OP scaled bitmap
swapd0
How do I calculate the correct value of REMAINER field in a vertical scaled object?
I've tried to put it to zero, use the same value as the VSCALE field, but all of them have some issues. Some times the OP draw more scanlines(extra scan line with random pixels), or it draws first scan line bigger than the others.
Edited by swapd0
" Some times the OP draw more scanlines(extra scan line with random pixels) "
Are extra scanlines drawn before your bitmap, or after your bitmap?
"How do I calculate the correct value of REMAINER field in a vertical scaled object?"
Do you need to calculate REMAINDER bits, or just initialize REMAINDER bits?
My understanding, from a version of the Software Reference, is:
...that you initialize the REMAINDER bits when create object list and when you recreate the object list after every vertical blank.
...the hardware updates this on a per scanline basis, in between vertical blanks.
It's been a LONG time since I looked, but IIRC the Scaled objects have a bug.. sorry, feature :D  Which is the random extra scan line you see.  I *think* the solution to this is to add a blank line to the bottom of your source object.
Sorry I cannot help with the remainder calcs, I haven't looked into those yet
  • 2 months later...
I've done some testing and I think that this is the best way to draw scaled bitmaps without wasting some cycles drawing an extra scan line (scaled), and without leaving an empty scan line in the bitmap.
1. always decrement object height by one (even if y scale it's $20)
2. set remainder = scale y
I haven't done many test with smaller objects (y scale < $20) but for now it looks ok.
