Mindfield Posted July 27, 2003 Share Posted July 27, 2003 Is it possible to split the video signal from an A/V cable to work on an old-style composite monitor? I have a C64 monitor that's sitting around and not earning its keep (except with the C64 itself) and was wondering if it's possible to hook an A/V-based system up to it. I have an old 27" floor model TV that works for most systems, but it has a V-hold problem with a few systems (Saturn, mostly) that causes screen flickering that gets especially bad on bright screens. If I could hook that up to the C64 monitor it'd probably help a great deal. Quote Link to comment Share on other sites More sharing options...
jsoper Posted July 27, 2003 Share Posted July 27, 2003 What model is the Commie monitor? I think most of them have the RCA jacks for composite AV input. With a 1702 they are on the front with chroma/luma on the back. Neither one if for the chan2/chan3 RF signal if you are using that. If you really need chroma/luma, then Radio Shack sells a $21 converter thingee that converts composite video. IMHO, it won't produce svideo (chroma luma) sharpness, just the signals (why would the converter do a better job at the separation than your TV?). I use one on the output of my switchbox that has all the composite systems plugged into it. You will probably also need to make an adapter cable that has an s-video jack at one end and rca plugs at the other. Quote Link to comment Share on other sites More sharing options...
Mindfield Posted July 27, 2003 Author Share Posted July 27, 2003 lol! I don't know why, but I never actually notice the A/V connections on the front. Yes, it is a 1702. I'm going to have to fiddle with that and see how it works! It's a pain in the arse plugging it all into my TV, using the monitor would probably be a great deal easier. Thanks! Quote Link to comment Share on other sites More sharing options...
JB Posted July 27, 2003 Share Posted July 27, 2003 As a side note, the Saturhn has choma/luma signals on it's AV connector. http://www.gamesx.com/avpinouts/saturnav.htm Quote Link to comment Share on other sites More sharing options...
