RiverPhoenix Posted April 20, 2020 Share Posted April 20, 2020 Hi everyone, Someone can help me? After an update, I got a freeze a few times, tried to fix it and ended up screwing up the console - before there were freezes, but it was playable. Now after the screen with the "atgames" logo, this screen appears in the attachment, I tried all the menu options, nothing worked. I tried to use "adb" and "android tool 2.69", but I don't know what to do. I think that only someone with more knowledge can help with this software problem, perhaps copying the original files of another model to my console. I'm sorry to sell the damaged atari. Quote Link to comment Share on other sites More sharing options...
Draxxon Posted April 21, 2020 Share Posted April 21, 2020 your stuck in recovery mode. flash the firmware again. Quote Link to comment Share on other sites More sharing options...
RiverPhoenix Posted April 21, 2020 Author Share Posted April 21, 2020 Hi Draxxon, “apply update from SD card” with the firmware didn’t resolves because the screen returned, tough the apparently installed . I used every option of the menu, “mount/system” had an error. I tried to install the firmware with the “android toll” (nand usb) too. I think the system is empty, or without system files, cache, emulator, kernel. So confused, I have no idea. Quote Link to comment Share on other sites More sharing options...
MrFister Posted April 15, 2021 Share Posted April 15, 2021 @Draxxon This sounds just like the same issue. @RiverPhoenix was this ever resolved? If so how? Quote Link to comment Share on other sites More sharing options...
0078265317 Posted April 16, 2021 Share Posted April 16, 2021 2 hours ago, MrFister said: @Draxxon This sounds just like the same issue. @RiverPhoenix was this ever resolved? If so how? I had the same issue. No solution. Just got another cheap fb 9 from amazon for 27 dollars and flashed it. All is good now. Quote Link to comment Share on other sites More sharing options...
martinsterusky@gmail.com Posted December 23, 2021 Share Posted December 23, 2021 please the same problem is not possible to fix the console just buy a new one? Quote Link to comment Share on other sites More sharing options...
Draxxon Posted December 24, 2021 Share Posted December 24, 2021 depends on the problem. was it a bad flash? did you open up the console and put it into recovery mode for some reason? Is it a defective unit? who knows? Quote Link to comment Share on other sites More sharing options...
0078265317 Posted December 25, 2021 Share Posted December 25, 2021 I had the same issue. Had to toss it and just buy a new one. Also does only gold version have wireless. Or does the regular or deluxe have the wireless antenna inside also and just not come with wireless controllers. Quote Link to comment Share on other sites More sharing options...
THX-1138 Posted January 11, 2022 Share Posted January 11, 2022 Help! I've tried following these threads on adding ROMs via SD for a Flashback 9 (AR3050). I don't know if I've got confused when referring back to this site as there are several threads on the subject, but something went wrong. The console just gets stuck at the AtGames logo now. Following suggestions on this site, I've opened the device and powered it on while holding the reset switch on the PCB and get the same problem as others above. Seems to have no partitions, "Wipe Data/Factory Reset" doesn't work, "Wipe cache partition", "Mount /system" and "View recovery logs" fail as their respective partitions cannot be found. "Apply update from SD card" also doesn't work as it's not seeing the SD card contents, just ".." I cannot afford to just throw this away. It was a present and only arrived 24 hours ago! By opening it up to reset it, I've lost any chance of getting a replacement or sending it back. There has to be a way to reflash this. 1 Quote Link to comment Share on other sites More sharing options...
THX-1138 Posted January 12, 2022 Share Posted January 12, 2022 I fixed the problem myself by making a USB cable to connect to the PCB, then from Linux I re-flashed each partition individually including the boot partition, kernel, recovery etc. etc. The thing that was difficult to source was a dump of the entire NAND partitions, which is not the same as the user updates - they only update the emulator and rom partitions without touching the underlying OS. Quote Link to comment Share on other sites More sharing options...
