csoren Posted June 15, 2020 Share Posted June 15, 2020 (edited) EDIT: Added picture of the board I got my first 99/4a and I'm doing some simple repairs (defective RAM) and trying to restore the keyboard. I don't know what to expect from the 99/4a but the keyboard feels a little ... just worn or old. Definitely nowhere near as pleasant to use as my other vintage computers. I doubt it's supposed to feel like this. I don't know which type it is, but I've attached a picture. The problem I'm having is I have to generally hit the keys right in the center, if I don't there's lots of friction because the stalks are so long, so they bend, binding against the sides of the bottom of the key. Is there a recommended way to remedy this? Is it a known problem? I've tried contact cleaner and it does seem to improve it, but doesn't remove the friction completely. I've contemplated simply giving it a good wash. Any and all ideas welcome. Edited June 15, 2020 by csoren Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 15, 2020 Share Posted June 15, 2020 Ok now I see the back picture.. anyway you can clean the switches with a cleaner with Teflon for keyboards.. or deoxit Quote Link to comment Share on other sites More sharing options...
csoren Posted June 15, 2020 Author Share Posted June 15, 2020 (edited) 5 minutes ago, arcadeshopper said: What's the back look like? Did you look at the FAQ pinned post section about keyboard issues? I've added a picture of the board to the post. I did look at the FAQ but it doesn't seem to cover my issue. That's also where I got the idea to try contact cleaner, even though the keys don't appear corroded. They work fine, other than the friction. Edited June 15, 2020 by csoren Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 15, 2020 Share Posted June 15, 2020 I've added a picture of the board to the post. I did look at the FAQ but it doesn't seem to cover my issue. That's also where I got the idea to try contact cleaner, even though the keys don't appear corroded. They work fine, other than the friction.See above I noted your picture and editedSent from my LM-G820 using Tapatalk Quote Link to comment Share on other sites More sharing options...
csoren Posted June 15, 2020 Author Share Posted June 15, 2020 1 hour ago, arcadeshopper said: Ok now I see the back picture.. anyway you can clean the switches with a cleaner with Teflon for keyboards.. or deoxit Thanks, this gave me a few ideas for things to search for ... and a rabbit hole of keyboard lubes, tests and opinions appeared. Well, I have definitely found a few things to try 1 Quote Link to comment Share on other sites More sharing options...
