Omega-TI Posted October 28, 2020 Share Posted October 28, 2020 11 hours ago, jedimatt42 said: I would expect, having looked at the parts, it would go nicely on an UberGrom board. Wow, that would be kind of neat. The sad thing is, I've not programmed a 1284P in so long I've forgotten how to do it. The 49F040 is a piece of cake though. You know the old saying, "Use it or lose it". Sadly, I've lost it. Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted October 28, 2020 Share Posted October 28, 2020 Just in case anyone burns one.... 1 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted October 28, 2020 Author Share Posted October 28, 2020 I was trying to LOAD("DSK9.T80XBGEM.OBJ") a few days ago using the fast assembly object code loader. This threw an error in XB, but did not throw an error using MiniMemory. To make a very long story pretty short, here is what I found. Besides the usual addresses that you can REF in the minimemory loader such as VSBW, VWTR, etc., I added others including SCROLL. T80XB has an assembly sub called, you guessed it, SCROLL. When the loader is adding DEF's to the list of assembly subs it checks to see if it is in the REF table. If so then an error is issued. I will look tonight to see if it is possible to have SCROLL both REF'd and DEF'd. That may be the best way to deal with this. 3 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted October 28, 2020 Share Posted October 28, 2020 14 hours ago, Omega-TI said: The sad thing is, I've not programmed a 1284P in so long I've forgotten how to do it. You could use GROMCFG on the TI. 2 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted October 29, 2020 Author Share Posted October 29, 2020 (edited) The fix to the problem described in post 303 was simple. I simply bypass the check for REFs and DEFs being the same. Now you have the best of both worlds. You can: REF XMLLNK DEF SCROLL SCROLL LWPI WKSP BLWP @XMLLNK DATA >0026 etc..... and that works fine. The loader knows to add scroll to the list of assembly subroutines. Or you can: REF SCROLL REF XMLLNK DEF SCRL SCRL LWPI WKSP BLWP @XMLLNK DATA SCROLL etc..... and that also works fine. The loader knows to look up SCROLL in the table of REFs. Notice that, unlike the normal XB loader, you can use REFs. If you try to do both REF SCROLL and DEF SCROLL you get an error message when assembling using the TI assembler and Asm994a, and probably all others as well. Edited October 29, 2020 by senior_falcon 3 Quote Link to comment Share on other sites More sharing options...
Tursi Posted October 29, 2020 Share Posted October 29, 2020 10 hours ago, Asmusr said: You could use GROMCFG on the TI. Everyone made it very clear that they hated the tools I provided. Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted October 29, 2020 Share Posted October 29, 2020 On 10/27/2020 at 7:26 PM, Omega-TI said: Wow, that would be kind of neat. The sad thing is, I've not programmed a 1284P in so long I've forgotten how to do it. The 49F040 is a piece of cake though. You know the old saying, "Use it or lose it". Sadly, I've lost it. You'll give up a feature in post #289 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted October 30, 2020 Share Posted October 30, 2020 On 10/28/2020 at 10:50 PM, jedimatt42 said: You'll give up a feature in post #289 Very true, but I was thinking more for my beige unit in one of my new beige shells. Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted October 31, 2020 Author Share Posted October 31, 2020 (edited) While working on the new CALLs for GEM, I found a bug in Asm994a. As mentioned earlier, the new object code loader can use REFs. Here's the bug: REF GPLWS LWPI GPLWS END When assembled with the TI assembler, loading this one line of code gives the expected >02E0,>83E0 When assembled with Asm994a, loading this one line gives >83E0,>0000 and if there are lines after this the loader seems to slow to a crawl. I'm guessing it's somehow getting out of sync. DATA GPLWS gives the expected >83E0 with either assembler. I will make a note of this bug in the GEM manual. Edited October 31, 2020 by senior_falcon 2 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted November 1, 2020 Author Share Posted November 1, 2020 Being able to move the vdp stack within a running program is the key to having a CALL TML that works properly. Or, if you are in the TML environment, CALL XB256 or CALL T80XB would also entail moving the stack. I have finally had some success doing this. It was a simple test program that created 2 strings and then printed them. The program started up, did the prescan before startup, then the first line CALL LINK'd to an assembly routine that moved the stack. After the stack was moved the program worked as expected. Now to test with more complex programs that use DEF's and user subs. 4 Quote Link to comment Share on other sites More sharing options...
+RXB Posted November 1, 2020 Share Posted November 1, 2020 1 hour ago, senior_falcon said: Being able to move the vdp stack within a running program is the key to having a CALL TML that works properly. Or, if you are in the TML environment, CALL XB256 or CALL T80XB would also entail moving the stack. I have finally had some success doing this. It was a simple test program that created 2 strings and then printed them. The program started up, did the prescan before startup, then the first line CALL LINK'd to an assembly routine that moved the stack. After the stack was moved the program worked as expected. Now to test with more complex programs that use DEF's and user subs. Moving Stack is a problem as some hard coded routines exist in XB that will assume VDP address >0958 one of them is in XB ROMs other in GPL. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted November 1, 2020 Share Posted November 1, 2020 2 hours ago, RXB said: Moving Stack is a problem as some hard coded routines exist in XB that will assume VDP address >0958 one of them is in XB ROMs other in GPL. There is no hard-coded reference in the console ROM or GROMs. Where are they in XB? ...lee 1 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted November 1, 2020 Author Share Posted November 1, 2020 4 hours ago, RXB said: Moving Stack is a problem as some hard coded routines exist in XB that will assume VDP address >0958 one of them is in XB ROMs other in GPL. That's not an issue at all. That was figured out with TML in the early 1990's. T40XB and T80XB use the same trick. It's the actual stack that needs to be moved to make room for graphics. Instead of ending at >37D7, my test program moves it so it ends at >2FFF, all done from a running program. 2 Quote Link to comment Share on other sites More sharing options...
