gtremblay Posted July 12, 2020 Share Posted July 12, 2020 juste a follow up for the NTSC composite mod on Atari 2600 JR. The TIA chip differs between PAL and NTSC. most mods I've seen are for PAL. like : https://www.console-corner.de/videomod.html (PAL_MOD_SPOT.JPG attached) TC4050 PIN 2 - 3K3 Widerstand TC4050 PIN 10 - 2K2 Widerstand TC4050 PIN 12 - 330 Widerstand TC4050 PIN 15 - 1K Widerstand TIA PIN 9 Color - 1K Widerstand & 100p Kondensator Audio Which give weird color with NTSC machine. so the instead using pins 5-6-7 of TIA PAL for LUM0, LUM1 and LUM2 I use the 5-7-8 pins with TIA NTSC so at the end: sync for both PAL and NTSC is pin 12 (CD4050) = TIA 2 lum1 for both PAL and NTSC is pin 10 (CD4050) = TIA 5 then : FOR PAL lum2 pin 15 (CD4050) = TIA 6 lum0 pin 2 (CD4050) = TIA 7 FOR NTSC lum2 from pin 15 (for PAL) to pin2 (for NTSC) (CD4050) = TIA 7 lum0 from pin 2 (for PAL) to pin 6 (for NTSC) (CD4050) = TIA 8 if you do PAL mod on NTSC machine, black background will appear grey and you'll have some weird color like (PAL mod on NTSC machine picture) in ICE hockey, the ice is grey instead of white and so on... 2 1 Quote Link to comment Share on other sites More sharing options...
Voxel Posted July 14, 2020 Share Posted July 14, 2020 On 7/12/2020 at 7:53 PM, gtremblay said: Nice work. Surprised you did not park up your car when you used your phone to take a picture of your day out, would have been a lot clearer. Quote Link to comment Share on other sites More sharing options...
gtremblay Posted July 14, 2020 Author Share Posted July 14, 2020 thanks! yeah.. now you say it, I realize that I should stop my car (and not just drop the joystick ) before taking the pictures.. I was just too focused on the background colors... 1 Quote Link to comment Share on other sites More sharing options...
Voxel Posted July 15, 2020 Share Posted July 15, 2020 We all get caught up admiring our good work. 1 Quote Link to comment Share on other sites More sharing options...
Shawn Posted December 26, 2020 Share Posted December 26, 2020 (edited) nm, answered my own question with a second read. Edited December 27, 2020 by Shawn Quote Link to comment Share on other sites More sharing options...
Shawn Posted December 27, 2020 Share Posted December 27, 2020 (edited) So this attached diagram would be for PAL or NTSC installation? I'm looking for a proper diagram for NTSC installation please. Edited December 27, 2020 by Shawn Quote Link to comment Share on other sites More sharing options...
gtremblay Posted January 15, 2021 Author Share Posted January 15, 2021 Maybe I'm too late and you figure it out but your diagram is for PAL, pin 15 is not use in NTSC version the difference for NTSC is : instead of pin 15 (for PAL) , it is pin2 (for NTSC) instead of pin 2 (for PAL) , it is pin 6 (for NTSC) 1 Quote Link to comment Share on other sites More sharing options...
Daddelretro Posted January 3, 2022 Share Posted January 3, 2022 I did this mod on my NTSC Junior console, but I have a strong ghosting: If I switch to B/W, the ghosting disappears: Can anyone point me to a solution for this? Quote Link to comment Share on other sites More sharing options...
Level42 Posted August 12, 2022 Share Posted August 12, 2022 Has anyone ever explained why a CD4050 is used ? I've seen simple mods with just a single transistor, what's the difference between using a CMOS non-inverting Hex buffer and a simple transistor and why not use a TTL non inverting hex-buffer, CMOS are know to be relatively slow. Just wondering :) Quote Link to comment Share on other sites More sharing options...
+batari Posted August 14, 2022 Share Posted August 14, 2022 On 8/12/2022 at 7:03 AM, Level42 said: Has anyone ever explained why a CD4050 is used ? I've seen simple mods with just a single transistor, what's the difference between using a CMOS non-inverting Hex buffer and a simple transistor and why not use a TTL non inverting hex-buffer, CMOS are know to be relatively slow. Just wondering :) Surprisingly there is actually no non-inverting hex TTL buffer with normal outputs with a remotely similar ubiquity as the CD4050. There are only rare/obscure examples and many with alternate outputs (like open collector or Schmitt trigger). Besides, the 2600’s dot clock is only 3.57 MHz which the CD4050 can handle. Really, though, I don’t know that this circuit is ideal without a transistor. The output comes directly from the resistor ladder and so the impedance is certainly far from correct. 1 Quote Link to comment Share on other sites More sharing options...
Level42 Posted August 15, 2022 Share Posted August 15, 2022 (edited) Ah surprised ab out the TTL info.... LOL. Yeah well I have a Sunnyvale (NTSC of course) 4 switcher here (in PAL land) with a CD4050 mod and I hadn't used it for quite some time and hooked it up again recently and where it worked fine before, I do get a working picture except it doesn't sync. I may have tried it on another TV before though, so maybe one is less "picky" about the sync then the other.... will have to try that other TV.... Edited August 15, 2022 by Level42 Quote Link to comment Share on other sites More sharing options...
