GDMike Posted October 23, 2020 Share Posted October 23, 2020 (edited) It's true. Some things are so simple, like basic. In Turbo Forth, to place a character on the screen, is simply, 100 42 V! Placing an asterisk at location 100 of the screen., vs CALL HCHAR(3,23,42) I think the basic format is right, at 40 col mode. I'll be at it rt after I finish SNP. Edited October 23, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 26, 2022 Share Posted August 26, 2022 I am testing different things in my un-released kernel and of course go down the rabbit hole of modifying the programs. Here is Oregon trail re-worked with much better numbers used to determine results. It is also pre-compiled as a binary program for Editor/Assembler cartridge so you can use it without needing the Forth system. It takes 3 files due to the large amount of text in the game which I moved from VDP RAM to CPU RAM so it was simpler to compile as an E/A5 program. Note: It can be won! I have done it. But then I know a few things... Newest source code for the curious. (This is actually my attempt to write a game language on Forth) Spoiler \ ORGEGON TRAIL BY majestyx on Atariage \ RE-WRITE for CAMEL99 Forth. Game specific language demonstration \ Brian Fox Dec 12, 2019 // Update Aug 25 2022 \ INCLUDE DSK1.TOOLS NEEDS RANDOM FROM DSK1.RANDOM NEEDS INPUT FROM DSK1.INPUT NEEDS CASE: FROM DSK1.FASTCASE NEEDS CASE FROM DSK1.CASE NEEDS ENUM FROM DSK1.ENUM NEEDS MARKER FROM DSK1.MARKER CR .( Compiling Oregon Trail ) .( .) : PRINT." POSTPONE CR POSTPONE ." ; IMMEDIATE \ Print a stack string centered on the screen : CENTERTYPE ( addr len -- ) DUP C/L@ SWAP - 2/ 1- SPACES TYPE ; \ Compile text string and print on a newline centered on the screen : CENTER." ?COMP POSTPONE CR POSTPONE S" POSTPONE CENTERTYPE ; IMMEDIATE \ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \ helpers for choice tables.... \ : CLIP ( n lo hi -- n') ROT MIN MAX ; \ clip input to lo/hi DECIMAL \ RANDOM is used to select random actions range= 0 .. n \ Usage: 7 RANDOM DISEASES : RANDOM ( n -- n ) RND ; \ random# returns 1 .. n : RANDOM# ( n -- n ) RND 1+ ; \ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \ G A M E L A N G U A G E DECIMAL : 3RD ( a b c -- a b c a ) 2 PICK ; \ get a copy of 3rd item on the stack \ text game language extensions : BETWEEN ( n lo hi -- ?) 1+ WITHIN ; : %CHANCE ( n -- ? ) 100 RND > ; .( .) \ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \ control structure replaces if else then : DOTHIS POSTPONE IF ; IMMEDIATE : OTHERWISE POSTPONE ELSE ; IMMEDIATE : CONTINUE POSTPONE THEN ; IMMEDIATE \ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \ syntax sugar for creating vector tables : CHOICE: :NONAME ; : CHOICES, ( addr... addr[n] n -- ) DEPTH 1- OVER < ABORT" Not enough choices on stack" 0 ?DO COMPILE, LOOP ; \ compile addresses \ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \ read #input into a variable and test for limits : VALID-INPUT ( variable lo hi -- n ) BEGIN 3RD DUP #INPUT @ 3RD 3RD BETWEEN \ fetch from variable, check limits UNTIL 2DROP @ ; \ drop limits, fetch variable value HEX : TOUPPER ( c -- c') 5F AND ; DECIMAL : YES? ( -- ?) PRINT." Y/N?" KEY TOUPPER [CHAR] Y = ; : .R ( n width -- ) \ print n right justified >R DUP ABS 0 <# #S ROT SIGN #> R> OVER - SPACES TYPE ; : DEBIT ( n variable -- ) DUP >R @ SWAP NEGATE + 0 MAX R> ! ; : CREDIT ( n variable -- ) +! ; .