rietveld Posted August 21, 2020 Share Posted August 21, 2020 Just a quick look at me formatting a disk on my Gotek. Sorry for the upside down Gotek, i was just excited that it worked. Quote Link to comment Share on other sites More sharing options...
NIAD Posted August 21, 2020 Share Posted August 21, 2020 So you connected the Gotek drive to the ADAM FDD’s controller board via the ribbon cable? What model Gotek drive is that as there are numerous models? Looked like you formatted a 160K disk, correct? Well, actually, it would have to be if you are using a standard ADAM FDD although the firmware for larger disk formats is available and all that is needed is to burn to a chip and swap out the existing firmware chip to work with 320K, 360K or 720K disk images. Did you try using the verify format option of File Manager? Was the directory INITialized correctly? Have you had time to copy files to the disk image file and verify them? Have you tested a bootable program like SmartBasic or CP/M? Quote Link to comment Share on other sites More sharing options...
rietveld Posted August 21, 2020 Author Share Posted August 21, 2020 5 hours ago, NIAD said: So you connected the Gotek drive to the ADAM FDD’s controller board via the ribbon cable? What model Gotek drive is that as there are numerous models? Looked like you formatted a 160K disk, correct? Well, actually, it would have to be if you are using a standard ADAM FDD although the firmware for larger disk formats is available and all that is needed is to burn to a chip and swap out the existing firmware chip to work with 320K, 360K or 720K disk images. Did you try using the verify format option of File Manager? Was the directory INITialized correctly? Have you had time to copy files to the disk image file and verify them? Have you tested a bootable program like SmartBasic or CP/M? Fully working Gotek as Drive 2 on the Coleco Adam. Booting into CP/M from the Gotek Loading Cartsoft disks using the Gotek Quote Link to comment Share on other sites More sharing options...
rietveld Posted August 21, 2020 Author Share Posted August 21, 2020 I can also just boot direcly from the Gotek by mounting a disk in it and turning on the Adam without the Hard drive. Quote Link to comment Share on other sites More sharing options...
NIAD Posted August 21, 2020 Share Posted August 21, 2020 Great stuff and the Gotek Drive will be a perfect fix if the disk drive mechanics breakdown, but the controller board is still good. Can you power the Gotek drive from the ADAM FDD internal power connector or does the Gotek have it’s own power supply? Also, is the Gotek drive a standard drive size and therefor can be mounted inside the Adam FDD case In place of the MPI disk drive mechanics? Quote Link to comment Share on other sites More sharing options...
rietveld Posted August 21, 2020 Author Share Posted August 21, 2020 (edited) 9 minutes ago, NIAD said: Great stuff and the Gotek Drive will be a perfect fix if the disk drive mechanics breakdown, but the controller board is still good. Can you power the Gotek drive from the ADAM FDD internal power connector or does the Gotek have it’s own power supply? Also, is the Gotek drive a standard drive size and therefor can be mounted inside the Adam FDD case In place of the MPI disk drive mechanics? My Gotek is using a molex to floppy adapter on the end of the Coleco's drive power, it just takes the standard 5 1/4 connector to a small floppy connector, got it for $2. The Gotek is the same size as a 3 1/2 floppy . I am using a $7 bracket that lets it fit into a 5 1/4 drive slot. Pretty much any Gotek will work as they all just emulate a floppy drive. I paid $22 for mine and I flashed it with a free version of "flash floppy" and it works with all Coleco .dsk images without any conversion. Just copy and paste the .dsk to the usb thumb drive . The Gotek has jumpers that let you set it as Drive 1 or 2. I am actually thinking of keeping it in place of the pkysical 5 1/4 for now since i can have my entire .dsk library on it at one time. Edited August 21, 2020 by rietveld Quote Link to comment Share on other sites More sharing options...
NIAD Posted August 22, 2020 Share Posted August 22, 2020 Thanks. Just looked over the Gotek website and actually answered some of my questions but appreciate your answers as well. Seeing as we know your model works properly, I prefer to stick with the same model even though as you said, any of the Gotek drives should/would work. Can you share the model number, please? Quote Link to comment Share on other sites More sharing options...
rietveld Posted August 22, 2020 Author Share Posted August 22, 2020 30 minutes ago, NIAD said: Thanks. Just looked over the Gotek website and actually answered some of my questions but appreciate your answers as well. Seeing as we know your model works properly, I prefer to stick with the same model even though as you said, any of the Gotek drives should/would work. Can you share the model number, please? https://m.aliexpress.com/item/1710069272.html?srcSns=sns_WhatsApp&spreadType=socialShare&bizType=ProductDetail&tt=MG&aff_request_id=2f1a64aa6a2a48d892a35351447ec94f-1598057642461-03177-_dUcUn2O&aff_platform=default&sk=_dUcUn2O&mergeHashcode=50126131101&description=C%24+25.74++20%OFF+|+Free+Shipping+SFR1M44-U100+Normal+version+3.5+Inch+++1.44MB+USB+SSD+FLOPPY+DRIVE+EMULATOR+GOTEK&aff_trace_key=2f1a64aa6a2a48d892a35351447ec94f-1598057642461-03177-_dUcUn2O&businessType=ProductDetail&title=C%24+25.74++20%OFF+|+Free+Shipping+SFR1M44-U100+Normal+version+3.5+Inch+++1.44MB+USB+SSD+FLOPPY+DRIVE+EMULATOR+GOTEK&platform=AE&terminal_id=48306eed748249b0b276e38f7dfc2fe7&templateKey=white_backgroup_101 Quote Link to comment Share on other sites More sharing options...
rietveld Posted August 22, 2020 Author Share Posted August 22, 2020 (edited) i replaced the numeric display with this OLCD https://www.amazon.ca/DSD-Tech-OLED-Display-Arduino/dp/B07D9H83R4 you can keep the stock display but it only shows disk numbers so you need to keep track of what is on each disk i just replaced the display with an OLCD so that it will display the full disk name OLCD just plugs in place of the stock display but again the stock display is perfectly useable as long as you know what is on the disk Edited August 22, 2020 by rietveld Quote Link to comment Share on other sites More sharing options...
