Fred Olivas Posted September 13, 2020 Share Posted September 13, 2020 Still confused but by reason of deduction I have determined that SDrive-32X.eep is the eeprom writer file I need to install FIRST. But still not sure which one to install. Like I posted, I have the BEST Duino for this project and it has the Atmel 328p microchip on board. Still don't know which of the two .eep files to install. Quote Link to comment Share on other sites More sharing options...
DrVenkman Posted September 13, 2020 Share Posted September 13, 2020 13 minutes ago, Fred Olivas said: Still confused but by reason of deduction I have determined that SDrive-32X.eep is the eeprom writer file I need to install FIRST. But still not sure which one to install. Like I posted, I have the BEST Duino for this project and it has the Atmel 328p microchip on board. Still don't know which of the two .eep files to install. Um, what? You write the hex files to the SDrive-MAX. From the Readme file included with the firmware downloads from Gitghub: Firmware programming: First use the eeprom-writer.hex to set the correct values to the EEPROM! Wait until the writer has done, then programm the SDrive.hex into the flash. That's it! Quote Link to comment Share on other sites More sharing options...
Fred Olivas Posted September 13, 2020 Share Posted September 13, 2020 Now I understand your confusion. There are 2 versions of .eep from which to choose: SDrive32.eep or SDrive328.eep. Not sure which one to choose. There is no eeprom-writer.hex file to be found anywhere. Not even GitHub. Thank you for your response. Quote Link to comment Share on other sites More sharing options...
darwinmac Posted September 13, 2020 Share Posted September 13, 2020 55 minutes ago, Fred Olivas said: Now I understand your confusion. There are 2 versions of .eep from which to choose: SDrive32.eep or SDrive328.eep. Not sure which one to choose. There is no eeprom-writer.hex file to be found anywhere. Not even GitHub. Thank you for your response. @Fred Olivas - I think @DrVenkman's confusion is because, in the released firmware, there are no *.eep files. You do not make clear what version of the firmware is running on your Sdrive Max. Here are my thoughts: 1. If you have version 1.2, you have the latest released version of the firmware. Kbr is working on 1.3, but it has not been released yet. You would have to compile that version manually in order to use it. It only has a few fixes so it probably is not essential for you right now. I am sure simply using xloader will not be enough for you to use firmware version 1.3. 2. If you have built your Sdrive Max yourself and need the 1.2 firmware, the Github link for that firmware version is in the first post of this thread. From that link, if you click the link for "Assets", you'll see a zip file that contains the 1.2 firmware for every supported screen. You probably went to the main Github page which now points to version 1.3 (also known as master). That version does not have a compiled version you can simply load onto your Sdrive Max. I do not want to go through all of the steps of installing the 1.2 firmware since there is a great page (https://atari8bit.net/everything-sdrive-max/) that explains the process very well. Bob C Quote Link to comment Share on other sites More sharing options...
Fred Olivas Posted September 13, 2020 Share Posted September 13, 2020 Hi, I don't have any firmware on my SDrive Max yet. Just a new Arduino waiting to be loaded. But before I load latest firmware I must upload the eeprom-writer.hex file (according to what I've read) which doesn't seem to be available anywhere that is why I was wondering if SDrive32.eep or SDrive328.eep was what I was looking for and which one of these two do I select? I don't know what the difference is as no one has offered an explaination as to which file is the correct file. Quote Link to comment Share on other sites More sharing options...
darwinmac Posted September 13, 2020 Share Posted September 13, 2020 36 minutes ago, Fred Olivas said: Hi, I don't have any firmware on my SDrive Max yet. Just a new Arduino waiting to be loaded. But before I load latest firmware I must upload the eeprom-writer.hex file (according to what I've read) which doesn't seem to be available anywhere that is why I was wondering if SDrive32.eep or SDrive328.eep was what I was looking for and which one of these two do I select? I don't know what the difference is as no one has offered an explaination as to which file is the correct file. I do not know where you downloaded your file, but if you go here, you will find the files you need: https://github.com/kbr-net/sdrive-max/releases/tag/V1.2 The *.eep files are probably source files which will not help you. Bob C Quote Link to comment Share on other sites More sharing options...
Fred Olivas Posted September 13, 2020 Share Posted September 13, 2020 Thank you. I downloaded and installed and version 1.2 is now installed however my Eleoo touchscreen is no longer recognizing my stylus. I included the SDrive.atr but not clear if this is the problem. It all looks good but not active. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
darwinmac Posted September 13, 2020 Share Posted September 13, 2020 Did you try every folder? I do not know what chip that touchscreen uses. Normally, you will find that one of them will work perfectly unless that touchscreen is not compatible. Bob C Quote Link to comment Share on other sites More sharing options...
