lowlytech Posted March 1, 2020 Share Posted March 1, 2020 This sounds goofy I know but I wanted to check with you guys first. I have a C128 power supply that I don't have any history on other than it sat for 20 years in a halfway torn down house exposed to some pretty nasty stuff. I opened it up and pulled all the boards out to give it a good clean, also replaced the 2A fuse since it was blown. Tested it and the 5 and 9 volts seems pretty good under no load now. So I was going to put it back together again, and low and behold the fuse PCB just seems to not have a home. I can't believe that would just float around in there, I didn't take pictures before I tore into it last week unfortunately and google searching for an image turns up a majority of power supplies that don't look like this one. Anyone know the proper way this needs to be reassembled or is this it? Thanks... Quote Link to comment Share on other sites More sharing options...
cbmeeks Posted March 5, 2020 Share Posted March 5, 2020 I have a C128 PSU at home. If I can remember, I will take it apart and snap a pic. Quote Link to comment Share on other sites More sharing options...
lowlytech Posted March 8, 2020 Author Share Posted March 8, 2020 Thanks cbmeeks, I appreciate it. Hope yours is the same revision as this one. Quote Link to comment Share on other sites More sharing options...
