Beeblebrox Posted December 13, 2022 Share Posted December 13, 2022 2 hours ago, TZJB said: You may need to drill out or change the plug for 2.5mm as it is fitted with a 2.1mm plug according to the specs. Jack - 2.1 x 5.5mm Female CE marked and approved Ah cr@p - yah right - these things just literally turned up and they are indeed too small. I could source the correct plugs or find some adapters maybe. Had assumed they were fine after personal recommendations, (not blaming anyone here BTW - I should have double checked myself). Incidentally I am quite surprised how heavy these modern PSUs are. I was expecting something a fraction of the weight heh heh. Feel very substantial. I'm sure I'll get em working. Edit: BTW I didn't think drilling the plugs themselves was an option and the metal inside is not a complete circle of metal as it were and I didn't think it would survive. However as I have got three of these PSUs and replacing the plug is an option I just tried drilling one out with a suitable drill bit. It didn't go well..... Plug indeed cannot be drilled out. So a replacement plug is the way I am going with all three. Luckily the polarity doesn't matter. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted December 13, 2022 Share Posted December 13, 2022 I think these will work: 10x 2.5mm x 5.5mm Male Plug + Female Square Socket Jack DC Connector https://www.ebay.co.uk/itm/262321089247? They come with both male plug (which I need) and the female sockets - but as it is cheap and there are 10 x sets it makes far more sense financially. It says DC but I am assuming I can use them on these PSUs? DC connectors suitable for a wide range of applications including replacing or repairing existing connectors. 10 pairs of connectors Right angle sockets Solder termination Strong plastic barrel with strain relief Technical Information Size 2.5mm x 5.5mm Barrel Length 9mm Rating 0.5A 12VDC Socket Dimensions 10.6 x 8.8 x 13.7mm (H x W x L) Insulation Resistance 100MΩ Operating Temperature -20°C to +70°C Quote Link to comment Share on other sites More sharing options...
mimo Posted December 13, 2022 Share Posted December 13, 2022 Oh pants, I am so sorry I didn't check the barrel size. My brain isn't what it used to be. Can I refund you? Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted December 13, 2022 Share Posted December 13, 2022 11 minutes ago, mimo said: Oh pants, I am so sorry I didn't check the barrel size. My brain isn't what it used to be. Can I refund you? @mimoAh mate no worries honestly - I should have doubled checked myself so please don't worry. Easily rectified with the plugs I've bought which were peanuts. It's a great buy considering elsewhere I was looking at £38+ per PSU. 1 Quote Link to comment Share on other sites More sharing options...
