Stormbringer Posted June 30, 2020 Share Posted June 30, 2020 So I've started testing some of my other Atari's and never got around to the XEGS before. I'm not too familiar with it. Upon power up it looks like its stuck on the cassette boot as if the START was held down. sometimes it works normal, most of the time not. if I hit the reset it will boot into Basic or to the missile command like normal. the keyboard test works too for the START, OPTION, etc.?!?!?!? Anyhow, my first suspect was the START switch being crap... I tried jamming on the button several times to release any oxidization (like a 1200xl keyboard) but no good. Then I tried un-soldering the switch, this B@#C#%s melts!!!... ok, I got the switch out and fixed the switch... set that aside and expected the XEGS to boot into either basic with the keyboard or missile command. That did not happen. Still having the same issue. Any ideas what to look for next? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted June 30, 2020 Share Posted June 30, 2020 (edited) if it was making it into basic or missile command... then you muffed the switch, thought it was fixed... and now it doesn't do as before. Then I'd go back to the switch. After restoring things to how they were... then I'd replace the ROM with a know good one to start down the process. Do you have a disk drive? Edited June 30, 2020 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted June 30, 2020 Share Posted June 30, 2020 It could be the GTIA. Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 1, 2020 Share Posted July 1, 2020 Fairly sure you can quickly abort the cassette boot by pressing Break twice quickly - try before any other key, otherwise after one. Otherwise you need to wait for it to timeout - about 15 seconds after you press a key. Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted July 1, 2020 Author Share Posted July 1, 2020 (edited) 16 hours ago, _The Doctor__ said: if it was making it into basic or missile command... then you muffed the switch, thought it was fixed... and now it doesn't do as before. Then I'd go back to the switch. After restoring things to how they were... then I'd replace the ROM with a know good one to start down the process. Do you have a disk drive? Yes, It boots the disk after I reset the machine. If you re-read my post I un-soldered the switch and it was removed. it was acting this way before I touched the switch and after it was removed. so im sure the switch isnt the issue.. I'm guessing the GTIA might be going flakey?!?!? No chips seem to get especially hot. Edited July 1, 2020 by Stormbringer Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted July 1, 2020 Share Posted July 1, 2020 (edited) It sure could be the GTIA, but the ROM is notorious for dying in storage on these. There is another couple of things that normally need doing... https://atariage.com/forums/topic/284673-tech-tipp-strange-behavior-of-an-atari-xegs-and-solution/?tab=comments#comment-4149229 strange and inconsistent start ups and kr are normally the two outlined in that thread, ROM, keyboard support chips, pokey... in that order. of course swapping whatever you have handy is what I'd do first, as it cost nothing but time and maybe solder... as always blow up images so as to absolutely see where end of SMD's and other components actually touch and terminate. Edited July 1, 2020 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