( .) \ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \ set screen color with black letters HEX : CYAN ( -- ) 17 7 VWTR ; : GREEN ( -- ) 13 7 VWTR ; : YELLOW ( -- ) 1B 7 VWTR ; DECIMAL : ROLL-DICE ( -- n ) 12 RANDOM# ; \ Random # 1..12 \ : TESTDICE BEGIN ROLL-DICE . ?TERMINAL UNTIL ; \ random delay with dot printing : ... ( n -- ) 8 RANDOM# 0 ?DO [CHAR] . EMIT 250 MS LOOP ; \ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \ O R E G O N C O D E S T A R T S H E R E DECIMAL \ game data 1847 CONSTANT YEAR 100 CONSTANT DESTINATION ( how far we have to travel) VARIABLE TEMP VARIABLE ACCURACY VARIABLE TOTAL .( .) \ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \ status variables for the traveller VARIABLE BUDGET VARIABLE HEALTH VARIABLE OXEN VARIABLE OXEN# ( normally 2) VARIABLE FOOD VARIABLE QUALITY VARIABLE AMMO VARIABLE CLOTHES VARIABLE MISC VARIABLE CASH VARIABLE WOUNDED VARIABLE ACTION VARIABLE MILEAGE VARIABLE DAY VARIABLE LASTDAY ( # days to get to oregon is random ) VARIABLE MONTH : NEWGAME HEALTH OFF OXEN OFF 2 OXEN# ! FOOD OFF AMMO OFF CLOTHES OFF ( no peeking!) MISC OFF CASH OFF WOUNDED OFF MILEAGE OFF 1 DAY ! 30 RANDOM# 30 + LASTDAY ! ( max will be 59 days) 400 RANDOM# 500 + 800 MIN BUDGET ! ; : DEBIT-TOTAL ( n -- ) TOTAL DEBIT ; : ?DAY TRUE ABORT" Bad day#" ; : ?MONTH TRUE ABORT" Bad Month#" ; \ days print themselves : .MON ." Monday" ; : .TUE ." Tuesday" ; : .WED ." Wednesday" ; : .THU ." Thursday" ; : .FRI ." Friday" ; : .SAT ." Saturday" ; : .SUN ." Sunday" ; .( .) \ a table of execution addresses of days CASE: DAYS ( day# -- ) | .SUN | .MON | .TUE | .WED | .THU | .FRI | .SAT | ?DAY ;CASE : .DOW DAY @ 6 MOD DAYS ." , " ; : .DAY# DAY @ 2 .R ; \ Months print themselves : JAN ." January" ; : JUL ." July" ; : FEB ." February" ; : AUG ." August" ; : MAR ." March" ; : SEP ." September" ; : APR ." April" ; : OCT ." October" ; : MAY ." May" ; : NOV ." November" ; : JUN ." June" ; : DEC ." December" ; CASE: MONTHS ( 1..12 -- ) \ prints month by no. input | ?MONTH | JAN | FEB | MAR | APR | MAY | JUN | JUL | AUG | SEP | OCT | NOV | DEC | ?MONTH ;CASE : .MONTH ( -- ) MONTH @ MONTHS ; : .DATE ( -- ) .DOW .MONTH .DAY# ." , " YEAR . ; .( .) \ DOLLAR value formatted printing : >$< ( -- n ) [CHAR] $ HOLD ; : >.< ( -- n ) [CHAR] . HOLD ; : '00' [CHAR] 0 DUP HOLD HOLD ; : .DOLLARS ( n -- ) DUP ABS 0 <# '00' >.< #S >$< ROT SIGN #> TYPE SPACE ; : @.$ ( addr -- ) @ .DOLLARS ; : .BALANCE PRINT." YOU HAVE " TOTAL @.