collision detection and memory
satyrsfaction
Hi, i'm very much a beginner at this -- i started a little adventure style game as a means of learning Batari Basic....I hope to expand on it later. I'm having two major problems. First, the collision detection i came up with is terrible. I wanted to use the collision prevention in Random Terrain's manual, but it doesn't seem to work, perhaps because my game is a different play field size? Second, i'm out of memory and unfinished. what can i do to save memory, or to move stuff to other banks -- i'm just not sure how that works. will variable values stay assigned if you switch banks? Will play field information stay if you assign it from a different bank?
textadv.bas.bin textadv.bas
Well, I solved my memory problems for now. Apparently you can put the playfield data in another bank and it works fine. I still don't know how to fix my collision detection with the playfield. I just don't understand how to adapt Random Terrain's collision prevention to this new play field resolution.
textadventure.bas.bin textadventure.bas
9 minutes ago, satyrsfaction said:
Thanks, but  I'm not sure I understand what you mean -- i'm just a beginner.
The numbers used with pfread can be used with pfpixel. When I change the screen resolution, I comment out the collision detection code with rem and put in pfpixel so I can see if things are lined up properly. Since you are new, do it with a working example program first so you can see exactly where pfpixel is supposed to be in relation to the sprite. Then you can play with the numbers until it looks the same in your program.
Edited by Random Terrain
OK, i tried it and with the sample program, the pixels appeared on top of the sprite. So i tried it with my game, and I'm having difficulty lining up the pixels. what do the numbers mean? which ones should I try changing? thanks for your help.
This post might be helpful:
atariage.com/forums/topic/131795-pf-pixels-to-sprite-pixels/?do=findComment&comment=1589440
