zbyti Posted June 28, 2020 Share Posted June 28, 2020 @funkheld please change the thread. How to compile? http://gury.atari8.info/effectus/ Quote Link to comment Share on other sites More sharing options...
funkheld Posted June 28, 2020 Share Posted June 28, 2020 (edited) hey ... hey ... but not the effectus with the corona ... why is there the old crap in there Edited June 28, 2020 by funkheld Quote Link to comment Share on other sites More sharing options...
zbyti Posted June 28, 2020 Share Posted June 28, 2020 (edited) OK, I fixed this issue https://github.com/Gury8/effectus/pull/6 if System.Pos('{DIV}', params[1]) > 0 then begin params[1] := ReplaceStr(params[1],'{DIV}',' div '); end; if System.Pos('{MOD}', params[1]) > 0 then begin params[1] := ReplaceStr(params[1],'{MOD}',' MOD '); end; if System.Pos('{AND}', params[1]) > 0 then begin params[1] := ReplaceStr(params[1],'{AND}',' AND '); end; if System.Pos('{OR}', params[1]) > 0 then begin params[1] := ReplaceStr(params[1],'{OR}',' OR '); end; if System.Pos('{LSH}', params[1]) > 0 then begin params[1] := ReplaceStr(params[1],'{SHL}',' SHL '); end; if System.Pos('{RSH}', params[1]) > 0 then begin params[1] := ReplaceStr(params[1],'{RSH}',' RSH '); end; if System.Pos('{XOR}', params[1]) > 0 then begin params[1] := ReplaceStr(params[1],'{XOR}',' XOR '); end; nescroll.eff nescroll.xex Edited June 28, 2020 by zbyti it's fine now 1 Quote Link to comment Share on other sites More sharing options...
Gury Posted June 29, 2020 Author Share Posted June 29, 2020 Great work, zbyti. 1 Quote Link to comment Share on other sites More sharing options...
zbyti Posted June 29, 2020 Share Posted June 29, 2020 @Gury I think the "if" statement can be omitted in this case, just replace, if "{AND/OR ...}" exists will be replaced. 1 Quote Link to comment Share on other sites More sharing options...
zbyti Posted June 29, 2020 Share Posted June 29, 2020 (edited) [BUG ERROR 5.0.1] fixed https://github.com/Gury8/effectus/pull/7 Fix provided by me work in some cases but in other break things... I look closer to this code: temp04 := ''; for i := 0 to High(paramsEx) do begin if System.Pos('(', paramsEx[i]) > 0 then begin // Assignment is ARRAY BYTE or ARRAY CARD variable temp03 := Extract(1, paramsEx[i], '('); if (vars.IndexOfName(temp03) >= 0) and (VarValue(2, vars.IndexOfName(temp03), _VAR_BYTE_ARRAY) or VarValue(2, vars.IndexOfName(temp03), _VAR_CARD_ARRAY)) then begin paramsEx[i] := ReplaceStr(paramsEx[i], '(', '['); paramsEx[i] := ReplaceStr(paramsEx[i], ')', ']'); end; end; temp04 += paramsEx[i]; if i < High(paramsEx) then begin temp04 += op[i]; // this is not correct in all cases end; end; params[1] := temp04; end; EDIT: I'm working on that, for now some revert https://github.com/Gury8/effectus/pull/7 "+1" worked by coincidence Edited June 29, 2020 by zbyti fixed 1 Quote Link to comment Share on other sites More sharing options...