$ ." left" ; : GET_ACCURACY ( -- ) PRINT." How well can you shoot?" PRINT." (1) BEST" PRINT." (2) GOOD" PRINT." (3) FAIR" PRINT." (4) Not sure..." PRINT." (5) BAD" PRINT." (1..5) : " ACCURACY 1 5 VALID-INPUT DUP 4 = IF DROP 6 RND 1+ 25 * THEN ACCURACY ! ; : TEAM ( -- ) CR PRINT." How much do you want to spend" PRINT." on your team of oxen? ($50-$500)" OXEN 50 500 VALID-INPUT ; : GETFOOD ( -- ) PRINT." ON FOOD " FOOD 0 TOTAL @ VALID-INPUT ; : GETAMMO ( -- ) PRINT." ON AMMUNITION " AMMO 0 TOTAL @ VALID-INPUT ; : CLOTHING ( -- ) PRINT." ON CLOTHING " CLOTHES 0 TOTAL @ VALID-INPUT ; : GETMISC ( -- ) PRINT." ON MISC. SUPPLIES " MISC 0 TOTAL @ VALID-INPUT ; : .Y/N ( ? --) DOTHIS ." Yes" OTHERWISE ." No" CONTINUE ; .( .) : .SUPPLIES CR PRINT." -- Supplies Report --" CR .DATE PRINT." FOOD : " FOOD @.$ PRINT." BULLETS : " AMMO @.$ PRINT." CLOTHING : " CLOTHES @.$ PRINT." MISC. SUPPLIES: " MISC @.$ PRINT." CASH : " CASH @.$ PRINT." -- Status --" PRINT." Health : " HEALTH @ 4 .R PRINT." Wounded : " WOUNDED @ .Y/N CR ; : BUYSTUFF PRINT." Let's get you set you for the trip:" TEAM DEBIT-TOTAL .BALANCE GETFOOD DEBIT-TOTAL .BALANCE GETAMMO DEBIT-TOTAL .BALANCE CLOTHING DEBIT-TOTAL .BALANCE GETMISC DEBIT-TOTAL .BALANCE TOTAL @ CASH ! ; : SETUP CR PRINT." Your budget for the trip is: " BUDGET @.$ BUDGET @ TOTAL ! GET_ACCURACY BUYSTUFF 100 HEALTH ! WOUNDED OFF .SUPPLIES ; .( .) \ ===================================================== \ End of game messages : AGAIN? CR PRINT." Type RUN to play again" PRINT." Type BYE to leave the game" ABORT ; : SORRY GREEN CR PRINT." ********************************" PRINT." We are sorry. You didn't make it" PRINT." to the great territory of Oregon." PRINT." We will notify yer kinfolk." CR PRINT." - Sincerely" CR PRINT." The Oregon" PRINT." -Chamber of Commerce-" HEALTH OFF AGAIN? ; : CONGRATS GREEN CR CR PRINT." *****************************" PRINT." * Y O U M A D E I T *" PRINT." *****************************" PRINT." President James K. Polk" PRINT." sends you his heartiest" PRINT." congratulations." CR PRINT." He wishes you a prosperous life" PRINT." at your new Oregon home." CR CR AGAIN? ; .( .) : SEE-DOCTOR CR ... PRINT." The doc wants " 20 RANDOM# 4 + DUP .DOLLARS HEALTH DEBIT PRINT." to patch you up." CASH @ 8 < DOTHIS PRINT." You cain't afford it partner!" OTHERWISE CR PRINT." You got enough money." PRINT." He's good with the needle & thread" PRINT." Let him do it?" YES? DOTHIS CASH DEBIT ( subtract the payment) WOUNDED OFF 12 RANDOM# HEALTH CREDIT PRINT." You ain't as dumb as ya look." OTHERWISE CR PRINT." Ya feel lucky I reckon!" CR CONTINUE CONTINUE ; .( .) \ ==================================================== \ random sickness selector Health debit for each sickness CHOICE: ." Swine Flu" 10 HEALTH DEBIT ; CHOICE: ." Scurvy" 15 HEALTH DEBIT ; CHOICE: ." Infection" 20 HEALTH DEBIT ; CHOICE: ." Consumption" 20 HEALTH DEBIT ; CHOICE: ." Typhoid fever" 23 HEALTH DEBIT ; CHOICE: ." Pneumonia" 30 HEALTH DEBIT ; CHOICE: ." an unknown disease" 30 HEALTH DEBIT ; CHOICE: ." Smallpox" 45 HEALTH DEBIT ; CHOICE: ." Bubonic plague" 55 HEALTH DEBIT ; CHOICE: ." Rabies" 0 HEALTH ! ; CASE: DISEASES 10 CHOICES, ;CASE : SICKNESS 10 RANDOM