20,$00,$00 ;Green Dragon (Room,X,Y,Movement,State) .byte <(Rm1B-Rm00),$80,$20 ;Magnet (Room,X,Y) .byte <(Rm12-Rm00),$20,$20 ;Sword (Room,X,Y) .byte <(Rm1C-Rm00),$30,$20 ;Challise (Room,X,Y) .byte <(Rm04-Rm00),$29,$37 ;Bridge (Room,X,Y) .byte <(Rm11-Rm00),$20,$40 ;Yellow Key (Room,X,Y) .byte <(Rm0E-Rm00),$20,$40 ;White Key (Room,X,Y) .byte <(Rm1D-Rm00),$20,$40 ;Black Key (Room,X,Y) .byte $1C ;Portcullis State (closed) .byte $1C ;Portcullis State (closed) .byte $1C ;Portcullis State (closed) .byte <(Rm1A-Rm00),$20,$20,$00,$00,$78 ;Bat (Room,X,Y,Movement,State/Fed-up,Carrying) Game2Objects: ;...Games 2 & 3 .byte <(Rm02-Rm00),$4D,$20 ;Map portal (room,X,Y) .byte <(Rm15-Rm00),$51,$12 ;Black Dot (Room,X,Y) .byte <(Rm14-Rm00),$50,$20,$A0,$00 ;Red Dragon (Room,X,Y,Movement,State) .byte <(Rm19-Rm00),$50,$20,$A0,$00 ;Yellow Dragon (Room,X,Y,Movement,State) .byte <(Rm04-Rm00),$50,$20,$A0,$00 ;Green Dragon (Room,X,Y,Movement,State) .byte <(Rm0E-Rm00),$80,$20 ;Magnet (Room,X,Y) .byte <(Rm11-Rm00),$20,$20 ;Sword (Room,X,Y) .byte <(Rm14-Rm00),$30,$20 ;Challise (Room,X,Y) .byte <(Rm0B-Rm00),$40,$40 ;Bridge (Room,X,Y) .byte <(Rm09-Rm00),$20,$40 ;Yellow Key (Room,X,Y) .byte <(Rm06-Rm00),$20,$40 ;White Key (Room,X,Y) .byte <(Rm19-Rm00),$20,$40 ;Black Key (Room,X,Y) .byte $1C ;Portcullis State (closed) .byte $1C ;Portcullis State (closed) .byte $1C ;Portcullis State (closed) .byte <(Rm02-Rm00),$20,$20,$90,$00,$78 ;Bat (Room,X,Y,Movement,State/Fed-up,Carrying) ALIGN 256,0 ;NOTE: All dragon matrices must be on the same page ; If an object is listed before the dragon, it is "feared" ; If an object is listed after the dragon, it is "guarded" RedDragMatrix: ;Red dragon object matrix .byte SwordR,RDragonR ;Sword, Red Dragon .byte RDragonR,PlayerRoom ;Red Dragon, Ball .byte RDragonR,ChalliseR ;Red Dragon, Challise .byte RDragonR,WKeyR ;Red Dragon, White Key RDragonStates: ;12 bytes, list of states for all dragons .byte $00 ;State 00 (roaming), first byte shared w/previous .word GfxRDrag0 IF ANIMATE_DRAGON .byte $01 ;State 00 (roaming), first byte shared w/previous .word GfxRDrag0a .byte $03 ;State 01 (dead) .word GfxRDrag2 .byte $04 ;State 02 (swallowed player) ELSE .byte $01 ;State 01 (dead) .word GfxRDrag2 .byte $02 ;State 02 (swallowed player) ENDIF .word GfxRDrag0 .byte $FF ;State FF (biting player) .word GfxRDrag1 YelDragMatrix: ;Yellow dragon's object matrix .byte SwordR,YDragonR ;Sword, Yellow Dragon .byte YKeyR,YDragonR ;Yellow Key, Yellow Dragon .byte YDragonR,PlayerRoom ;Yellow Dragon, Ball .byte YDragonR,ChalliseR ;Yellow Dragon, Challise YDragonStates: ;12 bytes, list of states for all dragons .byte $00 ;State 00 (roaming), first byte shared w/previous .word GfxYDrag0 IF ANIMATE_DRAGON .byte $01 ;State 01 (roaming) .word GfxYDrag0a .byte $03 ;State 02-3 (dead) .word GfxYDrag2 .byte $04 ;State 04 (swallowed player) ELSE .byte $01 ;State 01 (dead) .word GfxYDrag2 .byte $02 ;State 02 (swallowed player) ENDIF .word GfxYDrag0 .byte $FF ;State 03/05-FF (biting player) .word GfxYDrag1 GreenDragonMatrix: ;Green dragon's object matrix .byte SwordR,GDragonR ;Sword, Green Dragon .byte GDragonR,PlayerRoom ;Green Dragon, Ball .byte GDragonR,ChalliseR ;Green Dragon Challise .byte GDragonR,BridgeR ;Green Dragon, Bridge .byte GDragonR,MagnetR ;Green Dragon, Magnet .byte GDragonR,BKeyR ;Green Dragon, Black Key GDragonStates: ;12 bytes, list of states for all dragons .byte $00 ;State 00 (roaming), first byte shared w/previous .word GfxGDrag0 IF ANIMATE_DRAGON .byte $01 ;State 00 (roaming), first byte shared w/previous .word GfxGDrag0a .byte $03 ;State 01 (dead) .word GfxGDrag2 .byte $04 ;State 02 (swallowed player) ELSE .byte $01 ;State 01 (dead) .word GfxGDrag2 .byte $02 ;State 02 (swallowed player) ENDIF .word GfxGDrag0 .byte $FF ;State FF (biting player) .word GfxGDrag1 IF USE_TITLE_DISPLAY = 0 NumberInfo: ;Game selection digit location... .byte $00,$50,$40 ;#5 Number: Room 00,(50,40) ENDIF Object_Data_LSB: ;LSB of object room/x/y table (or ram location of room #'s) ;NOTE: NullData must be listed first! NullData: .byte <NullR ;$00 Null object's room (LSB) YGateData: .byte <PortInfo1 ;$01 Yellow castle gate's room (LSB) WGateData: .byte <PortInfo2 ;$02 White castle gate's room (LSB) BGateData: .byte <PortInfo3 ;$03 Black castle gate's room (LSB) MapPortData: .byte <MapPortR ; Map portal's room (LSB) SurroundData: .byte <SurroundR ;$04 Invisible Surround's room (LSB) AuthorData: .byte <AuthorInfo ;$05 Author signature's room (LSB) IF USE_TITLE_DISPLAY = 0 NumberData: .byte <NumberInfo ;$06 Game selection digit's room (LSB) ENDIF RDragonData: .byte <RDragonR ;$07 Red Dragon's room (LSB) YDragonData: .byte <YDragonR ;$08 Yellow Dragon's room (LSB) GDragonData: .byte <GDragonR ;$09 Green Dragon's room (LSB) SwordData: .byte <SwordR ;$0A Sword's room (LSB) BridgeData: .byte <BridgeR ;$0B Bridge's room (LSB) YKeyData: .byte <YKeyR ;$0C Yellow key's room (LSB) WKeyData: .byte <WKeyR ;$0D White key's room (LSB) BKeyData: .byte <BKeyR ;$0E Black key's room (LSB) BatData: .byte <BatR ;$0F Bat's room (LSB) DotData: .byte <DotR ;$10 Secret dot's room (LSB) ChalliseData: .byte <ChalliseR ;$11 Challise's room (LSB) MagnetData: .byte <MagnetR ;$12 Magnet's room (LSB) Object_Data_MSB: ;MSB of object room/x/y table (zero if ram) | Size of object ; object# ;Sprite size (Picture shows shape, 8 pixels per character)0 ;SIZE0 One copy (X........) single 8-pixel copy ;SIZE1 Two copies - close (X.X......) eight pixels between 8-pixel copies ;SIZE2 Two copies - medium (X...X....) twenty-four pixels between 8-pixel copies ;SIZE3 Three copies - close (X.X.X....) eight pixels between 8-pixel copies ;SIZE4 Two copies - wide (X.......X) fifty-six pixels between 8-pixel copies ;SIZE5 Double sized player (XX.......) single 16-pixel copy ;SIZE6 Three copies - medium (X...X...X) twenty-four pixels between 8-pixel copies ;SIZE7 Quad sized player (XXXX.....) single 32-pixel copy .byte $00 | SIZE0 ;$00 Null object's room (MSB) Single width .byte (>PortInfo1)&$1F | SIZE0 ;$01 Yellow castle gate's room (MSB) Single width .byte (>PortInfo2)&$1F | SIZE0 ;$02 White castle gate's room (MSB) Single width .byte (>PortInfo3)&$1F | SIZE0 ;$03 Black castle gate's room (MSB) Single width .byte $00 | SIZE0 ; Map portal's room (MSB) Single width .byte $00 | SIZE7 ;$04 Invisible Surround's room (MSB) Quadruple width .byte (>AuthorInfo)&$1F | SIZE0 ;$05 Author signature's room (MSB) Single width IF USE_TITLE_DISPLAY = 0 .byte (>NumberInfo)&$1F | SIZE0 ;$06 Game selection digit's room (MSB) Single width ENDIF .byte $00 | SIZE0 ;$07 Red Dragon's room (MSB) Single width .byte $00 | SIZE0 ;$08 Yellow Dragon's room (MSB) Single width .byte $00 | SIZE0 ;$09 Green Dragon's room (MSB) Single width .byte $00 | SIZE0 ;$0A Sword's room (MSB) Single width .byte $00 | SIZE7 ;$0B Bridge's room (MSB) Quadruple width .byte $00 | SIZE0 ;$0C Yellow key's room (MSB) Single width .byte $00 | SIZE0 ;$0D White key's room (MSB) Single width .byte $00 | SIZE0 ;$0E Black key's room (MSB) Single width .byte $00 | SIZE0 ;$0F Bat's room (MSB) Single width .byte $00 | SIZE0 ;$10 Secret dot's room (MSB) Single width .byte $00 | SIZE0 ;$11 Challise's room (MSB) Single width .byte $00 | SIZE0 ;$12 Magnet's room (MSB) Single width Object_State_LSB: ;ram$addr of state for animated sprites, gfx$addr LSB for static objects... .byte <GfxNull ;$00 Null object's state (LSB) .byte <YGateR ;$01 Yellow castle gate's state (LSB) .byte <WGateR ;$02 White castle gate's state (LSB) .byte <BGateR ;$03 Black castle gate's state (LSB) .byte <GfxMapPort ; Map portal's state (LSB) .byte <GfxSurround ;$04 Invisible Surround's state (LSB) .byte <GfxAuthor ;$05 Author signature's state (LSB) IF USE_TITLE_DISPLAY = 0 .byte <Level ;$06 Game selection digit's state (LSB) ENDIF .byte <RDragonR+4 ;$07 Red Dragon's state (LSB) .byte <YDragonR+4 ;$08 Yellow Dragon's state (LSB) .byte <GDragonR+4 ;$09 Green Dragon's state (LSB) IF ROTATING_SWORD .byte <SwordState ;$0A Sword's state (LSB) ELSE .byte <GfxSwordL ;$0A Sword's state (LSB) ENDIF .byte <GfxBridge ;$0B Bridge's state (LSB) .byte <GfxYKey ;$0C Yellow key's state (LSB) .byte <GfxWKey ;$0D White key's state (LSB) .byte <GfxBKey ;$0E Black key's state (LSB) .byte <BatR+4 ;$0F Bat's state (LSB) .byte <GfxDot ;$10 Secret dot's state (LSB) IF SIMULATE_CHALISE_FLASH .byte <BatR+4 ;$0F Bat's state (LSB) ELSE .byte <GfxChallise ;$11 Challise's state (LSB) ENDIF .byte <GfxMagnet ;$12 Magnet's state (LSB) Object_State_MSB: ;$00 for animated sprites, gfx$addr MSB for static objects... .byte >GfxNull ;$00 Null object's state (MSB) .byte $00 ;$01 Yellow castle gate's state (MSB) .byte $00 ;$02 White castle gate's state (MSB) .byte $00 ;$03 Black castle gate's state (MSB) .byte >GfxMapPort ; Map portal's state (MSB) .byte >GfxSurround ;$04 Invisible Surround's state (MSB) .byte >GfxAuthor ;$05 Author signature's state (MSB) IF USE_TITLE_DISPLAY = 0 .byte $00 ;$06 Game selection digit's state (MSB) ENDIF .byte $00 ;$07 Red Dragon's state (MSB) .byte $00 ;$08 Yellow Dragon's state (MSB) .byte $00 ;$09 Green Dragon's state (MSB) IF ROTATING_SWORD .byte $00 ;$0A Sword's state (MSB) ELSE .byte >GfxSwordL ;$0A Sword's state (MSB) ENDIF .byte >GfxBridge ;$0B Bridge's state (MSB) .byte >GfxYKey ;$0C Yellow key's state (MSB) .byte >GfxWKey ;$0D White key's state (MSB) .byte >GfxBKey ;$0E Black key's state (MSB) .byte $00 ;$0F Bat's state (MSB) .byte >GfxDot ;$10 Secret dot's state (MSB) IF SIMULATE_CHALISE_FLASH .byte $00 ;$0F Bat's state (MSB) ELSE .byte >GfxChallise ;$11 Challise's state (MSB) ENDIF .byte >GfxMagnet ;$12 Magnet's state (MSB) State_List_LSB: ;only used for animated sprites... .byte $00 ;$00 Null object's list of states (LSB) .byte <PortStates ;$01 Yellow castle gate's list of states (LSB) .byte <PortStates ;$02 White castle gate's list of states (LSB) .byte <PortStates ;$03 Black castle gate's list of states (LSB) .byte $00 ; Map portal's list of states (LSB) .byte $00 ;$04 Invisible Surround's list of states (LSB) .byte $00 ;$05 Author signature's list of states (LSB) IF USE_TITLE_DISPLAY = 0 .byte <NumberStates ;$06 Game selection digit's list of states (LSB) ENDIF .byte <RDragonStates;$07 Red Dragon's list of states (LSB) .byte <YDragonStates;$08 Yellow Dragon's list of states (LSB) .byte <GDragonStates;$09 Green Dragon's list of states (LSB) IF ROTATING_SWORD .byte <SwordStates ;$0A Sword's list of states (LSB) ELSE .byte $00 ;$0A Sword's list of states (LSB) ENDIF .byte $00 ;$0B Bridge's list of states (LSB) .byte $00 ;$0C Yellow key's list of states (LSB) .byte $00 ;$0D White key's list of states (LSB) .byte $00 ;$0E Black key's list of states (LSB) .byte <BatStates ;$0F Bat's list of states (LSB) .byte $00 ;$10 Secret dot's list of states (LSB) IF SIMULATE_CHALISE_FLASH .byte <ChaliseState ;$0F Chalise list of states (LSB) ELSE .byte $00 ;$11 Challise's list of states (LSB) ENDIF .byte $00 ;$12 Magnet's list of states (LSB) State_List_MSB: ;only used for animated sprites... .byte $00 ;$00 Null object's list of states (MSB) .byte >PortStates ;$01 Yellow castle gate's list of states (MSB) .byte >PortStates ;$02 White castle gate's list of states (MSB) .byte >PortStates ;$03 Black castle gate's list of states (MSB) .byte $00 ; Map portal's list of states (MSB) .byte $00 ;$04 Invisible Surround's list of states (MSB) .byte $00 ;$05 Author signature's list of states (MSB) IF USE_TITLE_DISPLAY = 0 .byte >NumberStates ;$06 Game selection digit's list of states (MSB) ENDIF .byte >RDragonStates;$07 Red Dragon's list of states (MSB) .byte >YDragonStates;$08 Yellow Dragon's list of states (MSB) .byte >GDragonStates;$09 Green Dragon's list of states (MSB) IF ROTATING_SWORD .byte >SwordStates ;$0A Sword's list of states (MSB) ELSE .byte $00 ;$0A Sword's list of states (MSB) ENDIF .byte $00 ;$0B Bridge's list of states (MSB) .byte $00 ;$0C Yellow key's list of states (MSB) .byte $00 ;$0D White key's list of states (MSB) .byte $00 ;$0E Black key's list of states (MSB) .byte >BatStates ;$0F Bat's list of states (MSB) .byte $00 ;$10 Secret dot's list of states (MSB) IF SIMULATE_CHALISE_FLASH .byte >ChaliseState ;$0F Chalise list of states (MSB) ELSE .byte $00 ;$11 Challise's list of states (MSB) ENDIF .byte $00 ;$12 Magnet's list of states (MSB) Level1Diffs: ;Map differences for level 1 ;These "RD" tags used in the room matrix...subtract RD0 to get proper $80 value RD1: .byte <(Rm10-Rm00) ;Down from Room $01 Below Hedge maze -> Outside black Castle RD2: .byte <(Rm05-Rm00) ;Down from Room $02 Below yellow castle -> Hedge maze above entry RD3: .byte <(Rm1D-Rm00) ;Down from Room 03 Above the catacombs -> Under right corridor RD4: .byte <(Rm1C-Rm00) ;ULRD from $1B in black castle -> Above right corr. (r of catacombs) RD5: .byte <(Rm1B-Rm00) ;Down from Room $1C Above right corr. -> Just inside black castle RD6: .byte <(Rm03-Rm00) ;Up from Room $1D Under right corridor -> Above the catacombs Level2Diffs: ;Map differences for level 2 Level3Diffs: ;Map differences for level 3 .byte <(Rm0F-Rm00) ;Down from Room $01 Below Hedge maze -> Outside white Castle .byte <(Rm11-Rm00) ;Down from Room $02 Below yellow castle -> Outside yellow Castle .byte <(Rm0A-Rm00) ;Down from Room 03 Above the catacombs -> Catacombs entry .byte <(Rm16-Rm00) ;ULRD from $1B in black castle -> Black maze entry .byte <(Rm0C-Rm00) ;Down from Room $1C Above right corr. -> Right corr (r of catacombs) .byte <(Rm0C-Rm00) ;Up from Room $1D Under right corridor -> Right corr (r of catacombs) IF FIX_RANDOM Room_Bounds_Tbl: ;Room Bounds Data...range of room #'s for random object placement in game 3 .byte ChalliseR,$02,$0A ;Challise, minimum screen#, maximum screen# .byte YKeyR,$02,$1D ;Yellow Key .byte BKeyR,$07,$1D ;Black Key .byte WKeyR,$0B,$1D ;White Key .byte RDragonR,$01,$1D ;Red Dragon .byte YDragonR,$01,$1D ;Yellow Dragon .byte GDragonR,$01,$1D ;Green Dragon .byte SwordR,$01,$1D ;Sword .byte BridgeR,$01,$1D ;Bridge .byte BatR,$01,$1D ;Bat .byte MagnetR,$01,$1D ;Magnet ELSE Room_Bounds_Tbl: ;Room Bounds Data...range of room #'s for random object placement in game 3 .byte ChalliseR,$13,$1A ;Challise, minimum screen#, maximum screen# .byte RDragonR,$01,$1D ;Red Dragon .byte YDragonR,$01,$1D ;Yellow Dragon .byte GDragonR,$01,$1D ;Green Dragon .byte SwordR,$01,$1D ;Sword .byte BridgeR,$01,$1D ;Bridge .byte YKeyR,$01,$1D ;Yellow Key .byte WKeyR,$01,$16 ;White Key .byte BKeyR,$01,$12 ;Black Key .byte BatR,$01,$1D ;Bat .byte MagnetR,$01,$1D ;Magnet ENDIF Object_Map_Tbl: ;must immediately follow Room_Bounds_Tbl .word Game1Objects ;object template for first game .word Game2Objects ;object template for second .word Game2Objects ;(reuse second for third before randomization) EntryRoomOffsets: ;Castle Entry Rooms (Yellow, White, Black)...the 1st screen inside a castle .byte <(Rm12-Rm00),<(Rm1A-Rm00),<(Rm1B-Rm00) ALIGN 256 Xeor: ;used for all object movement .byte $80 .byte $80 .byte $80 .byte $80 .byte $80 .byte $00 .byte $00 .byte $00 .byte $80 .byte $FF .byte $FF .byte $FF Yeor: ;used for all object movement .byte $80 ;shared .byte $80 ;shared .byte $80 ;shared .byte $80 ;shared .byte $80 .byte $FF .byte $00 .byte $80 .byte $80 .byte $FF .byte $00 .byte $80 .byte $80 .byte $FF .byte $00 .byte $80 IF FIX_RANDOM RoomGFX_LSB_Tbl: ;LSB of gfx ;room#, description Rm00: IF USE_TITLE_DISPLAY = 0 .byte <Room00 ;old $00, new $00 Number room ENDIF Rm12: .byte <Room12 ;old $12, new $01 Inside yellow castle Rm1B: .byte <Room1B ;old $1B, new $02 Just inside black castle Rm13: .byte <Room13 ;old $13, new $03 Black maze right of entry Rm14: .byte <Room14 ;old $14, new $04 Black maze challise room Rm15: .byte <Room15 ;old $15, new $05 Black maze dot's room Rm16: .byte <Room16 ;old $16, new $06 Black maze entry Rm17: .byte <Room17 ;old $17, new $07 Red maze above black key's room Rm18: .byte <Room18 ;old $18, new $08 Red maze above entry Rm19: .byte <Room19 ;old $19, new $09 Red maze black key's room Rm1A: .byte <Room1A ;old $1A, new $0A Red maze entry Rm01: .byte <Room01 ;old $01, new $0B Below Hedge maze Rm02: .byte <Room02 ;old $02, new $0C Below yellow castle Rm03: .byte <Room03 ;old $03, new $0D Above the catacombs Rm04: .byte <Room04 ;old $04, new $0E Hedge maze below black castle Rm05: .byte <Room05 ;old $05, new $0F Hedge maze above entry Rm06: .byte <Room06 ;old $06, new $10 Hedge maze bottom Rm07: .byte <Room07 ;old $07, new $11 Hedge maze center Rm08: .byte <Room08 ;old $08, new $12 Hedge maze entry Rm09: .byte <Room09 ;old $09, new $13 Catacombs middle Rm0A: .byte <Room0A ;old $0A, new $14 Catacombs entry Rm0B: .byte <Room0B ;old $0B, new $15 Catacombs side Rm0C: .byte <Room0C ;old $0C, new $16 Right corridor right of catacombs Rm0D: .byte <Room0D ;old $0D, new $17 Left corridor below white Castle Rm0E: .byte <Room0E ;old $0E, new $18 Below left corridor Rm0F: .byte <Room0F ;old $0F, new $19 Outside white Castle Rm10: .byte <Room10 ;old $10, new $1A Outside black Castle Rm11: .byte <Room11 ;old $11, new $1B Outside yellow Castle Rm1C: .byte <Room1C ;old $1C, new $1C Above right corridor right of catacombs Rm1D: .byte <Room1D ;old $1D, new $1D Under right corridor Rm1E: .byte <Room1E ;old $1E, new $1E Warren Robinett's room RoomGFX_MSB_Tbl: ;MSB of gfx ;room#, description ; Bit 5-7 ($20/$40/$80): bank number where room GFX exists ; Bit 4 (+$10): False if surround object needed IF USE_TITLE_DISPLAY = 0 .byte (>Room00)&$0F | BANK0 ;$00 Number room ENDIF .byte (>Room12)&$0F | BANK0 ;$12 Inside yellow castle .byte (>Room1B)&$0F | BANK0 ;$1B Just inside black castle .byte (>Room13)&$0F | BANK0 | SURROUND ;$13 Black maze right of entry .byte (>Room14)&$0F | BANK0 | SURROUND ;$14 Black maze challise room .byte (>Room15)&$0F | BANK0 | SURROUND ;$15 Black maze dot's room .byte (>Room16)&$0F | BANK0 | SURROUND ;$16 Black maze entry .byte (>Room17)&$0F | BANK0 ;$17 Red maze above black key's room .byte (>Room18)&$0F | BANK0 ;$18 Red maze above entry .byte (>Room19)&$0F | BANK0 ;$19 Red maze black key's room .byte (>Room1A)&$0F | BANK0 ;$1A Red maze entry .byte (>Room01)&$0F | BANK0 ;$01 Below Hedge maze .byte (>Room02)&$0F | BANK0 ;$02 Below yellow castle .byte (>Room03)&$0F | BANK0 ;$03 Above the catacombs .byte (>Room04)&$0F | BANK0 ;$04 Hedge maze below black castle .byte (>Room05)&$0F | BANK0 ;$05 Hedge maze above entry .byte (>Room06)&$0F | BANK0 ;$06 Hedge maze bottom .byte (>Room07)&$0F | BANK0 ;$07 Hedge maze center .byte (>Room08)&$0F | BANK0 ;$08 Hedge maze entry .byte (>Room09)&$0F | BANK0 | SURROUND ;$09 Catacombs middle .byte (>Room0A)&$0F | BANK0 | SURROUND ;$0A Catacombs entry .byte (>Room0B)&$0F | BANK0 | SURROUND ;$0B Catacombs side .byte (>Room0C)&$0F | BANK0 ;$0C Right corridor right of catacombs .byte (>Room0D)&$0F | BANK0 ;$0D Left corridor below white Castle .byte (>Room0E)&$0F | BANK0 ;$0E Below left corridor .byte (>Room0F)&$0F | BANK0 ;$0F Outside white Castle .byte (>Room10)&$0F | BANK0 ;$10 Outside black Castle .byte (>Room11)&$0F | BANK0 ;$11 Outside yellow Castle .byte (>Room1C)&$0F | BANK0 ;$1C Above right corridor right of catacombs .byte (>Room1D)&$0F | BANK0 ;$1D Under right corridor .byte (>Room1E)&$0F | BANK0 ;$1E Warren Robinett's room IF MONOCOLOR ;NOTE: the following table is not used for Multicolor mode (so walls are unable to flash there) IF PAL Wall_Color_Tbl: ;playfield color ;room#, description...if an odd number, room is to Flash IF USE_TITLE_DISPLAY = 0 .byte $A6 ;$00 Number room ENDIF .byte $2C ;$12 Inside yellow castle .byte $46 ;$1B Just inside black castle .byte $08 ;$13 Black maze right of entry .byte $08 ;$14 Black maze challise room .byte $08 ;$15 Black maze dot's room .byte $08 ;$16 Black maze entry .byte $46 ;$17 Red maze above black key's room .byte $46 ;$18 Red maze above entry .byte $46 ;$19 Red maze black key's room .byte $46 ;$1A Red maze entry .byte $38 ;$01 Below blue maze .byte $58 ;$02 Below yellow castle .byte $3A ;$03 Above the catacombs .byte $D6 ;$04 Blue maze below black castle .byte $D6 ;$05 Blue maze above entry .byte $D6 ;$06 Blue maze bottom .byte $D6 ;$07 Blue maze center .byte $D6 ;$08 Blue maze entry .byte $08 ;$09 Catacombs middle .byte $08 ;$0A Catacombs entry .byte $08 ;$0B Catacombs side .byte $B8 ;$0C Right corridor right of catacombs .byte $78 ;$0D Left corridor below white Castle .byte $98 ;$0E Below left corridor .byte $0C ;$0F Outside white Castle .byte $00 ;$10 Outside black Castle .byte $2C ;$11 Outside yellow Castle .byte $A6 ;$1C Above right corridor right of catacombs .byte $46 ;$1D Under right corridor .byte $A6 ;$1E Warren Robinett's room ELSE Wall_Color_Tbl: ;playfield color ;room#, description...if an odd number, room is to Flash IF USE_TITLE_DISPLAY = 0 .byte $66 ;$00 Number room ENDIF .byte $1A ;$12 Inside yellow castle .byte $36 ;$1B Just inside black castle .byte $08 ;$13 Black maze right of entry .byte $08 ;$14 Black maze challise room .byte $08 ;$15 Black maze dot's room .byte $08 ;$16 Black maze entry .byte $36 ;$17 Red maze above black key's room .byte $36 ;$18 Red maze above entry .byte $36 ;$19 Red maze black key's room .byte $36 ;$1A Red maze entry .byte $D8 ;$01 Below blue maze .byte $C8 ;$02 Below yellow castle .byte $E8 ;$03 Above the catacombs .byte $86 ;$04 Blue maze below black castle .byte $86 ;$05 Blue maze above entry .byte $86 ;$06 Blue maze bottom .byte $86 ;$07 Blue maze center .byte $86 ;$08 Blue maze entry .byte $08 ;$09 Catacombs middle .byte $08 ;$0A Catacombs entry .byte $08 ;$0B Catacombs side .byte $98 ;$0C Right corridor right of catacombs .byte $B8 ;$0D Left corridor below white Castle .byte $A8 ;$0E Below left corridor .byte $0C ;$0F Outside white Castle .byte $00 ;$10 Outside black Castle .byte $1A ;$11 Outside yellow Castle .byte $66 ;$1C Above right corridor right of catacombs .byte $36 ;$1D Under right corridor .byte $66 ;$1E Warren Robinett's room ENDIF ENDIF IF USE_UNIQUE_BACKGROUND_COLORS IF PAL Ground_Color_Tbl: ;if an odd number, background is to Flash IF USE_TITLE_DISPLAY = 0 .byte $08 ;$00 Number room ENDIF .byte $08 ;$12 Inside yellow castle .byte $08 ;$1B Just inside black castle .byte $08 ;$13 Black maze right of entry .byte $08 ;$14 Black maze challise room .byte $08 ;$15 Black maze dot's room .byte $08 ;$16 Black maze entry .byte $08 ;$17 Red maze above black key's room .byte $08 ;$18 Red maze above entry .byte $08 ;$19 Red maze black key's room .byte $08 ;$1A Red maze entry .byte $08 ;$01 Below Hedge maze .byte $08 ;$02 Below yellow castle .byte $08 ;$03 Above the catacombs .byte $08 ;$04 Hedge maze below black castle .byte $08 ;$05 Hedge maze above entry .byte $08 ;$06 Hedge maze bottom .byte $08 ;$07 Hedge maze center .byte $08 ;$08 Hedge maze entry .byte $08 ;$09 Catacombs middle .byte $08 ;$0A Catacombs entry .byte $08 ;$0B Catacombs side .byte $08 ;$0C Right corridor right of catacombs .byte $08 ;$0D Left corridor below white Castle .byte $08 ;$0E Below left corridor .byte $08 ;$0F Outside white Castle .byte $08 ;$10 Outside black Castle .byte $08 ;$11 Outside yellow Castle .byte $08 ;$1C Above right corridor right of catacombs .byte $08 ;$1D Under right corridor .byte $08 ;$1E Warren Robinett's room ELSE Ground_Color_Tbl: ;if an odd number, background is to Flash IF USE_TITLE_DISPLAY = 0 .byte $08 ;$00 Number room ENDIF .byte $08 ;$12 Inside yellow castle .byte $08 ;$1B Just inside black castle .byte $08 ;$13 Black maze right of entry .byte $08 ;$14 Black maze challise room .byte $08 ;$15 Black maze dot's room .byte $08 ;$16 Black maze entry .byte $08 ;$17 Red maze above black key's room .byte $08 ;$18 Red maze above entry .byte $08 ;$19 Red maze black key's room .byte $08 ;$1A Red maze entry .byte $08 ;$01 Below Hedge maze .byte $08 ;$02 Below yellow castle .byte $08 ;$03 Above the catacombs .byte $08 ;$04 Hedge maze below black castle .byte $08 ;$05 Hedge maze above entry .byte $08 ;$06 Hedge maze bottom .byte $08 ;$07 Hedge maze center .byte $08 ;$08 Hedge maze entry .byte $08 ;$09 Catacombs middle .byte $08 ;$0A Catacombs entry .byte $08 ;$0B Catacombs side .byte $08 ;$0C Right corridor right of catacombs .byte $08 ;$0D Left corridor below white Castle .byte $08 ;$0E Below left corridor .byte $08 ;$0F Outside white Castle .byte $08 ;$10 Outside black Castle .byte $08 ;$11 Outside yellow Castle .byte $08 ;$1C Above right corridor right of catacombs .byte $08 ;$1D Under right corridor .byte $08 ;$1E Warren Robinett's room ENDIF ENDIF North_Map_Tbl: ;room to the North ;room#, description (from -> to) IF USE_TITLE_DISPLAY = 0 .byte $00 ;$00 Number room -> $00 Number room ENDIF .byte Rm12-Rm00 ;$12 Inside yellow castle -> $12 Inside yellow castle .byte RD4-RD0 ;$1B inside black castle -> 4th set of differences .byte Rm15-Rm00 ;$13 Black maze right of entry -> $15 Black maze dot's room .byte Rm16-Rm00 ;$14 Black maze challise room -> $16 Black maze entry .byte Rm13-Rm00 ;$15 Black maze dot's room -> $13 Black maze right of entry .byte Rm14-Rm00 ;$16 Black maze entry -> $14 Black maze challise room .byte Rm19-Rm00 ;$17 Red maze above black key's room -> $19 Red maze black key's room .byte Rm1A-Rm00 ;$18 Red maze above entry -> $1A Red maze entry .byte Rm17-Rm00 ;$19 Red maze black key's room -> $17 Red maze above black key's room .byte Rm18-Rm00 ;$1A Red maze entry -> $18 Red maze above entry .byte Rm08-Rm00 ;$01 Below Hedge maze -> $08 Hedge maze entry .byte Rm11-Rm00 ;$02 Below yellow castle -> $11 Outside yellow castle .byte Rm06-Rm00 ;$03 Above the catacombs -> $06 Hedge maze bottom .byte Rm10-Rm00 ;$04 Hedge maze below black castle -> $10 Outside black castle .byte Rm1D-Rm00 ;$05 Hedge maze above entry -> $1D Under right corridor .byte Rm07-Rm00 ;$06 Hedge maze bottom -> $07 Hedge maze center .byte Rm04-Rm00 ;$07 Hedge maze center -> $04 Hedge maze below black castle .byte Rm05-Rm00 ;$08 Hedge maze entry -> $05 Hedge maze above entry .byte Rm0A-Rm00 ;$09 Catacombs middle -> $0A Catacombs entry .byte Rm03-Rm00 ;$0A Catacombs entry -> $03 Above the catacombs .byte Rm09-Rm00 ;$0B Catacombs side -> $09 Catacombs middle .byte Rm1C-Rm00 ;$0C Right corridor right of catacombs -> $1C Above right corridor .byte Rm0F-Rm00 ;$0D Left corridor below white Castle -> $0F Outside white castle .byte Rm0D-Rm00 ;$0E Below left corridor -> $0D Left corridor below white castle .byte Rm0E-Rm00 ;$0F Outside white Castle -> $0E Below left corridor .byte Rm01-Rm00 ;$10 Outside black Castle -> $01 Below Hedge maze .byte Rm06-Rm00 ;$11 Outside yellow Castle -> $06 Hedge maze bottom .byte Rm1D-Rm00 ;$1C Above right corridor,right of catacombs -> $1D Under right corridor .byte RD6-RD0 ;$1D Under right corridor -> 6th set of differences .byte Rm06-Rm00 ;$1E Warren Robinett's room -> $06 Hedge maze bottom East_Map_Tbl: ;room to the Right ;room#, description (from -> to) IF USE_TITLE_DISPLAY = 0 .byte $00 ;$00 Number room -> $00 Number room ENDIF .byte Rm12-Rm00 ;$12 Inside yellow castle -> $12 Inside yellow castle .byte RD4-RD0 ;$1B inside black castle -> 4th set of differences .byte Rm14-Rm00 ;$13 Black maze right of entry -> $14 Black maze challise room .byte Rm15-Rm00 ;$14 Black maze challise room -> $15 Black maze dot's room .byte Rm16-Rm00 ;$15 Black maze dot's room -> $16 Black maze entry .byte Rm13-Rm00 ;$16 Black maze entry -> $13 Black maze right of entry .byte Rm18-Rm00 ;$17 Red maze above black key's room -> $18 Red maze above entry .byte Rm17-Rm00 ;$18 Red maze above entry -> $17 Red maze above black key's room .byte Rm1A-Rm00 ;$19 Red maze black key's room -> $1A Red maze entry .byte Rm19-Rm00 ;$1A Red maze entry -> $19 Red maze black key's room .byte Rm02-Rm00 ;$01 Below Hedge maze -> $02 Below yellow castle .byte Rm03-Rm00 ;$02 Below yellow castle -> $03 Above the catacombs .byte Rm01-Rm00 ;$03 Above the catacombs -> $01 Below Hedge maze .byte Rm05-Rm00 ;$04 Hedge maze below black castle -> $05 Hedge maze above entry .byte Rm06-Rm00 ;$05 Hedge maze above entry -> $06 Hedge maze bottom .byte Rm04-Rm00 ;$06 Hedge maze bottom -> $04 Hedge maze below black castle .byte Rm08-Rm00 ;$07 Hedge maze center -> $08 Hedge maze entry .byte Rm07-Rm00 ;$08 Hedge maze entry -> $07 Hedge maze center .byte Rm0A-Rm00 ;$09 Catacombs middle -> $0A Catacombs entry .byte Rm09-Rm00 ;$0A Catacombs entry -> $09 Catacombs middle .byte Rm0C-Rm00 ;$0B Catacombs side -> $0C Right corridor right of catacombs .byte Rm0D-Rm00 ;$0C Right corridor right of catacombs -> $0D Left cr below white castle .byte Rm0B-Rm00 ;$0D Left corridor below white Castle -> $0B Catacombs side .byte Rm10-Rm00 ;$0E Below left corridor -> $10 Outside black castle .byte Rm0F-Rm00 ;$0F Outside white Castle -> $0F Outside white castle .byte Rm1C-Rm00 ;$10 Outside black Castle -> $1C Above right corridor right of catacombs .byte Rm03-Rm00 ;$11 Outside yellow Castle -> $03 Above the catacombs .byte Rm07-Rm00 ;$1C Above right corridor right of catacombs -> $07 Hedge maze center .byte Rm01-Rm00 ;$1D Under right corridor -> $01 Below Hedge maze .byte Rm01-Rm00 ;$1E Warren Robinett's room -> $01 Below Hedge maze South_Map_Tbl: ;room to the South ;room#, description (from -> to) IF USE_TITLE_DISPLAY = 0 .byte $00 ;$00 Number room -> $00 Number room ENDIF .byte Rm12-Rm00 ;$12 Inside yellow castle -> $12 Inside yellow castle .byte RD4-RD0 ;$1B Inside black castle -> 4th set of differences .byte Rm15-Rm00 ;$13 Black maze right of entry -> $15 Black maze dot's room .byte Rm16-Rm00 ;$14 Black maze challise room -> $16 Black maze entry .byte Rm13-Rm00 ;$15 Black maze dot's room -> $13 Black maze right of entry .byte Rm1B-Rm00 ;$16 Black maze entry -> $1B Inside black castle .byte Rm19-Rm00 ;$17 Red maze above black key's room -> $19 Red maze black key's room .byte Rm1A-Rm00 ;$18 Red maze above entry -> $1A Red maze entry .byte Rm17-Rm00 ;$19 Red maze black key's room -> $17 Red maze above black key's room .byte Rm18-Rm00 ;$1A Red maze entry -> $18 Red maze above entry .byte RD1-RD0 ;$01 Below Hedge maze -> 1st set of differences .byte RD2-RD0 ;$02 Below yellow castle -> 2nd set of differences .byte RD3-RD0 ;$03 Above the catacombs -> 3rd set of differences .byte Rm07-Rm00 ;$04 Hedge maze below black castle -> $07 Hedge maze center .byte Rm08-Rm00 ;$05 Hedge maze above entry -> $08 Hedge maze entry .byte Rm03-Rm00 ;$06 Hedge maze bottom -> $03 Above the catacombs .byte Rm06-Rm00 ;$07 Hedge maze center -> $06 Hedge maze bottom .byte Rm01-Rm00 ;$08 Hedge maze entry -> $01 Below Hedge maze .byte Rm0B-Rm00 ;$09 Catacombs middle -> $0B Catacombs side .byte Rm09-Rm00 ;$0A Catacombs entry -> $09 Catacombs middle .byte Rm1C-Rm00 ;$0B Catacombs side -> $1C Above right corridor right of catacombs .byte Rm1D-Rm00 ;$0C Right corridor right of catacombs -> $1D Under right corridor .byte Rm0E-Rm00 ;$0D Left corridor below white Castle -> $0E Below left corridor .byte Rm0F-Rm00 ;$0E Below left corridor -> $0F Outside white Castle .byte Rm0D-Rm00 ;$0F Outside white Castle -> $0D Left corridor below white Castle .byte Rm04-Rm00 ;$10 Outside black Castle -> $04 Hedge maze below black castle .byte Rm02-Rm00 ;$11 Outside yellow Castle -> $02 Below yellow castle .byte RD5-RD0 ;$1C Above right corridor right of catacombs -> 5th set of differences .byte Rm10-Rm00 ;$1D Under right corridor -> $10 Outside black Castle .byte Rm06-Rm00 ;$1E Warren Robinett's room -> $06 Hedge maze bottom West_Map_Tbl: ;room to the Left ;room#, description (from -> to) IF USE_TITLE_DISPLAY = 0 .byte $00 ;$00 Number room -> $00 Number room ENDIF .byte Rm12-Rm00 ;$12 Inside yellow castle -> $12 Inside yellow castle .byte RD4-RD0 ;$1B inside black castle -> 4th set of differences .byte Rm16-Rm00 ;$13 Black maze right of entry -> $16 Black maze entry .byte Rm13-Rm00 ;$14 Black maze challise room -> $13 Black maze dot's room .byte Rm14-Rm00 ;$15 Black maze dot's room -> $14 Black maze challise room .byte Rm15-Rm00 ;$16 Black maze entry -> $15 Black maze dot's room .byte Rm18-Rm00 ;$17 Red maze above black key's room -> $18 Red maze above entry .byte Rm17-Rm00 ;$18 Red maze above entry -> $17 Red maze above black key's room .byte Rm1A-Rm00 ;$19 Red maze black key's room -> $1A Red maze entry .byte Rm19-Rm00 ;$1A Red maze entry -> $19 Red maze black key's room .byte Rm03-Rm00 ;$01 Below Hedge maze -> $03 Above the catacombs .byte Rm01-Rm00 ;$02 Below yellow castle -> $01 Below Hedge maze .byte Rm02-Rm00 ;$03 Above the catacombs -> $02 Below yellow castle .byte Rm06-Rm00 ;$04 Hedge maze below