zbyti Posted June 29, 2020 Share Posted June 29, 2020 (edited) It's a mess // Check operators in the operand CheckOper('+', params[1]); CheckOper('-', params[1]); CheckOper('*', params[1]); CheckOper('DIV', params[1]); // Integer division, not float number division ('/') CheckOper('MOD', params[1]); CheckOper('AND', params[1]); CheckOper('OR', params[1]); CheckOper('XOR', params[1]); CheckOper('RSH', params[1]); CheckOper('LSH', params[1]); if oper.Count > 0 then begin for j := 0 to 255 do begin for i := 0 to oper.Count - 1 do begin if StrToInt(ExtractDelimited(1, oper.ValueFromIndex[i], [';'])) = j then begin op.Add(oper.Names[i]); break; end; end; end; end; ;........................ temp04 += paramsEx[i]; if i < High(paramsEx) then begin temp04 += op[i]; end; A=(RANDOM&15)*31 B=(RANDOM%15)+32 C=(RANDOM!15)-33 ;---goes to--- A := (RANDOM AND 15) AND 31; B := (RANDOM AND 15) OR 32; C := (RANDOM AND 15) XOR 33; {AND} {AND} * {AND} {OR} + {AND} {XOR} {OR} ;---should be--- {AND} * {OR} + {XOR} - {------------------------------------------------------------------------------ Description: Count operator occurrences in an expression -----------------------------------------------------------------------------} procedure CheckOper(op, expr : string); var x, y : integer; begin y := 1; repeat x := nPos(op, expr, y); if x > 0 then begin if Length(op) = 1 then begin oper.Add(op + '=' + IntToStr(x) + ';0'); end else begin oper.Add('{' + op + '}=' + IntToStr(x) + ';0'); writeln(expr); writeln('x=', x,' y=', y); writeln('CheckOper: ', op); end; end; inc(y); until x = 0; end; (RANDOM{AND}15)*31+1 x=3 y=1 CheckOper: AND (RANDOM{AND}15)*31+1 x=9 y=2 CheckOper: AND (RANDOM{OR}15)+32+1 x=3 y=1 CheckOper: AND (RANDOM{OR}15)+32+1 x=9 y=1 CheckOper: OR (RANDOM{XOR}15)-33+1 x=3 y=1 CheckOper: AND (RANDOM{XOR}15)-33+1 x=10 y=1 CheckOper: OR (RANDOM{XOR}15)-33+1 x=9 y=1 FIX IS: // Check operators in the operand CheckOper('+', params[1]); CheckOper('-', params[1]); CheckOper('*', params[1]); CheckOper('{DIV}', params[1]); // Integer division, not float number division ('/') CheckOper('{MOD}', params[1]); CheckOper('{AND}', params[1]); CheckOper('{OR}', params[1]); CheckOper('{XOR}', params[1]); CheckOper('{RSH}', params[1]); CheckOper('{LSH}', params[1]); {------------------------------------------------------------------------------ Description: Count operator occurrences in an expression -----------------------------------------------------------------------------} procedure CheckOper(op, expr : string); var x, y : integer; begin y := 1; repeat x := nPos(op, expr, y); if x > 0 then begin oper.Add(op + '=' + IntToStr(x) + ';0') end; inc(y); until x = 0; end; Edited June 29, 2020 by zbyti catch ya 1 Quote Link to comment Share on other sites More sharing options...
zbyti Posted June 29, 2020 Share Posted June 29, 2020 (edited) OK, it's done https://github.com/Gury8/effectus/pull/7 I'm to old for this Tested! Edited June 29, 2020 by zbyti 1 Quote Link to comment Share on other sites More sharing options...
funkheld Posted June 29, 2020 Share Posted June 29, 2020 why is this source-asm? : PROC WAIT=*(BYTE F)[$18$65$14$C5$14$D0$FC$60] greeting Quote Link to comment Share on other sites More sharing options...
zbyti Posted June 29, 2020 Share Posted June 29, 2020 @Gury I think we can combine this code: CheckOper('{DIV}', params[1]); // Integer division, not float number division ('/') CheckOper('{MOD}', params[1]); CheckOper('{AND}', params[1]); CheckOper('{OR}', params[1]); CheckOper('{XOR}', params[1]); CheckOper('{RSH}', params[1]); CheckOper('{LSH}', params[1]); params[1] := ReplaceStr(params[1],'{DIV}',' div '); params[1] := ReplaceStr(params[1],'{MOD}',' MOD '); params[1] := ReplaceStr(params[1],'{AND}',' AND '); params[1] := ReplaceStr(params[1],'{OR}',' OR '); params[1] := ReplaceStr(params[1],'{LSH}',' SHL '); params[1] := ReplaceStr(params[1],'{RSH}',' SHR '); params[1] := ReplaceStr(params[1],'{XOR}',' XOR '); 1 Quote Link to comment Share on other sites More sharing options...
funkheld Posted June 29, 2020 Share Posted June 29, 2020 ,' div '); ? greeting Quote Link to comment Share on other sites More sharing options...