DISEASES ; : ?DEAD HEALTH @ 1 < DOTHIS ... CR PRINT." Unfortunately you died on" 1000 MS CR .DATE SORRY CONTINUE ; CHOICE: ." hand" 4 HEALTH DEBIT ; CHOICE: ." leg" 7 HEALTH DEBIT ; CHOICE: ." arm" 5 HEALTH DEBIT ; CHOICE: ." backside :-)" CR ." (sorry, 't ain't funny)" 8 HEALTH DEBIT ; CHOICE: ." belly" 10 HEALTH DEBIT ; CHOICE: ." head..." HEALTH OFF ; CHOICE: ." heart!" HEALTH OFF ; CASE: ANATOMY 7 CHOICES, ;CASE : BODYPART 7 RANDOM ANATOMY ; .( .) \ ===================================================== \ BAD luck : STARVED PRINT." You ran out of food and" PRINT." starved to death" HEALTH OFF SORRY ; : SNAKEBITE PRINT." You got bit by a snake!" ... PRINT." Right in the " BODYPART 50 %CHANCE DOTHIS PRINT." there ain't no cure fer it!" HEALTH OFF SORRY OTHERWISE PRINT." You darn near died!" 10 RANDOM HEALTH DEBIT CONTINUE ; : MASSACRE PRINT." You were attacked and" PRINT." massacred by criminals" HEALTH OFF SORRY ; : FROZE PRINT." Weather took a turn partner." PRINT." It went down to 30 below." PRINT." You and the family froze solid" HEALTH OFF SORRY ; .( .) : NOMEDICINE CR PRINT." You ran out of medical supplies." PRINT." There was no way to help." HEALTH OFF ; : BANDITS PRINT." Bandits Attacked!" HONK CR 30 %CHANCE DOTHIS PRINT." You ran out of bullets--" PRINT." They got lots of yer cash" 50 RANDOM# CASH DEBIT AMMO OFF CONTINUE 20 %CHANCE DOTHIS PRINT." and... they took one of your oxen" 1 OXEN# DEBIT CONTINUE 10 %CHANCE DOTHIS WOUNDED ON CONTINUE ; .( .) : VERYSICK PRINT." Partner you is looking sickly." PRINT." The Doc says you gotta rest here " PRINT." fer " 5 RANDOM# 1+ DUP . ." days. " DAY CREDIT PRINT." cuz you got " SICKNESS ... ?DEAD CR 13 %CHANCE DOTHIS PRINT." I got some bad news partner" ... NOMEDICINE ?DEAD CONTINUE 50 %CHANCE DOTHIS PRINT." You is on the mend partner!" 40 HEALTH CREDIT OTHERWISE PRINT." You didn't make a full recovery" PRINT." but ya ain't dead yet!" 13 RANDOM# HEALTH CREDIT CONTINUE ; \ ========================================= CHOICE: ." wheel" ; CHOICE: ." axle" ; CHOICE: ." yoke" ; CHOICE: ." whipple-tree" ; CHOICE: ." seat" ; CASE: PARTS 5 CHOICES, ;CASE : PART 5 RANDOM PARTS ; : BUSTED-WAGON PRINT." Yer wagon gots a busted " PART PRINT." It's gonna take some time to fix 'er up!" 3 RANDOM# DAY CREDIT ... PRINT." That'll cost ya " 5 RANDOM# DUP .DOLLARS CASH DEBIT 5 RANDOM# MISC DEBIT ; : SWAMPED CR PRINT." Wagon gets swamped fording a" PRINT." river. You lost some food" 20 RANDOM 10 + FOOD DEBIT ... 33 %CHANCE DOTHIS PRINT." and some clothes" 20 RANDOM# CLOTHES DEBIT CONTINUE ; : FOG PRINT." Lost your way in a heavy fog" ... PRINT." You lost " 3 RANDOM# DUP . DAY CREDIT ." days." 20 RANDOM# FOOD DEBIT ; : FIRE PRINT." There was a fire in your" PRINT." wagon. Food and supplies" PRINT." are damaged!" 20 RANDOM 10 + FOOD DEBIT 10 RANDOM 2 + MISC DEBIT ; CR .( 50% complete ...) CR : RAIN PRINT." Heavy rain" ... PRINT." Time & supplies were lost." ... 3 RANDOM# DAY CREDIT 7 RANDOM# MISC DEBIT 12 RANDOM# FOOD DEBIT ; : BAD-WATER PRINT." Bad water, You lost time" PRINT." looking for a clean spring." ... 