black castle -> $06 Hedge maze bottom .byte Rm04-Rm00 ;$05 Hedge maze above entry -> $04 Hedge maze below black castle .byte Rm05-Rm00 ;$06 Hedge maze bottom -> $05 Hedge maze above entry .byte Rm08-Rm00 ;$07 Hedge maze center -> $08 Hedge maze entry .byte Rm07-Rm00 ;$08 Hedge maze entry -> $07 Hedge maze center .byte Rm0A-Rm00 ;$09 Catacombs middle -> $0A Catacombs entry .byte Rm09-Rm00 ;$0A Catacombs entry -> $09 Catacombs middle .byte Rm0D-Rm00 ;$0B Catacombs side -> $0D Left corridor below white Castle .byte Rm0B-Rm00 ;$0C Right corridor right of catacombs -> $0B Catacombs side .byte Rm0C-Rm00 ;$0D Left corridor below white Castle -> $0C Right cr right of catacombs .byte Rm10-Rm00 ;$0E Below left corridor -> $10 Outside black Castle .byte Rm0F-Rm00 ;$0F Outside white Castle -> $0F Outside white Castle .byte Rm1C-Rm00 ;$10 Outside black Castle -> $1C Above right corridor right of catacombs .byte Rm01-Rm00 ;$11 Outside yellow Castle -> $01 Below Hedge maze .byte Rm08-Rm00 ;$1C Above right corridor right of catacombs -> $08 .byte Rm03-Rm00 ;$1D Under right corridor -> $03 Above the catacombs .byte Rm03-Rm00 ;$1E Warren Robinett's room -> $03 Above the catacombs ELSE RoomGFX_LSB_Tbl: ;LSB of gfx ;room#, description Rm00: IF USE_TITLE_DISPLAY = 0 .byte <Room00 ;$00 Number room ENDIF Rm01: .byte <Room01 ;$01 Below Hedge maze Rm02: .byte <Room02 ;$02 Below yellow castle Rm03: .byte <Room03 ;$03 Above the catacombs Rm04: .byte <Room04 ;$04 Hedge maze below black castle Rm05: .byte <Room05 ;$05 Hedge maze above entry Rm06: .byte <Room06 ;$06 Hedge maze bottom Rm07: .byte <Room07 ;$07 Hedge maze center Rm08: .byte <Room08 ;$08 Hedge maze entry Rm09: .byte <Room09 ;$09 Catacombs middle Rm0A: .byte <Room0A ;$0A Catacombs entry Rm0B: .byte <Room0B ;$0B Catacombs side Rm0C: .byte <Room0C ;$0C Right corridor right of catacombs Rm0D: .byte <Room0D ;$0D Left corridor below white Castle Rm0E: .byte <Room0E ;$0E Below left corridor Rm0F: .byte <Room0F ;$0F Outside white Castle Rm10: .byte <Room10 ;$10 Outside black Castle Rm11: .byte <Room11 ;$11 Outside yellow Castle Rm12: .byte <Room12 ;$12 Inside yellow castle Rm13: .byte <Room13 ;$13 Black maze right of entry Rm14: .byte <Room14 ;$14 Black maze challise room Rm15: .byte <Room15 ;$15 Black maze dot's room Rm16: .byte <Room16 ;$16 Black maze entry Rm17: .byte <Room17 ;$17 Red maze above black key's room Rm18: .byte <Room18 ;$18 Red maze above entry Rm19: .byte <Room19 ;$19 Red maze black key's room Rm1A: .byte <Room1A ;$1A Red maze entry Rm1B: .byte <Room1B ;$1B Just inside black castle Rm1C: .byte <Room1C ;$1C Above right corridor right of catacombs Rm1D: .byte <Room1D ;$1D Under right corridor Rm1E: .byte <Room1E ;$1E Warren Robinett's room RoomGFX_MSB_Tbl: ;MSB of gfx ;room#, description ; Bit 5-7 ($20/$40/$80): bank number where room GFX exists ; Bit 4 (+$10): False if surround object needed IF USE_TITLE_DISPLAY = 0 .byte (>Room00)&$0F | BANK0 ;$00 Number room ENDIF .byte (>Room01)&$0F | BANK0 ;$01 Below Hedge maze .byte (>Room02)&$0F | BANK0 ;$02 Below yellow castle .byte (>Room03)&$0F | BANK0 ;$03 Above the catacombs .byte (>Room04)&$0F | BANK0 ;$04 Hedge maze below black castle .byte (>Room05)&$0F | BANK0 ;$05 Hedge maze above entry .byte (>Room06)&$0F | BANK0 ;$06 Hedge maze bottom .byte (>Room07)&$0F | BANK0 ;$07 Hedge maze center .byte (>Room08)&$0F | BANK0 ;$08 Hedge maze entry .byte (>Room09)&$0F | BANK0 | SURROUND ;$09 Catacombs middle .byte (>Room0A)&$0F | BANK0 | SURROUND ;$0A Catacombs entry .byte (>Room0B)&$0F | BANK0 | SURROUND ;$0B Catacombs side .byte (>Room0C)&$0F | BANK0 ;$0C Right corridor right of catacombs .byte (>Room0D)&$0F | BANK0 ;$0D Left corridor below white Castle .byte (>Room0E)&$0F | BANK0 ;$0E Below left corridor .byte (>Room0F)&$0F | BANK0 ;$0F Outside white Castle .byte (>Room10)&$0F | BANK0 ;$10 Outside black Castle .byte (>Room11)&$0F | BANK0 ;$11 Outside yellow Castle .byte (>Room12)&$0F | BANK0 ;$12 Inside yellow castle .byte (>Room13)&$0F | BANK0 | SURROUND ;$13 Black maze right of entry .byte (>Room14)&$0F | BANK0 | SURROUND ;$14 Black maze challise room .byte (>Room15)&$0F | BANK0 | SURROUND ;$15 Black maze dot's room .byte (>Room16)&$0F | BANK0 | SURROUND ;$16 Black maze entry .byte (>Room17)&$0F | BANK0 ;$17 Red maze above black key's room .byte (>Room18)&$0F | BANK0 ;$18 Red maze above entry .byte (>Room19)&$0F | BANK0 ;$19 Red maze black key's room .byte (>Room1A)&$0F | BANK0 ;$1A Red maze entry .byte (>Room1B)&$0F | BANK0 ;$1B Just inside black castle .byte (>Room1C)&$0F | BANK0 ;$1C Above right corridor right of catacombs .byte (>Room1D)&$0F | BANK0 ;$1D Under right corridor .byte (>Room1E)&$0F | BANK0 ;$1E Warren Robinett's room ;NOTE: the following table is not used for Multicolor mode (so walls are unable to flash there) IF MONOCOLOR IF PAL Wall_Color_Tbl: ;playfield color ;room#, description...if an odd number, room is to Flash IF USE_TITLE_DISPLAY = 0 .byte $A6 ;$00 Number room ENDIF .byte $38 ;$01 Below blue maze .byte $58 ;$02 Below yellow castle .byte $3A ;$03 Above the catacombs .byte $D6 ;$04 Blue maze below black castle .byte $D6 ;$05 Blue maze above entry .byte $D6 ;$06 Blue maze bottom .byte $D6 ;$07 Blue maze center .byte $D6 ;$08 Blue maze entry .byte $08 ;$09 Catacombs middle .byte $08 ;$0A Catacombs entry .byte $08 ;$0B Catacombs side .byte $B8 ;$0C Right corridor right of catacombs .byte $78 ;$0D Left corridor below white Castle .byte $98 ;$0E Below left corridor .byte $0C ;$0F Outside white Castle .byte $00 ;$10 Outside black Castle .byte $2C ;$11 Outside yellow Castle .byte $2C ;$12 Inside yellow castle .byte $08 ;$13 Black maze right of entry .byte $08 ;$14 Black maze challise room .byte $08 ;$15 Black maze dot's room .byte $08 ;$16 Black maze entry .byte $46 ;$17 Red maze above black key's room .byte $46 ;$18 Red maze above entry .byte $46 ;$19 Red maze black key's room .byte $46 ;$1A Red maze entry .byte $46 ;$1B Just inside black castle .byte $A6 ;$1C Above right corridor right of catacombs .byte $46 ;$1D Under right corridor .byte $A6 ;$1E Warren Robinett's room ELSE Wall_Color_Tbl: ;playfield color ;room#, description...if an odd number, room is to Flash IF USE_TITLE_DISPLAY = 0 .byte $66 ;$00 Number room ENDIF .byte $D8 ;$01 Below blue maze .byte $C8 ;$02 Below yellow castle .byte $E8 ;$03 Above the catacombs .byte $86 ;$04 Blue maze below black castle .byte $86 ;$05 Blue maze above entry .byte $86 ;$06 Blue maze bottom .byte $86 ;$07 