SpartaDOS X 4.49 (release version)
drac030
Something that would disable CAR (here SDX) and do a reboot afterwards, so in fact what COLD /N does. With SELECT-key kept, loading/booting such tiny binary would allow immediately have QMEG OS menu back, but now with disabled SDX, instead loading it all the way to SDX prompt to do COLD /N.
So cartridges which disallow a disk boot no longer suppress SDX itself? That's what I'm seeing, anyway (SIDE cartridge loader no longer boots when U1MB SDX is enabled). Isn't this functionally a reversion to the behaviour of older SDX versions? Obviously the SIDE cart build of SDX always behaved this way (otherwise it would never have been possible to boot SDX from the SIDE cartridge; the loader would have always started instead).
I think I like the new behaviour better, anyway.
Another issue found...
1. Run SDX from SIDE (SDX mode) to command prompt.
2. Type CAR to switch to SIDE-loader.
3. Pressing SIDE button DOES not disable SIDE-loader anymore, resetting Atari always causes coming back to SIDE loader (can't switch back to Sparta without power off).
Edited by Jacques
The button is supposed to re-enable the SIDE loader, not disable it. But it also resets the SDX bank to 0, so if you booted prior SDX version from the SIDE cart and ran the loader with 'CAR', pressing the button and then pressing reset would cause SDX to reappear (just tested with SDX 4.49c to be sure). I haven't flashed SDX 4.49 final to a SIDE2 yet; I'll see what happens when I do.
But to run such a binary you wold have to load an ATR with it to D1 anyways. If so, why not to have an AUTOEXEC.BAT with COLD/N command inside on that ATR?
@flashjazzcat SDX should no longer allow initialization of other cartridges at boot. This was nonsense, as during init a cartridge may set up some values in the memory, which SDX, when continuing to start afterwards, overwrites. So now it is the CAR command which initializes and starts cartridges inserted into the SDX cartridge port.
Not really, with QMEG and SIO2SD you CAN boot BINARY from any D1-D8 drive (doesn't have to be ATR), so that would be a big help and spare a lot of time against booting SDX and only afterwards COLD/N in AUTOEXEC.BAT via SIO.
Understood. I consider this a sensible approach too. :)
BTW: I just flashed SDX on the SIDE cart and I'm not seeing the behaviour Jacques described. I run the loader with CAR, run a game, press the button, and I get SDX back. If I boot with the switch in the 'loader' position, things of course proceed as normal (i.e. the button brings the loader back). This all makes sense.
PS: I think what Jacques is almost looking for here is an 'on/off' button on the SIDE cartridge. The purpose of the SIDE cartridge in SDX mode is... to provide built-in SDX. On an U1MB machine, you can turn SDX right off and boot with no cartridge ROM at all, but you can't do this with a SIDE cartridge. You need to pull the cartridge, or boot SDX and then do a 'COLD /N'. That's the way I always looked at it, at least.
Edited by flashjazzcat
7 minutes ago, flashjazzcat said:
(...) if you booted prior SDX version from the SIDE cart and ran the loader with 'CAR', pressing the button and then pressing reset would cause SDX to reappear (just tested with SDX 4.49c to be sure). I haven't flashed SDX 4.49 final to a SIDE2 yet; I'll see what happens when I do.
Try 4.49, please, because it definitely doesn't work like this for me on 4.49 and SIDE(1), the button doesn't allow to reappear SDX in such scenario anymore.
See prior post: it's done, and behaves as I would expect given the changes explained.
I will try with an emulated SIDE1 (I no longer have a real one, unfortunately). ;)
Can you repeat it without loading the game? So going into SIDE loader with CAR from SDX prompt, and then trying to reinstate SDX back (SIDE button->warm reset)? On real Atari there's no way out from SIDE loader in this scenario without power off, honestly, without or with QMEG and even its "COLD" reboot ;)
Edited by Jacques
Done... still boots SDX. I would expect this, since the button re-enables both ROMs (SDX and loader, the latter appearing as an external cartridge plugged into an imaginary pass-thru slot in the back of the SIDE cart). SDX not booting in these circumstances would be most puzzling.
Yes, but I thought you were saying that SDX prevents QMEG from booting anything because it takes over and lands in the DOS prompt before the QMEG menu appears. If I misunderstood, please elaborate.
For now I have written a small proggie which you put into your CONFIG.SYS/CFG file. If SELECT is not depressed, it does nothing. If SELECT is depressed, it disables SDX and does a cold reboot.
Tell me if this is of any help.
EDIT: sorry, bad program. Please refetch the attachment.
dissdx.zip
Edited by drac030
Attachmend replaced
Maybe the button on my SIDE1 is faulty or there's something different in it's firmware, I tried now on SIDE2 and it's like you wrote, no problem to reinstate SDX by using SIDE2 button.
Yeah: the only other possibility is that on a real SIDE1, the button only reset the external ROM bank and not the SDX one (and I can't verify this myself any more). But even this wouldn't explain things working for you using an older SDX version.
dissdx.zip 199 B · 3 downloads
Thank you Draco, this replaced attachment now works as expected and IS disabling SDX with SELECT depressed.
It's useful, but still it takes a bit of time, because SDX needs to boot-up and then DEVICE DISSDX is preceeded with DEVICE SPARTA and DEVICE SIO in one of my .cfg files I created for this.
If there would be additional standalone non-SDX binary that I could boot-up from QMEG directly and would act exactly the same as DISSDX, it would be perfect, but anyway, my life with 4.49 became easier already, thank you.
Edited by Jacques
I see, and it is possible to write such a program, but it would not be written so quickly considering the number of different SDX builds.
15 minutes ago, flashjazzcat said:
Well, thanks to @Jacques asking me to test things with SIDE1, I just discovered a small bug in version 4.0 of SIDE.SYS. :) Thanks!
You're welcome :) I'm glad it helped elsewhere (as a SIDE-effect ?), while I'll still investigate what's wrong with my SIDE1.
Oh, I see... So in fact DISSDX.SYS uses SDX internal "COLD /N"-like mechanism present in each build, while such standalone binary would need handling for different SDX versions (I assume). Thanks for what I already have, then!
27 minutes ago, _The Doctor__ said:
The SELECT key held down at cold start and or warm reset is used to enter the MIO, please tell me this isn't being used for some other purpose and muck things up...
It is so, but I do not think Jacques has the MIO, and the program is just for him - and perhaps other QMEG users, who have a sudden problem, because SDX suddenly behaves under QMEG like under any other instance of Atari OS :D