3 RANDOM# DAY CREDIT 3 RANDOM HEALTH DEBIT ; : SONLOST PRINT." Your son wandered off" ... PRINT." Spent a day looking for him" 1 DAY CREDIT 2 FOOD DEBIT ; : OXLOST PRINT." OX wandered off. Two days lost" ... 2 DAY CREDIT PRINT." (Tie him up next time)" 4 RANDOM FOOD DEBIT ; .( .) : TERRAIN PRINT." RUGGED MOUNTAINS" ... 37 %CHANCE DOTHIS PRINT." You got lost and loose valuable" PRINT." time trying to find a trail." 2 DAY CREDIT OTHERWISE PRINT." You pushed through." CONTINUE 21 %CHANCE DOTHIS PRINT." Wagon damaged! Lost time and supplies" 2 RANDOM# DAY CREDIT 4 RANDOM# FOOD DEBIT 2 RANDOM MISC DEBIT CONTINUE ; : BLIZZARD PRINT." Blizzard in mountains at south pass" ... 47 %CHANCE DOTHIS PRINT." Snow was " 3 RANDOM 2 + . ." feet deep" PRINT." Time & supplies lost" 2 RANDOM# DAY CREDIT 2 RANDOM MISC DEBIT 4 RANDOM# FOOD DEBIT OTHERWISE PRINT." You made it safely through." PRINT." Only light snow." CR CONTINUE ; .( .) CASE: TRAGEDIES ( ndx --) | SNAKEBITE | MASSACRE | FROZE | BANDITS | VERYSICK | BUSTED-WAGON | SWAMPED | FOG | FIRE | RAIN | BAD-WATER | SONLOST | OXLOST | TERRAIN | BLIZZARD ;CASE DECIMAL : SHITHAPPENS CR ... PRINT." Tragedy has done commenced!" CR 14 RANDOM TRAGEDIES ?DEAD ; : ?BROKE CASH @ 1 < DOTHIS PRINT." Partner, yer flat broke!" CONTINUE ; .( .) : DOCTOR? PRINT." Wanna see a doctor?" YES? DOTHIS SEE-DOCTOR OTHERWISE PRINT." Ok, it's yer funeral." CONTINUE ; : ?HEALTH 20 %CHANCE DOTHIS ( don't report this all the time) HEALTH @ 20 < DOTHIS CR PRINT." You don't look so good partner." DOCTOR? CONTINUE HEALTH @ 20 30 BETWEEN DOTHIS CR PRINT." You gotta look after yerself better." CONTINUE HEALTH @ 31 49 BETWEEN DOTHIS CR PRINT." You feelin' ok? Ya looks kinda pale." CONTINUE HEALTH @ 49 > DOTHIS CR PRINT." Yer still lookin' purty healthy" CONTINUE CONTINUE ; : ?SEE-DOCTOR CR PRINT." Wanna have a doc look at you?" YES? DOTHIS SEE-DOCTOR 60 %CHANCE DOTHIS PRINT." He patched you up!" 10 RANDOM HEALTH CREDIT WOUNDED OFF OTHERWISE PRINT." He fixed it but yer still hurtin'" WOUNDED OFF 20 RANDOM# HEALTH DEBIT CONTINUE CONTINUE ?DEAD ; .( .) : GOTSHOT PRINT." OUCH! You got shot in the " BODYPART 20 RANDOM# HEALTH DEBIT ?DEAD WOUNDED ON 5 RANDOM# MISC DEBIT 10 RANDOM# AMMO DEBIT 25 %CHANCE DOTHIS PRINT." and they took one of your oxen." 1 OXEN# DEBIT CONTINUE ?SEE-DOCTOR ; : ?GOTSHOT WOUNDED @ DOTHIS GOTSHOT CONTINUE ; : WANNAEAT ( -- n) CR PRINT." How do you wanna eat?" PRINT." (1) POORLY" PRINT." (2) OK" PRINT." (3) WELL? " QUALITY 1 3 VALID-INPUT ; : RUNNING PRINT." You are running away" ... 5 %CHANCE DOTHIS WOUNDED ON CONTINUE 10 %CHANCE DOTHIS GOTSHOT CONTINUE 9 RANDOM# OXEN @ * MILEAGE CREDIT 30 RANDOM# OXEN DEBIT 25 RANDOM# HEALTH DEBIT 3 RANDOM DAY CREDIT ; .( .) : ATTACK PRINT." You are attacking " ... 