+OLD CS1 Posted August 10, 2020 Share Posted August 10, 2020 39 minutes ago, 0078265317 said: I meant specifically for apple stuff. heheheh oh Quote Link to comment Share on other sites More sharing options...
0078265317 Posted August 12, 2020 Author Share Posted August 12, 2020 https://www.ebay.com/itm/C50MFF-SCSI-1-Tee-Adapter-Centronic-50-Male-to-Two-Centronic-50-Female-Split/223931324882?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 I also got this interesting adapter. It converts 1 c50 to 2 c50 so I can attach more stuff and I don't beed a device with 2 connections in the back. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 2, 2020 Author Share Posted September 2, 2020 I got a used quantum scsi 500mb 50 pin hard drive off ebay for 5 bucks plus 12 something shipping. Also got 7.0 install floppy disks off ebay. Couple questions. What is the most MB system 7 can handle. Will I be able to use all 500 at once. Or will I have to partition. And someday if I sell it. Is it worth more if I keep the original 20mb inside even if its not working. Or it does not matter. Because I upgraded to 4mb ram and its not even original. And it works but its not mint so if the 500 works and I replace it might get more. Or stock original everything is worth more. Since its been opened before probably does not matter. Maybe if it was all original mint never opened or uppraded. But its not. Quote Link to comment Share on other sites More sharing options...
wierd_w Posted September 2, 2020 Share Posted September 2, 2020 (edited) HFS tops out at ~1gb, IIRC. HFS+ can do much bigger. You should be able to do that whole 500mb drive as one volume. I would still see if dropping some 3-in-1 oil on the head actuator step motor of the internal 20mb fixes its zombie status. Edited September 2, 2020 by wierd_w Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 2, 2020 Author Share Posted September 2, 2020 8 minutes ago, wierd_w said: HFS tops out at ~1gb, IIRC. HFS+ can do much bigger. You should be able to do that whole 500mb drive as one volume. I would still see if dropping some singer A1 oil on the head actuator step motor of the internal 20mb fixes its zombie status. But its only 20mb which is useless. Unless you are saying the original internal is valuable. There was another miniscribe 20 on ebay for 35 bucks. So not worth much. Or if the 500 works I can mail the 20mb to you no charge and you can try fixing it. If broken then just trash it. Not worth it. Quote Link to comment Share on other sites More sharing options...
wierd_w Posted September 2, 2020 Share Posted September 2, 2020 I dont have any scsi requiring retro systems though... As for being useless, I would disagree! Just get an appropriate external housing, then swap out the drives. (Put 20mb in the external housing, put 500mb internal), load up the 20mb with a collection of SMI images for various old mac systems, and make it bootable. Use it as a rescue/install media platform. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 2, 2020 Author Share Posted September 2, 2020 1 hour ago, wierd_w said: I dont have any scsi requiring retro systems though... As for being useless, I would disagree! Just get an appropriate external housing, then swap out the drives. (Put 20mb in the external housing, put 500mb internal), load up the 20mb with a collection of SMI images for various old mac systems, and make it bootable. Use it as a rescue/install media platform. Assuming its fixable. Might not be. And last time the ebay guy used the 500mb it worked. But sitting in a desk drawer for 20 to 27 years might not fire up either. But worth a shot since the cheapest 500mb was 75 dollars. Even a 20mb was 35. And a 230mb was 50 plus 20 shipping. So 17.55 plus tax worth a shot. Quote Link to comment Share on other sites More sharing options...
