pixelmischief Posted June 29, 2020 Share Posted June 29, 2020 (edited) How do I do POS and PRINT #6 in graphics 1+16? It isn't working in FastBASIC. EDIT: Found it. Comma instead of semi-colon. GR. 1+16: PRINT #6,"HELLO" Edited June 30, 2020 by pixelmischief Quote Link to comment Share on other sites More sharing options...
dmsc Posted June 30, 2020 Share Posted June 30, 2020 Hi! 1 hour ago, pixelmischief said: How do I do POS and PRINT #6 in graphics 1+16? It isn't working in FastBASIC. This program: GR. 16+1 ? #6, "#" POS. 1, 1: ? #6,"HOLA" POS. 2, 2: ? #6,"chao" REPEAT UNTIL KEY() Produces this output: There is a little incompatibility between FastBasic and Atari BASIC: in Fastbasic you always put a comma after the I/O channel, instead of the ";" in Atari BASIC, so the following are equivalent: Atari BASIC: ? #6,"A" : ? #6;"A" FastBasic: ? #6,,"A" : ? #6,"A" The reason for the incompatibility is because I tough the Atari BASIC syntax was not very logical (as it is different than other I/O channel specs), and in the first versions also it was shorter to implement. Have Fun! 1 Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted June 30, 2020 Author Share Posted June 30, 2020 (edited) @dmsc You might want to merge the PRINT #ioch and plain old PRINT sections of your manual. Or duplicate this particular tidbit in both places. Having found the first PRINT statement reference, I didn't look for the second. Found it by accident. Edited June 30, 2020 by pixelmischief 2 Quote Link to comment Share on other sites More sharing options...
dmsc Posted June 30, 2020 Share Posted June 30, 2020 Hi! 2 minutes ago, pixelmischief said: @dmsc You might want to merge the PRINT #ioch and plain old PRINT sections of your manual. Or duplicate this particular tidbit in both places. Having found the first PRINT statement reference, I didn't look for the second. FOund it by accident. Yes, I tried to group statements by use, so I separated the PRINT and INPUT to the console from the "PRINT #" and "INPUT #". Do you think that adding a note "See the Device Input and Output Statements section for the PRINT # usage" (and the same at the INPUT) would work? Or perhaps "For the PRINT with I/O channel (PRINT #), see the Device Input and Output Statements section bellow" ? Thanks! Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted June 30, 2020 Author Share Posted June 30, 2020 @dmsc Yeah. That will work just fine. Quote Link to comment Share on other sites More sharing options...
dmsc Posted June 30, 2020 Share Posted June 30, 2020 Hi! 1 hour ago, pixelmischief said: @dmsc Yeah. That will work just fine. Done, see at https://github.com/dmsc/fastbasic/blob/master/manual.md#console-print-and-input-statements Have Fun! Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted June 30, 2020 Author Share Posted June 30, 2020 1 minute ago, dmsc said: Have Fun! I am! But more than that, thanks to you, I can MAKE fun! 1 Quote Link to comment Share on other sites More sharing options...