24 RANDOM# AMMO DEBIT AMMO @ 10 < DOTHIS CR PRINT." Crap! We is gettin' low on ammo!" CR CONTINUE 50 RANDOM# ACCURACY @ / %CHANCE DOTHIS PRINT." You scared them off!" PRINT." and found their money and food" CR 60 RANDOM# FOOD CREDIT 55 RANDOM# CASH CREDIT 15 RANDOM# HEALTH CREDIT OTHERWISE GOTSHOT CONTINUE ; : DEFEND PRINT." We circled the wagons" ... PRINT." and let 'em have it!" ... 24 RANDOM# AMMO DEBIT AMMO @ 0= DOTHIS CR PRINT." Ah Spit! We is outta ammo!" CR CONTINUE 50 RANDOM# ACCURACY @ / %CHANCE DOTHIS CR PRINT." You are a pretty good shot!" PRINT." They took off and left us alone" CR 10 RANDOM# HEALTH CREDIT 10 RANDOM# OXEN CREDIT 20 RANDOM# AMMO DEBIT OTHERWISE CR PRINT." We took some hits but survived" 5 %CHANCE DOTHIS WOUNDED ON CONTINUE 25 RANDOM# AMMO DEBIT 10 RANDOM# HEALTH DEBIT 10 RANDOM# OXEN DEBIT 30 %CHANCE DOTHIS GOTSHOT CONTINUE CONTINUE ; .( .) : KEEP-MOVING CR 3 %CHANCE DOTHIS PRINT." Rollin Rollin Rollin..." PRINT." Man my butt is swollen..." CR OTHERWISE PRINT." Move 'em out " CONTINUE ... 3 RANDOM HEALTH DEBIT 10 RANDOM# OXEN DEBIT 4 RANDOM CLOTHES DEBIT 9 RANDOM# OXEN# @ * MILEAGE CREDIT 26 %CHANCE DOTHIS SHITHAPPENS CONTINUE ; CASE: REACTION ( n -- ) | RUNNING | ATTACK | KEEP-MOVING | DEFEND ;CASE : HOSTILE-DECIDE ( -- ) PRINT." They look hostile!" PRINT." Whaddya reckon we should do?" PRINT." (1) RUN" PRINT." (2) ATTACK" PRINT." (3) CONTINUE" PRINT." (4) DEFEND" ACTION 1 4 VALID-INPUT DROP CR ... ACTION @ 1- REACTION ?GOTSHOT ; \ ====================================== \ random names for food CHOICE: ." eatin'" ; CHOICE: ." food" ; CHOICE: ." viddles" ; CHOICE: ." grub" ; CASE: FOODS 4 CHOICES, ;CASE : FOODSTUFF 4 RANDOM FOODS ; .( .) \ ====================================== \ game animals CHOICE: ." deer" PRINT." We got food for days!" CR 87 FOOD CREDIT ; CHOICE: ." possum" PRINT." Ain't much food but better than nothin'" CR 10 FOOD CREDIT ; CHOICE: ." squirrel" PRINT." We is gonna be hungry" CR 5 FOOD CREDIT ; CHOICE: ." duck" PRINT." A little greasy, but fillin'" CR 15 FOOD CREDIT ; CHOICE: ." turkey" PRINT." Now that's some good viddles" CR 25 FOOD CREDIT ; CASE: VARMINTS 5 CHOICES, ;CASE : ANIMAL 5 RANDOM VARMINTS ; .( .) : HUNT PRINT." You are hunting" PRINT." Be vaarrwee quiet " ... PRINT." Press space bar to fire" BEGIN KEY? BL = UNTIL CR PRINT." BANG!" CR ACCURACY @ RANDOM# HEALTH @ * \ HEALTH affects accuracy 55 MAX %CHANCE DOTHIS PRINT." You shot a " ANIMAL OTHERWISE PRINT." You missed." PRINT." Yer gonna be hungry tonight." ... 5 FOOD DEBIT 3 HEALTH DEBIT CONTINUE 5 RANDOM 1+ AMMO DEBIT ; : .CASH ." You have " CASH @.$ ." cash" ; : BUYFOOD PRINT." How much do you want to spend?" CR .CASH TEMP 1 CASH @ VALID-INPUT DUP CASH DEBIT FOOD CREDIT CR .CASH ." left" ; \ ================================================ \ status testers begin with a ? : ?FOOD \ test DOTHIS we have enough Food points left FOOD @ 0= DOTHIS STARVED CONTINUE FOOD @ 10 < DOTHIS PRINT." You need to do some hunting PRINT." or by some " FOODSTUFF ." !!!" PRINT." 1. Hunt" PRINT." 2. Buy Food" PRINT." Enter to go on" CR KEY CASE [CHAR] 1 OF HUNT ENDOF [CHAR] 2 OF BUYFOOD ENDOF ENDCASE CONTINUE ; .