wolhess Posted April 21, 2020 Author Share Posted April 21, 2020 3 hours ago, dhe said: Given my recent bad experience with ChinaRam, I believe a basic TL866 programmer is worth the money, just for it's ability to check ram! It would seem the forging bad chips has become a really industry in China. Is the TL866 able to test the 4116? I didn‘t see this in the manual or in the chip-list. I have a TL866. Quote Link to comment Share on other sites More sharing options...
+dhe Posted April 21, 2020 Share Posted April 21, 2020 I don't know about that one, I used it to check a 8K static ram. Unfortunately my TL866 is at work - far far away... Quote Link to comment Share on other sites More sharing options...
Sid1968 Posted April 21, 2020 Share Posted April 21, 2020 (edited) 22 minutes ago, wolhess said: Maybe I will test to change the Elkos! A good idea! Advice: Turning the rotary potentiometer in the PHA2037 more to the left sets the color saturation higher. Before you do anything, make photos to see how it looked before. Edited April 21, 2020 by Sid1968 1 Quote Link to comment Share on other sites More sharing options...
Papalapa Posted May 16, 2020 Share Posted May 16, 2020 On 4/20/2020 at 10:32 PM, wolhess said: For me the best picture currently is with a PHA 2036 and the Sony LCD TV. But I will try some other configurations in the Next days. I have a PHA 2037 (RGB Modulator) too and I bought a line doubler OSSC from https://videogameperfection.com/products/open-source-scan-converter/ So I have some possibilities. The best will be a FA18A mk2, when it is available. I agree, After lots of tests with different monitors and video converters the solution for me has been to use the PHA 2036. Here are the steps: 1) Luminance signal thorugh VGA converter on LCD monitor 2) Components cable on LCD monitor 3) Components to VGA converter on TRC monitor 4) Internal components to RGB converter 5) PHA 2036 on LCD monitor I'm really surprised of the quality image obtained with only the RF modulator, it seems composite video instead. Thank you @Flottmann1 ? Next step will be to open the PHA2036 and try to get the video signal before the modulator and see what happens. I hope to have a little bit better quality. We will see... 4 Quote Link to comment Share on other sites More sharing options...
Papalapa Posted May 17, 2020 Share Posted May 17, 2020 The best solution: composite video. I thought it would just be soldering an RCA to the video signal before to enter into the modulator as happens with the ZX-Spectrum but the PHA 2036 that I have is the one with a plastic case, not a metallic one and it has been a little more entertaining. Basically I have installed an adapter circuit and now I already have composite video. Without obviously becoming RGB signal, the change from RF to composite is noticeable. The adpater circuit The "modulator" with audio/video outputs Video signal on TV 4 Quote Link to comment Share on other sites More sharing options...
wolhess Posted June 13, 2020 Author Share Posted June 13, 2020 Hi, My beige TI console is broken, No Power and the 0.200A fuse in the transformer is also broken. I replaced the transformer but immediately the second transformers fuse is broken. I think the power supply board is defective. So my question is, can I replace the power supply board of the beige console with a power supply board from a silver/black console? Here are the pictures of the both power supplies: The PS of the beige console: The PS of the black/silver console: Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted June 13, 2020 Share Posted June 13, 2020 (edited) On 5/17/2020 at 1:47 PM, Papalapa said: The best solution: composite video. I thought it would just be soldering an RCA to the video signal before to enter into the modulator as happens with the ZX-Spectrum but the PHA 2036 that I have is the one with a plastic case, not a metallic one and it has been a little more entertaining. Basically I have installed an adapter circuit and now I already have composite video. Without obviously becoming RGB signal, the change from RF to composite is noticeable. The adpater circuit ... The "modulator" with audio/video outputs ... Video signal on TV ... It seems like the you enjoyed my online tutorial? http://www.ti99iuc.it/web/index.php?pagina=mod_proj1&artid=121&_GUIDA: MODULATORE PAL MOD. PHA2030/2036 - MODIFICA RCA/SCART - (PLASTIC CASE)#.XuS6bUUzaUk Edited June 13, 2020 by ti99iuc Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted June 13, 2020 Share Posted June 13, 2020 2 hours ago, wolhess said: So my question is, can I replace the power supply board of the beige console with a power supply board from a silver/black console? As far as I can recall, the outputs are the same. However, the linear P/S(the one with, the 1 big capacitor)requires a CT(off-center taped) transformer. 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 13, 2020 Share Posted June 13, 2020 Yes also I have power supplies in stock tooSent from my LM-G820 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Papalapa Posted June 14, 2020 Share Posted June 14, 2020 20 hours ago, ti99iuc said: It seems like the you enjoyed my online tutorial? http://www.ti99iuc.it/web/index.php?pagina=mod_proj1&artid=121&_GUIDA: MODULATORE PAL MOD. PHA2030/2036 - MODIFICA RCA/SCART - (PLASTIC CASE)#.XuS6bUUzaUk Absolutely YES, thanks a lot for the tuto.. ? 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted June 21, 2020 Share Posted June 21, 2020 My console was shorting transformers last year and I found out that the metal contact on the side port was touching something. After pushing that copper plate in and fixed my problem. I think my speech connected wrong at one point. Quote Link to comment Share on other sites More sharing options...
