_The Doctor__ Posted January 9, 2022 Share Posted January 9, 2022 1 Quote Link to comment Share on other sites More sharing options...
darwinmac Posted January 9, 2022 Share Posted January 9, 2022 @_The Doctor__ - Thanks so much for finding the thread. I kept running into old Sdrive Max threads that had nothing to do with the 1.3 firmware. I made sure to leave my thanks for ascrnet. Bob C 2 Quote Link to comment Share on other sites More sharing options...
+mytek Posted January 10, 2022 Share Posted January 10, 2022 Well dang it! I tried multiple times to re-flash the firmware on my SDrive-Max to V1.3 yesterday, but kept getting weird errors that possibly point towards an issue with the boot loader. Not sure how to fix that, and quite frankly I don't have the time to take it any further this week, so it'll have to wait. Quote Link to comment Share on other sites More sharing options...
Bikerbob Posted December 27, 2022 Share Posted December 27, 2022 SO I am looking to update my SDrive-Max. It was one made for me. SO the sdrive-max-v13.zip has a whole bunch of folders in it. I think the numbers in the folder names refers to the screen controller? How do I know which screen controller I have in it? Do I have to take it all apart?? Is there a default? Do I try and if it looks bad .. try again? Quote Link to comment Share on other sites More sharing options...
+mytek Posted December 27, 2022 Share Posted December 27, 2022 2 minutes ago, Bikerbob said: How do I know which screen controller I have in it? Do I have to take it all apart?? Is there a default? Do I try and if it looks bad .. try again? You can just try them one at a time until the screen works. No harm will come by doing this Quote Link to comment Share on other sites More sharing options...
Bikerbob Posted December 27, 2022 Share Posted December 27, 2022 (edited) 34 minutes ago, mytek said: You can just try them one at a time until the screen works. No harm will come by doing this I can see when it first boots up.. its does flash TFT 9341 - So thats solved.. but when I try and use Xloader to flash .. it locks up.. and yes I am doing the eeprom_writer.hex first.. I can flash this with arduino-ide correct?? I setup a board arduino-Uno.. do I need a library? anyone seen a tutorial on flashing? Is it possible the Arduino Uno is locked ? so that it cannot be flashed? When I run Xloader it just resets the device several times, IDE says cannot access the programmer. James Edited December 27, 2022 by Bikerbob Quote Link to comment Share on other sites More sharing options...
Bikerbob Posted December 27, 2022 Share Posted December 27, 2022 I cant seem to find it else where so I will post the last 1.3v firmware up here in .hex format. James sdrive-max-v13.zip 1 Quote Link to comment Share on other sites More sharing options...
Bikerbob Posted December 27, 2022 Share Posted December 27, 2022 (edited) On 5/26/2020 at 6:34 PM, StickJock said: I'm having difficulty updating my SDrive-Max firmware. I've downloaded & extracted the 1.2 files. When I run Xloader & select the eeprom_writer.hex file & click upload, it says "Uploading..." and freezes. I have to unplug the USB cable to get it to come back, at which point is says, "Upload failed". The display clears, flashes white, then goes back to the SDmax display. It does this twice. Like it is resetting twice. My configuration is correct as I can flash a separate, new Uno (although, oddly, not with the SDrive.hex file, which doesn't freeze but does come back with "Update failed".). Flashing the eeprom_writer.hex file to the spare uno shows the normal writing & verifying progress bars on the display. I finally got around to wanting to update my fw as I tried to format a DD disk and it failed, as previously discussed about the v1.1 fw. Any ideas? My setup includes a homemade UNO2SIO board, as well as a bicolor LED on the TX & RX lines with a 220 ohm resistor on the comman annode. I unsoldered the annode wire on my RX/TX LED, and I was then able to flash the new fw. So I am guessing that maybe 220 ohm is the wrong value to use here? I think that I had tried a 470 ohm, but one side of the LED wouldn't light up when I was breadboarding it, so I went to a smaller LED. Any suggestions on what the proper value of resistor I should use here is? Or should I rework my board to hook the annode right to pwr and use two separate resistors on the RX & TX? It's been 30 years since I studied EE at university, so I remember just enough to be dangerous! Thanks. Ok, so I assume this is the issue I am having. mine has a 260 ohm resistor on the green command led.. I can cut it and resolder I guess. But how is this build supposed to be so I dont have to open it up to do this in the future? James Edited December 27, 2022 by Bikerbob Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted December 27, 2022 Share Posted December 27, 2022 I just tried to program a second S-Drive I was building, you can program using the following commands in CMD.EXE Basically using Avrdude, you will need to change the the file paths to suit your system and the COM port. I got the right .HEX files on the 3rd attempt, take a few seconds to program "C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avrdude.exe" "-CC:\Program Files (x86)\Arduino\hardware\tools\avr\etc\avrdude.conf" -v -patmega328p -carduino -PCOM4 -b115200 -D "-Uflash:w:D:\S-Drive Max 1.3\atmega328-ili9329\eeprom_writer.hex:i" than when it's finished "C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avrdude.exe" "-CC:\Program Files (x86)\Arduino\hardware\tools\avr\etc\avrdude.conf" -v -patmega328p -carduino -PCOM4 -b115200 -D "-Uflash:w:D:\S-Drive Max 1.3\atmega328-ili9329\SDrive.hex:i" 1 Quote Link to comment Share on other sites More sharing options...
Bikerbob Posted December 27, 2022 Share Posted December 27, 2022 Well my idea of cutting the resistor off and it would program did not work, did not even get to the point where it would accept the Xloader command. Just errored out said could not send to com port. So back to the drawing board on that one. James Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted December 27, 2022 Share Posted December 27, 2022 1 Quote Link to comment Share on other sites More sharing options...