( .) : ?WOUNDED WOUNDED @ 0 <> DOTHIS CR PRINT." Did you know you are wounded?" DOCTOR? CONTINUE ; : ?TIMEOUT DAY @ LASTDAY @ > DOTHIS CR PRINT." It's a terrible shame." 1000 MS PRINT." Y'all didn't get to Oregon in time." 1000 MS PRINT." I reckon yer lost" CR CR SORRY CONTINUE ; .( .) \ good stuff that can happen OR NOT! CHOICE: ." Comanche" ; CHOICE: ." Sioux" ; CHOICE: ." Apache" ; CHOICE: ." Cheyenne" ; CHOICE: ." Navaho" ; CHOICE: ." Blackfoot" ; CASE: TRIBES 6 CHOICES, ;CASE : TRIBE 5 RND TRIBES ; : NATIVES CR PRINT." You bumped into a tribe of " TRIBE ." ." 8 %CHANCE DOTHIS PRINT." You said something wrong..." PRINT." They took your wife and kids." ... PRINT." and left you alone to die." HEALTH OFF ?DEAD SORRY CONTINUE 50 %CHANCE DOTHIS PRINT." They gave you some fresh " FOODSTUFF 20 RANDOM# FOOD CREDIT 20 RANDOM# HEALTH CREDIT CONTINUE 22 %CHANCE DOTHIS PRINT." and fed your animals!" 50 RANDOM# OXEN CREDIT CONTINUE ; : HUNTER 33 %CHANCE DOTHIS CR PRINT." You met a hunter and he gave you a " ANIMAL CONTINUE ; : GRAZING 50 %CHANCE DOTHIS CR PRINT." Good luck!" PRINT." Your Oxen found some nice grazing." 25 RANDOM# OXEN CREDIT CONTINUE ; : GOODWEATHER 63 %CHANCE DOTHIS CR PRINT." The weather is good for travelling." 2 OXEN CREDIT 2 HEALTH CREDIT 2 CLOTHES CREDIT CONTINUE ; CASE: GOODTHINGS | NATIVES | HUNTER | GRAZING | GOODWEATHER ;CASE : HAPPYDAYS 4 RANDOM GOODTHINGS ; .( .) : AreWeThereYet? MILEAGE @ DESTINATION > DOTHIS CONGRATS THEN PRINT." We travelled " MILEAGE @ . ." miles." ; : CONSUME \ things are used up every day 6 RANDOM# HEALTH DEBIT 10 RANDOM# OXEN# @ * 2+ OXEN DEBIT 10 RANDOM# FOOD DEBIT 9 RANDOM# CLOTHES DEBIT 10 RANDOM# MISC DEBIT ; : ?OXEN OXEN @ 10 < DOTHIS PRINT." Yer oxen are almost dead!" PRINT." Wanna stop for grazing" YES? DOTHIS 35 RANDOM# OXEN CREDIT PRINT." Your oxen got a good rest" CR OTHERWISE 30 RANDOM# OXEN DEBIT CONTINUE OXEN @ 0= DOTHIS PRINT." Your oxen are dead." PRINT." You ran them into the ground!" PRINT." You never made it out..." STARVED CONTINUE OXEN @ 15 < DOTHIS PRINT." Your oxen are still weak" OTHERWISE PRINT." You oxen are doing better" CONTINUE CONTINUE ; : ?ENEMIES 5 %CHANCE DOTHIS CR PRINT." Uhoh, we got company!" HOSTILE-DECIDE CONTINUE ; CHOICE: CR CR ." Your cheap coat fell apart. " CR ." You died of exposure. " ; CHOICE: CR CR ." Your cheap boots rotted away. " CR CR ." Your feet rotted next! " ; CHOICE: CR CR ." Your cheap underwear chaffed your privates!" CR CR ." You died crying..." ; CHOICE: CR CR ." That cheap hat was infested with earwig eggs." CR ." They ate your brain" ; CASE: WARDROBE-FAILURE 4 CHOICES, ;CASE : ?CLOTHING CLOTHES @ 1 < DOTHIS 4 RANDOM WARDROBE-FAILURE HEALTH OFF SORRY CONTINUE ; .( .) : TITLE-PAGE TEXT GREEN CENTER." * O R E G O N T R A I L *" CR CENTER." The game that time forgot" CR CR CR 2000 MS CENTER." Based on BASIC version CENTER." by Majestyx on Atariage" 1000 MS CR CR CR CR CENTER." Re-write in Forth by TheBF" CR CENTER." Version 1.6" 0 22 AT-XY CENTER." Press a key to begin" KEY DROP ; : OPENING TITLE-PAGE YELLOW PAGE PRINT." -- You're on the Oregon trail" ... 