drac030 Posted June 25, 2020 Share Posted June 25, 2020 (edited) 15 hours ago, pixelmischief said: Now if I can just get an 80-column setup working from the Sophia. Haven't tried yet. Don't know where to start. Unpack from the Toolkit these files: RC_GR8.SYS CON.SYS Load them in this order (RC*.* first, CON.* later). Then from the CP prompt tell this: CON 80 This will enable 80-column mode for the CP. CON 40 gets you back to 40 columns. It is more convenient to load these two *.SYS files from a config file (CONFIG.SYS or SPARTA.DOS>*.CFG). At least 1 bank of free Ext RAM is required for this to work. So no RAMDISK.SYS loaded beforehand, which would occupy all the ext or such. In case of "out of RAM", MEM /X typed at the DOS prompt will inform you what is the amount of free banks. If 0, tweak the config until non-0, basically. Edited June 25, 2020 by drac030 4 Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted June 26, 2020 Share Posted June 26, 2020 @drac030 Yo! Thanks! Quote Link to comment Share on other sites More sharing options...