Bikerbob Posted December 28, 2022 Share Posted December 28, 2022 Got it!! had to do it on windows 10 - and disconnect the LED from the command line.. I did get it to program today.. SO I am up at 1.3 now. Guess it holds the A5 command line high? and it needs to be low? Anyway.. all updated now. James Quote Link to comment Share on other sites More sharing options...
E474 Posted March 12, 2023 Share Posted March 12, 2023 On 12/27/2022 at 3:21 PM, Bikerbob said: I cant seem to find it else where so I will post the last 1.3v firmware up here in .hex format. James sdrive-max-v13.zip 314.34 kB · 22 downloads Hi, I just downloaded and extracted the zip file, and updated from a working 0.9 firmware to 1.3: /tmp/sdrive-max-v13/atmega328-RM68090$ sudo avrdude -carduino -pm328p -P /dev/ttyUSB0 -U flash:w:eeprom_writer.hex avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e950f (probably m328p) avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: reading input file "eeprom_writer.hex" avrdude: input file eeprom_writer.hex auto detected as Intel Hex avrdude: writing flash (6032 bytes): Writing | ################################################## | 100% 1.03s avrdude: 6032 bytes of flash written avrdude: verifying flash memory against eeprom_writer.hex: avrdude: load data flash data from input file eeprom_writer.hex: avrdude: input file eeprom_writer.hex auto detected as Intel Hex avrdude: input file eeprom_writer.hex contains 6032 bytes avrdude: reading on-chip flash data: Reading | ################################################## | 100% 0.81s avrdude: verifying ... avrdude: 6032 bytes of flash verified avrdude: safemode: Fuses OK (E:00, H:00, L:00) avrdude done. Thank you. /tmp/sdrive-max-v13/atmega328-RM68090$ sudo avrdude -carduino -pm328p -P /dev/ttyUSB0 -U flash:w:SDrive.hex avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e950f (probably m328p) avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: reading input file "SDrive.hex" avrdude: input file SDrive.hex auto detected as Intel Hex avrdude: writing flash (32108 bytes): Writing | ################################################## | 100% 5.49s avrdude: 32108 bytes of flash written avrdude: verifying flash memory against SDrive.hex: avrdude: load data flash data from input file SDrive.hex: avrdude: input file SDrive.hex auto detected as Intel Hex avrdude: input file SDrive.hex contains 32108 bytes avrdude: reading on-chip flash data: Reading | ################################################## | 100% 4.24s avrdude: verifying ... avrdude: 32108 bytes of flash verified avrdude: safemode: Fuses OK (E:00, H:00, L:00) avrdude done. Thank you. Unfortunately, when I plug in the SDrive-Max to my Atari 800XL, I just get a white screen on the SDrive-Max display, and nothing else, e.g. the 800XL goes to Self Test, and the SDrive-MAX just sits there (I was expecting it to display the cross-hair 4 corner calibration routine, or just boot up as normal). If I take out the micro-SD card, which was working previously, I don't get a "missing SD card" error, so something has obviously gone wrong. If I unplug the SDrive-Max from the 800XL, and power it up via the micro-USB cable I programmed it with, it still boots to a white screen (with or without an sd card in it). Any ideas on how to fix? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted March 12, 2023 Share Posted March 12, 2023 Pick the correct screen and flash Quote Link to comment Share on other sites More sharing options...
E474 Posted March 12, 2023 Share Posted March 12, 2023 Yes, now I'm reading up on it, that makes a lot of sense. Unfortunately it looks like it might be bricked. I get: ~/Documents/systems/Atari/SDrive Max/sdrive-max-v13/atmega328-ili9341$ sudo avrdude -carduino -pm328p -P /dev/ttyUSB0 -U flash:w:eeprom_writer.hex avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00 avrdude done. Thank you. I got some firmware reset files ages ago, (which I got from this post: but no luck with those: ~/Documents/systems/Atari/SDrive Max/reset_arduino_hex_code$ sudo avrdude -c usbasp -pm328p -P usb -U flash:w:eeprom_clear.ino.with_bootloader.standard.hex avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp' avrdude done. Thank you. Or: ~/Documents/systems/Atari/SDrive Max/reset_arduino_hex_code$ sudo avrdude -c usbasp -pm328p -P usb -U flash:w:eeprom_clear.ino.standard.hex avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp' avrdude done. Thank you. or: sudo avrdude -c usbasp -pm328p -P /dev/ttyUSB0 -U flash:w:eeprom_clear.ino.with_bootloader.standard.hex avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp' avrdude done. Thank you. If I look at the output of dmesg: 10910.643463] usb 3-2: new full-speed USB device number 14 using xhci_hcd [10910.805055] usb 3-2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.63 [10910.805060] usb 3-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0 [10910.805062] usb 3-2: Product: USB2.0-Serial [10910.816215] ch341 3-2:1.0: ch341-uart converter detected [10910.830196] usb 3-2: ch341-uart converter now attached to ttyUSB0 It looks like the reset firmware either targets a different device, or needs aliasing (somehow), which is almost definitely rabbit hole territory. Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted April 9, 2023 Share Posted April 9, 2023 Any chance for a .ROM / .CAR support ? Although IIRC it may be impossible do to the SIO ? 1 Quote Link to comment Share on other sites More sharing options...
+mytek Posted April 9, 2023 Share Posted April 9, 2023 1 hour ago, Ricky Spanish said: Any chance for a .ROM / .CAR support ? Although IIRC it may be impossible do to the SIO ? Yep I believe that is only possible via the cartridge port or PBI. SIO can't pull that one off as far as I recall. 1 Quote Link to comment Share on other sites More sharing options...
