bfollowell Posted October 31, 2019 Share Posted October 31, 2019 I received my new U.K. 520STE that I'll be converting to a U.S. unit. I will be upgrading the RAM to 4MB and I have beautiful new old stock Atari 4160STE upgrade case badge that I want to install on it. I don't want to destroy the old badge in the process of removing it though. Is there a good method for removing the old badge without bending/warping/destroying it in the process? Also, what would be good to use to install the 4160 badge that would leave it easy to remove if needed? Thanks. Quote Link to comment Share on other sites More sharing options...
guus.assmann Posted November 1, 2019 Share Posted November 1, 2019 Mostly, if you heat up the label, the glue will become soft and the label will come of more easy. Quote Link to comment Share on other sites More sharing options...
mimo Posted November 1, 2019 Share Posted November 1, 2019 Heat and some dental floss gently worked underneath the label, then kinda see-saw it back and forth As for the replacement, something not too sticky, and not too much of it, I think I used a glue stick when I did mine years ago Quote Link to comment Share on other sites More sharing options...
bfollowell Posted November 1, 2019 Author Share Posted November 1, 2019 Thanks guys. I will remember heat, floss, and slow, gentle movements. And to remove the heat occasionally, so that I don't melt the case! Quote Link to comment Share on other sites More sharing options...
atarian1 Posted November 2, 2019 Share Posted November 2, 2019 16 hours ago, mimo said: Heat and some dental floss gently worked underneath the label, then kinda see-saw it back and forth Huh? ? You just gently push through the two holes underneath the label. Take off the top cover. See those two holes underneath the label? Just gently push each hole until the label comes off. That's how I did it. Quote Link to comment Share on other sites More sharing options...
bfollowell Posted November 2, 2019 Author Share Posted November 2, 2019 Ah, I see those two holes. I'll give that a try and see how easy it seems before pulling out the heat gun. Thanks. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted November 2, 2019 Share Posted November 2, 2019 2 holes are the way to go. I've had the edges still stick hard though and it want to "bulge" where I was pushing through the 2 holes so I always keep an Exacto knife (super sharp, think scalpel!) and it will get under the edges without doing damage. Just go slow and careful - watch that knife too - it's like its got a razor /laser edge! PS I use it for doing my D&D paper models. Quote Link to comment Share on other sites More sharing options...
