Avid Fan Posted July 27, 2003 Share Posted July 27, 2003 I was wondering about the 2600 expansion module. Is it reliable? Better or worse than the 5200 VCS adaptor? Can you use the coleco controllers? Or do you have to buy 2600 compatable joysticks? Quote Link to comment Share on other sites More sharing options...
opcode Posted July 27, 2003 Share Posted July 27, 2003 You can use CV controllers for sure. AFAIK the expansion module is able to run almost every VCS game, though not all of them, since it was reverse engineered. I think there is a compatibility list somewhere... Opcode Quote Link to comment Share on other sites More sharing options...
surfnmadness Posted July 27, 2003 Share Posted July 27, 2003 Per the Colecovision FAQs, it does not appear to have any carts that would not work. In fact, it was the bases for the Coleco Gemini system made later. http://www.classicgaming.com/colecofaq/ Quote Link to comment Share on other sites More sharing options...
Avid Fan Posted July 28, 2003 Author Share Posted July 28, 2003 I think my chances of buying a Colecovision before I get a 5200 just doubled Quote Link to comment Share on other sites More sharing options...
joeybastard Posted July 28, 2003 Share Posted July 28, 2003 I have never had a cart not work in the CV expansion module. There was some problem with sone of the carts fitting in, but if I remember correctly you could jimmy the port door and they would work. I think from a technical standpoint, the CV expansion is probably the most compatible thing next to an actual VCS. Quote Link to comment Share on other sites More sharing options...
SS Posted July 28, 2003 Share Posted July 28, 2003 I have never had a cart not work in the CV expansion module. There was some problem with sone of the carts fitting in, but if I remember correctly you could jimmy the port door and they would work. I think from a technical standpoint, the CV expansion is probably the most compatible thing next to an actual VCS. Has anyone tried the CV expansion module with Vault Assault? I know that game has some problems with a 2600 Jr. Or an original Space Treat? It had issues with some different hardware too. Quote Link to comment Share on other sites More sharing options...
joeybastard Posted July 28, 2003 Share Posted July 28, 2003 I unfortunately don't have any of the homebrews yet so I can't say if they work with the CV expansion. Quote Link to comment Share on other sites More sharing options...