Fred Olivas Posted September 14, 2020 Share Posted September 14, 2020 interestingly I had the touch screen working quite well with version 1.1 and then I bricked the Arduino and had to purchase a new one. I have tried every other sdrive.hex file listed with some surprising results ranging from weird colors to being reversed. What doesn't happen is the configure crosses don't appear, it just jumps to the screen which never goes into sleep mode and does not respond to any touch whatsoever. Now that I've installed eeprom-writer.eep I thought that I could try any sdrive.hex file I desired. Sadly this is not the case. XLoader just states Upload Failed. Have others found a solution for the Elegoo (Amazon) touch screen? Quote Link to comment Share on other sites More sharing options...
Fred Olivas Posted September 14, 2020 Share Posted September 14, 2020 New update to my recent post regarding the Elegoo LCD screen. I found a version that absolutely works. Version 1.0! All other version don't work. Now screen is acting correctly and functions well. I wish I could update to a more debugged and current version but alas, it's not to be, as of yet. Quote Link to comment Share on other sites More sharing options...
Fred Olivas Posted September 14, 2020 Share Posted September 14, 2020 Hello all, Finally figured it out. I have a Elegoo LCD screen attached to an Arduino UNO and the ONLY firmware I am able to load and function properly is version 1.0. No other updates work with this screen and I've tried them all, many with strange consequences. To those of you using this combination, have you been able to update your firmware and if so, how? Quote Link to comment Share on other sites More sharing options...
DrVenkman Posted September 14, 2020 Share Posted September 14, 2020 26 minutes ago, Fred Olivas said: Hello all, Finally figured it out. I have a Elegoo LCD screen attached to an Arduino UNO and the ONLY firmware I am able to load and function properly is version 1.0. No other updates work with this screen and I've tried them all, many with strange consequences. To those of you using this combination, have you been able to update your firmware and if so, how? Yes, I have the same combination of an Elegoo screen and Uno, built myself a couple years ago with components purchased from Amazon. I have upgraded it routinely since I built it all the way up to the current 1.2 without a problem. However, the name brand name of the screen doesn’t indicate what type of chipset it uses. Manufacturers can and do change parts without necessarily changing their public documentation or product listings. The original public firmware was something like 0.6 or 0.7; at the time, the unit required an ili9341-based screen. Since then, a number of other screen chipsets have been supported. If you download the firmware from Github expand the zip file structure, you will see that there are several folders inside, one for each possible supported screen chipset. Inside these folders you will find appropriate .hex files to correspond to that particular screen chipset. It might help if you posted some photos of your screen and perhaps someone can help ID what chipset you’ve got. Quote Link to comment Share on other sites More sharing options...
Fred Olivas Posted September 14, 2020 Share Posted September 14, 2020 Okay gonna try and upload my screen photo. But out of curiosity, which .hex or .bin file did you use? I understand that once the eeprom-writer.hex file is uploaded, it can't be uploaded again with bricking the Arduino UNO. I took a photo of my screen and sent myself the photo in my Gmail account. The problem is that I don't know how to add the photo to this site nor can I figure out how to save the photo elsewhere on my computer. Sorry. Quote Link to comment Share on other sites More sharing options...
DrVenkman Posted September 14, 2020 Share Posted September 14, 2020 8 minutes ago, Fred Olivas said: Okay gonna try and upload my screen photo. But out of curiosity, which .hex or .bin file did you use? My screen is in fact an ili9341-based screen. So whenever I update my unit as new firmware versions are released, I make sure I’ve got the .hex files I need from that particular folder. I write the eeprom-writer.hex; then per the instructions wait for the Arduino to reset itself. Then I write SDrvie.hex. Every time you update from one version of firmware to the next, you must use both .hex files. Quote Link to comment Share on other sites More sharing options...
Fred Olivas Posted September 14, 2020 Share Posted September 14, 2020 Hot dog I did it! First time ever. Anyway here is a photo of my Elegoo LCD screen that doesn't seem to play well with the SDrive Max project. Quote Link to comment Share on other sites More sharing options...
Fred Olivas Posted September 14, 2020 Share Posted September 14, 2020 Okay this is great info. I was under the impression that I could only upload the eeprom-writer.hex file once! This won't brick my Arduino? Great news! Will give it a try now. Quote Link to comment Share on other sites More sharing options...
Fred Olivas Posted September 14, 2020 Share Posted September 14, 2020 Managed to get an image of the two chips on the back of the Elegoo LCD screen. LVC245A 3590004 YXD828F Stamped on each IC. Does this help identify what screen I have? Quote Link to comment Share on other sites More sharing options...
Cocoe68 Posted November 7, 2020 Share Posted November 7, 2020 I bought a 3.5" screen controller ili9486 but it has larger resolution than any of compiled versions and I see a small part of total screen available. I don't know if new screens will be added to this magic floppy emulador. Thanks Quote Link to comment Share on other sites More sharing options...