+RXB Posted November 2, 2020 Share Posted November 2, 2020 20 hours ago, Lee Stewart said: There is no hard-coded reference in the console ROM or GROMs. Where are they in XB? ...lee Lee One in start up of XB GROM and another in XB ROMs usually at start up of XB. In RXB 2020 I have modified these to be moved to your choice. Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted November 4, 2020 Author Share Posted November 4, 2020 On 11/1/2020 at 10:54 AM, senior_falcon said: Being able to move the vdp stack within a running program is the key to having a CALL TML that works properly. Or, if you are in the TML environment, CALL XB256 or CALL T80XB would also entail moving the stack. I have finally had some success doing this. It was a simple test program that created 2 strings and then printed them. The program started up, did the prescan before startup, then the first line CALL LINK'd to an assembly routine that moved the stack. After the stack was moved the program worked as expected. Now to test with more complex programs that use DEF's and user subs. I did some re-coding and with the changes it looks like user SUBs and DEFs work fine with the stack moved. (Only one program tested so far.) So it should be possible to CALL TML as described above andthe program will select the proper graphics mode as needed. So far this will only work if that is the first statement in the program. In the next few days I will investigate whether it is possible to change graphics modes at any point within a program. 7 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted November 5, 2020 Author Share Posted November 5, 2020 I made another small change and now it looks like the stack can be moved at any point within a running program. I have a little more testing to do to be sure there are no snags (there usually are!) and assuming all goes as expected should be adding this to GEM soon. I had a great idea for an addition to XB 2.8 G.E.M. - the ability to run ROM programs on a v2.2 console. And then I realized that would be kind of tough if XB has to be in the slot! 2 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted November 6, 2020 Share Posted November 6, 2020 1 hour ago, senior_falcon said: I had a great idea for an addition to XB 2.8 G.E.M. - the ability to run ROM programs on a v2.2 console. And then I realized that would be kind of tough if XB has to be in the slot! Which brings up a technical question, assuming one wanted GEM or some other cartridge image like Force Command to always to be available, no matter what is plugged into their cartridge port, could a cartridge work with some sort of "P-Box based cartridge adapter"? Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted November 6, 2020 Author Share Posted November 6, 2020 That's way beyond my pay grade. I'm pretty ignorant about the TI99. I learned a few tricks and have been making the most of them ever since. 2 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted November 6, 2020 Share Posted November 6, 2020 (edited) 8 hours ago, Omega-TI said: Which brings up a technical question, assuming one wanted GEM or some other cartridge image like Force Command to always to be available, no matter what is plugged into their cartridge port, could a cartridge work with some sort of "P-Box based cartridge adapter"? Check out the SNUG HSGPL Card. That being said, you can still only access one cartridge at a time. Edited November 6, 2020 by atrax27407 1 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted November 6, 2020 Share Posted November 6, 2020 9 hours ago, Omega-TI said: Which brings up a technical question, assuming one wanted GEM or some other cartridge image like Force Command to always to be available, no matter what is plugged into their cartridge port, could a cartridge work with some sort of "P-Box based cartridge adapter"? Sounds to me like a good candidate for a TSR type run, perhaps brought up from an interrupt key. The other real issue being where it would reside as a fixture. Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted November 6, 2020 Share Posted November 6, 2020 Why don't we start a separate topic for this? Perhaps Omega could do a poll. 1 2 Quote Link to comment Share on other sites More sharing options...
+acadiel Posted November 6, 2020 Share Posted November 6, 2020 On 10/28/2020 at 11:38 PM, Tursi said: Everyone made it very clear that they hated the tools I provided. GROMCFG is super easy to use. I don't know why people hate it so much. I've used it probably 30+ times. 3 Quote Link to comment Share on other sites More sharing options...
Tursi Posted November 6, 2020 Share Posted November 6, 2020 8 hours ago, acadiel said: GROMCFG is super easy to use. I don't know why people hate it so much. I've used it probably 30+ times. The original thread provides sufficient enlightenment. But thanks. 1 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted November 7, 2020 Author Share Posted November 7, 2020 I can now move both ends of the stack from within a running program, with no hiccups, glitches or other problems that I can detect. It also works from command line in the immediate mode. This means that G.E.M. can have CALL TML, CALL XB256, CALL T40XB, etc. I will see whether these can be more versatile. i.e. CALL XB256 will load and start up XB256 with the default 3 disk files. Or you could have CALL XB256(2) which would do the same as CALL FILES(2) and then load XB256. 7 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted November 13, 2020 Author Share Posted November 13, 2020 The pieces of the puzzle are beginning to fit together. As hoped, CALL XB256 will be able to load and start up XB256 with the default 3 disk files, while CALL XB256(4) would load and start XB256 with 4 disk files open. I now need to do a check for sufficient stack memory to throw an error if moving the stack will leave the program without enough memory. 3 Quote Link to comment Share on other sites More sharing options...
