raz0red Posted May 12, 2020 Share Posted May 12, 2020 (edited) Hi all- For the past several months I have been working on a JavaScript port of Wii7800, my Wii port of the ProSystem emulator. This really started out as an exercise to learn some newer web APIs, but has progressed to the point where I figured it is worth sharing. You can find it at the following location: https://raz0red.github.io/js7800 It does not currently support mobile (something I plan to add in the future), and requires an updated version of a modern browser (Chrome, Firefox, Safari) on newer hardware to run without lags. It also definitely lacks the accuracy of the latest 7800 emulators, such as the excellent A7800. This is something I also hope to work on integrating in the future. However it does include my Wii modifications to ProSystem, so it should support most cartridge formats, larger sizes, improved bank switching, updated header detection, improved Pokey support, partial XM support, etc. Some of its features include: Global high score support: For games that support the High Score Cartridge (HSC), I have set up a central server that will serve and persist high scores. Towards the end of the default cartridge list (below emulator), you will find a collection of excellent homebrew titles that support global high scores (grouped in the category, "High Score Compatible"). It is worth noting that not all variants of these cartridges are supported globally. This is due to the fact that the scoring models may have changed between releases. You can find a raw dump of the compatible cartridges, identified by MD5 hash, here. USB Controller support: Modern controllers such as Xbox, Playstation 3 or newer, and Switch should work. Dual-analog controls are also supported for Robotron and TiME Salvo. Customizable cartridge lists: By default, the cartridge list drop-down menu contains a collection of excellent homebrew titles. But, you can also define and share your own lists. I have documented the list format along with a step by step tutorial on the Wiki found here that shows how to create and share a list. Drag-and-drop ROMs: You can drag-and-drop ROM links directly into JS7800 and they will load. As shown in the image below, a ROM link is being dragged from the AtariAge forum into JS7800 and loaded. It is also worth noting, that you typically need to start the drag on top of the download count (as shown below). This feature makes it pretty easy to navigate AtariAge and try the latest homebrew releases without downloading them directly. (JS7800 also supports drag-and-drop of local files) There is a "help/info" button located below the emulator that provides fairly detailed documentation. I also want to personally thank RevEng, PacManPlus, and mksmith for graciously answering all of my annoying questions. ? Finally, I tried to contact most homebrew developers to obtain permission to include their ROMs in the default list of cartridges. However, if for some reason you do not want your title included, please just let me know. I will immediately remove it from the default list. As this is fairly early, I am sure a number of defects exist. Please just let me know what is happening and I will try my best to address it. Thanks a lot, Chris Edited May 12, 2020 by raz0red 13 4 Quote Link to comment Share on other sites More sharing options...
+Karl G Posted May 12, 2020 Share Posted May 12, 2020 Super cool! My WIP ran fine with your emulator. I will be following this project with interest. ? 4 1 Quote Link to comment Share on other sites More sharing options...
RevEng Posted May 12, 2020 Share Posted May 12, 2020 The online high score tables adds a new dimension... when someone bumps your high-score down in the table, it's motivation to come back and do the same to their score. Just like the good old days, at the arcade. Great job, Chris! ? 3 1 Quote Link to comment Share on other sites More sharing options...
raz0red Posted May 12, 2020 Author Share Posted May 12, 2020 31 minutes ago, RevEng said: The online high score tables adds a new dimension... when someone bumps your high-score down in the table, it's motivation to come back and do the same to their score. Just like the good old days, at the arcade. Great job, Chris! ? Thank you very much, I really appreciate it! Also, thanks again for all the help. Sadly, all my scores in Scramble have already been topped... ? Chris 1 Quote Link to comment Share on other sites More sharing options...
TailChao Posted May 12, 2020 Share Posted May 12, 2020 Always nice to have more options for emulation - and hey, this one's cross platform out of the box. Great work! 1 Quote Link to comment Share on other sites More sharing options...
PacManPlus Posted May 12, 2020 Share Posted May 12, 2020 I'm loving this 2 Quote Link to comment Share on other sites More sharing options...
RevEng Posted May 12, 2020 Share Posted May 12, 2020 When things get a bit less hectic for me, I'm going to try to take the Salvo high-score. If anybody sees "APE" in the hi-score listings, that's me. 2 Quote Link to comment Share on other sites More sharing options...
+Muddyfunster Posted May 12, 2020 Share Posted May 12, 2020 This is really neat. I also tried all of my WIP projects, all ran flawlessly. 2 Quote Link to comment Share on other sites More sharing options...