Zzalg_Repus Posted December 3, 2020 Share Posted December 3, 2020 (edited) Hey there! I'm just a recent user of the SDrive Max (coming from/still using several SIO2SDs) with firmware V1.2. It's all working great, except for the TURBO tape option, which just crashes the SDrive Max when enabled - it's "Sync Wait..." forever. No "Baud", "Length" or "Gap" numbers. Regular Tape-Emu (600 Baud) works fine, except that you cannot "Exit" a loading tape file properly - the display gets garbled and the SDrive gets unresponsive, while still loading the "tape". (Note the "DA:<empty>" prompt). Can somebody reproduce this with V1.2 and is does this actually work with lower firmware versions? Cheers, Frank Edited December 3, 2020 by Zzalg_Repus typo Quote Link to comment Share on other sites More sharing options...
Back2skooldaze Posted December 4, 2020 Share Posted December 4, 2020 Hi just bought my first sd drive-max for my atari 8bits and using the XLOADER to upgrade firmware is really easy and very comvenient for future upgrading What i'd like to know is whats with the scrolling feature in the cfg setting in the drive ? Is it mean't to scroll using the pen on the drive screen to scroll through quickly to all the games/files on the sd card? I am having to use the NEXT and PREVIOUS buttons on the drive max screen? Can someone please confirm if the scroll is for this or not? Otherwise i think these drives are excellent for the atari. nice case designs only draw back would be theres no on and off switch on the drive so when atari is off the drive remains on via usb power so unplugging the usb power is ok but nice for a proper on and off switch? Also i think the SIO cable could be longer. I have four 1050 drives one 810 and atari 850 interface then the APE cable all connected up so adding in the sd drive-max the SIO is a bit short as you have to hold the sd drive-max at times to start poking the screen LOL The usb cable i got was wayyyyy too short so luckily i had a new white usb cable that i bought for my printers back in the late 90's to early 20's for printers that i had. At least the usb cable i got with the sd drive-max is good for flashing Quote Link to comment Share on other sites More sharing options...
+mytek Posted January 8, 2022 Share Posted January 8, 2022 I'm not sure if this is an issue only associated with firmware version V1.2, but I'm seeing the drive go to sleep after sitting idle for at least 2 minutes. I haven't verified this to be the same on previous firmware versions. Anyway I posted a video showing this 'falling asleep' issue on my recently upgraded SDrive-Max over on my SDrive-Simple thread. BTW, this issue is not determined by the SDrive.atr in use, and also equally applies to any DOS boot disk that has been renamed SDrive.atr on the SD Card. So for instance I have a BW-DOS 1.3 atr that I use for program development renamed as SDrive.atr on the SD card so that the SDrive-max will automatically boot it when the Atari is powered-up. With this disk, if the SDrive falls asleep after sitting idle for 2 minutes or more, then a subsequent write to that disk (e.g., Save"D:SAMPLE.BAS or Enter"D:SAMPLE.LST) will likely get corrupted as the drive wakes back up. The wake-up doesn't seem to affect reading in a disk file, only adding a bit of a delay doing so. Because of this, and considering that many people probably predominately use there SDrives for loading programs and games, this issue has perhaps not been apparent. I've only been testing my Max with the Atari 576NUC+, so a bit later today I'll also see if this happens on my 600XL as well, and then report back on the results. Quote Link to comment Share on other sites More sharing options...
+mytek Posted January 8, 2022 Share Posted January 8, 2022 (edited) I just checked out the SDrive-Max connected to a stock 600XL with the 2 chip 64K upgrade and it does the same thing - drive falls asleep after 2 minutes. So I think this confirms that it is an SDrive firmware issue, or perhaps it's just the way it's suppose to be. Anyone else seeing this, or if there is someone in the know, would you care to comment about why it does this? Edited January 8, 2022 by mytek Quote Link to comment Share on other sites More sharing options...
darwinmac Posted January 8, 2022 Share Posted January 8, 2022 @mytek - I haven’t been able to reproduce the problem on my Sdrive Max. I have a 64K XEGS. However, I just upgraded my firmware to 1.3b since someone here compiled it. I thought the changes were very small, but it might make a difference. I let the Sdrive Max sit so long that the attract mode appeared on screen. I tried it twice and both times the files in the directory appeared immediately. I didn’t build the device myself. Bob C 1 Quote Link to comment Share on other sites More sharing options...
+mytek Posted January 8, 2022 Share Posted January 8, 2022 13 minutes ago, darwinmac said: I haven’t been able to reproduce the problem on my Sdrive Max. I have a 64K XEGS. However, I just upgraded my firmware to 1.3b since someone here compiled it. I thought the changes were very small, but it might make a difference. When I get a chance I'll update my Max to V1.3 and see if that fixes it. Where can I download that? Quote Link to comment Share on other sites More sharing options...
darwinmac Posted January 8, 2022 Share Posted January 8, 2022 It’s here on AA, but I haven’t been able to find the thread again to thank the person for compiling the beta firmware. Whenever I try to search for it, I find too many other Sdrive Max threads and I can’t find the 1.3b firmware again. Bob C Quote Link to comment Share on other sites More sharing options...