wierd_w Posted September 2, 2020 Share Posted September 2, 2020 Given the behavior of the drive (20mb), i would say it is either a faulty terminator resistor pack, OR, its stepper motor is not actuating well. The latter is more likely the culprit, and easily investigated with 2 to 3 drops of quality machine oil. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 2, 2020 Author Share Posted September 2, 2020 2 minutes ago, wierd_w said: Given the behavior of the drive (20mb), i would say it is either a faulty terminator resistor pack, OR, its stepper motor is not actuating well. The latter is more likely the culprit, and easily investigated with 2 to 3 drops of quality machine oil. Yea probably. One of the format third party tools I tried said its not writing well. So might be the motor. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 3, 2020 Author Share Posted September 3, 2020 Got another big problem now. I tried one last time to format some third party app. It bombed. I restarted and I get unhappy black sad mac iocon. 0000000F 00000003 According to google that is bad ram icon. Cant believe I killed the ram. Even no disk inserted it is doing that. So must be bad ram. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 3, 2020 Author Share Posted September 3, 2020 (edited) Its not bad ram thank god. I disconnected everything. I held Command + Option + Shift + Delete on boot. And then it booted up and cleared the sad mac on reboot. And the external bernoulli scsi is booting also. Awesome. Edited September 3, 2020 by 0078265317 Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 4, 2020 Author Share Posted September 4, 2020 Also good news I found working copies mac paint on macintosh repository and flight sim 1.02 on macintosh garden. made the disk image in diskdup I think it was. Copy does not work. Have to make the image in diskdup. Its 800k not 400 disk it makes but 400k of files only how odd. But boots up and works. Has to boot from internal floppy but works no error. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 5, 2020 Author Share Posted September 5, 2020 Also the 500mb arrived today. Now I need to get a proper external scsi case. I tried taking apart my bernoulli and borrowing the power and cable both are 50 pins. No dice. Powers and I can hear it spin. But hd sc setup finds no drives. Quote Link to comment Share on other sites More sharing options...
wierd_w Posted September 5, 2020 Share Posted September 5, 2020 What is the LUN ID on the drive? Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 5, 2020 Author Share Posted September 5, 2020 LUN? SCSI id on the external bernoulli is set to 1. Quote Link to comment Share on other sites More sharing options...
wierd_w Posted September 5, 2020 Share Posted September 5, 2020 SCSI ID is called LUN, Logical Unit Number. It's the jargon term. If the enclosure is handling the ID, then I would make sure the drive itself is declaring itself as unit 0. What model number is this drive? I will see if I can find it in the tularc documentation. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 5, 2020 Author Share Posted September 5, 2020 1 hour ago, wierd_w said: SCSI ID is called LUN, Logical Unit Number. It's the jargon term. If the enclosure is handling the ID, then I would make sure the drive itself is declaring itself as unit 0. What model number is this drive? I will see if I can find it in the tularc documentation. I got another problem. SE is on last lims I think. It shut off in the middle of using it. maybe too much plugged. 5 things. Mouse, keyboard, tablet artpad 2, macally batwing joystick, and bernoulli external scsi tape 90. I had done this fews days ago no problem. Today after unplugging everything and just the SE it boots up. The outlet strip went bad. Now I connect just the external bernoulii, keyboard and mouse. The bernoulli boots up. But the mouse and keyboard are not responding. Even with a boot floppy and no external tape drive no keyboard or mouse working. I fried the adb ports maybe. Quote Link to comment Share on other sites More sharing options...
wierd_w Posted September 5, 2020 Share Posted September 5, 2020 maybe bad lytic caps in the SE's PSU? Might explain the spurrious ram error as well, if you are not getting good power from the PSU. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 5, 2020 Author Share Posted September 5, 2020 that was illegal instruction error not ram. Anyhow its getting too expensive. So thanks for all the help but I think I will just pack her up. Replacing the supply is too expensive and time consuming. And will eventually fail also. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 5, 2020 Author Share Posted September 5, 2020 I found this also. I am not going to do this. But just neat somebody thought of this hack. http://www.toughdev.com/content/2017/05/replacing-the-power-supply-in-the-macintosh-se/ Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 5, 2020 Author Share Posted September 5, 2020 After leaving it unplugged all night I tried again now. Its completely dead now. There were few sparks like it was trying to power. But is completely dead now. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 5, 2020 Author Share Posted September 5, 2020 I tried one last time. Took out pram battery from cage. Looks almost new. Never leaked. Hard to believe. No dice. Still does not boot. PSU totally dead. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 7, 2020 Author Share Posted September 7, 2020 Would it be worth trying to get another cheap supply like this and fix it. Or the caps will just go bad again eventually. https://www.ebay.com/itm/124250522096 Quote Link to comment Share on other sites More sharing options...
wierd_w Posted September 8, 2020 Share Posted September 8, 2020 I would personally just read off all the values on the lytic caps in the dead supply, then replace them. (be sure to note on the HV board their orientation, just in case the silkscreen is missing/wrong, using a sharpie marker.) Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 8, 2020 Author Share Posted September 8, 2020 2 hours ago, wierd_w said: I would personally just read off all the values on the lytic caps in the dead supply, then replace them. (be sure to note on the HV board their orientation, just in case the silkscreen is missing/wrong, using a sharpie marker.) I cant solder for the life of me. Quote Link to comment Share on other sites More sharing options...
