Mazzspeed Posted February 10, 2021 Share Posted February 10, 2021 On 12/29/2019 at 10:38 AM, carlsson said: @towmater Is that an SD2IEC device you are using? That is not how you mount disk images. Using old school C64 syntax, you would use this: OPEN 1,9,15 PRINT#1,"CD:CPM.D71" CLOSE 1 (optional) LOAD"*",9,1 (or LOAD"$",9 if you want to get the listing) I think the C128 has commands for DIRECTORY and sending commands directly to the drive, but since I never was a C128 person I don't know exactly which ones are available. Geezus. Just install a JiffyDOS ROM and enter: @CD:CPM* Then press [SHIFT] & [RUN/STOP]. If you want the directory listing after mounting the D71 using @CD, just enter: @$ If you want a time stamped directory listing (assuming you have an RTC, otherwise many time stamps are applied when you copy the file onto your FAT32 formatted CF card), use the =T switch. So enter: @$=T Quote Link to comment Share on other sites More sharing options...
bluejay Posted February 10, 2021 Share Posted February 10, 2021 https://www.cpm8680.com/cpmc64/ This website gives you a good idea on how to make .d** format CP/M floppies. You can then use the image with an SD2IEC or write it to a real Commodore drive to load whatever CP/M program you wish. I used VICE running at max speed to quickly copy a bunch of CP/M software onto a proper CP/M D71 image, and wrote the image to a floppy using Star Commander and a 1571. Everything went excellently. Quote Link to comment Share on other sites More sharing options...
Mazzspeed Posted February 10, 2021 Share Posted February 10, 2021 DirMaster is perfect for making D64/71/81 images and more on your PC to transfer to your Commodore. Furthermore, it works perfectly under Linux using Wine: https://style64.org/dirmaster Quote Link to comment Share on other sites More sharing options...