+slx Posted June 29, 2020 Share Posted June 29, 2020 On 5/1/2020 at 7:55 PM, ivop said: Is there an official definition of the Action! language? Like an EBNF description or something. There is, in Appendix A of the manual (p. 191 in my edition). 2 1 Quote Link to comment Share on other sites More sharing options...
Gury Posted June 30, 2020 Author Share Posted June 30, 2020 12 hours ago, zbyti said: @Gury I think we can combine this code: CheckOper('{DIV}', params[1]); // Integer division, not float number division ('/') CheckOper('{MOD}', params[1]); CheckOper('{AND}', params[1]); CheckOper('{OR}', params[1]); CheckOper('{XOR}', params[1]); CheckOper('{RSH}', params[1]); CheckOper('{LSH}', params[1]); params[1] := ReplaceStr(params[1],'{DIV}',' div '); params[1] := ReplaceStr(params[1],'{MOD}',' MOD '); params[1] := ReplaceStr(params[1],'{AND}',' AND '); params[1] := ReplaceStr(params[1],'{OR}',' OR '); params[1] := ReplaceStr(params[1],'{LSH}',' SHL '); params[1] := ReplaceStr(params[1],'{RSH}',' SHR '); params[1] := ReplaceStr(params[1],'{XOR}',' XOR '); We can. Take into consideration that such changes need testing of other inner working of Effectus. You can test this with your test suit or with package examples (run with batch file test.bat). After batch is finished with compiling the code, you can check the file effectus.txt for errors by searching the word "errors". Btw, I do this everytime I include any new feature. 1 Quote Link to comment Share on other sites More sharing options...
zbyti Posted June 30, 2020 Share Posted June 30, 2020 @Gury if You merge https://github.com/Gury8/effectus/pull/7 I try something new today 1 Quote Link to comment Share on other sites More sharing options...
Gury Posted June 30, 2020 Author Share Posted June 30, 2020 O, my bad It happens... 1 Quote Link to comment Share on other sites More sharing options...
funkheld Posted June 30, 2020 Share Posted June 30, 2020 (edited) Hi good afternoon. can you just tinker with it? ------------------------------------------- effectus.exe man_anim.eff -b:3600 ------------------------------------------- determine the start of the code yourself. thank you. greeting this is it works: -------------------------------------- effectus.exe man_anim.eff -nc mp.exe man_anim.pas -code:3600 mads.exe man_anim.a65 -x -i:base -o:man_anim.xex -------------------------------------- Edited June 30, 2020 by funkheld Quote Link to comment Share on other sites More sharing options...
funkheld Posted June 30, 2020 Share Posted June 30, 2020 (edited) error in the real ! String exceeds line >>>> is this ? --------------------------------------- Filename: real.pas 30.06.2020 12:55:52 Mad Pascal Compiler version 1.6.4 [2020/06/20] for 6502 Compiling real.pas real.pas (155,7) Error: String exceeds line ---------------------------------------- greeting TYPE REAL=[CARD R1,R2,R3] ;ATARI'S FP FORMAT IS 6 BYTES BYTE CIX=$F2 INT FR0INT=$D4 CARD INBUFF=$F3 REAL FR0=$D4, FR1=$E0 BYTE ARRAY LBUFF=$580 ;************************************ ;BUILT-IN FP ROUTINES ;************************************ PROC ROM_AFP=$D800() PROC ROM_FASC=$D8E6() PROC ROM_IFP=$D9AA() PROC ROM_FPI=$D9D2() PROC ROM_FSUB=$DA60() PROC ROM_FADD=$DA66() PROC ROM_FMULT=$DADB() PROC ROM_FDIV=$DB28() PROC ROM_EXP=$DDC0() PROC ROM_EXP10=$DDCC() PROC ROM_LOG=$DECD() PROC ROM_LOG10=$DED1() PROC ROM_INIT=$DA51() ;************************************ ;A DUMMY PROCEDURE USED TO ACCESS THE ;FP ROUTINES ;************************************ PROC JUNK() RETURN ;************************************ ; MOVE REAL TO ANOTHER REAL ;************************************ PROC REALASSIGN(REAL POINTER A,B) B.R1=A.R1 B.R2=A.R2 B.R3=A.R3 RETURN ;************************************ ; CONVERT INTEGER TO REAL ;************************************ PROC INTTOREAL(INT I REAL POINTER R) FR0INT=I JUNK=ROM_IFP JUNK() REALASSIGN(FR0,R) RETURN ;************************************ ; CONVERT REAL TO INTEGER ;************************************ INT FUNC REALTOINT(REAL POINTER R) REALASSIGN(R,FR0) ROM_FPI() RETURN(FR0INT) ;************************************ ; SUBTRACT REALS ;************************************ PROC REALSUB(REAL POINTER A,B,C) REALASSIGN(A,FR0) REALASSIGN(B,FR1) ROM_FSUB() REALASSIGN(FR0,C) RETURN ;************************************ ; ADD REALS ;************************************ PROC REALADD(REAL POINTER A,B,C) REALASSIGN(A,FR0) REALASSIGN(B,FR1) ROM_FADD() REALASSIGN(FR0,C) RETURN ;************************************ ; MULTIPLY REALS ;************************************ PROC REALMULT(REAL POINTER A,B,C) REALASSIGN(A,FR0) REALASSIGN(B,FR1) ROM_FMULT() REALASSIGN(FR0,C) RETURN ;************************************ ; DIVIDE REALS ;************************************ PROC REALDIV(REAL POINTER A,B,C) REALASSIGN(A,FR0) REALASSIGN(B,FR1) ROM_FDIV() REALASSIGN(FR0,C) RETURN ;************************************ ; CONVERT REAL TO ASCII STRING ;************************************ PROC STRR(REAL POINTER R BYTE ARRAY S) BYTE I,C BYTE POINTER PTR REALASSIGN(R,FR0) ROM_FASC() PTR=INBUFF WHILE PTR^='0 DO PTR==+1 OD I=0 DO C=PTR(I) I==+1 S(I)=C&$7F UNTIL C&$80 OD S(0)=I RETURN ;************************************ ; CONVERT STRING TO REAL ;************************************ PROC VALR(BYTE ARRAY S REAL POINTER R) BYTE I FOR I=1 TO S(0) DO LBUFF(I-1)=S(I) OD LBUFF(I-1)=0 ; AN INVALID VALUE INBUFF=LBUFF CIX=0 ROM_AFP() REALASSIGN(FR0,R) RETURN ;************************************ ; BASE E EXPONENTIATION ;************************************ PROC EXP(REAL POINTER A,B) REALASSIGN(A,FR0) ROM_EXP() REALASSIGN(FR0,B) RETURN ;************************************ ; BASE 10 EXPONENTIATION ;************************************ PROC EXP10(REAL POINTER A,B) REALASSIGN(A,FR0) ROM_EXP10() REALASSIGN(FR0,B) RETURN ;************************************ ; NATURAL LOGARITHM ;************************************ PROC LN(REAL POINTER A,B ) REALASSIGN(A,FR0) ROM_LOG() REALASSIGN(FR0,B) RETURN ;************************************ ; BASE 10 LOGARITHM ;************************************ PROC LOG10(REAL POINTER A,B) REALASSIGN(A,FR0) ROM_LOG10() REALASSIGN(FR0,B) RETURN ;************************************ ; POWER FUNCTION ;************************************ PROC POWER(REAL POINTER A,B,C) LN(A,C) REALMULT(B,C,C) EXP(C,C) RETURN ;************************************ ;PRINT REAL TO DEVICE ;************************************ PROC PRINTRD(BYTE D REAL POINTER A) BYTE ARRAY TEMP(20) STRR(A,TEMP) PRINTD(D,TEMP) RETURN ;************************************ ;PRINT REAL TO DEFAULT DEVICE ;************************************ PROC PRINTR(REAL POINTER A) PRINTRD(DEVICE,A) RETURN ;************************************ ;PRINT REAL TO DEVICE W/EOL ;************************************ PROC PRINTRDE(BYTE D REAL POINTER A) PRINTRD(D,A) PUTDE(D) RETURN ;************************************ ;PRINT REAL TO DEFAULT DEVICE W/EOL ;************************************ PROC PRINTRE(REAL POINTER A) PRINTRDE(DEVICE,A) RETURN ;************************************ ;INPUT REAL FROM A DEVICE ;************************************ PROC INPUTRD(BYTE D REAL POINTER A) BYTE ARRAY TEMP(128) INPUTMD(D,TEMP,126) VALR(TEMP,A) RETURN ;************************************ ;INPUT REAL FROM DEFAULT DEVICE ;************************************ PROC INPUTR(REAL POINTER A) INPUTRD(DEVICE,A) RETURN PROC Main() REAL X,Y,Z GRAPHICS(1) DO PRINT("INPUT X: ") INPUTR(X) PUTE() PRINT("INPUT Y: ") INPUTR(Y) PUTE() PUTD(6,'}) REALADD(X,Y,Z) PRINTD(6,"X+Y :") PRINTRDE(6,Z) REALSUB(X,Y,Z) PRINTD(6,"XY :") PRINTRDE(6,Z) REALMULT(X,Y,Z) PRINTD(6,"X*Y :") PRINTRDE(6,Z) REALDIV(X,Y,Z) PRINTD(6,"X/Y :") PRINTRDE(6,Z) EXP(X,Z) PRINTD(6,"EXP X:") PRINTRDE(6,Z) EXP10(X,Z) PRINTD(6,"EXP10 X:") PRINTRDE(6,Z) LN(X,Z) PRINTD(6,"LN X :") PRINTRDE(6,Z) LOG10(X,Z) PRINTD(6,"LOG10 X:") PRINTRDE(6,Z) PUTD(6,$9B) OD RETURN Edited June 30, 2020 by funkheld Quote Link to comment Share on other sites More sharing options...
zbyti Posted June 30, 2020 Share Posted June 30, 2020 (edited) @Gury If you wait 1-2 days I try to make some simple refactoring. Less code = less reading & less room for bugs etc. Edited June 30, 2020 by zbyti 1 Quote Link to comment Share on other sites More sharing options...
Gury Posted June 30, 2020 Author Share Posted June 30, 2020 How much is going on when I am out from the forum Of course I can wait, just go for it if time and motivation allow you that. I will add additional important issue requests later to main repo, so we will have more control over what is important and what is not. 1 Quote Link to comment Share on other sites More sharing options...
funkheld Posted June 30, 2020 Share Posted June 30, 2020 Hi good afternoon. my things are important. thank you. greeting Quote Link to comment Share on other sites More sharing options...
zbyti Posted June 30, 2020 Share Posted June 30, 2020 (edited) Tip from @tebe how to use debugger: fpc -Mdelphi -g effectus.pas gdb effectus run path\test-code.pas Lazarus IDE, Debugger Setup, IDE Window:Breakpoints Edited June 30, 2020 by zbyti ide/gdb link 1 Quote Link to comment Share on other sites More sharing options...
funkheld Posted June 30, 2020 Share Posted June 30, 2020 hell, thanks for debug. greeting Quote Link to comment Share on other sites More sharing options...
zbyti Posted July 1, 2020 Share Posted July 1, 2020 (edited) @Gury This PR it's not much but let it be a good start tested :] The history of commits is a bit messy because I chose the wrong command from the console history twice :D The logic of core.pas will slowly need to be changed to step-by-step procedures. I don't know the code well enough to grasp the whole thing. Maybe I will find something worth simplifying today but those changes from PR may be merged. Edited July 1, 2020 by zbyti add info 1 Quote Link to comment Share on other sites More sharing options...
zbyti Posted July 1, 2020 Share Posted July 1, 2020 (edited) @Gury Now I trying to recognize if ReplaceToken may will be more generic with two dimensional array for whole source. btw. I found this and this very instructive. Edited July 1, 2020 by zbyti parser 1 Quote Link to comment Share on other sites More sharing options...
funkheld Posted July 1, 2020 Share Posted July 1, 2020 Hi good afternoon. you are very .... very hardworking. thank you. greeting Quote Link to comment Share on other sites More sharing options...
