Question on arrays
I've been tightening and scaling up some of the engine features in EXO and I wanted to plot a sprite based on which number in the array is called, so I could remove some of my early brute force code.
So for the test example I declare a bunch of set up variables and then I set up a simple loop to plot them :
 set romsize 48k
 set tallsprite on
 set doublewide on
 set tv ntsc
 set zoneheight 8
 dim rocket_x = $2224.$222E
 dim rocket_y = $2238.$2242
 dim rocket_max = var29
 incgraphic gfx/rocket.png
  P0C1=$08 ; med
  P0C2=$0c ; light
  P0C3=$04 ; dark
 rocket_x[1] = 75 : rocket_y[1] = 56
 rocket_x[2] = 45 : rocket_y[2] = 56
 rocket_max = 2
mainloop
 clearscreen
 for a = 1 to rocket_max
 plotsprite rocket 0 rocket_x[rocket_max] rocket_y[rocket_max] 0 2
 ;plotsprite rocket 0 rocket_x rocket_y 0 2
 next a
 drawscreen
 goto mainloop
I'm trying to plot the sprite called rocket, using palette #0 and using the rocket_x and rocket_y co-ordinates in the array but the code will not compile.
rocket_x and rocket_y are 8.8 variables each with 10 bytes space allocated (so in my theoretical thinking I can safely have rocketmax = 9 before I run out of space and have to extend the array)
Am I defining these variables incorrectly as I cannot get the code to compile unless I remove the [] condition (and it then doesn't do what it is intended).
I suspect I'm in the "can't see the wood for the trees" mode of thinking.
Any guidance or advice would be appreciated!
You have it mostly right, but have assumed the parser is more capable than it is. :) For pretty much anything other than variable assignments, arrays don't work as arguments. (true for bB as well) The easiest work-around is to assign your array indexes to a temporary location first.
e.g.
mytempx = rocket_x[rocket_max]
mytempy = rocket_y[rocket_max]
plotsprite rocket 0 mytempx mytempy 0 2
Avoid using the system temp# variables for this purpose, because plotsprite will probably obliterate them before using them. I always dim a few "mytemp" variables for this sort of purpose. (also handy for generalized subroutines that can operate on different game objects)
Gah! thanks @RevEng
I can compile but the sprite just sits in the corner of the screen. It's as though the plotsprite isn't picking up the co-ords from the array, even using the temp variables :
I added mytempx and mytempy as 8.8 vars and drop the array values in before passing that to plotsprite.
 next a
Thanks,
source below :
 set romsize 48k
 set tallsprite on
 set doublewide on
 set tv ntsc
 set zoneheight 8
 dim rocket_max = var1
 dim mytempx = b.c
 dim mytempy = d.e
  P0C1=$08 ; med
  P0C2=$0c ; light
  P0C3=$04 ; dark
 rocket_max = 2
mainloop
 clearscreen
  next a
 drawscreen
 goto mainloop
Ok, it looks like 8.8 assignments from arrays doesn't do what you're wanting, since arrays are strictly byte sized things.
If you change this...
 dim mytempx = b.c
 dim mytempy = d.e
to...
 dim mytempx = b
 dim mytempy = d
...then your code will work as expected.  (well, I think you wanted to use "mytempx = rocket_x[a]" instead of "mytempx = rocket_x[rocket_max]")
If you still want to treat those temps as 8.8 in certain circumstances, then you can dim another view of them like that...
dim mytempx8 = b.c
