MemberAtarian Posted January 23, 2020 Share Posted January 23, 2020 Hi guys, I made a six-sprite kernel with 6 pointers and added a pointer for changing the luma of the color. dim Score1IconPointer = c dim Score2IconPointer = e dim Score3IconPointer = g dim Score4IconPointer = i dim Score5IconPointer = k dim Score6IconPointer = m dim ColorPointer = o dim ScoreColor= q ScoreColor= $14 asm title_eat_overscan2 clc lda INTIM bmi title_eat_overscan2 title_do_vertical_sync2 lda #2 sta WSYNC ;one line with VSYNC sta VSYNC ;enable VSYNC sta WSYNC ;one line with VSYNC sta WSYNC ;one line with VSYNC lda #0 sta WSYNC ;one line with VSYNC sta VSYNC ;turn off VSYNC ;lda #42+128 ifnconst vblank_time lda #42+128 else lda #vblank_time+128 endif sta TIM64T title_vblank_loop2 lda INTIM bmi title_vblank_loop2 lda #0 sta WSYNC sta VBLANK sta ENAM0 sta ENAM1 sta ENABL lda #230 sta TIM64T SelectDone LDA #<Lock STA Score1IconPointer LDA #>Lock STA Score1IconPointer+1 LDA #<Term STA Score2IconPointer LDA #>Term STA Score2IconPointer+1 LDA #<Vent STA Score3IconPointer LDA #>Vent STA Score3IconPointer+1 LDA #<UP STA Score4IconPointer LDA #>UP STA Score4IconPointer+1 LDA #<DOWN STA Score5IconPointer LDA #>DOWN STA Score5IconPointer+1 LDA #<AZ5 STA Score6IconPointer LDA #>AZ5 STA Score6IconPointer+1 LDA #<Colors STA ColorPointer LDA #>Colors STA ColorPointer+1 LDA #$03 ; 2 STA NUSIZ0 ; 3 STA NUSIZ1 ; 3 STA HMCLR sta WSYNC ; 3 tsx ; 2 stx temp3 ; 3 sleep 25 LDY #7 ; 2 STY VDELP0 ; 3 STY VDELP1 ; 3 STA RESP0 ; 3 STA RESP1 ; 3 lda #$60 ; 2 sta HMP0 ; 3 lda #$70 ; 2 sta HMP1 ; 3 sleep 4 STA HMOVE ; 3 DisplayLoop lda (ColorPointer),y ; 5 adc ScoreColor ; 3 sta COLUP0 ; 3 sta COLUP1 ; 3 lax (Score1IconPointer),y ; 5 lda (Score2IconPointer),y ; 5 stx GRP0 ; 3 sta GRP1 ; 3 lda (Score3IconPointer),y ; 5 sta GRP0 ; 3 lax (Score5IconPointer),y ; 5 txs ; 2 lax (Score4IconPointer),y ; 5 lda (Score6IconPointer),y ; 5 stx GRP1 ; 3 tsx ; 2 stx GRP0 sta GRP1 ; 3 stx GRP0 dey ; 3 nop bpl DisplayLoop ; 2 iny sty GRP0 sty GRP1 sty NUSIZ0 sty NUSIZ1 sty COLUP0 sty COLUP1 ldx temp3 txs sta WSYNC PFWAIT2 lda INTIM bne PFWAIT2 end goto OVERSCAN2 asm Lock .byte #%00111100 .byte #%01011010 .byte #%01011010 .byte #%01000010 .byte #%01111110 .byte #%00100100 .byte #%00100100 .byte #%00011000 Term .byte #%01000000 .byte #%10100011 .byte #%01000100 .byte #%11100100 .byte #%11100100 .byte #%10101011 .byte #%10100000 .byte #%01000000 Vent .byte #%00000100 .byte #%00001100 .byte #%11111100 .byte #%01100100 .byte #%00100110 .byte #%00111111 .byte #%00110000 .byte #%00100000 DOWN .byte #%00111100 .byte #%01000010 .byte #%10011001 .byte #%00111100 .byte #%01111110 .byte #%00011000 .byte #%00011000 .byte #%00011000 UP .byte #%00111100 .byte #%01000010 .byte #%10011001 .byte #%00011000 .byte #%00011000 .byte #%01111110 .byte #%00111100 .byte #%00011000 AZ5 .byte #%00000110 .byte #%00000001 .byte #%01110111 .byte #%00000100 .byte #%10111111 .byte #%11101000 .byte #%10100100 .byte #%01011100 Nothing .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 .byte #%00000000 Colors .byte #$02 .byte #$04 .byte #$06 .byte #$08 .byte #$08 .byte #$06 .byte #$04 .byte #$02 ScoreColors .byte #$02 .byte #$04 .byte #$06 .byte #$08 .byte #$08 .byte #$06 .byte #$04 .byte #$02 .OVERSCAN2 ;lda #35+128 ifnconst overscan_time lda #35+128 else lda #overscan_time+128-3-1 endif sta TIM64T lda #%11000010 sta WSYNC sta VBLANK jmp title_eat_overscan2 end I don't want to remove the pointers because I want to use it for universal puproses (six digit score, picture, inventory, status screen, etc.) and make it a little colored. I even tried it without the colors, where I can