Prizrak Posted May 10, 2020 Share Posted May 10, 2020 I usually use drivesort to get my roms to sort alphabetically on the SD cart and make navigation easier. Is there a file count limit for this program. Working on the PlusCart project I tried to sort the same files we have on the server (over 6,000) on a card to use in my Harmony and even though it says it's sorting them it's not successful. I have found another program called FAT Sorter and that seems to do the trick. I'm using the same 2GB card I've always used and have never had problem. Wanted to see if anyone else has had similar problems or if you have a better solution you folks use to keep things organized and tidy on your carts. Sent from my SM-N960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