Blue maze center .byte $86 ;$08 Blue maze entry .byte $08 ;$09 Catacombs middle .byte $08 ;$0A Catacombs entry .byte $08 ;$0B Catacombs side .byte $98 ;$0C Right corridor right of catacombs .byte $B8 ;$0D Left corridor below white Castle .byte $A8 ;$0E Below left corridor .byte $0C ;$0F Outside white Castle .byte $00 ;$10 Outside black Castle .byte $1A ;$11 Outside yellow Castle .byte $1A ;$12 Inside yellow castle .byte $08 ;$13 Black maze right of entry .byte $08 ;$14 Black maze challise room .byte $08 ;$15 Black maze dot's room .byte $08 ;$16 Black maze entry .byte $36 ;$17 Red maze above black key's room .byte $36 ;$18 Red maze above entry .byte $36 ;$19 Red maze black key's room .byte $36 ;$1A Red maze entry .byte $36 ;$1B Just inside black castle .byte $66 ;$1C Above right corridor right of catacombs .byte $36 ;$1D Under right corridor .byte $66 ;$1E Warren Robinett's room ENDIF ENDIF IF USE_UNIQUE_BACKGROUND_COLORS IF PAL Ground_Color_Tbl: ;if an odd number, background is to Flash IF USE_TITLE_DISPLAY = 0 .byte $08 ;$00 Number room ENDIF .byte $08 ;$01 Below Hedge maze .byte $08 ;$02 Below yellow castle .byte $08 ;$03 Above the catacombs .byte $08 ;$04 Hedge maze below black castle .byte $08 ;$05 Hedge maze above entry .byte $08 ;$06 Hedge maze bottom .byte $08 ;$07 Hedge maze center .byte $08 ;$08 Hedge maze entry .byte $08 ;$09 Catacombs middle .byte $08 ;$0A Catacombs entry .byte $08 ;$0B Catacombs side .byte $08 ;$0C Right corridor right of catacombs .byte $08 ;$0D Left corridor below white Castle .byte $08 ;$0E Below left corridor .byte $08 ;$0F Outside white Castle .byte $08 ;$10 Outside black Castle .byte $08 ;$11 Outside yellow Castle .byte $08 ;$12 Inside yellow castle .byte $08 ;$13 Black maze right of entry .byte $08 ;$14 Black maze challise room .byte $08 ;$15 Black maze dot's room .byte $08 ;$16 Black maze entry .byte $08 ;$17 Red maze above black key's room .byte $08 ;$18 Red maze above entry .byte $08 ;$19 Red maze black key's room .byte $08 ;$1A Red maze entry .byte $08 ;$1B Just inside black castle .byte $08 ;$1C Above right corridor right of catacombs .byte $08 ;$1D Under right corridor .byte $08 ;$1E Warren Robinett's room ELSE Ground_Color_Tbl: ;if an odd number, background is to Flash IF USE_TITLE_DISPLAY = 0 .byte $08 ;$00 Number room ENDIF .byte $08 ;$01 Below Hedge maze .byte $08 ;$02 Below yellow castle .byte $08 ;$03 Above the catacombs .byte $08 ;$04 Hedge maze below black castle .byte $08 ;$05 Hedge maze above entry .byte $08 ;$06 Hedge maze bottom .byte $08 ;$07 Hedge maze center .byte $08 ;$08 Hedge maze entry .byte $08 ;$09 Catacombs middle .byte $08 ;$0A Catacombs entry .byte $08 ;$0B Catacombs side .byte $08 ;$0C Right corridor right of catacombs .byte $08 ;$0D Left corridor below white Castle .byte $08 ;$0E Below left corridor .byte $08 ;$0F Outside white Castle .byte $08 ;$10 Outside black Castle .byte $08 ;$11 Outside yellow Castle .byte $08 ;$12 Inside yellow castle .byte $08 ;$13 Black maze right of entry .byte $08 ;$14 Black maze challise room .byte $08 ;$15 Black maze dot's room .byte $08 ;$16 Black maze entry .byte $08 ;$17 Red maze above black key's room .byte $08 ;$18 Red maze above entry .byte $08 ;$19 Red maze black key's room .byte $08 ;$1A Red maze entry .byte $08 ;$1B Just inside black castle .byte $08 ;$1C Above right corridor right of catacombs .byte $08 ;$1D Under right corridor .byte $08 ;$1E Warren Robinett's room ENDIF ENDIF North_Map_Tbl: ;room to the North ;room#, description (from -> to) IF USE_TITLE_DISPLAY = 0 .byte $00 ;$00 Number room -> $00 Number room ENDIF .byte Rm08-Rm00 ;$01 Below Hedge maze -> $08 Hedge maze entry .byte Rm11-Rm00 ;$02 Below yellow castle -> $11 Outside yellow castle .byte Rm06-Rm00 ;$03 Above the catacombs -> $06 Hedge maze bottom .byte Rm10-Rm00 ;$04 Hedge maze below black castle -> $10 Outside black castle .byte Rm1D-Rm00 ;$05 Hedge maze above entry -> $1D Under right corridor .byte Rm07-Rm00 ;$06 Hedge maze bottom -> $07 Hedge maze center .byte Rm04-Rm00 ;$07 Hedge maze center -> $04 Hedge maze below black castle .byte Rm05-Rm00 ;$08 Hedge maze entry -> $05 Hedge maze above entry .byte Rm0A-Rm00 ;$09 Catacombs middle -> $0A Catacombs entry .byte Rm03-Rm00 ;$0A Catacombs entry -> $03 Above the catacombs .byte Rm09-Rm00 ;$0B Catacombs side -> $09 Catacombs middle .byte Rm1C-Rm00 ;$0C Right corridor right of catacombs -> $1C Above right corridor .byte Rm0F-Rm00 ;$0D Left corridor below white Castle -> $0F Outside white castle .byte Rm0D-Rm00 ;$0E Below left corridor -> $0D Left corridor below white castle .byte Rm0E-Rm00 ;$0F Outside white Castle -> $0E Below left corridor .byte Rm01-Rm00 ;$10 Outside black Castle -> $01 Below Hedge maze .byte Rm06-Rm00 ;$11 Outside yellow Castle -> $06 Hedge maze bottom .byte Rm12-Rm00 ;$12 Inside yellow castle -> $12 Inside yellow castle .byte Rm15-Rm00 ;$13 Black maze right of entry -> $15 Black maze dot's room .byte Rm16-Rm00 ;$14 Black maze challise room -> $16 Black maze entry .byte Rm13-Rm00 ;$15 Black maze dot's room -> $13 Black maze right of entry .byte Rm14-Rm00 ;$16 Black maze entry -> $14 Black maze challise room .byte Rm19-Rm00 ;$17 Red maze above black key's room -> $19 Red maze black key's room .byte Rm1A-Rm00 ;$18 Red maze above entry -> $1A Red maze entry .byte Rm17-Rm00 ;$19 Red maze black key's room -> $17 Red maze above black key's room .byte Rm18-Rm00 ;$1A Red maze entry -> $18 Red maze above entry .byte RD4-RD0 ;$1B inside black castle -> 4th set of differences .byte Rm1D-Rm00 ;$1C Above right corridor,right of catacombs -> $1D Under right corridor .byte RD6-RD0 ;$1D Under right corridor -> 6th set of differences .byte Rm06-Rm00 ;$1E Warren Robinett's room -> $06 Hedge maze bottom East_Map_Tbl: ;room to the Right ;room#, description (from -> to) IF USE_TITLE_DISPLAY = 0 .byte $00 ;$00 Number room -> $00 Number room ENDIF .byte Rm02-Rm00 ;$01 Below Hedge maze -> $02 Below yellow castle .byte Rm03-Rm00 ;$02 Below yellow castle -> $03 Above the catacombs .byte Rm01-Rm00 ;$03 Above the catacombs -> $01 Below Hedge maze .byte Rm05-Rm00 ;$04 Hedge maze below black castle -> $05 Hedge maze above entry .byte Rm06-Rm00 ;$05 Hedge maze above entry -> $06 Hedge maze bottom .byte Rm04-Rm00 ;$06 Hedge maze bottom -> $04 Hedge maze below black castle .byte Rm08-Rm00 ;$07 Hedge maze center -> $08 Hedge maze entry .byte Rm07-Rm00 ;$08 Hedge maze entry -> $07 Hedge maze center .byte Rm0A-Rm00 ;$09 Catacombs middle -> $0A