fine tune with "nop"-s, but I couldn't get any better results. Typically, these are the two best version I can get by changing the sleep macros and the position of the single "nop" in the loop. One version is where the last bit of sprite one becomes the third sprite's last bit (it is saved too soon) or the first bit of sprite 6 becomes the first bit of sprite 4 (sta happens too late). Can you help me a little? It's based on the method how bB kernel creates the score. testshit.bas.bin Quote Link to comment Share on other sites More sharing options...
KK/Altair Posted January 23, 2020 Share Posted January 23, 2020 I'm not quite sure which exactly STA happens to early or too late, but if you'd like to split the 2-cycle NOP in half for greater flexibility, you can use shadow registers on the $01xx page. In other words, for every TIA or RAM basic address, there's an alternate location 256 bytes higher. And by using these locations you can easily force the assembler not to use zeropage addressing mode - because the address is not on the zero page. Bad: STA GRP0 ; 3 - let's assume for this example it's 1 cycle too early NOP ; 2 STY GRP1 ; 3 Fix: STA GRP0+256 ; 4 - bullseye! this instruction now takes 1 cycle longer, but on VCS does exactly the same STY GRP1+256 ; 4 - this one needs 1 cycle delay too, to write at 8th cycle exactly as before This trick is VERY useful on the VCS to get 1-cycle NOPs. 2 Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted January 24, 2020 Author Share Posted January 24, 2020 8 hours ago, KK/Altair said: This trick is VERY useful on the VCS to get 1-cycle NOPs. Seems like useful. Hope I can get it somehow work, I tried many variations this morning, but eeeeeeeeh. Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted January 24, 2020 Author Share Posted January 24, 2020 It seems like it just makes it corrupted at other places. Sometimes I feel like TIA only handles cycles at his own will, and saving to a variable costs more, while loading costs nothing. Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted January 24, 2020 Author Share Posted January 24, 2020 (edited) Okay, it seems like the only way to proper do this is like in the 48p kernel in title screen kernel, you will lose the 0 bit in every case in the first sprite because you have to erase that bit first with the ball. Edited January 24, 2020 by MemberAtarian Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted January 24, 2020 Share Posted January 24, 2020 17 hours ago, KK/Altair said: STA GRP0+256 ; 4 - bullseye! this instruction now takes 1 cycle longer, but on VCS does exactly the same STY GRP1+256 ; 4 - this one needs 1 cycle delay too, to write at 8th cycle exactly as before Assuming you're using dasm, I find using the FORCE extensions to be easier: STA.w GRP0 ; 4 - bullseye! this instruction now takes 1 cycle longer, but on VCS does exactly the same STY.w GRP1 ; 4 - this one needs 1 cycle delay too, to write at 8th cycle exactly as before the .w tells dasm to use Absolute addressing instead of Zero Page addressing. From the dasm manual: EXTENSIONS: FORCE extensions are used to force an addressing mode. In some cases, you can optimize the assembly to take fewer passes by telling it the addressing mode. Force extensions are also used with DS,DC, and DV to determine the element size. NOT ALL EXTENSIONS APPLY TO ALL PROCESSORS! example: lda.z charlie i -implied ind -indirect word 0 -implied 0x -implied indexing (0,x) 0y -implied indexing (0,y) b -byte address bx -byte address indexed x by -byte address indexed y w -word address wx -word address indexed x wy -word address indexed y l -longword (4 bytes) (DS/DC/DV) r -relative u -uninitialized (SEG) First character equivalent substitutions: b z d (byte, zeropage, direct) w e a (word, extended, absolute) Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted January 26, 2020 Share Posted January 26, 2020 The problem is that the last 4 writes to the sprite registers (3 updates + dummy write) need to start in rapid succession exactly 3 cycles before the end of the 2nd sprite's image when VDEL is enabled in both sprites. The TSX instruction disrupts that flow...so it will always be 1 cycle too early or too late in one of the images. You can either live without using that bit position in the GFX data, or rewrite the routine so that the Y register is able to be saved/restored during the loop (and thus, can hold GFX data for one of the sprites in between). Worst-case, use a temp array of 8 bytes to hold pre-determined color data. BTW have you noticed that the HMOVE before the loop is hitting at cycle 61? Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted January 27, 2020 Author Share Posted January 27, 2020 (edited) On 1/26/2020 at 10:07 AM, Nukey Shay said: The problem is that the last 4 writes to the sprite registers (3 updates + dummy write) need to start in rapid succession exactly 3 cycles before the end of the 2nd sprite's image when VDEL is enabled in both sprites. The TSX instruction disrupts that flow...so it will always be 1 cycle too early or too late in one of the images. You can either live without using that bit position in the GFX data, or rewrite the routine so that the Y register is able to be saved/restored during the loop (and thus, can hold GFX data for one of the sprites in between). Worst-case, use a temp array of 8 bytes to hold pre-determined color data. BTW have you noticed that the HMOVE before the loop is hitting at cycle 61? If I rewrite it to reuse the Y, I have to drop the cycle loading the ColorPointer (which loads the shading) and adding the base color to it. And that's something I don't want to do. The problem is, that I don't have much cycles to change, there was only 2 for placing with nop or +256 (.w) so I don't have much if I want to keep it universal, so you can load everything into pointers and enter this loop, so this can became a score, indicator, healthbar, inventory, single picture, etc. I also tried to change the position of HMOVE, HMP0 and HMP1, also tried with VDELs (0,0), (0,1), (1,0), (1,1), if I can do something, but it was always really off. The only solution I found was using some "magic tricks" (fixing the lost bit with ball and m0, then overlap 2 missiles with the pf) I read about in bB's title kernel and using them with a 2line kernel. Edited January 27, 2020 by MemberAtarian Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted January 27, 2020 Share Posted January 27, 2020 1 hour ago, MemberAtarian said: If I rewrite it to reuse the Y, I have to drop the cycle loading the ColorPointer (which loads the shading) and adding the base color to it. And that's something I don't want to do. But that can be pre-calculated and placed into a temp Ram array, which I stated. You might need to weigh the advantages of using a generic subroutine vs. multiple routines dedicated to what is to be displayed. Rom is more plentiful than Ram. 1 Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted January 27, 2020 Author Share Posted January 27, 2020 1 minute ago, Nukey Shay said: But that can be pre-calculated and placed into a temp Ram array, which I stated. You might need to weigh the advantages of using a generic subroutine vs. multiple routines dedicated to what is to be displayed. Rom is more plentiful than Ram. There are not enough cycles to load sprite variable, store in temp array and then save it one point. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted January 27, 2020 Share Posted January 27, 2020 Well, then unroll the loop. There's still 3 cycles left over (or 1 cycle, if LAX is not used). The routine then fills 1 page of Rom, but who cares? Means to an end. LF51C ldy #$07 ;2 1st scanline lda (ColorPointer),y ;5 adc ScoreColor ;3 sta COLUP0 ;3 sta COLUP1 ;3 lda (Score1IconPointer),y ;5 sta GRP0 ;3 lda (Score2IconPointer),y ;5 sta GRP1 ;3 lda (Score3IconPointer),y ;5 sta GRP0 ;3 lda (Score5IconPointer),y ;5 sta temp ;3 lax (Score4IconPointer),y ;5 lda (Score6IconPointer),y ;5 ldy temp ;3 stx GRP1 ;3 sty GRP0 ;3 sta GRP1 ;3 sta GRP0 ;3 sta $2E ;3 unused cycles ldy #$06 ;2 2nd scanline lda (ColorPointer),y ;5 adc ScoreColor ;3 sta COLUP0 ;3 sta COLUP1 ;3 ...etc Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted January 27, 2020 Author Share Posted January 27, 2020 7 minutes ago, Nukey Shay said: Well, then unroll the loop. There's still 3 cycles left over (or 1 cycle, if LAX is not used). The routine then fills 1 page of Rom, but who cares? Means to an end. LF51C ldy #$07 ;2 1st scanline lda (ColorPointer),y ;5 adc ScoreColor ;3 sta COLUP0 ;3 sta COLUP1 ;3 lda (Score1IconPointer),y ;5 sta GRP0 ;3 lda (Score2IconPointer),y ;5 sta GRP1 ;3 lda (Score3IconPointer),y ;5 sta GRP0 ;3 lda (Score5IconPointer),y ;5 sta temp ;3 lax (Score4IconPointer),y ;5 lda (Score6IconPointer),y ;5 ldy temp ;3 stx GRP1 ;3 sty GRP0 ;3 sta GRP1 ;3 sta GRP0 ;3 sta $2E ;3 unused cycles ldy #$06 ;2 2nd scanline lda (ColorPointer),y ;5 adc ScoreColor ;3 sta COLUP0 ;3 sta COLUP1 ;3 ...etc Okay, but this is way too space wasting and fixes the height to 8. t Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted January 27, 2020 Share Posted January 27, 2020 Dedicated routines are beginning to look attractive, right? Especially if there's only a few color/sprite font choices in the first place. BTW there is no limit on height so long as there is no limit to Rom. You could have an unrolled loop occupy an entire bank (or multiple banks) if necessary...and just leap to LDY# at whatever sprite size is needed. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted January 27, 2020 Share Posted January 27, 2020 I suspect the kernel you're basing this on was taking advantage of the fact that the digit graphics only used 7 pixels for the shape, with 1 pixel for spacing between digits. Since the space pixel doesn't change between digits it didn't matter if the timing was slightly off. I've done the same before, as seen in this blog post: Quote score timer test pattern The timing is off by a single pixel, resulting in the leftmost pixel of TimerB to also show up as the leftmost pixel of RightScoreB. We can easily work around this by designing the font to not use the leftmost pixel. blue stripes = LeftScoreA and LeftScoreB white stripes = TimerA and TimerB green stripes = RightScoreA and RightScoreB Something that might help so you don't have to unroll is to change what you color. Instead of color the players: sta COLUP0 sta COLUP1 color the playfield, which saves 3 cycles: sta COLUPF The rest of the this requires you to: set the players and background to black set playfield to mirrored make sure the 48 pixels are centered on the screen turn on only the pixels of PF2 that appear behind the 48 pixels Then instead of graphics like this: Make them stencils like this - the 0s will show the playfield color: 1 Quote Link to comment Share on other sites More sharing options...