+mksmith Posted May 13, 2020 Share Posted May 13, 2020 Well done Chris - looking forward to seeing how this progresses ??? 2 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted May 13, 2020 Share Posted May 13, 2020 This has all the same POKEY emulation quirks as Prosystem... i.e. some things will work on it and not in A7800, and vice versa. 1 Quote Link to comment Share on other sites More sharing options...
raz0red Posted May 13, 2020 Author Share Posted May 13, 2020 1 hour ago, Synthpopalooza said: This has all the same POKEY emulation quirks as Prosystem... i.e. some things will work on it and not in A7800, and vice versa. Yes, that is not too surprising. However, if you look at the code, you will see it is quite a bit different than the version that is part of the last ProSystem release (includes updates to Ron Fries PokeySound). Also, it adds support for RANDOM and POTS. The latter is needed to support the way a number of cartridges detect the presence of XM and Pokey chips. But, you are absolutely correct, the Pokey sound is far from perfect. Chris 2 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted May 13, 2020 Share Posted May 13, 2020 One thing I have noticed, as a rule: Any POKEY music relying on standard AUDCTL=$00 8-bit mode, or anything using 16-bit AUDCTL=$50 or $28, with the $Ax pure tone square setting, seems to be ok. When you move into other settings ... it's hit or miss. So I use A7800 and ProSystem both for testing my music. 1 Quote Link to comment Share on other sites More sharing options...
raz0red Posted May 13, 2020 Author Share Posted May 13, 2020 (edited) 35 minutes ago, Synthpopalooza said: One thing I have noticed, as a rule: Any POKEY music relying on standard AUDCTL=$00 8-bit mode, or anything using 16-bit AUDCTL=$50 or $28, with the $Ax pure tone square setting, seems to be ok. When you move into other settings ... it's hit or miss. So I use A7800 and ProSystem both for testing my music. Ah, interesting, that is a really great insight. Just out of curiosity, have you heard of, or experienced similar issues with Pokey on Atari 8-bit computer emulators? The reason I ask is that it appears that most of the emulators out there leverage some variant of Ron Fries' PokeySound. If other emulators are not having the same issues, it is most likely an issue with the way PokeySound is being driven from ProSystem. Sorry if this has already been discussed previously. Thanks a lot, Chris Edited May 13, 2020 by raz0red Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted May 13, 2020 Share Posted May 13, 2020 Altirra is the best, and to my reckoning, it is about 99.9 % accurate to real HW. This even includes a lot of undocumented settings I have been messing around with. http://virtualdub.org/altirra.html is the site, I think. It has a good POKEY reference manual too. 1 Quote Link to comment Share on other sites More sharing options...
BydoEmpire Posted May 13, 2020 Share Posted May 13, 2020 This is fantastic! 3 Quote Link to comment Share on other sites More sharing options...
+Trebor Posted May 14, 2020 Share Posted May 14, 2020 Hey Chris...Thanks for offering this to the community. The high score system being in place for people to literally compete globally is definitely a huge plus and the interface is quite nice. One item that needs considerable improvement though is the 'hot' palette it inherited from the ProSystem emulator. It contains many 'impossibles' with the handpicked values found within that palette; especially regarding the $1x, $Ex, $Fx ranges, the overall bright red look of $2x, $3x, $4x, a strong sudden ramp up of contrast or/and saturation in the middle of the luminance ramp for hues, among other oddities: A more feasible and in the 'realm of possibilities' color palette - striving for a 'hot' palette (~27.7 degree shift) - appears more like this: Not sure, if there is an easy way to import a Prosystem *.pal file, or need the hex values in some other format, or something different altogether, but if interested and needed, I can contribute data. 3 Quote Link to comment Share on other sites More sharing options...
raz0red Posted May 14, 2020 Author Share Posted May 14, 2020 2 minutes ago, Trebor said: Hey Chris...Thanks for offering this to the community. The high score system being in place for people to literally compete globally is definitely a huge plus and the interface is quite nice. One item that needs considerable improvement though is the 'hot' palette it inherited from the ProSystem emulator. It contains many 'impossibles' with the handpicked values found within that palette; especially regarding the $1x, $Ex, $Fx ranges, the overall bright red look of $2x, $3x, $4x, a strong sudden ramp up of contrast or/and saturation in the middle of the luminance ramp for hues, among other oddities: A more feasible and in the 'realm of possibilities' color palette - striving for a 'hot' palette (~27.7 degree shift) - appears more like this: Not sure, if there is an easy way to import a Prosystem *.pal file, or need the hex values in some other format, or something different altogether, but if interested and needed, I can contribute data. Wow, that is great! thanks for the feedback. It would be great to work with you to integrate it. I will send you a PM and we will make this happen. I will also integrate it into the Wii port. Thanks again, Chris 2 Quote Link to comment Share on other sites More sharing options...
+mksmith Posted May 14, 2020 Share Posted May 14, 2020 Chris, @Trebor Robert is the palette master! 3 Quote Link to comment Share on other sites More sharing options...
raz0red Posted May 14, 2020 Author Share Posted May 14, 2020 7 minutes ago, mksmith said: Chris, @Trebor Robert is the palette master! Yes, he absolutely is! Chris 3 Quote Link to comment Share on other sites More sharing options...
