2020 HSC Round 2 T:ME Salvo
toiletunes
Standard controls
Ends April 8
HSC record: 15,480 S.BAZ. Beat the record for +2 Bonus Points!
Totals as of round 1:
12 Toiletunes
11 Dr Moocowz
8 S.BAZ
7 gambler172
6 roadrunner
5 oyamafamily
4 JohnnyBritish
3 jblenkle
Scores this round:
11,960 oyamafamily 10
10,180 Dr Moocowz 9
9,880 troff 8
6,700 Toiletunes 7
5,180 BydoEmpire 6
3,200 roadrunner 5
720 jblenkle 4
Edited by toiletunes
5 hours ago, Dr Moocowz said:
10180
Took a few games to get warmed up. I definitely had some silly deaths adjusting to standard controls.
Wow, that's a great score!  Any tips?  I find this a really, really tough game.  I tend to lose track of my player with so much going on all over the screen.
Edited by BydoEmpire
Sure!
- Collecting the 4 dudes and making them survive gets you a nice chunk of points if you make it to the end of the board with them alive (1st dude = 100, 2nd dude = 200, 3rd dude = 400, 4th dude = 800, total of 1500).
- To help collect them, there's these four flashing bars. One of them will start to get bigger, which indicates they're going to be the next one to spawn. Once I spot that, I go next to it (if it's the top 2 spots, they spawn right below the bar; if it's the bottom 2 spots, the spawn right above the bar) and hang out, doing my best to stay in the area without getting killed. It's important to get them right away before they have a chance to wander off and get killed by a baddie.
- The S rockets/bombs are your friends! They will kill all active baddies!, although not instantly (gotten burned by that a few times ?)
- It's tough, but always try to be aware of which column/row you are in and fire a bullet immediately when you see a bad guy entering into the row or column. I know that's most of the game, just try to be hyperaware of it. :)
- After I have all the dudes collected (or they're dead), I like to hangout in a corner to make it 1 row and 1 column to keep an eye on for baddies and fire when one enters. They don't usually respawn right next to you. Although if a bullet is coming from both directions, you got no where to run. :)
- You can a few baddies as the board is loading (when they're running down the sides). That's a tiny little kickstart to complete the level.
- Every 2 completed levels, you'll get a challenge level and the key to it is to figure out the pattern, camp in a spot and blast them all! The first one you might need to see once or twice, but after that, you should be able to get a "PERFECT" fairly easily
Hopefully this stuff is helpful to you all!
