billyj1285 Posted March 24, 2020 Share Posted March 24, 2020 Good afternoon everyone, I this post in Atari 2600 programming too, however it is a batari basic question, so I posted here too. I have a really dumb question. I am sorry. I have looked it up and experimented, however I just cant figure this simple thing out. I have a small start of a game. Its just a sprite going up and down right now. This is Batari basic by the way. I just want to set the console reset switch to reset. I have tried the ifthen and I just cannot get it to work. Here is the listing. I am also having trouble making that bottom row solid. I am sorry. I am new and am just having a little trouble. any help would be apprciated. Thanks, Bj set kernel_options player1colors playercolors pfcolors player0x = 75 player0y = 80 COLUBK=$15 main playfield: ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end f=f+1 rem POSSIBLY INEFFICIENT CODE, SEPARATE COLOR INFO FOR EACH FRAME... if f = 10 then player0: %01100110 %00100100 %00100100 %11111111 %00111100 %00111100 %00111100 %00100100 end if f = 10 then player0color: $FC; $FC; $FC; $F4; $F4; $F2; $F0; $F0; end if f = 20 then player0: %00000110 %01100100 %00100100 %11111111 %00111100 %00111100 %00111100 %00100100 end if f = 20 then player0color: $FC; $FC; $FC; $F4; $F4; $F2; $F0; $F0; end if f = 30 then player0: %01100000 %00100110 %00100100 %11111111 %00111100 %00111100 %00111100 %00100100 end if f = 30 then player0color: $FC; $FC; $FC; $F4; $F4; $F2; $F0; $F0; end drawscreen if joy0up then player0y = player0y - 1 if joy0down then player0y = player0y + 1 goto main Quote Link to comment Share on other sites More sharing options...
TwentySixHundred Posted March 25, 2020 Share Posted March 25, 2020 I haven't compiled your code in batari however im thinking by having a quick look you're after something like this. set kernel_options player1colors playercolors pfcolors reset player0x = 75 player0y = 80 COLUBK=$15 main playfield: ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end f=f+1 rem POSSIBLY INEFFICIENT CODE, SEPARATE COLOR INFO FOR EACH FRAME... if f = 10 then player0: %01100110 %00100100 %00100100 %11111111 %00111100 %00111100 %00111100 %00100100 end if f = 10 then player0color: $FC; $FC; $FC; $F4; $F4; $F2; $F0; $F0; end if f = 20 then player0: %00000110 %01100100 %00100100 %11111111 %00111100 %00111100 %00111100 %00100100 end if f = 20 then player0color: $FC; $FC; $FC; $F4; $F4; $F2; $F0; $F0; end if f = 30 then player0: %01100000 %00100110 %00100100 %11111111 %00111100 %00111100 %00111100 %00100100 end if f = 30 then player0color: $FC; $FC; $FC; $F4; $F4; $F2; $F0; $F0; end drawscreen if switchreset then goto reset if joy0up then player0y = player0y - 1 if joy0down then player0y = player0y + 1 goto main One thing to note when reading bitwise operations is the syntax is different from traditional variables. So in BASIC syntax some examples: Peek: on or off if switchreset then goto reset or if !switchreset then goto skip_blah_blah_blah Poke/push values into individual bits (in this case abit0): on or off if switchreset then a{0} = 1 or if !switchreset then a{0} = 0 To read/peek at the state of say individual bits within a variable you would use the same syntax i explained with the reset switch. For example: rem check if a{0} = 1 if so then turn off a{0} and turn on a{1} if a{0} then a{0} = 0 : a{1} = 1 or rem check if not a{0} if so then turn on a{0} and turn off a{1} if !a{0} then a{0} = 1 : a{1} = 0 ect ect Check out RT's site for further examples Quote Link to comment Share on other sites More sharing options...
Lillapojkenpåön Posted March 25, 2020 Share Posted March 25, 2020 I did the same thing, but can't get anything to happen, does this work for you? set kernel_options player1colors playercolors pfcolors reset loop ;drawscreen ;if switchreset then loop player0x = 75 player0y = 80 COLUBK=$15 playfield: ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end player0color: $FC; $FC; $FC; $F4; $F4; $F2; $F0; $F0; end main if joy0up then player0y = player0y - 1 if joy0down then player0y = player0y + 1 f=f+1 rem POSSIBLY INEFFICIENT CODE, SEPARATE COLOR INFO FOR EACH FRAME... if f = 10 then player0: %01100110 %00100100 %00100100 %11111111 %00111100 %00111100 %00111100 %00100100 end if f = 20 then player0: %00000110 %01100100 %00100100 %11111111 %00111100 %00111100 %00111100 %00100100 end if f = 30 then player0: %01100110 %00100100 %00100100 %11111111 %00111100 %00111100 %00111100 %00100100 end if f = 40 then f = 0 : player0: %01100000 %00100110 %00100100 %11111111 %00111100 %00111100 %00111100 %00100100 end drawscreen if switchreset then goto reset goto main Quote Link to comment Share on other sites More sharing options...
TwentySixHundred Posted March 25, 2020 Share Posted March 25, 2020 8 minutes ago, Lillapojkenpåön said: I did the same thing, but can't get anything to happen, does this work for you? Ok so i fired it up and had a look, everything is working fine for me. reset_switch.bas edit: @Lillapojkenpåön i see what you have done wrong, the condition statement you placed is outside the mainloop meaning it never gets read. Quote Link to comment Share on other sites More sharing options...
Lillapojkenpåön Posted March 25, 2020 Share Posted March 25, 2020 I can't seem to map my keys in any of my stella versions, when I open it up again reset is back to F2, which just lowers the volume on my computer. Quote Link to comment Share on other sites More sharing options...
TwentySixHundred Posted March 25, 2020 Share Posted March 25, 2020 5 minutes ago, Lillapojkenpåön said: I can't seem to map my keys in any of my stella versions, when I open it up again reset is back to F2, which just lowers the volume on my computer. You don't have a function key? "FN" next to the windows key? If so press and hold the FN key and press F2 simultaneously Quote Link to comment Share on other sites More sharing options...
Lillapojkenpåön Posted March 25, 2020 Share Posted March 25, 2020 (edited) 37 minutes ago, TwentySixHundred said: edit: @Lillapojkenpåön i see what you have done wrong, the condition statement you placed is outside the mainloop meaning it never gets read. Nope it's in there, I just put it after drawscreen so you have as much time as possible for the init code, and don't overcycle, Fn + F2 worked, thanks. EDIT: Oh you mean the one at the top, that's just a comment. Edited March 25, 2020 by Lillapojkenpåön 1 Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted March 25, 2020 Share Posted March 25, 2020 Have you tried adapting this example program: randomterrain.com/atari-2600-memories-batari-basic-commands.html#switchreset Quote Link to comment Share on other sites More sharing options...
billyj1285 Posted March 25, 2020 Author Share Posted March 25, 2020 This is great. Thank you all for helping. Quote Link to comment Share on other sites More sharing options...