12 RANDOM# MONTH ! 1 DAY ! CR .DATE ... SETUP ; .( .) : CAMP CR PRINT." Oxen are tied up, fire is lit." PRINT." Get some sleep partner" ... 33 %CHANCE DOTHIS PRINT." Uhoh! I heard some footsteps" PRINT." over yonder!" HOSTILE-DECIDE OTHERWISE CR PRINT." We had a peacful night" PRINT." Eat some vittles and git goin'" 10 RANDOM# FOOD DEBIT 10 HEALTH CREDIT 20 RANDOM# OXEN# @ * OXEN CREDIT CONTINUE ; .( .) : VALIDATE ( c addr len -- ? ) ROT SCAN NIP ; : MENU-KEY ( c) BEGIN KEY DUP S" 12349" VALIDATE 0= WHILE DROP REPEAT ; .( .) : MENU CR PRINT." It's day " .DAY# PRINT." What do you want to do?" PRINT." 1) Keep moving" PRINT." 2) Setup Camp for the night" PRINT." 3) Hunt" PRINT." 4) Check supplies" CR ." > " MENU-KEY DUP EMIT CASE [CHAR] 1 OF KEEP-MOVING ENDOF [CHAR] 2 OF CAMP ENDOF [CHAR] 3 OF HUNT ENDOF [CHAR] 4 OF .SUPPLIES ENDOF [CHAR] 9 OF ." Secret programmer escape ;-)" ABORT ENDOF HONK ENDCASE ; CR .( . Starting...) : RUN ( -- ) DECIMAL NEWGAME OPENING BEGIN MENU CONSUME 15 %CHANCE DOTHIS SHITHAPPENS OTHERWISE AreWeThereYet? CONTINUE 26 %CHANCE DOTHIS HAPPYDAYS CONTINUE ( test our status) ?FOOD ?OXEN ?CLOTHING ?BROKE ?ENEMIES ?WOUNDED ?HEALTH ?DEAD 1 DAY CREDIT ?TIMEOUT AGAIN ; : START WARM RUN ; LOCK INCLUDE DSK1.SAVESYS ' START SAVESYS DSK3.OREGON OREGONTRAIL.ZIP 7 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 26, 2022 Share Posted August 26, 2022 While I'm at it here is a politically incorrect SNAKE game where the snake likes mice not apples. I can't get past 14 ft. in "Viper" speed mode. Let me know how you do. Requires Editor/Assembler cartridge or equivalent program file loader. Source available on request. SNAKE-EA5.ZIP 3 Quote Link to comment Share on other sites More sharing options...
tmop69 Posted August 28, 2022 Share Posted August 28, 2022 I've converted Snake and Oregon Trail in SSS cart for FinalGrom, etc. [HOMEBREW] Oregon Trail V1.6 (2020)(TheBF).bin [HOMEBREW] The Snake (2020)(TheBF).bin [HOMEBREW] The Snake (2022)(TheBF).bin 4 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 28, 2022 Share Posted August 28, 2022 1 hour ago, tmop69 said: I've converted Snake and Oregon Trail in SSS cart for FinalGrom, etc. I don't have a Final Grom (guess I should). I am interested in the process of how you do that. Quote Link to comment Share on other sites More sharing options...
tmop69 Posted August 28, 2022 Share Posted August 28, 2022 1 hour ago, TheBF said: I don't have a Final Grom (guess I should). I am interested in the process of how you do that. I've used ModuleCreator2 tool. Just convert the EA5 files in V9T9 format with TiDir, then use the GUI of the tool to create the SSS. There are also the MakeCart util from Tursi and the Java program from Rasmus that can be used to create carts. ModuleCreator2 is generating a 8.bin SSS file that can be used with FinalGROM, MiSTer FPGA TI99 core and the various emulators (Classic99, MAME). 2 2 Quote Link to comment Share on other sites More sharing options...
