Mille Borne in Applesoft BASIC
hloberg
the problem with the alt character set change on FLASH is only in the Apple IIe enhanced I have found. I know there is a soft switch that turns off the alt character set but I haven't got it to work for some reason.  it's probably  because I don't understand how soft switches work.
As I said, the softswitch is activated with "POKE 49166,0".  If you want to make sure it isn't hit on a machine that doesn't know what to do with it, do "if peek(-1101)=6 then poke 49166,0" - it'll trip on the original //e, but it does have an effect there too even without the MouseText.
("peek(-1101)=6" is a check used by Apple themselves.)
The //c and IIgs support MouseText too.
A softswitch is just a "switch" that's triggerable by software; by reading or writing a particular memory locations (sometimes it matters which, and which value is written, others it doesn't - depends on the particular switch - they're all documented in the technical reference manual for the machine in question). So the POKE @The Usotsuki and I had mentioned is the softswitch. Writing a value to that location via POKE (any value - I'd said 1, @The Usotsuki said 0, but either will work fine - it's the fact of writing that matters, not the value) will tell the enhanced //e (and //c's, and IIgs's) to display the primary character set when FLASH is used, rather than MouseText. At least, if it's a normal one :)
Does it? I'm surprised I haven't seen it documented in the Apple IIc Technical Reference Manual (Appendix F - Apple II Series Differences). Also, is it actually known to be unsafe to trip this switch on older machines?
Do you mean specifically for determining if poke 49166,0 is safe, or just for checking whether the current machine is an Apple //e or higher?