John Stamos Mullet Posted May 14, 2020 Share Posted May 14, 2020 This is going to come out of left field a bit - but is there any way your recent Prosystem source of the Wii Port can be folded into the Retroarch/libretro build? I love the fact that some kind soul ported prosystem into Retroarch, as it drives my PS3 and Retropie emulators, but it was ported from really old source code, like I think from Prosystem 1.3e or something. tl;dr version: Retroarch's current version of Prosystem doesn't have any of your awesome fixes, so if there's any way to patch that and submit it to their git, or maybe point me in the right direct as to how it differs - I would be eternally grateful. 1 Quote Link to comment Share on other sites More sharing options...
John Stamos Mullet Posted May 14, 2020 Share Posted May 14, 2020 Also - the libretro git version Of Prosystem has the correct "hot" Trebor palette in it already, as part of the source code. (I ported it shortly after they added Prosystem to the official Retroarch build) So you could grab it from there and not have to manipulate all the values in a text editor. https://github.com/libretro/prosystem-libretro 1 Quote Link to comment Share on other sites More sharing options...
raz0red Posted May 14, 2020 Author Share Posted May 14, 2020 6 minutes ago, John Stamos Mullet said: Also - the libretro git version Of Prosystem has the correct "hot" Trebor palette in it already, as part of the source code. (I ported it shortly after they added Prosystem to the official Retroarch build) So you could grab it from there and not have to manipulate all the values in a text editor. https://github.com/libretro/prosystem-libretro Great, thanks! I will check it out. Quote Link to comment Share on other sites More sharing options...
raz0red Posted May 14, 2020 Author Share Posted May 14, 2020 21 minutes ago, John Stamos Mullet said: This is going to come out of left field a bit - but is there any way your recent Prosystem source of the Wii Port can be folded into the Retroarch/libretro build? I love the fact that some kind soul ported prosystem into Retroarch, as it drives my PS3 and Retropie emulators, but it was ported from really old source code, like I think from Prosystem 1.3e or something. tl;dr version: Retroarch's current version of Prosystem doesn't have any of your awesome fixes, so if there's any way to patch that and submit it to their git, or maybe point me in the right direct as to how it differs - I would be eternally grateful. Sure, absolutely. Just send me a PM and we can figure out how to do that. Thanks, Chris 1 Quote Link to comment Share on other sites More sharing options...
+Kaboomer Posted May 14, 2020 Share Posted May 14, 2020 On 5/11/2020 at 7:33 PM, raz0red said: USB Controller support: Modern controllers such as Xbox, Playstation 3 or newer, and Switch should work. Dual-analog controls are also supported for Robotron and TiME Salvo. This is incredible! Just played a bunch of fav's with it! Thank you so much for creating this! People are awesome! Curious if there's any way to get paddles to work on this (e.g. Arkanoid, Super Circus Atari)? I have the "2600-dapter II" and was hoping there's a way! 3 1 Quote Link to comment Share on other sites More sharing options...
raz0red Posted May 14, 2020 Author Share Posted May 14, 2020 (edited) 1 hour ago, Kaboomer said: Curious if there's any way to get paddles to work on this (e.g. Arkanoid, Super Circus Atari)? I have the "2600-dapter II" and was hoping there's a way! Hi- Thanks a lot for the kind words! Currently, there is not a way to use paddle controllers. There are a couple things that need to be done to make that happen. First, paddle support needs to be integrated into JS7800. I did make some progress (as a POC) during my development on the latest version of the Wii port. I spent some time looking through the A7800 source, which has excellent support, and was able to make it function (albeit it was a quite hacky on my end). The second thing that needs to be done is to add the ability to provide custom mappings from the HTML Gamepad API. The HTML Gamepad API provides a "standard" mapping that most modern controllers should map to. This essentially takes the common buttons of modern controllers and maps them to a standard layout. My guess is that the "2600-dapter II" may not map to the standard mapping, and therefore would need a custom mapping. You can actually test this if you go into the "Settings" portion of JS7800 and go to the Gamepads page. That page displays whether the connected controller(s) have a standard mapping. It will also indicate if the buttons (or paddle) is currently being mapped. If you press the buttons, etc. on a controller, a "white dot" will appear to show what 7800 control it is being mapped to (this is only applicable to joysticks at this time). The paddle controller, I assume, would need to map to an analog input. Further, this site, can be used to get more detailed information about the connected controller. I would be very curious to know what that site has to say about the "2600-dapter II". Does it map the POT movement to an analog input? I do definitely want to add paddle support. I think the first step would probably be supporting it via mouse input (or touch once a mobile version of JS7800 is released). The second would be figuring out how to map adapters such as the "2600-dapter II" it to the HTML Gamepad API. Thanks again, Chris Edited May 14, 2020 by raz0red 4 Quote Link to comment Share on other sites More sharing options...
