Collision Physics
Karl G
Does anyone have a good reference for simple collision physics for game developers? My particular interest right now would be what you could call "billiard ball physics" - Two round objects colliding on a 2D plane. I want to figure out how the velocity of each colliding object is affected by the collision. Presumably this depends on the angle of the collision, and I could always have pre-calculated data in data tables if the math for it is too hairy.
I have no practical reference for gaming billiard physics, but at it's heart the collision physics boil down to Pythagoras. (alternative doc here) The key to that is the collision calculations are done in terms of velocity vectors, rather than any sort of independent x,y velocity components. You'll probably need to "rotate" both vectors so one vector is oriented as a baseline, for the trig table lookups, and then un-rotate the resulting vectors to get the proper orientation. (and then you can convert the velocity vectors to x,y velocity components, for frame-to-frame position updates.)
The devil is in the details, of course. Maybe someone else will have a clearer roadmap, or some clever shortcuts.
One Lone Coder has a good video (and subsequent video) handling billard physics.
He does all the work in C++, but the equations are based off Elastic Collisions
https://en.m.wikipedia.org/wiki/Elastic_collision
 Or you might check GameDev stack exchange.
https://gamedev.stackexchange.com/questions/7862/is-there-an-algorithm-for-a-pool-game
  • Like 4