Catacombs entry .byte Rm09-Rm00 ;$0A Catacombs entry -> $09 Catacombs middle .byte Rm0C-Rm00 ;$0B Catacombs side -> $0C Right corridor right of catacombs .byte Rm0D-Rm00 ;$0C Right corridor right of catacombs -> $0D Left cr below white castle .byte Rm0B-Rm00 ;$0D Left corridor below white Castle -> $0B Catacombs side .byte Rm10-Rm00 ;$0E Below left corridor -> $10 Outside black castle .byte Rm0F-Rm00 ;$0F Outside white Castle -> $0F Outside white castle .byte Rm1C-Rm00 ;$10 Outside black Castle -> $1C Above right corridor right of catacombs .byte Rm03-Rm00 ;$11 Outside yellow Castle -> $03 Above the catacombs .byte Rm12-Rm00 ;$12 Inside yellow castle -> $12 Inside yellow castle .byte Rm14-Rm00 ;$13 Black maze right of entry -> $14 Black maze challise room .byte Rm15-Rm00 ;$14 Black maze challise room -> $15 Black maze dot's room .byte Rm16-Rm00 ;$15 Black maze dot's room -> $16 Black maze entry .byte Rm13-Rm00 ;$16 Black maze entry -> $13 Black maze right of entry .byte Rm18-Rm00 ;$17 Red maze above black key's room -> $18 Red maze above entry .byte Rm17-Rm00 ;$18 Red maze above entry -> $17 Red maze above black key's room .byte Rm1A-Rm00 ;$19 Red maze black key's room -> $1A Red maze entry .byte Rm19-Rm00 ;$1A Red maze entry -> $19 Red maze black key's room .byte RD4-RD0 ;$1B inside black castle -> 4th set of differences .byte Rm07-Rm00 ;$1C Above right corridor right of catacombs -> $07 Hedge maze center .byte Rm01-Rm00 ;$1D Under right corridor -> $01 Below Hedge maze .byte Rm01-Rm00 ;$1E Warren Robinett's room -> $01 Below Hedge maze South_Map_Tbl: ;room to the South ;room#, description (from -> to) IF USE_TITLE_DISPLAY = 0 .byte $00 ;$00 Number room -> $00 Number room ENDIF .byte RD1-RD0 ;$01 Below Hedge maze -> 1st set of differences .byte RD2-RD0 ;$02 Below yellow castle -> 2nd set of differences .byte RD3-RD0 ;$03 Above the catacombs -> 3rd set of differences .byte Rm07-Rm00 ;$04 Hedge maze below black castle -> $07 Hedge maze center .byte Rm08-Rm00 ;$05 Hedge maze above entry -> $08 Hedge maze entry .byte Rm03-Rm00 ;$06 Hedge maze bottom -> $03 Above the catacombs .byte Rm06-Rm00 ;$07 Hedge maze center -> $06 Hedge maze bottom .byte Rm01-Rm00 ;$08 Hedge maze entry -> $01 Below Hedge maze .byte Rm0B-Rm00 ;$09 Catacombs middle -> $0B Catacombs side .byte Rm09-Rm00 ;$0A Catacombs entry -> $09 Catacombs middle .byte Rm1C-Rm00 ;$0B Catacombs side -> $1C Above right corridor right of catacombs .byte Rm1D-Rm00 ;$0C Right corridor right of catacombs -> $1D Under right corridor .byte Rm0E-Rm00 ;$0D Left corridor below white Castle -> $0E Below left corridor .byte Rm0F-Rm00 ;$0E Below left corridor -> $0F Outside white Castle .byte Rm0D-Rm00 ;$0F Outside white Castle -> $0D Left corridor below white Castle .byte Rm04-Rm00 ;$10 Outside black Castle -> $04 Hedge maze below black castle .byte Rm02-Rm00 ;$11 Outside yellow Castle -> $02 Below yellow castle .byte Rm12-Rm00 ;$12 Inside yellow castle -> $12 Inside yellow castle .byte Rm15-Rm00 ;$13 Black maze right of entry -> $15 Black maze dot's room .byte Rm16-Rm00 ;$14 Black maze challise room -> $16 Black maze entry .byte Rm13-Rm00 ;$15 Black maze dot's room -> $13 Black maze right of entry .byte Rm1B-Rm00 ;$16 Black maze entry -> $1B Inside black castle .byte Rm19-Rm00 ;$17 Red maze above black key's room -> $19 Red maze black key's room .byte Rm1A-Rm00 ;$18 Red maze above entry -> $1A Red maze entry .byte Rm17-Rm00 ;$19 Red maze black key's room -> $17 Red maze above black key's room .byte Rm18-Rm00 ;$1A Red maze entry -> $18 Red maze above entry .byte RD4-RD0 ;$1B Inside black castle -> 4th set of differences .byte RD5-RD0 ;$1C Above right corridor right of catacombs -> 5th set of differences .byte Rm10-Rm00 ;$1D Under right corridor -> $10 Outside black Castle .byte Rm06-Rm00 ;$1E Warren Robinett's room -> $06 Hedge maze bottom West_Map_Tbl: ;room to the Left ;room#, description (from -> to) IF USE_TITLE_DISPLAY = 0 .byte $00 ;$00 Number room -> $00 Number room ENDIF .byte Rm03-Rm00 ;$01 Below Hedge maze -> $03 Above the catacombs .byte Rm01-Rm00 ;$02 Below yellow castle -> $01 Below Hedge maze .byte Rm02-Rm00 ;$03 Above the catacombs -> $02 Below yellow castle .byte Rm06-Rm00 ;$04 Hedge maze below black castle -> $06 Hedge maze bottom .byte Rm04-Rm00 ;$05 Hedge maze above entry -> $04 Hedge maze below black castle .byte Rm05-Rm00 ;$06 Hedge maze bottom -> $05 Hedge maze above entry .byte Rm08-Rm00 ;$07 Hedge maze center -> $08 Hedge maze entry .byte Rm07-Rm00 ;$08 Hedge maze entry -> $07 Hedge maze center .byte Rm0A-Rm00 ;$09 Catacombs middle -> $0A Catacombs entry .byte Rm09-Rm00 ;$0A Catacombs entry -> $09 Catacombs middle .byte Rm0D-Rm00 ;$0B Catacombs side -> $0D Left corridor below white Castle .byte Rm0B-Rm00 ;$0C Right corridor right of catacombs -> $0B Catacombs side .byte Rm0C-Rm00 ;$0D Left corridor below white Castle -> $0C Right cr right of catacombs .byte Rm10-Rm00 ;$0E Below left corridor -> $10 Outside black Castle .byte Rm0F-Rm00 ;$0F Outside white Castle -> $0F Outside white Castle .byte Rm1C-Rm00 ;$10 Outside black Castle -> $1C Above right corridor right of catacombs .byte Rm01-Rm00 ;$11 Outside yellow Castle -> $01 Below Hedge maze .byte Rm12-Rm00 ;$12 Inside yellow castle -> $12 Inside yellow castle .byte Rm16-Rm00 ;$13 Black maze right of entry -> $16 Black maze entry .byte Rm13-Rm00 ;$14 Black maze challise room -> $13 Black maze dot's room .byte Rm14-Rm00 ;$15 Black maze dot's room -> $14 Black maze challise room .byte Rm15-Rm00 ;$16 Black maze entry -> $15 Black maze dot's room .byte Rm18-Rm00 ;$17 Red maze above black key's room -> $18 Red maze above entry .byte Rm17-Rm00 ;$18 Red maze above entry -> $17 Red maze above black key's room .byte Rm1A-Rm00 ;$19 Red maze black key's room -> $1A Red maze entry .byte Rm19-Rm00 ;$1A Red maze entry -> $19 Red maze black key's room .byte RD4-RD0 ;$1B inside black castle -> 4th set of differences .byte Rm08-Rm00 ;$1C Above right corridor right of catacombs -> $08 .byte Rm03-Rm00 ;$1D Under right corridor -> $03 Above the catacombs .byte Rm03-Rm00 ;$1E Warren Robinett's room -> $03 Above the catacombs ENDIF IF BANKS = 0 ORG $2FF8,0 RORG $FFF8 .byte "3911" ENDIF IF BANKS = 1 ORG $4FF6,0 RORG $FFF6 .byte "3/9/11" ENDIF IF BANKS = 2 ORG $8FF4,0 RORG $FFF4 .byte "3/9/2011" ENDIF .word START ;cold start vector .word START ;interrupt vector Edited October 16, 2019 by keithbk 1 1 Quote Link to comment Share on other sites More sharing options...