NIAD Posted August 22, 2020 Share Posted August 22, 2020 Thank you for the links. Quote Link to comment Share on other sites More sharing options...
NIAD Posted August 24, 2020 Share Posted August 24, 2020 After watching some mod videos on the Gotek drives, a couple quick questions that I haven't stumbled upon answers to yet in the hopes that you know... - Does the original firmware work with ADAM disk images as is or does it have to be upgraded to FlashFloppy? - Does the original firmware support the display of disk image names on a new OLCD display such as the one you installed along with the disk image number and track or does it have to be upgraded to FlashFloppy? Quote Link to comment Share on other sites More sharing options...
rietveld Posted August 24, 2020 Author Share Posted August 24, 2020 4 hours ago, NIAD said: After watching some mod videos on the Gotek drives, a couple quick questions that I haven't stumbled upon answers to yet in the hopes that you know... - Does the original firmware work with ADAM disk images as is or does it have to be upgraded to FlashFloppy? - Does the original firmware support the display of disk image names on a new OLCD display such as the one you installed along with the disk image number and track or does it have to be upgraded to FlashFloppy? you need flash floppy to be a ble to use Adam .dsk files and to push the disk / track info to the OLED. Flash Floppy is free and is super easy to flash . just plug the gotek into a pc and us windows or linux to write the the firmware . Here is the main Github site for doing this. Once the flash floppy is written to the Gotek all you need to do is copy/paste .dsk files onto a thumb drive, insert into gotek, and load like a real disk https://github.com/keirf/FlashFloppy/wiki/Firmware-Programming 1 Quote Link to comment Share on other sites More sharing options...
rietveld Posted August 24, 2020 Author Share Posted August 24, 2020 The reason you need flash floppy is that these Goteks were originally designed to replace the 3 1/2 driveds in old industrial sewing machines Quote Link to comment Share on other sites More sharing options...
NIAD Posted August 24, 2020 Share Posted August 24, 2020 Again thanks for the info. i actually recall reading about the Gotek drive years ago, but never followed up once MicroFox released their Virtual Disk Drive. While watching some mod videos, it seems that some drives do not come with the Header used for updating the firmware and some include a red power LED that is hidden away in the case and one only knows if it is installed if they open the case. Quote Link to comment Share on other sites More sharing options...
rietveld Posted August 25, 2020 Author Share Posted August 25, 2020 2 hours ago, NIAD said: Again thanks for the info. i actually recall reading about the Gotek drive years ago, but never followed up once MicroFox released their Virtual Disk Drive. While watching some mod videos, it seems that some drives do not come with the Header used for updating the firmware and some include a red power LED that is hidden away in the case and one only knows if it is installed if they open the case. Quote Link to comment Share on other sites More sharing options...
rietveld Posted August 25, 2020 Author Share Posted August 25, 2020 Just now, rietveld said: The gotek i linked you to comes with the header. I dont even bother with a special cable . I just use a standard usb cable and jumper the pins . i have the same model gotek on my trs80 model 1, Dragon 32, ibm 5150, kaypro , osborne, PET, and heath kit. For 25 bucks they are well worth getting one for each system. i dont mind walking anyone thru the process since i have done it at least 6 times so far Quote Link to comment Share on other sites More sharing options...
rietveld Posted September 10, 2020 Author Share Posted September 10, 2020 GOTEK UPDATE i built a 34pin ribbon cable with 2 drive connectors so i can have both the gotek and 5 1/4 drives hooked up to the single adam disk controller. I put a small toggle switch in line on the drive select line of the cable and ca n now use ither the gotek or physical drive with just a flip of the switch 1 Quote Link to comment Share on other sites More sharing options...
rietveld Posted September 30, 2020 Author Share Posted September 30, 2020 3 Quote Link to comment Share on other sites More sharing options...
Sixthview Posted January 16, 2021 Share Posted January 16, 2021 I gave up trying when I found out about flashing it and all that Jazz as it was just too daunting of a task. I have found some sellers offering a Gotek with Flash Floppy pre-loaded. What version are you using, or would any version of Flash Floppy do the trick? Quote Link to comment Share on other sites More sharing options...
rietveld Posted January 16, 2021 Author Share Posted January 16, 2021 3 hours ago, Sixthview said: I gave up trying when I found out about flashing it and all that Jazz as it was just too daunting of a task. I have found some sellers offering a Gotek with Flash Floppy pre-loaded. What version are you using, or would any version of Flash Floppy do the trick? any version of flash floppy works Quote Link to comment Share on other sites More sharing options...
rietveld Posted January 16, 2021 Author Share Posted January 16, 2021 (edited) 3 hours ago, Sixthview said: I gave up trying when I found out about flashing it and all that Jazz as it was just too daunting of a task. I have found some sellers offering a Gotek with Flash Floppy pre-loaded. What version are you using, or would any version of Flash Floppy do the trick? Please watch this video. It is a simple point and click process using a windows computer, USB a to usb a cable and a few jumper wires. If I can do it anyone can do it. You just choose FLASHFLOPPY as the software you want to flash not the amiga one in that video Edited January 16, 2021 by rietveld Quote Link to comment Share on other sites More sharing options...
