Marco Mollison Sr. Posted July 15, 2003 Share Posted July 15, 2003 Hi has anyone figured out how to get around the 16 meg HDD partition limitation on the atari 8 bit machines? Link to comment Share on other sites More sharing options...
classics Posted August 11, 2003 Share Posted August 11, 2003 Hi has anyone figured out how to get around the 16 meg HDD partition limitation on the atari 8 bit machines? It isnt so much a limitation as it is a need to stick with the Atari OS standard SIO frame. Such frames mean nothing to say a real hard disk, but all the Atari DOS systems are designed around the 2-byte sector ID in the SIO frame. If you write your own DOS system you can have partitions as large as you want, but only that DOS would be able to read and write to such partitions. Link to comment Share on other sites More sharing options...
Marco Mollison Sr. Posted August 12, 2003 Author Share Posted August 12, 2003 I just figured that since I and many others use Sparta dos that someone might have come out with an upgrade to it.. But oh well I guess not... Having a large capacity hard drive with the capability of even 32meg partitions would be an improvement, since the limitation on most controllers is 8 partitions active at a time there would be a better chance for a Systems operator to accomodate more downloads (if there are very many BBS's left). Link to comment Share on other sites More sharing options...
Gregory DG Posted August 12, 2003 Share Posted August 12, 2003 Hi has anyone figured out how to get around the 16 meg HDD partition limitation on the atari 8 bit machines? You can hook up a hard drive to the 8-bits?! Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
