+gnusto Posted July 11, 2020 Share Posted July 11, 2020 http://calc6502.com/RobotGame/summary.html Basically this guy wrote a python interpreter that finds locality use of the accumulator and can decide when to use page 0 instead for a "local variable" freeing up the accumulator. His gains are 5-10% versus his raw assembly - also compares equivalent code generated from cc65 and forth (blast from the past!). He spent a LOT of time on this. Original purpose is a game for a calculator on 65c02, so it's a little more efficient code wise due to the PHX etc instructions. But generally this should work for 6502 as well. 4 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 11, 2020 Share Posted July 11, 2020 Interesting... but sort of a pity he used a 65C02 given it's lack of representation in the real world. I've just skimmed through but there could be other issues like the fact you can only devote so much z-page to such variables and it can impact on some absolute variables that could otherwise achieve savings by using z-page. But a valid study... in the grand scheme of things games and programs probably underutilize zero page. Partially by just not doing efficiency runs and partially by not knowing which OS locations you can borrow. Quote Link to comment Share on other sites More sharing options...
+gnusto Posted July 11, 2020 Author Share Posted July 11, 2020 12 hours ago, Rybags said: Interesting... but sort of a pity he used a 65C02 given it's lack of representation in the real world. I've just skimmed through but there could be other issues like the fact you can only devote so much z-page to such variables and it can impact on some absolute variables that could otherwise achieve savings by using z-page. But a valid study... in the grand scheme of things games and programs probably underutilize zero page. Partially by just not doing efficiency runs and partially by not knowing which OS locations you can borrow. He's 65C02 because he the target is a hand held calculator, so he needs the power efficiency. But yeah, rare comparatively. I've sometimes wondered if you couldn't build a 6502 evaluator engine into an emulator - a form of profile guided optimization. 6502 is usually written by hand with the human building data structures and reference models in their head; the actually running code will not necessarily follow the original vision. A long time ago I was helping a friend with a game on the 8-bit and pointed out to him that some of his setup code before gameplay could be copied into page 0 from a net perspective run faster, since it was short and only ran once (but looped repeatedly). That kind of pattern is something a profile optimizer could recognize pretty easily. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted July 15, 2020 Share Posted July 15, 2020 Does this also handle 65c802 and 65c816 code? Quote Link to comment Share on other sites More sharing options...
+gnusto Posted July 15, 2020 Author Share Posted July 15, 2020 I suppose it could be modified, but it wouldn't understand the width of 65816 registers or the ability to re-assign the direct page. It would work for the 6502 emulation mode though. Quote Link to comment Share on other sites More sharing options...
