+jedimatt42 Posted March 6 Share Posted March 6 For all models of TIPI, disk access requires the PI to be booted. Including the speech module shaped boards. There are versions of XB that may let you skip the loading of LOAD... You could hex edit your own XB, and change DSK occurrences to any other 3 letters and that would stop trying to load. You could turn on the PI. You could put a switch on the OE of the 74'245 chip on the board to pull it high when you want the TIPI disabled. You could build a different microcontroller that connects to the wires and returns failure codes back to the TIPI. You could rewrite the DSR to check for timeouts, and return DEVERR, slowing down all access for healthy operations. You could reprogram the CPLD to require a state on one of the test pads before enabling the TIPI's bus. ... There are lots of choices. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted March 7 Share Posted March 7 18 minutes ago, jedimatt42 said: There are lots of choices. I Could've Had A V-8!.mp4 2 Quote Link to comment Share on other sites More sharing options...
RickyDean Posted May 20 Share Posted May 20 On 3/6/2024 at 1:11 PM, kneehighspy said: i know this is an old question, so trying to load extended basic with the tipi32k it locks up (unless pi is installed and booted). is the only workaround disabling / removing the eprom? i know extended basic works fine with the old sidecar 32k and tipi combo. any info is appreciated, thanks! ...mike I will tell you, I had 5 tipi/32k's made from your PCB's and they are all programmed ready to go. Thanks moving the 32k on top and shrinking it down. if that was you? Quote Link to comment Share on other sites More sharing options...
kneehighspy Posted May 21 Share Posted May 21 23 hours ago, RickyDean said: I will tell you, I had 5 tipi/32k's made from your PCB's and they are all programmed ready to go. Thanks moving the 32k on top and shrinking it down. if that was you? yes that was me. glad to hear things are working for ya! ...mike 1 Quote Link to comment Share on other sites More sharing options...
