Scottie4442 Posted January 1, 2020 Share Posted January 1, 2020 (edited) I found this at mouser.com: mouser part number: 895-USBRS2321.8BT5.0, FTDI part number: USB-RS232-WE-1800-BT_5.0. This is available at other electronics dealers, digikey, etc. I used this to make a usb -> 4-pin DIN cable, so no adapter needed in the middle, although it is a little expensive, by the time you buy the cable and the serial to usb adapter this is about the same price. from the usb FTDI cable the connections are: yellow wire pin 4, orange wire pin 2, black wire pin 3, all others can be heat shrinked out of the way. Edited January 1, 2020 by Scottie4442 Quote Link to comment Share on other sites More sharing options...
