Dutchboy Posted June 2, 2020 Share Posted June 2, 2020 I got the 32k sidecar and on most of my carts it works fine. TI Invaders however, will not play unless I remove the sidecar. Is this typical? Quote Link to comment Share on other sites More sharing options...
+mizapf Posted June 2, 2020 Share Posted June 2, 2020 "Will not play" means what exactly? Does the computer lock up? Can you select Invaders on the selection screen? 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 2, 2020 Share Posted June 2, 2020 And no and are you using a cartridge or finalgrom99 or flashrom or ?Sent from my LM-G820 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Dutchboy Posted June 3, 2020 Author Share Posted June 3, 2020 Using the TI cartridge not the Finalgrom99 or flashrom. The screen is just blue you can't get to the selection screen. I can play Munchman with the sidecar in place. When I remove the sidecar the TI Invaders cart works just fine. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 3, 2020 Share Posted June 3, 2020 Interesting. Are you powering the 32k with the external supply?Sent from my LM-G820 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Dutchboy Posted June 3, 2020 Author Share Posted June 3, 2020 No it is directly in the expansion port. Not running a speech synth. I guess I could try using a power supply for it. The triple cart of homebrew with Titanium, scrabble, and road hunter works great. 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 3, 2020 Share Posted June 3, 2020 It's not a typical problem... My TI Invaders cart works fine with my console powered 32k & console powered TIPI... TI Invader carts are old... 99/4A's are old. You might clean the cart contacts... clean the sideport contacts, etc... 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 3, 2020 Share Posted June 3, 2020 check the FAQ for info on cleaning the cart port Quote Link to comment Share on other sites More sharing options...
Dutchboy Posted June 4, 2020 Author Share Posted June 4, 2020 Thanks I will try that. Quote Link to comment Share on other sites More sharing options...
